Compact Field Oriented Controller, ASI + Grin, limited run
justin_le   10 MW
Re: Compact Field Oriented Controller, ASI + Grin, limited r
Post by justin_le » Apr 09 2015 8:18am
On the left is the CNC'd enclosure for the BAC500+ devices that we made in a limited one-time run last year and which this thread was all about. On the right is the BAC800 circuitboards (72V capable) along with the the heatsink and wiring harness that we made, and in the middle is the expected geometry of the finished Grin modified BAC800 device once it is potted. So shorter and narrower but also taller than the CNC'd enclosures. More power in less volume overall
Grin/ASI BAC500+ compared to BAC800 concepts
BAC800 Prototype Compared.jpg (30.29 KiB) Viewed 6254 times
Question for you guys. Do you prefer having all the cables coming out of the same one end of the controller, or do you prefer when there is a logical flow through of the power, with the battery leads coming in from one end and then the controller leads going out the other end? I'm usually partial to the flow-through concept, but in this one case the manufacturing for us will be a lot easier if the cables all come out the back as depicted. I'm curious if others have strong opinions about this, and if it would be worth us making a more complicated mold that has cable exits from both ends.
Previously competed in the Suntrip race on a back to back tandem solar powered row/cycle trike. 550 watt solar roof, dual Grin All Axle hub motors, dual Phaserunner controllers, 12 LiGo batteries, and a whole wack of gear.
Now back in Vancouver learning to be a dad with my Big Dummy Frame (yes This One, thanks ES!) with GMAC 10T rear hub motor, Phaserunner controller, and 52V 19Ah EM3EV pack
My website: http://www.ebikes.ca
Please contact via email, info@ebikes.ca, rather than PMs, which are disabled
riba2233   1 MW
Post by riba2233 » Apr 09 2015 8:27am
I prefer everything on the same end.
This looks great! Where are the fets?
My electric moped: http://www.evalbum.com/4966
My electric car: http://www.evalbum.com/5364
grindz145   100 MW
Post by grindz145 » Apr 09 2015 8:34am
Now THAT is a beautiful little controller :)
I also prefer to have all leads on one end. Maybe you can show us an example of clean feed-through wiring, and maybe you can sway us the other direction :mrgreen:
circuit   100 kW
Post by circuit » Apr 09 2015 8:34am
to me, all motor stuff (phases and sensors) is better on opposite side from battery and other signals. In this way I only get some wires coming in one side and coming out from other, making it a 'small box on the cable'.
smart and Tiny BMS solution
Visit my blog. Personal projects: Clean Peugeot conversion | Ultralight enduro
Any and all information, such as texts, specifications, drawings or other material that I post are to be used only as a reference for personal, non-commercial projects ONLY. Any republication for personal or commercial needs must be agreed on individually. Use of any information, that I post, for commercial purposes is strictly prohibited.
district9prawn   1 kW
Post by district9prawn » Apr 09 2015 8:40am
I usually prefer all cables on the same end but am not too particular about it.
If funds permit I will jump on one of these beauties as soon as they become available!
Neu 8057 6kW left hand drive hardtail with 18 fet Vesc: viewtopic.php?f=6&t=96754
speedmd   1 GW
1 GW
Post by speedmd » Apr 09 2015 8:42am
From a water proofing standpoint, one end best for me.
justin_le   10 MW
Post by justin_le » Apr 09 2015 2:20pm
riba2233 wrote:I prefer everything on the same end.
OK, that seems pretty definitive from this small groups at least. Will proceed for now with all cables on one end then!
Where are the fets?
They are sandwitched between the aluminum heat sink on the bottom and an aluminum spreader on the top. This way we have direct metal contact on all exposed metal of the TO-220 package, rather than just on the back face. You can see the 6 fets more clearly in this shot, the top spreader plate has 6 threaded holes in it and the screws go in from below:
BAC800 Unpotted Closer View.jpg (39.19 KiB) Viewed 6214 times
We've just finished CNC machining a half dozen of these heatsink pieces and have sent them out for engineering hardcoat anodizing so that they are electrically isolating and can be installed without any insulating pad. Give them a week to get back here and we can start finalizing these prototypes.
amberwolf   100 GW
Post by amberwolf » Apr 09 2015 2:26pm
justin_le wrote: Do you prefer having all the cables coming out of the same one end of the controller, or do you prefer when there is a logical flow through of the power, with the battery leads coming in from one end and then the controller leads going out the other end?
It would depend on where everything is on the vehicle.
If a battery is at one end of the vehicle, motor at the other, and controller between, it would make sense to have cables in flow-thru layout.
If a battery and motor are at the same end with controller somewhere right there, it would not much matter in most cases, and same-end exit might be useful for mounting options.
If all cables come out one end it does make it easier to mount it in "pockets" in the frame without worrying about curving wires back around it to route them back to various stuff.
If you found this advice helpful, supporting contributions are accepted here.
Beginning of a New Life
Give a listen to my music!
(More here, including experimental)
riba2233   1 MW
Post by riba2233 » Apr 09 2015 2:27pm
That's really nice :)
speedmd   1 GW
1 GW
Post by speedmd » Apr 09 2015 2:31pm
If your making a mold for it, you can lightly mark suitable spots in the mold for areas on the closed side for the DIY / DYI guys to drill and insert grommets for the communication cables to enter /exit. This way it takes the guess work out.
Jason3   10 mW
Post by Jason3 » Apr 09 2015 5:03pm
That's very cool! My preference would be to have all cables coming out one end. Put me down for a couple too :D
madin88   1 GW
1 GW
Post by madin88 » Apr 10 2015 4:02am
the compact size is aweseom. great job.
what will be the rated (continuos) power?
as for the wire exits it depends on the application and bike etc, but for waterproofing it would be better to have them all on one side..
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
voicecoils   10 MW
Post by voicecoils » Apr 10 2015 5:05am
+1 for cables all all on one end. Besides allowing for cleaner looking installs, it's handy to be able to orient the controller such that water will flow away from the cables exits instead of flowing along the cable and into the controller.
The Grin+ASI controller is well sealed but it never hurts to play it safe with water ingress.
Nanoha   100 W
Post by Nanoha » Apr 10 2015 6:02pm
Would it be better if the base of the controller was mounted upside down so that the FET side has more airflow? Maybe even a finned case for extra cooling so that we can push it further. :twisted:
Gab   100 W
Post by Gab » Apr 11 2015 6:13pm
So this controller will be programmeable ?
will we be able to program field weakening for higher top speed ?
ambroseliao   100 kW
Post by ambroseliao » Apr 11 2015 8:59pm
Fully! :D you need to read the thread from the first post!
http://www.ebikes.ca/ is the best!
TidalForce M-750X, Tidalforce S-750 with Crystalyte HS3540, 1x TF iO-X Cruiser. E+ 1000W hybrid bike. ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. Bosch Fat Packs, 37V 10Ah LiPO pack. Turnigy Multistar batteries
My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
Gab   100 W
Post by Gab » Apr 13 2015 7:26am
I like the anodised heatsinks on both sides of the fet. But i wounder how will you keep the screw from conducting to the mosfet housing ? its very easy for the screw thread to break through the anodiseing hence the screw will be alive and hence if it touches the inside of the fet hole it will conduct. Normal to220 bushes won't fit unless their is room above the fet?
bowlofsalad   1 MW
Post by bowlofsalad » Apr 13 2015 11:21am
Is it necessary to somehow isolate the USB connection that goes from a BAC500+ to a computer USB port?
speedmd   1 GW
1 GW
Post by speedmd » Apr 13 2015 12:25pm
Gab wrote:I like the anodised heatsinks on both sides of the fet. But i wounder how will you keep the screw from conducting to the mosfet housing ? its very easy for the screw thread to break through the anodiseing hence the screw will be alive and hence if it touches the inside of the fet hole it will conduct. Normal to220 bushes won't fit unless their is room above the fet?
It does not look like there is any insulation under them going by the photo. Would prefer from a mechanical stand point to have screws going in the opposite direction so you would have some longer thread engagement if it is possible to get at them easy enough for repair issues. Looks like it is already set to get threaded holes in the base, so it would not change machine setup.
robbie   1 W
1 W
Post by robbie » Apr 13 2015 1:42pm
The aluminum will be hard-coat anodized (not shown in the pictures), meaning the FETs will be electrically isolated from the heatsink bodies. We'll apply some thermal paste between the FETs and the heatsinks. The screws themselves will also be isolated from the larger heatsink as well as the FETs by use of shoulder washers from the backside of the larger heatsink. Due to the nature of the threading and hard-coat anodizing, the screws will be linked electrically to the heatspreader - but this is okay. The screws will only need to be torqued (and have a thread locking compound applied) once as they won't be a serviceable part (entire controller is potted in epoxy). We may not even have them accessible in the final part (tbd).
Hopefully, we'll be getting the hardcoated prototypes back this week and then we can start testing the potting and thermal performance of the heatsinks as currently designed! Woo! I'm excited about these little guys, they show a lot of promise!
*edit: spelling
agniusm   100 MW
Post by agniusm » Apr 13 2015 11:51pm
How about making bottom plate a bit thicker (if its not thick enough) to drill out couple 6mm holes (for DIY modders) for water loop, say something like this:
No doubt there will be people pushing these babies :D
liveforphysics   100 GW
Post by liveforphysics » Apr 14 2015 12:31am
agniusm wrote:How about making bottom plate a bit thicker (if its not thick enough) to drill out couple 6mm holes (for DIY modders) for water loop, say something like this:
It appears you could bolt the lower section to a water block if needed. No need to make every unit have the extra weight for the few who want to liquid cool.
speedmd   1 GW
1 GW
Post by speedmd » Apr 14 2015 7:05am
When the numbers can justify a custom extrusion, the base can have cooling fins designed in that would work well both for air or water.
MrDude_1   100 kW
Post by MrDude_1 » Apr 14 2015 8:37am
Forgive me if I missed it because I did try to read the entire thread... but is this REALLY silent on RC motors too?
Because this new block style (with the wires coming out the same side :mrgreen: ) BAC800 combined with a kepler style friction drive would make an ideal commuter-helper for my bike.
But I am really curious if a cheap RC motor like a Turnigy SK3 will be silent with this controller, since they're normally so whiny. I see the hub motors are silent, and thats a great sign, but...
Warning:This post is being read via light, a substance known to the state of California to cause cancer.
agniusm   100 MW
Post by agniusm » Apr 15 2015 4:03am
liveforphysics wrote: It appears you could bolt the lower section to a water block if needed. No need to make every unit have the extra weight for the few who want to liquid cool.
It looks to me that the bottom plate is something like 6-7mm. Adding a 1-2mm and milling out 2 5-6mm holes right through will add little to no weight and moding it for water cooling will be accessible even for noobs with off the shelf parts. I dont think it would add significant cost to manufacture. Just my 2 kopeika :)
P.S. or that:
speedmd wrote:When the numbers can justify a custom extrusion, the base can have cooling fins designed in that would work well both for air or water.
