Compact Field Oriented Controller, ASI + Grin, limited run
justin_le   10 MW
Re: Compact Field Oriented Controller, ASI + Grin, limited r
Post by justin_le » Dec 11 2014 8:18pm
okashira wrote:
\/ampa wrote:
okashira wrote: Can you do one more at ~13 amps? I would LOVE to see how things look at a partial relative load.
Since they run different voltage now. Its better to say another dyno test with 500W power draw from both.
That would be fine also.
Here it is. The infineon trapezoidal controller was at 48.0V with a 12.0 current limit set via a CA, wile the BAC500 FOC controller was run at 51.4V with an 11.2A current limit. So 575 watt input power limit in both cases, and the same unloaded RPM in both cases. The CA had a much easier time regulating the battery current draw on the FOC with it's torque throttle, while the infineon controller had a fair amount of feedback oscillation just as it was transitioning to the amps limit around 420 rpm, and you can see the corresponding scattering of torque and power data..
minor additions
Dyno Comparison at same Unloaded Motor RPM, 575 W limit.jpg (139.82 KiB) Viewed 5353 times
Overall, the performances are quite close near the top end of the speed range, but as the motor is loaded and slowed down then the FOC shows the same improved torque and efficiency which we were seeing before.
At this power limit, the FOC system was able to stay ABOVE 80% system efficiency from 160 rpm all the way to 450 rpm, which is impressive for a direct drive transmission considering that not too long ago we were lucky when the motors 'peaked' at ~81%.
Previously competed in the Suntrip race on a back to back tandem solar powered row/cycle trike. 550 watt solar roof, dual Grin All Axle hub motors, dual Phaserunner controllers, 12 LiGo batteries, and a whole wack of gear.
Now back in Vancouver learning to be a dad with my Big Dummy Frame (yes This One, thanks ES!) with GMAC 10T rear hub motor, Phaserunner controller, and 52V 19Ah EM3EV pack
My website: http://www.ebikes.ca
Please contact via email, info@ebikes.ca, rather than PMs, which are disabled
liveforphysics   100 GW
Post by liveforphysics » Dec 11 2014 8:25pm
That is such an amazing improvement. Who would have thought it could reduce total motor heat production by a solid 20% over a wide area of the torque curve. It should easily be worth another few hundred watts of continuous power output in most hubmotors, or climb a 20% longer hill before overheating etc.
Nice job Justin!
justin_le   10 MW
Post by justin_le » Dec 11 2014 8:36pm
liveforphysics wrote:That is such an amazing improvement. Who would have thought it could reduce total motor heat production by a solid 20% over a wide area of the torque curve. It should easily be worth another few hundred watts of continuous power output in most hubmotors, or climb a 20% longer hill before overheating etc.
Yeah I forgot to look at it that way, that a ~3% improvement in efficiency is more like a 20% reduction in "inefficiency", when you are talking in the ~85% efficiency regime. And so while the effect on range is small single digits, the effect on motor heating and associated limits caused by that is quite appreciable.
This does mean that I'm now going to need a fully updated model on the simulator for choosing a sinusoidal controller vs. a trapezoidal drive, since it's clear the differences are not to be swept under the rug.
Next up I would also like to try the dyno same comparison tests on a motor that isn't sinusoidal wound. Most of the new motors all have a winding scheme with a sinewave back-emf, but the older motors like the Crysatlyte 400 series and X5's were definitely more suited to a trapezoidal controller, and if that's the case then I'd expect to see much less improvement going to a FOC.
\/ampa   100 W
Post by \/ampa » Dec 11 2014 8:52pm
Thanks for this very usefull comparison.
The FOC have a clear advantage up to 275 RPM.
On my xmas wish list is a FOC controller right on the top now. :mrgreen:
justin_le wrote:Next up I would also like to try the dyno same comparison tests on a motor that isn't sinusoidal wound. Most of the new motors all have a winding scheme with a sinewave back-emf, but the older motors like the Crysatlyte 400 series and X5's were definitely more suited to a trapezoidal controller, and if that's the case then I'd expect to see much less improvement going to a FOC.
How can someone measure what back-emf wave form his motor have?
amberwolf   100 GW
Post by amberwolf » Dec 11 2014 11:38pm
If you have an oscilloscope, you can disconnect the motor from the controller, then hook the scope across any two phases, and spin it up with an external source (tire-to-tire friction drive from another motor wheel is one of the easiest), so that it acts as a generator.
EDIT (added): Also, if it's a rear DD motor, you can spin it up with the cranks, wheel offground. (if it's a geared motor you'll need to spin it backwards).
okashira   10 kW
Post by okashira » Dec 11 2014 11:41pm
I am digging this controller.
I want more power, but perhaps a dual or triple RC motor setup is in my future?
How would this controller handle being paired up with a friend? Could I run all three with one throttle input? :-D
Or I could run some sort of smart control setup that maxes out uses one motor for 0-90% torque, then kicks in the 2nd motor for 90%-200%, al-la Tesla model 85D
They could even be different speed motors, with one with better efficiency at low speed, the other with better efficiency at high speed... micro controller control to automatically distribute torque based on efficiency.
"Peace out - I'm done."
-- Bernhard Riemann, 1859
edisonmotors.net
Tesla Model S 18650 cells - like new - and custom packs from Tesla cells for sale. Any shape Any power Any capacity.
PM me or search my threads.
justin_le   10 MW
Post by justin_le » Dec 12 2014 2:04am
okashira wrote: How would this controller handle being paired up with a friend? Could I run all three with one throttle input? :-D
You can parallel the throttle inputs of several controllers for sure. We did the trick of tying the throttle signal and the analog ebrake signal together inside the housing, and then having a resistive divider on the input line that holds the throttle signal at 1.0V when nothing is plugged into it. If you pull the throttle less than 1V, it goes into regen torque, and if you drive it higher than 1.2V it delivers forwards torque. If you are driving the throttle signal from a CA3, then the output of that is stiff enough to drive quite a number of throttle inputs.
Usually this is a foolish way to do things, even though it's everyone's first line of thinking when it comes to dual motor setups. For best performance and efficiency you should have both your motors sized for the same speed, and except at very low power levels you should have both of them always and equally engaged.
justin_le   10 MW
Post by justin_le » Dec 12 2014 3:32am
\/ampa wrote:Thanks for this very usefull comparison.
OK, well we've sold just over half of them already. I'll post an update here when there are only 3-4 pieces remaining so that people who've been doing the 'wait and see' won't be caught off guard when there are none left. I should also remind people too that if you _don't_ already have a TTL->USB cable from a Satiator or a Cycle Analyst, then be sure to get that too with the order:
http://www.ebikes.ca/shop/ebike-parts/c ... a-usb.html
Otherwise you won't be able to do much with the controller since it's essential that it be plugged into a computer and tuned to your motor.
madin88   1 GW
1 GW
Post by madin88 » Dec 12 2014 8:15am
good point about the effect of BEMF.
could it be if a motor has same pole count and stator teeth it has same back emf wave form? because many motors have the 46 magnet 51 teeth design like 9C, Cromotor and also the crystalyte if i remember..
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
Miles   100 GW
Post by Miles » Dec 12 2014 8:59am
madin88 wrote:could it be if a motor has same pole count and stator teeth it has same back emf wave form?
It's a major factor. Magnet shape, magnet coverage, slot opening width, tooth shape, are others...
NordicNorm   1 mW
Post by NordicNorm » Dec 12 2014 10:33am
Justin,
Would the FOC be of equal benefit to a Stokemonkey rig or overkill?
madin88   1 GW
1 GW
Post by madin88 » Dec 12 2014 12:51pm
thx miles. i see many tests coming in future about this.. :)
okashira   10 kW
Post by okashira » Dec 12 2014 10:01pm
How would this controller do with an Astro motor?
AstroFlight says their motors are designed to produce a trapezoidal back EMF.
edisonmotors.net
MitchJi   1 GW
1 GW
Post by MitchJi » Dec 13 2014 12:38pm
Hi,
Justin wrote:...Next up I would also like to try the dyno same comparison tests...
Would it be useful to do comparison tests with the same ASI Grin FOC Controller and the same motor in sensored mode vs sensorless mode (more accurate timing)?
That is another possible advantage of a Controller with a high quality sensorless mode.
Best Wishes!
Mitch
Buying a new Tesla? Please consider using our referral code https://ts.la/lynnem96959 to get one thousand miles of free Supercharging.
The best quality batteries and lowest priced batteries for DIY EV's are tier 1 OEM Quality Cells from salvaged (wrecked) EV packs. Three examples are Chevy Volt and Nissan Leaf and Tesla Model 3 packs.
Nissan Leaf Module specs are here
Chevy Volt Pack Info - Salvage 16kwh Packs Under $2k here
bowlofsalad   1 MW
Post by bowlofsalad » Dec 13 2014 3:02pm
robbie wrote: The only difference with sensorless operation is that you'll want to tune the following settings:
Sensorless open loop starting current: 0.3
Sensorless open loop freq ramp time: 200ms
Sensorless closed loop enable freq: 20Hz
You'll want to do this by starting with the default values and tweaking - these values will depend on your setup.
Yowza, I just about cooked a little geared hub motor not realizing how much heat was generated in this process. Do you have any advice on how to tweak these settings? I jumped around fairly randomly, swapped the phases a few times and while the results changed, I was still pretty unsure about what I was doing after a large number of tries.
I love the efficiency comparisons and such.
Thanks
justin_le   10 MW
Post by justin_le » Dec 13 2014 5:10pm
Do you know the gear ratio and pole count of the hub motor you are dealing with, or in otherwords the ratio of the electrical RPM to the mechanical RPM?
This can help make more educated guesses on the open loop ramp time and closed loop frequency. Usually you'd want it to transition over to closed loop control as soon as possible, which means lower values for both the open loop ramp time, and also for the closed loop enable frequency. But a high pole count high gear reduction motor will have a higher electrical frequency for the same RPM, so the value in Hz would correspondingly need to be higher too. For the geared eZee motors, they are 80 effective poles, so a closed loop frequency of 20 Hz translates into 20Hz * 60 (sec/min) * / 80 (poles/rev) = 15 rpm. If your geared motor has only say 25 poles/rev, then the same closed loop frequency of 20Hz corresponds to 60 rpm on the wheel, which is pretty fast to still be running in an open-loop mode.
The open loop starting current is how much current it puts into the windings when it is doing a sensorless 'self start', and it's expressed as a fraction of your max phase current. If you left this at a value like 0.3 and didn't change the motor current rating from the 60A we had it at when shipped, then that would mean you are injecting 18A of current just for the self start process and that would definitely cause things to get hot.
We haven't actually played around with optimizing this setting on many of the various geared motors yet, mostly we've been playing with Direct Drive, so I'll try to do this in the next couple days and post the results here to give people benchmark numbers for some of the common geared hubs.
-Justin
melodious   100 kW
Post by melodious » Dec 13 2014 5:42pm
Thanks for the graph and subsequent discussion of it. Something wondrous just clicked after that and I learned just enough to take my knowledge base a wiser, inclined, leap forward. :wink:
Question: when the trapezoidal wave starts to show greater "depths & rises" is that the noise everyone associates with these waveforms vs. the "smoother & linear" sine wave (often said to be quieter) when used on a motor :?:
Surly Ogre rigid 29er, rear 10T MAC @ 50V 25AH & 40A: 30mph road/gravel/hill machine
42" dual diagonal Eskateboard @6s & 90mm wheels
Next: eMTB @10-12s & 8"-12" pneumatic wheels; Got Strapped? d-(',')z
bowlofsalad   1 MW
Post by bowlofsalad » Dec 14 2014 5:58am
-Justin
Thanks for responding to my message.
The motor is a Q75, I did various searches and the best I was able to find was 13.4 for the reduction ratio and 16 for the pole count, the motor is a 201rpm version, so I used those corresponding pieces of information. After thinking about it for a moment, would I need to put 8 in the 'Motor pole pairs' rather than 16?
I probably completely misunderstand what you are trying to say, but for a 16 pole geared hub motor I should do 20(hz) times 60(seconds) divided by 16(poles) and put 75 that as the rated motor speed while 'fine tuning' the other 3 settings?
justin_le wrote:The open loop starting current is how much current it puts into the windings when it is doing a sensorless 'self start', and it's expressed as a fraction of your max phase current. If you left this at a value like 0.3 and didn't change the motor current rating from the 60A we had it at when shipped, then that would mean you are injecting 18A of current just for the self start process and that would definitely cause things to get hot.
This explains a lot.
I should also probably mention that for a while I wasn't able to connect to the controller, I am able once again but I can't get it out of fault mode. The light flashes 18 times. Any ideas on what 18 flashes means and a solution to get the controller out of this seemingly locked fault mode?
robbie   1 W
1 W
Post by robbie » Dec 15 2014 1:10pm
bowlofsalad wrote: I should also probably mention that for a while I wasn't able to connect to the controller, I am able once again but I can't get it out of fault mode. The light flashes 18 times. Any ideas on what 18 flashes means and a solution to get the controller out of this seemingly locked fault mode?
I've had this error once before, and for me it was a result of changing the phase current limit to below the minimum (it defaulted to 17A I believe). Setting it up to 20A cleared the error. If this doesn't remove the error, please let me know and I'll investigate further.
The error itself refers to a voltage or current calibration error.
bowlofsalad   1 MW
Post by bowlofsalad » Dec 15 2014 1:18pm
robbie wrote:I've had this error once before, and for me it was a result of changing the phase current limit to below the minimum (it defaulted to 17A I believe). Setting it up to 20A cleared the error.
Excellent! I did exactly what you did, set the amp limit below 20A. I set the limit to 20A and the faulting stopped. Thank you!
justin_le   10 MW
Post by justin_le » Dec 15 2014 6:12pm
madin88 wrote:do you think it would be possible to compare the FOC controller in flux weakening mode so that RPM is similar to the trap controller?
Well, here I did that. With some quick trial and error I found that a 17% max field weakening current resulted in the same unloaded RPM with the FOC as I was getting with the trapezoidal controller. This setting is in the Peripheral Configuration -> Advanced Motor tab.
How to set automatic field weakening to increase unloaded motor RPM
Field Weakening Percentage.jpg (40.32 KiB) Viewed 5017 times
There is also have a table vs. RPM based field weakening option where you set the fielded weakening current as a function of your speed to have more control over this, but I didn't use that, just the automatic mode.
Table based approach for field weakening current
Field Weakening Table.jpg (76.57 KiB) Viewed 5017 times
And the Dynamometer test results compared with the 48V trapezoidal experiment are just as we'd hope. At higher speeds, the two controllers behave quite similarly, with the same max RPM and the same slope of torque vs RPM, but as the motor is more heavily loaded then the FOC starts showing increasingly better efficiency and torque output for the same input power.
Dyno comparison of trapezoidal controller with FOC controller and 17% max field weakening.
Comparison with Field Weakening.jpg (123.81 KiB) Viewed 5011 times
So it would seem there are no downsides to the automatic field weakening as far as having the best of both worlds, if you want the top end speed of trapezoid and the better loaded efficiency and smoothness of FOC.
Reason: Inline image troubles
speedmd   100 MW
Post by speedmd » Dec 15 2014 7:57pm
What is causing the blip/ sweet spot just above 350 rpm.
bspalteh   10 mW
Post by bspalteh » Dec 15 2014 7:59pm
What happens if you increase the field weakening value beyond that 17%, say 30% or whatever? Even faster top speed? Lower efficiency only at those top speeds or across the rest of the range? What are the advantages and downsides of doing that?
fechter   100 GW
Post by fechter » Dec 15 2014 8:20pm
Definitely seems to have more improvement in the low speed end. Once it gets past current limiting, the curves are pretty close. Not huge, but significant.
I wonder if some of the theoretical advantage is getting lost in the stator iron? Maybe try messing with the PWM frequency.
justin_le   10 MW
Post by justin_le » Dec 16 2014 2:32am
bspalteh wrote:What happens if you increase the field weakening value beyond that 17%, say 30% or whatever?
This is what happens, an even higher top speed! (from 440 rpm at 0%, now to 505 rpm at 30%)
Comparison of TC3080 motor with trapezoidal controller and FOC controller with 30% field weakening
Comparison with 30% Field Weakening.jpg (133.91 KiB) Viewed 4938 times
Right now, I'm using the "automatic field weakening" mode which I understand only uses the field weakening at higher speeds where it has benefit, rather than having it do it across the board which doesn't make much sense.
Here I've got the 0%, 17%, and 30% field weakened graphs all super imposed on each other, and you can see that they all behave identical once they are below the speed where field weakening is required. So I would say there isn't really a downside for general operation, and the efficiency at the high speeds achieved by field weakening isn't all that bad either. In this example, where the trapezoidal controller topped out at ~475 rpm producing no more output, the FOC controller with 30% field weakening was still putting out 450 watts of power at about 78% system efficiency.
Comparing 0%, 17%, and 30% max field weakening current performance with the same TC3080 motor
Field Weakening Levels Compared.jpg (145.43 KiB) Viewed 4938 times
speedmd wrote:What is causing the blip/ sweet spot just above 350 rpm.
That I really don't know. It's present on all the graphs that I've done with the FOC controller to a greater or lesser degree, but I don't see it on the tests with the infineon unit. On the last dyno I made a point to look closely at the behavior here and could definitely feel some oscillation and shaking in the dyno bench setup as it scanned through the 355-345 RPM band. So there is some kind of resonance at play.
