Hub motor project!
jacobbloy
Hub motor project!
Post by jacobbloy » Dec 24, 2014 12:05 am
Hi guys this is a sneak peek at my custom hubmotor project I have been working on for some time know. The motor screw onto any 8mm longboard axel! The urathan can be replaced and because of a lot of different design attempts we have found the best way to lock the urathan to the motor.
We are thinking of realeaseing the motors as open hardware or sell the motors for DIYers! We want to run a beta test soon to fix some more bugs and will allow some people to be apart of this.
We have also been working on CF stealth deck!
Please leave your feed back!
1000w so can be twin or single drive
Each motor weight is 1.35lb
Each motor has 2x ceramic bearings 1 on each side.
(202.98 KiB) Downloaded 70 times
(94.08 KiB) Downloaded 70 times
more discussion on the development of these motors are located here
https://endless-sphere.com/forums/viewto ... rdhubmotor
this is a link for crowd funding for a mould to be made for the wheels! the mould will be owned by endless sphere members and not by my self.
if the funding gets more then needed it will be used to fund other things like esc and controller!
torqueboards
1.21 GW
1.21 GW
Re: Hub motor project!
Post by torqueboards » Dec 24, 2014 12:49 am
Nice work! That looks freaking awesome!
How well do you think it will work going uphill?
DIYElectricSkateboard.com Electric Skateboard Kits
addicted2climbing
Post by addicted2climbing » Dec 24, 2014 1:32 am
Wow what a great job. I figured it was just a matter of time this would be developed. Any issue with debris and water from wet pavement getting inside? When will these be available to DIY'ers?
Marc
dirkdiggler
Post by dirkdiggler » Dec 24, 2014 2:49 am
Sweet!! I thought it'd be a long while before we got something like this. I think this is the best way to do it, no belts or motor mounts. Big question is how does this ride? What is the KV of the motor and what ESC are you using?
Put me on the list if you get some extra motors.
torqueboards
1.21 GW
1.21 GW
Post by torqueboards » Dec 24, 2014 5:39 am
I definitely like the idea and am keen towards it. However, I think that it will lack a lot of torque. More so for flat ground.
Can it climb hills?
psychotiller
Post by psychotiller » Dec 24, 2014 11:27 am
Brilliant! Pair a couple of those with all electronics mounted in the deck ,of say, a slalom variety?... :shock:
www.psychotiller.com
builds:
XT Wheels/Custom Hub & mount on Randal 180's/Drop Throughhttps://endless-sphere.com/forums/viewto ... 35&t=59259
6" Pneumatic Tire Drop Down/Drop Through https://endless-sphere.com/forums/viewto ... 35&t=60449
"Have you ever heard of Plato? Aristotle? Socrates? Morons!"-Vizzini
melodious
Post by melodious » Dec 24, 2014 1:46 pm
Can't wait to see it in action!
Ever thought about putting the same ideas to a mountainboard setup? :wink:
Surly Ogre rigid 29er, rear 10T MAC @ 50V 25AH & 40A: 30mph road/gravel/hill machine
42" dual diagonal Eskateboard @6s & 90mm wheels
Next: eMTB @10-12s & 8"-12" pneumatic wheels; Got Strapped? d-(',')z
beto_pty
Post by beto_pty » Dec 24, 2014 2:00 pm
Cool. ..
If they are under 100kv.. or twin motor design they should do the trick. .
Sign me up for the trials please. ..
Do or Do not. There is no try
PATY/neta https://endless-sphere.com/forums/viewto ... 35&t=65384
MIni-motor Build https://endless-sphere.com/forums/viewto ... 35&t=56839
Destroyer https://endless-sphere.com/forums/viewto ... 35&t=58504
Adrianas Board https://endless-sphere.com/forums/viewto ... 35&t=61171
Gargoyle https://endless-sphere.com/forums/viewto ... 35&t=61569
Velociraptor: 6s 10.4ah, Ezrun150, 9.8 mm abec11s, Quanum, 5060NTM, 16/48 hdt5, Piggyback Charge
Paragon
Post by Paragon » Dec 24, 2014 3:42 pm
Wow nice, I'm working on a board right now. Sign me up for a couple of them? How much will they be sold for?
mccloed
Post by mccloed » Dec 24, 2014 9:17 pm
God job! Definitely interested in testing them.
liveforphysics
Post by liveforphysics » Dec 25, 2014 4:05 am
If designed right, I've got no doubts they can deliver all the torque needed for hills and things. Justin's hubmotor skateboard climbed the very long steep hill I live on like it was nothing.
Hubmotors seem like the sensible path for skateboard drive IMHO.
jacobbloy
Post by jacobbloy » Dec 25, 2014 8:11 am
Hi guys! That's for the positive feed back!
Kv depends on wheel size, but 100kv even 80kv would be good but you loose out on coper and have to go thicker copper but making it sit in the small stator slots is key! Current kv we have tested is 100kv 150kv and 180kv! Power performs better with 180kv but 100kv is so much smoother for take of.
Esc's we have tested are!
Hobbywing
AP
E-cruiser straight motor swap:)
Sky rc toro
CC
All perform well!
Hill climbing is great with momentom/ high voltage passing through the motor.
Take off isn't as good on hills but this is because of the reduced resistance by not having a belt the deck just wants to roll back wards.
Take off is so much smoother! 1:1 ratio means momentum builds quicker and smoother!
Price depends on country we produce in and the amount we produce!
If we sell and operate from Australia then insurance and tax will drive the price!
To tell the truth I can get motor out with the wheel for $60 each just for hardware in lots of 100. but for $100 the quality is so much better! But then we add insurance shipping tax and profit for future production runs. We are looking at $150-$200 each motor. But if u think about it, $40 motor + $150 mount + $20 for 1 quality wheel + $10 belt depending on the kit $150 per motor is still a bargin even $200! But give me your opinions!
i had backers but the wanted to take control of my project so I got out!
The real problem is finding the money to get started! Kickstarter is an option but there are so many atm I feel I need this to be taken to the next level! Partnering with a deck like marbel would be cool!
But I'm a DIYer and I want to offer this as a DIY product!
torqueboards
1.21 GW
1.21 GW
Post by torqueboards » Dec 25, 2014 11:47 am
Sounds great. I'm in! I'm sure we could all do a group buy. What's ETA?
beto_pty
Post by beto_pty » Dec 25, 2014 1:20 pm
I say $150 sounds fair...
tung256
Post by tung256 » Dec 25, 2014 4:17 pm
you can always sell on ebay to test the water...
and with ebay, no insurance whatsoever. we all like what we are seeing.
jacobbloy
Post by jacobbloy » Dec 25, 2014 9:08 pm
Ebay is a thought!
Please any one pm me if your interested in group beta production run!
If we plan on 20 motors we can work on any bugs any one finds.
torqueboards
1.21 GW
1.21 GW
Post by torqueboards » Dec 25, 2014 9:30 pm
jacobbloy wrote:Ebay is a thought!
How many of these hub motors do we require for climbing hills?
I'm in for 2 depending on the cost.
beto_pty
Post by beto_pty » Dec 25, 2014 11:33 pm
jot me down for 2 as well..
killisch
Post by killisch » Dec 25, 2014 11:53 pm
Happy to grab 4 as long as reasonable quality is there.
torqueboards
1.21 GW
1.21 GW
Post by torqueboards » Dec 26, 2014 12:04 am
I'll go 4 too. :)
Paragon
Post by Paragon » Dec 26, 2014 12:21 am
I'll go 2 depending on the price
Silenthunter
Post by Silenthunter » Dec 26, 2014 7:43 pm
I would buy 8 of them if the price is right and the motors are built right and reliable.
jacobbloy
Post by jacobbloy » Dec 26, 2014 9:51 pm
Silenthunter wrote:I would buy 8 of them if the price is right and the motors are built right and reliable.
Hi guys, iv had a request for about 20 motors:)
The build quality is going to be the priority of this run! I'm talking to some local factory's to have it produced in Australia. Or the parts I have been making so far have been from the same factory as momentum kits are produced!
But keep in mind this is still in testing stage and I'm looking for reliable people who know about DIY electric skateboards and can help make the product better. If you order then this will be the first big production and if we find problems we need to work to gether to fix them and I will inspect every motor before shipping! And I'll look to replace any that have problems. But if you do not feel this is at a progression you would like we will offer another production later!
Each motor will be $130 for this beta run, unless we can get the order up to 50 motors and then I it will be $100.
Australia customers will have free shipping!
world wide will be $40.
If price is reduced for any reason I will refund the gap!
When I send the invoices to those who ordered I will give the choice of half payment or full payment! The second half will be requested before shipping.
Invoices will be sent on the 5th and the if possible payment by the 15th when I will be placing the order for parts.
For those of the forum I feel will be great benifit to the project I will be sending a motor to the for free out of my own pocket!
I thank every one for there help and support!
Happy holidays and have a great new year!
melodious
Post by melodious » Dec 26, 2014 10:26 pm
Who wants a functional motor/wheel combo if it only lasts 1000km and your forced to buy another. Can you go into more detail about changing & replacing worn wheels? Can a person, go from 70mm or 83mm to 90+mm without buying a new motor? Otherwise, it has the proprietary stigmata attached to it.
Vdraco
Post by Vdraco » Dec 27, 2014 2:35 am
Hi Guys,
Sign me up for two motors please :)
Great work!
