QS MOTOR,0.5-14kW Electric Hub Motor Manufacture China
QSMOTOR   1 kW
Location: QS Motor,Jinqing Town, Luqiao District, Taizhou City, Zhejiang Province
Re: QS MOTOR,0.5-14kW Electric Hub Motor Manufacture China
Post by QSMOTOR » Jun 23 2017 11:06pm
John Bozi wrote:
QSMOTOR wrote:
bigpie wrote:Would the 3000w with the high torque winding be any good for a gas gas trials bike conversion at 48v?
Hi,
The torque capability is same for each winding motor.
According to our test, for 3kW 50H V3 motor, the max. torque could reach to 180.0N.m.
Thanks,
If wheel size is the same for the 3kw 50H V3,
If the motor is ridden at 30kmh up a hill on different windings, which motor turn count will heat up the least?
Is it the 7t?
Or do all the different winding motors require the same torque or amount of power, so the same amount of heat will happen in every winding at low speeds?
Are you saying the volt and amp ratio makes no difference to heat in the motor at low speeds?
Specifically off road riders often ride an average of 30kmh, so in this case a 7t or custom 8t would be best to keep the motor cooler, correct?
Hi,
As your average speed is only 30kmh, we suggest you to use our 7T winding motor.(17*7T, 48v@300RPM)
For your question about speed and torque, you can refer to this comment " The lower turn motor can take more amps then a higher turn count motor.
Every turn count motor has exactly the same torque, its just a matter of how it gets there.
It requires less amps on a high turn count motor but that motor has longer strands of thinner copper wire then a low turn count motor. So its a balancing act."
Thanks,
Judy -Powered by SIA
No QS Motor, No Super EVs!
-QS Motor/Taizhou Quanshun Motor Co., Ltd. -Taizhou SIA Trading Co., Ltd. (Export Dept.)
-International Sales -Tel: +86 0576 88551619 -Skype: vito-ho -QQ: 289026969
-WhatsApp/WeChat: +86 13575887162 -Email: judy@tzquanshun.com
-Official Web: http://www.cnqsmotor.com/en/
-Facebook: https://www.facebook.com/judy.gong.775
-Amazon: https://www.amazon.com/s?k=SPOKE+HUB+MO ... nb_sb_noss
John Bozi   1 MW
Post by John Bozi » Jun 23 2017 11:15pm
thanks QS!
Is that suggestion based on less heating up of the motor?
and is that due to running higher volts to lower amp ratio?
thanks for clarification
rumme   100 kW
Post by rumme » Jun 24 2017 11:59am
I noticed the 43H magnet motors are rated at 1200 watts and the 3000 watt nominal motors use 50H magnets. Is it safe to say that any motor that is using the 43H magnets but claims to operate properly between 3000- 6000 watts , is not being honest ?
QSMOTOR   1 kW
Post by QSMOTOR » Jun 25 2017 7:26pm
rumme wrote:I noticed the 43H magnet motors are rated at 1200 watts and the 3000 watt nominal motors use 50H magnets. Is it safe to say that any motor that is using the 43H magnets but claims to operate properly between 3000- 6000 watts , is not being honest ?
Hi,
Thanks for your interested.
Our QS prefer to name 43H magnet motor as 1200W motor.
Because for 43H magnets motor, the 1200W means rated(Sustained) power, the peak power is 2400W. It even could reach to 3-6kW in a few seconds.
Such as our 1kW 35H motor, the momentary power is able to reach 4300W.
Thanks,
QSMOTOR
QSMOTOR   1 kW
Post by QSMOTOR » Jun 25 2017 7:32pm
John Bozi wrote:thanks QS!
Hi,
Yes, that's right.
Thanks,
QSMOTOR.
MadRhino   100 GW
Post by MadRhino » Jun 26 2017 6:37pm
Motor rated power is based on bench tests, and very conservative. We are many to have fed 10 kw bursts to cheap 35h 6X10 motors that were rated 1000 w. :twisted:
PS. Don't worry Vito. I will not claim the warranty. :D
Current bikes
Street: https://s20.postimg.org/ewrvugywt/Session_04_2015.jpg
Dirt: https://s20.postimg.org/lbqwr55ml/IMG_0157.jpg
bigbore   10 kW
Post by bigbore » Jun 27 2017 8:44am
He he Vito ... you know we are here to push the limits of everything we can!
My QS205 30X4T handle almost every day about 7Kw continuous for 4Km and with 10ml of ferrofluid in it do not exceed the temeprature of 80°C
ridethelightning   1 MW
Post by ridethelightning » Jun 27 2017 5:51pm
bigbore wrote:He he Vito ... you know we are here to push the limits of everything we can!
I have the same experience with my qs205 4t 50h v3, 17" wheel.
now with 10ml ferrofluid, can maintain speeds of 80-90kph on flat, for ~1/2 hour without going over 80C. i think it would go for longer, just have not tested it.
temps seem to stabilise @ 70-80c. ambient is ~12-15c.
GmagNeato   100 W
Post by GmagNeato » Jun 27 2017 6:33pm
Bigbore + RTL, not sure what voltages you guys are running.. what is the continuous current you’re pushing through the motor at those levels?
1st build: (commuter conversion) Novara HT / DIY 15s7p Panasonic NCRB's (harvested from used laptop packs) / 40a generic Chinese controller / 1500w 5T Leaf motor (STOCK)
2nd build: EEB frame / 20s4p of 7200mah Turnigy Hard Case Packs, 74v nominal, 28.8ah, 2131wh / Adaptto Max-E (9G4 firmware currently) + BMS + 70a Charge Coil onboard / QS 205 V3 Extra 5T
bigbore   10 kW
Post by bigbore » Jun 28 2017 3:49am
GmagNeato wrote:Bigbore + RTL, not sure what voltages you guys are running.. what is the continuous current you’re pushing through the motor at those levels?
I have a 20S14P battery made with 18650 cells so 72V nominal and a 19" MC tyre. On the display I read a continuous (while riding at 85Km/h) battery amp at about 95A but I don't know how many amps are going to the motor.
Post by ridethelightning » Jun 28 2017 5:13am
22s 18p 18650, 79.2v nominal.
I didnt really pay too much attention to the current/power while riding, mostly just the speeds and other vehicles :D
Im not even too sure my motor tuning settings on the max-e are optimised yet.
the other factor that might come into effect is the 6wag phase wires I installed right the way to the stator windings.
there is a LOT of copper in there(2 times that of 8awg), and i suspect it also helps to soak some heat out. will be adding hubsinks very soon too.
basically im really happy with the qs205 v3. it makes possible the functionality of light motorcycle performance..
bigbore   10 kW
Post by bigbore » Jun 28 2017 8:12am
ridethelightning wrote:22s 18p 18650, 79.2v nominal.
Yep! The same for me ... moto/bicycle in the same vehicle :D
I found out that the fine tuning of the motor parameters is pretty time consuming but at the end is very useful. I also have hubsinks but not installed yet because before installing I want to be sure they are really useful.
I use to test the motor during a long straight while coming back home from work at night when there are no other vehicle on the road both directions and tweaking with the options I found out that OVS=0 is the best for me to avoid motor overheat and another thing to keep in mind is the power reduction that is observed at constant speed after acceleration. If I do not have this reduction and then the power remains at about 10Kw (140A) at full throttle the motor overheats after a few minutes.
DasDouble   100 kW
Post by DasDouble » Jun 29 2017 7:03pm
I have to mention again,
Vito is doing an excellent service! I am so happy, I don´t even hesitate anymore to order QS products as they are as transparent and helpfull even after sale, as possible! THANK YOU REALLY MUCH! I have never seen such fast and detailed service like the one from Vito!
Thank you,
Elias
Mechatronics-Engineering Student
-Built own ebike: ✔
-Built own 3.2kWh LiIon battery (300Amps): ✔
-Overtake Porsche with own Ebike: ✔
-Take off with ebike: ✖
~14kW, 3.2kWh LiIon, QS 205 8ml ff, hubsink
macribs   1.21 GW
1.21 GW
Post by macribs » Jul 05 2017 12:20pm
What is the difference between 205 55H and 205 50H? And is the QS 205 55H motor also available with spoke flanges?
QS 205 55H: Max torque 184 N.m. Rated for 4000 Watt
QS 205 50H: Max torque 168 N.m. Rated for 3000 watt
Anyone tested QS 205 55H? A 10% increase in torque and even 30% higher rating for power. I wonder what to expect from that motor compared to the 205 50H? Acceleration, speed and heat wise. Will 205 55H take more continuous power then the 205 50H? Are there more copper fill as I see the weight is around 2.5 kilos more for the H55 over the H50.
Thinking this might be a good fit for the new Vector mid drive frame. Loose the rim, either get custom cover with sprocket or modify existing sider cover to take a sprocket.
Vito, could QS 205 55H motor be delivered with front sprocket on side cover?
Post by ridethelightning » Jul 05 2017 5:37pm
being a 205 familly member, it might possibly match the qs 205 50h side covers with freewheel mount..
Cricket_Swe   100 W
Post by Cricket_Swe » Jul 06 2017 3:05pm
Is it bad if it looks purple like this on the inside? I bought mine used
liveforphysics   100 GW
Post by liveforphysics » Jul 06 2017 3:13pm
That looks like a dyechem blue dye so you can easily see the shiny spots if you have mechanical contact. Not an issue fortunately.
BCTECH   100 W
Post by BCTECH » Jul 06 2017 3:15pm
Cricket_Swe wrote:Is it bad if it looks purple like this on the inside? I bought mine used
I got my new one last week and looks the same. not sure what coating is that, but should be fine
Cricket_Swe   100 W
Post by Cricket_Swe » Jul 06 2017 11:13pm
Thanks! That makes me feel better. Going to use ferrofluid when it arrives and hubsinks!
QSMOTOR   1 kW
Post by QSMOTOR » Jul 11 2017 7:30pm
MadRhino wrote:Motor rated power is based on bench tests, and very conservative. We are many to have fed 10 kw bursts to cheap 35h 6X10 motors that were rated 1000 w. :twisted:
Hi,
Thanks for your message.
Yes, it seems to work in theory.
But, we won't suggest you to do like this.
It might burn out the coil, also it will influence the motor working life.
Thanks,
QSMOTOR.
QSMOTOR   1 kW
Post by QSMOTOR » Jul 11 2017 7:53pm
Hi,
It's true that adding ferrofluid would be helpful for cooling.
Thanks,
Damon
QSMOTOR   1 kW
Post by QSMOTOR » Jul 11 2017 7:54pm
Cricket_Swe wrote:Thanks! That makes me feel better. Going to use ferrofluid when it arrives and hubsinks!
Hi,
Sounds cool.
Thanks,
QSMOTOR
QSMOTOR   1 kW
Post by QSMOTOR » Jul 11 2017 8:13pm
Hi,
Fine.
Thanks,
QSMOTOR.
QSMOTOR   1 kW
Post by QSMOTOR » Jul 11 2017 8:19pm
ridethelightning wrote:being a 205 familly member, it might possibly match the qs 205 50h side covers with freewheel mount..
Hi,
Thank you very much for your support.
QSMOTOR.
QSMOTOR   1 kW
Post by QSMOTOR » Jul 11 2017 8:44pm
macribs wrote:What is the difference between 205 55H and 205 50H? And is the QS 205 55H motor also available with spoke flanges?
Hello,
Thanks for your email.
1). This motor is not available with spoke flanges.
It's used for e-scooter, rather than e-bike.
Here is application picture for this motor.
2). Difference between QS 205 50H & QS 205 55H:
a. Magnet height is different:
50H's magnet height is 50mm, 55H's magnet height is 55mm.
b. Speed & torque:
As you know, 55H motor is powerful than 50H motor, so it will has higher speed & torque.
3). According to your provided infos, we recommend to choose QS 205 e-bike motor.
For more detailed infos for this motor, you can refer to below link:
http://www.cnqsmotor.com/en/article_rea ... e/536.html
Thanks,
QSMOTOR
