QS MOTOR,0.5-14kW Electric Hub Motor Manufacture China
parabellum   10 MW
Re: QS MOTOR,0.5-14kW Electric Hub Motor Manufacture China
Post by parabellum » Jun 09 2018 1:01am
QSMOTOR wrote:
Jun 08 2018 9:32pm
5. Electric bicycle hydraulic disc brake system
What is the hose length to rear brake in this system?
QSMOTOR   1 kW
Location: QS Motor,Jinqing Town, Luqiao District, Taizhou City, Zhejiang Province
Post by QSMOTOR » Jun 09 2018 1:37am
1. The length of rear oil tube is 1600mm, front oil tube is 900mm(as default), we also can do customized length according to your e-bike if you have requirement.
2. And the diameter of the plate we suggest is 203mm, but we also could provide 180mm. PCD6*44mm, 2mm thickness.
3. Callipers: double-piston 2*21mm
4. Installing Distance of front tire: 74mm(as default) or 51mm
5. Installing distance of rear tire: 51mm
6. Wiring: two core wiring
7. Materials: Caliper/Lever Forged aluminum, bracket: Cast aluminum
9. Current: 1A (max)
Any other questions, pls free to tell.
Thank you,
Judy -Powered by SIA
No QS Motor, No Super EVs!
-Taizhou Quanshun Motor Co., Ltd. -Taizhou SIA Trading Co., Ltd. (QS Export Department)
-International Sales -Tel: +86 0576 88551619 -QQ: 710436216 -Skype:judy.gong5
-WhatsApp: +86 13575887162 -Email: judy@tzquanshun.com
-Facebbok: https://www.facebook.com/tzqsmotor/ -Twitter: https://twitter.com/cyanzhang1
-Web: http://www.cnqsmotor.com/en/(under construction) http://qsmotor.en.alibaba.com/
Amazon: https://www.amazon.com/s/ref=w_bl_hsx_s ... ds=QSMOTOR
parabellum wrote:
Jun 09 2018 1:01am
QSMOTOR wrote:
Jun 08 2018 9:32pm
-QS Motor/Taizhou Quanshun Motor Co., Ltd. -Taizhou SIA Trading Co., Ltd. (Export Dept.)
-International Sales -Tel: +86 0576 88551619 -Skype: vito-ho -QQ: 289026969
-WhatsApp/WeChat: +86 13575887162 -Email: judy@tzquanshun.com
-Official Web: http://www.cnqsmotor.com/en/
-Facebook: https://www.facebook.com/judy.gong.775
-Amazon: https://www.amazon.com/s?k=SPOKE+HUB+MO ... nb_sb_noss
cwah   10 GW
Post by cwah » Jun 09 2018 5:20am
QSMOTOR wrote:
Jun 08 2018 9:32pm
Thank you for your message, this is Judy from QS motor.
1. As your requirement, you can use our 20inch 60V 1000w 205 35H V1 Cast Wheel Hub Motor, dropout 135mm. RPM about 585RPM at 60v, max speed is about 45km/h. Pls see below picture:
Here attach the drawing for this motor, pls check.
The unit price for this motor is $110/pc
2. The single freewheel is $6/pc
3. For controller, you can use sine wave Kelly controller KLS4812S with bluetooth, waterproof IP54, pls see this picture:
http://www.cnqsmotor.com/en/article_rea ... A/719.html
The unit price for this KLS4812S controller is $112/pc(including bluetooth)
We also could provide disc brake, throttle, do you need?
4. Half Twist Throttle With Voltage Display And Ignition
Unit price: $9.8/pc
Unit price: $95/set
And could you pls provide your e-mail address that would be convenient for us to communicate?
Best regards.
cwah wrote:
Jun 08 2018 5:00pm
Hello
I'm looking for a super reliable, silent and waterproof kit:
- my battery is 60v 3000W continuous power
- My bike is high load (150-200kg).
- I need speed between 25-60km/h
- I need a motor on 20" wheel (casted wheel) and 135mm dropout.
- controller has to be sine wave and absolutely silent and reliable
Do you have something?
Thanks
Do you have a more powerful motor than this one? The bike load is 200kg and need 60km/h.
Also are Kelly the best? What about sabvoton? I need silence and reliability
Thanks
QSMOTOR   1 kW
Post by QSMOTOR » Jun 11 2018 1:04am
cwah wrote:
Jun 09 2018 5:20am
QSMOTOR wrote:
Jun 08 2018 9:32pm
Unit price: $9.8/pc
Unit price: $95/set
Best regards.
cwah wrote:
Jun 08 2018 5:00pm
Hello
Thanks
Thanks
Just checked with our enginner, for 20inch 135mm dropout cast wheel hub motor, the most powerful is 800w 30H.
1000W 35H because of the limit of space, we did not do yet.
If load weight 200kg and 60km/h max speed, this motor could not support.
The most it could do is about 150kg and 40km/h. The RPM is 488RPM , the max torque is about 109N.m
Thank you,
By the way, could i know your e-mail address?
Judy
E-mail: judy@tzquanshun.com
dreamer291   10 µW
10 µW
Post by dreamer291 » Jun 21 2018 2:18am
I have an E-Max Scooter from 2010 and i don't know who is the Manufacturer from this Motor, Proud Eagle or QS Motor?
but the first Models with Proud Eagle Controller don't have a strong Motor later Models with Temp Sens in Motor and Sevcon Controller seems to be much stronger.
What is the strongest Motor i can use for my E-Max (Single Shaft, Detachable Wheel) ???
QSMOTOR   1 kW
Post by QSMOTOR » Jun 21 2018 10:13pm
For motor of your E-Max scooter, you can take a picture that i can see if it is our motor.
In order to recommend you suitable motor, could you pls provide below informations:
1. What is weight of your scooter and loading weight?
2. Your max speed requirement?
3. Climbing angle?
4. Tire size and model? For example: 130/60-17
5. Voltage and power requirement?
I will do analyest and calculate which motor suit you.
Thank you,
Judy
Skype: judy.gong5
dreamer291 wrote:
Jun 21 2018 2:18am
QSMOTOR   1 kW
Post by QSMOTOR » Jun 21 2018 11:00pm
QSMOTOR 273 V3 and V4 in wheel hub motor comparison
The may different with V3 is V4 can more cooper wire /thicker Cross-sectional area section, bear more current in usage, so you can see in out news with same KV, V4 peak speed is higher, and acceleration is fast
Similar kV from test report, pls see below:
Better acceleration and higher speed in real scooter test
ltu   100 mW
Post by ltu » Jun 23 2018 8:33am
hello vito
do you have available a 35h v2 fast wings(11kv or 10kv) hubmotor?
QSMOTOR   1 kW
Post by QSMOTOR » Jun 24 2018 7:19pm
ltu wrote:
Jun 23 2018 8:33am
hello vito
Hi Itu,
Thank you for your message, this is Judy colleague of Vito from QS motor.
For the hub motor, could you pls tell below informations that i can which is suit for you:
1. What is your application: e-bike, e-motorcycle, e-car?
2. Your tire size?
3. Max speed requirement?
4. Which voltage and power do you require?
Thank you,
Judy
Tel: +8613575887162
QSMOTOR   1 kW
Post by QSMOTOR » Jun 26 2018 3:31am
QSMOTOR Front Rear ebike electric bike kit Aluminum Wheel
Front Wheel Set
1.60X19" 2 Cross Pattern Moped Front Wheel Set
1.60X19" black moped aluminium wheel rim
32X10G Spoke (Iron with zinc coat).
Front Hub 32 holes, M20 diameter, 110mm dropouts, black
For Front Rim, Nipples, Spoke & Hub, $ 84.0 For Lacing & Truing, $ 25.0 Total Cost $ 109.0
Front hub 32 holes, drill to be 4.0mm to fit with 10G spoke (for new samples, it's in black and white).
P.s.: Now we could also make the spoke in black (Iron).
Moped Rear Wheel Set
Option 1. 1.60X17" 1 Cross Pattern Moped Rear Wheel Set
1.60X17" black moped aluminium wheel rim
36X10G Spoke (Iron with zinc coat).
QS 3000W 205 50H Hub Motor, 36 holes, 150mm dropouts, black(not include motor)
For Rear Rim, Nipples, Spoke, $51.9 For Lacing & Truing, $25.0
Total Cost $76.9
Option 2.1.85X18" 1 Cross Pattern Moped Rear Wheel Set
1.85X18" black moped aluminium wheel rim
For Rear Rim, Nipples, Spoke, $55.4 For Lacing & Truing, $25.0 Total Cost $80.4
Option 3. 1.60X18" Radial Pattern Moped Rear Wheel Set
1.60X18" Black moped aluminium wheel rim
36X10G Spoke, silver color (Iron with zinc coat)
For Rear Rim, Nipples, Spoke, $54.4 For Lacing & Truing, $25.0 Total cost $79.4
Option 4. 1.60X19" 1 Cross Pattern Moped Rear Wheel Set
1.60X19" Black moped aluminium wheel rim
36X10G Spoke , silver color (Iron with zinc coat)
QS 3000W 205 50H Hub Motor, 36 holes, 150mm dropouts, black (not include motor)
For Rear Rim, Nipples, Spoke, $53.9 For Lacing & Truing, $25.0 Total cost $78.9
Black spoke is avaiable.
Bicycle Rear Wheel Set
Option 1. 24"X2.125" 1 Cross Pattern Bicycle Rear Wheel Set
24"*2.125" black bicycle aluminium wheel rim
36X12G Spoke (Iron with zinc coat).
QS 1000W 205 35H Hub Motor, 36 holes, 135mm dropouts, black(not include motor)
For Rear Rim, Nipples, Spoke, $45.4 For Lacing & Truing, $25.0
Total Cost $70.4
Option 2. 26"X2.125" 1 Cross Pattern Bicycle Rear Wheel Set
26"*2.125" black bicycle aluminium wheel rim
Total Cost $70.4
PS. It's only avaiable for 205 35H V1 hub motor now.
Package
For front & rear wheel, we will new carton package 57*57*25cm for each (no need wooden support now).
This is ready for Amazon website:
http://www.amazon.com/dp/B07DC1MH2B
Judy
Skype: judy.gong5
Tel: 86-13575887162
QSMOTOR   1 kW
Post by QSMOTOR » Jul 01 2018 8:09pm
|Customization| Sabvoton SVMC72200 motor controller with CAN-BUS
There are two extra wires, for CAN-H, and CAN-L.
refer to below pictures.
Meanwhile, the 0-5V variable regen brake current could be set maximum, equal to phase current.
refer to below setting.
No QS, No Fun!
Thank you,
Judy
dapkcuf   100 µW
100 µW
Post by dapkcuf » Jul 02 2018 6:50am
Hello,
I am interrested to buy one of your motors.
I currently have a 22s8p battery pack (made of 18650 batteries).
My bike has 135mm dropouts.
I would like to use it at 3000W continuous (up to 4000W maximum).
What motor do you recommand?
Does it fit the 135mm dropouts?
Thanks.
QSMOTOR   1 kW
Post by QSMOTOR » Jul 02 2018 8:29pm
dapkcuf wrote:
Jul 02 2018 6:50am
Hello,
Thanks.
Dear dapkcuf,
Thank you for you message, this is Judy from QS motor.
For 135mm dropout spoke hub motor, the most powerful is 1000w 205 35H V1 spoke hub motor, up to 2000w maximum.
Could you pls tell below informations that i can see if this motor suit you?
1. Weight of your e-bike and loading weight?
2. Max speed requirement?
3. Battery voltage?
4. Tire size?
By the way, could i know your e-mail address that would be convenient for us to communication?
Thank you,
-International Sales -Tel: +86 0576 88551619 -QQ: 710436216  -Skype:judy.gong5 -E-mail: judy@tzquanshun.com
dapkcuf   100 µW
100 µW
Post by dapkcuf » Jul 05 2018 5:02am
Thanks for your update.
1. The bike himself is about 40-50kg (with a magic pie 3 hub + battery pack)
2. The max speed required is about 65km/h
3. Battery voltage is 92 full charge and 74 cutoff
4. Tire size is 26" (in a standard mountain bike frame)
I sent you my email in PM.
QSMOTOR   1 kW
Post by QSMOTOR » Jul 06 2018 3:06am
dapkcuf wrote:
Jul 05 2018 5:02am
Thank you for your reply.
Could i know your name and e-mail? You mean you send e-mail to judy@tzquanshun.com?
Do you have any requirement about climbing angle/Torque?
For your speed 65km/h, it is no problem for our 1000w 205 35H V1 spoke hub motor.
The RPM we can do 750RPM at 72V, the max torque is 124N.m
How about your idea?
Looking forward to your reply.
Judy
dapkcuf   100 µW
100 µW
Post by dapkcuf » Jul 06 2018 8:32am
Hello,
I sent you an email so that we can continue the conversation.
Regards,
QSMOTOR   1 kW
Post by QSMOTOR » Jul 12 2018 3:20am
dapkcuf wrote:
Jul 06 2018 8:32am
Hello,
Regards,
Dear Raf,
How are you?
Did you get my reply about our 1000w spoke hub motor via e-mail?
For 135mm dropout motor, the most powerful for us is 1000w 35H V1 spoke hub motor, the peak power is 2000w.
The max speed can be about 65km/h, the max torque is about 124N.m
For our 3000w V3 50H spoke hub motor, the dropout is 150mm.
For this motor, the peak power can be 10kw, max torque 193N.m
Which do you perfer?
Thank you,
Judy
QSMOTOR   1 kW
Post by QSMOTOR » Jul 19 2018 10:39pm
17X1.6inch 1000w - 2000w 260 moped wheel hub motor
It's avaiable for 1000w to 2000w hub motor, refer to below list.
1000w 260 27H V1
1500w 260 30H V1 & V1.2
2000W 260 35H V1 & V1.2
Thank you,
Judy
madin88   100 MW
Post by madin88 » Jul 20 2018 2:24pm
QSMOTOR wrote:
Jul 19 2018 10:39pm
1000w 260 27H V1
Nice!
whats the difference between V1 and V1.2?
More technical infos like available kV, peak eta, peak torque and weight would be good to know.
- 10kW belt drive with Neumotor 8057: viewtopic.php?f=30&t=91144&start=50#p1377787
- Fully road legal (L1E approval) e-bike based on Votec V-FR frame
/ MXUS 3T / 17" Mitas MC11 / Adaptto Max-E / 20s12p 25R
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
QSMOTOR   1 kW
Post by QSMOTOR » Jul 22 2018 8:43pm
madin88 wrote:
Jul 20 2018 2:24pm
QSMOTOR wrote:
Jul 19 2018 10:39pm
1000w 260 27H V1
Nice!
Dear Sir,
Thank you for your message.
The difference between V1 and V1.2 is the V1.2 enclarged groove make more copper wire into motor, produce more powerful magnetic force.
Below is the winding list for 260 30H V1:
Winding RPM Voltage kV Inductance mΩ
10*7T- 238 48 4.96 / /
15*5T 380 48 7.92 / /
16*5T- 409 48 8.52 / /
17*4T+ 450 48 9.38 / /
18*4T- 550 48 11.46 / /
The max torque for 1500w 260 30H V1 is 141N.m
For this motor, our normal dropout is 200mm, below is the drawing:
17inch 260 200mm dropout hub motor drawing.pdf
(328.09 KiB) Downloaded 74 times
Could you pls tell your application that i can give you suggestion?
Thank you,
Judy
masagero   1 W
1 W
Post by masagero » Aug 09 2018 8:18am
Hi guys can you tell me what is the difference between qs 205 50h v3 and gs 273 4000w for e bike?
QSMOTOR   1 kW
Post by QSMOTOR » Aug 10 2018 2:32am
Hi,
Can you inform me your email address?
I'd like to write details to you via email.
Thanks!
masagero   1 W
1 W
Post by masagero » Aug 11 2018 1:26am
You have PM
Ebuilt   1 W
1 W
Post by Ebuilt » Aug 13 2018 2:58pm
The “simple” answer is QS205 is for bike conversions, and the QS273 is for motorcycle conversions. Weight and size are a huge factor. If QS205 on a bicycle isnt fast enough for you, wearing your sunglasses at night should do the trick.
:bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt:
