QS MOTOR,0.5-14kW Electric Hub Motor Manufacture China
ecross   100 W
Re: QS MOTOR,0.5-14kW Electric Hub Motor Manufacture China
Post by ecross » Aug 14 2018 12:42am
QSMOTOR wrote:
Jul 01 2018 8:09pm
|Customization| Sabvoton SVMC72200 motor controller with CAN-BUS
There are two extra wires, for CAN-H, and CAN-L.
refer to below pictures.
Meanwhile, the 0-5V variable regen brake current could be set maximum, equal to phase current.
refer to below setting.
No QS, No Fun!
Thank you,
Judy
E-mail: judy@tzquanshun.com
Hello,
how much for the 72200 controller?
-is also the new TFT LCD on stock?
BR
NC 2805 mod.
H4080 mod.
4504 mod.
4503 mod. with watercooling
LiIon 24S16P from Sony, Sanyo, Panasonic
Siemens 2000W travel charger
boscovich   1 mW
Post by boscovich » Aug 20 2018 9:05pm
Hi there
I'm interested in a 2000w V3 hub motor for an electric bike in a 24in rim.
It will be for a lithium battery on an electric enduro frame ( 154mm Dropout width)
the bike and rider will be a total of approx 140kg
how much would it cost including building into the rim and postage for australia?
please let me know if further information is required.
Thanks!
glerwill   10 µW
10 µW
Post by glerwill » Aug 28 2018 3:57am
Hi, I'm thinking of converting www.rieju.es/m/16/450/rs3-nkd-50 one of these from a non runner to electric in UK - as a motorcycle (not limited), using a hub motor for simplicity.
Likely use - city commutes in traffic
Range - about 25 miles
Acceleration - desired as good as a 400cc Suzuke burgman scooter
Top speed - able to cope with occasional trips on the ring road so able to get to 70mph for short periods e.g. up to 5 miles
I would welcome a sanity check as to whether this is achievable at some reasonable level of cost?
Please may I ask you to keep suggestions to hub motors
My starting point is www.qs-motor.com/product/8000w-spoke-hu ... motorcycle
Your suggestions very welcome
macribs   1 GW
1 GW
Post by macribs » Aug 28 2018 6:37am
glerwill wrote:
Aug 28 2018 3:57am
I know UK is pretty straight forward to get a one-off build registered as a 45 km/h moped. Changing that to an A1 or even A without any limitations I would imagine that would be a much tougher task, can't remember seing anyone in the UK done anything different then a moped 45km/h legal build here on the forum. There are a few threads about what it takes to get a build road legal here on the forum. Search function will go a long way. You might find that is cheaper to get bike registered as a A1 motorcycle. Those are limited to maximum output power of 11 kw continuous. Note that it is 11 kw continuous output power. A1 bikes are not speed limited. You can ride highways and toll roads no problems, and you will be able to keep up with traffic. That means you can have 30 or 40 kw peak output and still get it registered as a A1, which in turn should yield cheaper insurance etc over a fullblown motorcycle class A.
I would anyway start with a phone call to your local DMV and check with your local authorities what it will take to get the build road legal. As a one off you don't need a full road and crash test, so it should be manageable. In UK afaik there ain't even no requirements to have a third party inspection done by sertification companies like the TÜV. The cost for this process I have no clue, but your official DMV should be able to help you with that.
As for the build itself that motor will work well for street riding, even if it is heavy. Be sure to pair it with a controller that can deliver loads of amps. 600 amps at least. More is merrier, for rapid acceleration. For off road usage that motor might make the build a little tail heavy, but dirt road and fire roads should be ok without going full throttle. Also take it easy in corners in the beginning to you learn the limits of tractions, such a heavy motor in the rear wheel can give you a few surprises in the beginning.
glerwill   10 µW
10 µW
Post by glerwill » Aug 28 2018 8:00am
Thanks macribs you raised some good points
I have a full motorbike licence so thought unrestricted - will look at A1 as well.
Road use only
Hadn't thought about unsprung weight on rear - presumably that's why some use mid drive
Graham
satanicoo   1 mW
Post by satanicoo » Oct 02 2018 11:18pm
Hey guys,
would love to mount 2 rim motors on my 2000kg sedan. Could i get some advice on what motors to get from QS?
SlowCo   100 kW
Post by SlowCo » Oct 03 2018 6:20am
satanicoo wrote:
Oct 02 2018 11:18pm
Hey guys,
Two of these:
http://www.cnqsmotor.com/en/article_rea ... r/275.html
And you will need two of these:
http://www.cnqsmotor.com/en/article_rea ... r/799.html
Then a battery pack that can provide the needed current and has enough Ah to last the distance you need. Ask QS for a matched motor/controller kit. It'll probably cost north of $4000,- incl. shipping and excl. taxes and the battery pack.
shinyballs   1 kW
Post by shinyballs » Oct 04 2018 9:44am
I got a QS 10"X3.0" 3000W 205 50H V3 for my Velocifero scooter
http://www.cnqsmotor.com/en/article_rea ... r/183.html
Looking for a good quality tubeless tire which is not more than 16" in total diameter for this motor. Something like this or better -
http://www.pccmotor.com/suchti132st4.html
Sale section etiquette, pls be courteous to other members, if you know of a better deal or do not agree with the sale price, do not shove links to similar products being sold by someone else in another member's post.. it's just not nice. If you suspect a scam pls FLAG the thread for moderation and it will be checked out... i know this is a tough one to call but put yourself in the seller's shoes and imagine how you would like it.
http://endless-sphere.com/forums/viewto ... 31&t=25446
DasDouble   100 kW
Post by DasDouble » Nov 13 2018 6:10pm
Hello,
I got a bill (first warning) from TNT for shipping two motors and a rim from QS factory to Germany (127,26€) from the 10th of September 2017 (today is 14. Novermber 2018). I payed it but I wonder if I really had to as I remember to have payed for shipping together with the motor. What is this? Do I really have to pay for shipping? I ordered two motors and a rim back then.. If you want I can upload the pictures of the whole bill I made back then.
Please answer QS motors! Im confused about this!
The packages were send at the 25th September 2017
Inv. no QSMW17EL0731001
Shipping Marks
Elias-Damon
QSMW17EL0731001
GERMANY
TOTAL 3 CTNS
"..the crazy kid exploring hipower ebike world ^^"
-Built own ebike: ✔
-Built own 3.2kWh LiIon battery (300Amps): ✔
-Overtake Porsche with own Ebike: ✔
-Take off with ebike: ✖
~14kW, 3.2kWh LiIon, QS 205 8ml ff, hubsink
macribs   1 GW
1 GW
Post by macribs » Nov 13 2018 6:48pm
Are you sure that bill was for shipping, and not VAT or handling fees for import paperwork? When I order from China I usually get a bill at a later day then arrival of the actual package. First package is received and signed for, then later the bill comes. In Norway we have 25% VAT on top of the total amount of sale + shipping. And the shipping company usually deals with the VAT and paperwork, I think they actually pay the VAT upfront, then collect from customer later, and they also slap on a handling fee on top of the VAT.
I know you don't pay VAT for purchases within EU in Germany, but from China my guess is 17% vat on top of the purchase price.
DasDouble   100 kW
Post by DasDouble » Nov 14 2018 4:03am
@macrbis, ah yeah I guess thats the thing. Thanks for clearing up
-Built own ebike: ✔
soyachips   1 µW
Post by soyachips » Jan 08 2019 5:01pm
Hi there,
I’m thinking of using one of the QS273 motors in a motorcycle conversion and trying to see if it will fit in my swingarm. The standard dropout/swingarm size for these motors is 200mm. My swingarm is ~210mm but need to put the brake caliper mounting bracket in there as well. Can anyone tell me if the circled part of the axle below is a spacer to keep the wheel in the middle of the swingarm or something else and is it removable? I was thinking of replacing it with the brake caliper mounting bracket.
The drawing comes from http://www.cnqsmotor.com/en/article_rea ... r/245.html
Depending on what it is and whether or not it’s removable, I might end up getting a custom axle when I order the motor.
Thanks!
Dauntless   100 GW
Post by Dauntless » Feb 22 2019 1:00am
We've had a number of posts by people who can't get your motors and need explanation from you.
Any sufficiently advanced technology is INDISTINGUISHABLE FROM MAGIC!
- Arthur C. Clarke
ecross   100 W
Post by ecross » Feb 22 2019 3:08am
Hello,
please send offer for:
1pcs.
-QS 3000W 205 (50H) E-bike hub motor extra/V3 type
-3x45 winding
-16" Rim
-1xcrossed version
NC 2805 mod.
H4080 mod.
4504 mod.
