QS MOTOR,0.5-14kW Electric Hub Motor Manufacture China
QSMOTOR   1 kW
Location: QS Motor,Jinqing Town, Luqiao District, Taizhou City, Zhejiang Province
Re: QS MOTOR,0.5-14kW Electric Hub Motor Manufacture China
Post by QSMOTOR » Jul 27 2019 3:45am
Last 4 days for QS MOTOR Sales Discount!
All QSMOTOR 3000W and above hub motors and mid drive motors, Kelly controllers, Sabvoton controllers has a discount until 31th July.
See the Alibaba link: https://tzxiya.en.alibaba.com/promotion ... 556eumCLfp
Amazon link: https://open.weixin.qq.com/connect/oaut ... t_redirect
Thank you,
Judy
E-mail: judy@tzquanshun.com
Wechat: gh13797405776
Skype: judy.gong5
Judy -Powered by SIA
No QS Motor, No Super EVs!
-QS Motor/Taizhou Quanshun Motor Co., Ltd. -Taizhou SIA Trading Co., Ltd. (Export Dept.)
-International Sales -Tel: +86 0576 88551619 -Skype: vito-ho -QQ: 289026969
-WhatsApp/WeChat: +86 13575887162 -Email: judy@tzquanshun.com
-Official Web: http://www.cnqsmotor.com/en/
-Facebook: https://www.facebook.com/judy.gong.775
-Amazon: https://www.amazon.com/s?k=SPOKE+HUB+MO ... nb_sb_noss
Gigas   1 mW
Post by Gigas » Jul 29 2019 2:45pm
do you have a recommendation to convert my 4 person golfcart from gas to one of your electric motors and controllers?
QSMOTOR   1 kW
Post by QSMOTOR » Jul 30 2019 6:45am
Gigas wrote:
Jul 29 2019 2:45pm
Pls reference this link: https://www.alibaba.com/product-detail/ ... 71d2kYbqiF
In order to recommend suitable motors, could you provide below informations:
1.E-car for passenger or loading?
2. Total weight of vehicle with battery, and loading weight?
3. Tire model? For example 130/70-13
4. Rated voltage?
5. Max speed requirement?
6. How many engines will you use for one vehicle?
7. PCD/CB data of the rim?
Within your details information, we could make assessment and calculation accordingly for your project.
Thank you,
Judy
Gigas   1 mW
Post by Gigas » Jul 30 2019 10:38am
QSMOTOR wrote:
Jul 30 2019 6:45am
Gigas wrote:
Jul 29 2019 2:45pm
4. Rated voltage?
Thank you,
Judy
1- it's for 4 passengers
2- weights is about 1400lbs empty(with batteries) and 2200-2400lbs loaded
3- these tires i'm thinking about getting - 23x10-14 https://www.buggiesunlimited.com/golf-c ... es/A19-167
4-not sure on the voltage - whatever works
5- I would like to get up the speed 30mph but 20 if just as fine too
6 - I would like to use 2 motors but also 4 motors would be a good option too
7 - i'm not sure of the tires as of yet as I need to replace them - whatever motor I get the wheels will follow
Rasmus F   10 µW
10 µW
Post by Rasmus F » Jul 30 2019 12:49pm
Hi
I need help choosing the right Hub motor for my project.
It's a small moped i'm electrifying..
Max load 150kg
Max speed, flat road 80kpm normal cruise speed 40kpm I think.
17" spoke wheel with moped rim
72V battery
this will be for road only, no offroad.
I have my mind set on the 205 50H V3 but am not sure which winding to choose..
If you offer Rims and brake systems, 1/2 twist throttle as well, i'm interested.
/Rasmus
QSMOTOR   1 kW
Post by QSMOTOR » Aug 04 2019 11:01pm
Rasmus F wrote:
Jul 30 2019 12:49pm
Hi
Max load 150kg
72V battery
/Rasmus
Hi Rasmus,
Thank you for your message, this is Judy from QSMOTOR.
As your requirement, pls see below calculation:
You can use 4T winding, the RPM is about 820 @72v, the max speed is about 75km/h-80km/h.
Below is the kits with motor, 17: rim, controller, speedometer, throttle, disc brake system:
Could i know your e-mail that i can send quotation to you?
Thank you,
Judy
Gigas   1 mW
Post by Gigas » Aug 05 2019 12:03pm
guess my requirements are too much - good day
QSMOTOR   1 kW
Post by QSMOTOR » Aug 08 2019 10:19pm
QS Motor 205 50H V3 Electric high power bicycle kit / E bike kit / spoke hub Motor 3000W Powerful Hub Motor Kit with TFT H6 speed meter
1 主图QS.jpg (122.75 KiB) Viewed 3188 times
For 205 3000W 205 V3 electric spoke hub Motor kit assembly, it could be used for high power electric bike, which could be 72V 70KPH.
e.g. Electric high power bike
E-bike weight, approx 47kg+80kg
Tire diameter: 2.50-19
Speed: 72V 70km/h
Climbing slope: 25°@127kg
Battery: 72V40h lithium battery
One set including below kits
1.1pc X QSMOTOR 3000W 205 50H V3 electric spoke hub Motor
2. 1pc X Motor Spacer
3. 1pc X Freewheel
4. 1set X 19X1.6inch moped front wheel and 19X1.6inch rear wheel
4. 1pc X Sabvoton 72150 controller (customized for TFT speedometer) with bluetooth adapter
5. 1pc X H6 speedometer
6. 1pc X Half Twist Throttle
7. 1pc X Thumb Throttle
8. 1pc X disc brake assembly
9. 1pc X DC DC converter 72v to 12V 10A
10.1pc X PAS
1. Motor
Test report:
2. Motor Spacer
To protect motor phase wire
3.Freewheel
General SPEC
1. Single speed 1/2*3/32*16T, only 16T is available now
2. Black
3. English System Thread
4. Suit for QS Spoke Motor (English thread)
4.19X1.6inch moped front wheel and 19X1.6inch rear wheel
1.60X19inch 2 Cross Pattern Moped Front Wheel Set
32X10G Spoke, silver color (Iron with zinc coat)
32 holes, 110mm dropouts, black
1.60X19inch 1 Cross Pattern Moped Rear Wheel Set
36X10G Spoke, silver color (Iron with zinc coat)
QS 3000W 205 50H Hub Motor, 36 holes, 150mm dropouts, black (not include motor)
5.Sabvoton 72150 motor controller (customized for H6 speedometer)
Product Description of Controller
1. Generally SPEC
1). sine wave controller, programmable, with regen function
2). DC Current Limit: 150A
3). Max. Phase Current: 350A
4). Protect Phase Current: 450A
5). Battery Voltage: 24V-72V rated, Max. 95V
6). Including one controller
7). controller size: 247mm*146mm*62mm
8). Net weight: 2kg
9). Default including bluetooth adapter.
10). Default function: Hall, Throttle, Electric brake, High Brake Level, speed switch
11). Special functions: Waterproof
PS. Please note there is no temp sensor for motor.
6.TFT H6 color speedometer display
SPEC
· 3.2 inch color TFT screen
· 48V/60V/72V power supply
· Shutdown leakage current <1Ua
· Supply controller terminal operating current 100mA
· Normal operating temperature of the instrument -20~65°C
Function
1.Battery display: 5 segments of power indication, the voltage value of each segment can be set according to customer requirements;
2.Speed mode: real-time speed RT SPEED, maximum speed MAX SPEED, average speed AVG SPEED;
3.Speed display: display range 00.0. ~ 99.9, unit Km / h km per hour, MPH miles per hour;
4.Assist gear position: 0~9 files, of which 0 gear is neutral and no boost, 1~9 corresponds to boost gear, and P is displayed in 6Km push mode;
5.Headlight display: displayed when the headlights are on;
6.motor temperature: monitor motor temperature in real time;
7.Mileage mode: cumulative mileage ODO, single mileage Trip
8.WH.KM: the controller power consumption ,wh/km
9.Motor temperature.
10.Regen Ah:Cumulative Ah while controller in regen mode .
11. Clock: Built-in battery, user set up;
12. Clock: Built-in battery, user set the year, month, day, hour, minute and second.
7.Half Twist Throttle with 3 speed toggle switch
8. Thumb Throttle for 0-5V variable regen brake
It could be mounted in left hand
9.Disc brake assembly
electric bicycle aluminum hydraulic disc brake system assembly
Specification:
1. Model: 152PYD+BS150
2. Including 2pcs 203mm plate, PCD6*44mm, 2mm thickness
3. The length of oil of both front and rear can be customized according to your e-bike(900mm for front, 1600mm for rear as default)
4. Callipers: double-piston 2*21mm
5. Installing Distance of front tire: 74mm(as default) or 51mm
6. Installing distance of rear tire: 51mm
7. Wiring: two core wiring
8. Materials: Caliper/Lever Cast aluminum, Bracket: Cast aluminum
9.Current: 1A (max)
10.DC DC converter
72V to 12V, 10A
11.PAS
Made of steel material, durable and reliable.
Mount on electric bicycle pedal, easy to install
1:1 power assist, make cycling easier and funnier.
Suitable for most of electric bicycles.
More details, see this link: https://www.alibaba.com/product-detail/ ... 71d2yR87IY
Thank you,
Judy
Skype: judy.gong5
999zip999   100 GW
Post by 999zip999 » Aug 10 2019 2:31pm
New for sale section. Please must post prices.
QSMOTOR   1 kW
Post by QSMOTOR » Aug 16 2019 7:49pm
New SVMC+H6+PAS Publish and Promotion in August 2019
It is New Speedometer with various functions, which suit for Sabvoton controller communicate via UART, main application for electric bicycle, to bring you more convenient experience and sense of technology.
Features of kits: Support Battery display, Speed display, Assist gear position, Headlight display, Motor temperature display, Regen function, energy consumption (KW/H) and Mileage mode etc.
Activity Time: 2019.08.07-2019.08.30
Activity Products: SVMC Controller + H6 speedometer + PAS + Bluetooth Adapter
Activity Discount: 15% OFF
Products and Price List:
https://www.alibaba.com/product-detail/ ... 71d2SpAuQU
Thank you,
Judy
tony5haw2013   10 mW
Post by tony5haw2013 » Sep 05 2019 2:40pm
Been trying to contact you but no replay from whatsapp or email, im looking to buy motors
Sent from my SM-G965F using Tapatalk
Dauntless   100 GW
Post by Dauntless » Sep 05 2019 11:11pm
Post what you want right here
Any sufficiently advanced technology is INDISTINGUISHABLE FROM MAGIC!
- Arthur C. Clarke
amberwolf   100 GW
Post by amberwolf » Sep 05 2019 11:27pm
Dauntless wrote:
Sep 05 2019 11:11pm
That doesnt' appear to work (at least some of the time), as there are posters in this thread (one right on this page) that did not get answered, even after providing the info needed.
I would guess they have so much business they can afford to ignore potential customers.
QSMOTOR   1 kW
Post by QSMOTOR » Sep 07 2019 3:52am
tony5haw2013 wrote:
Sep 05 2019 2:40pm
Could you tell your e-mail? Which e-mail you send?
Thank you,
Judy
My e-mail: judy@tzquanshun.com
QSMOTOR   1 kW
Post by QSMOTOR » Sep 07 2019 4:18am
amberwolf wrote:
Sep 05 2019 11:27pm
Dauntless wrote:
Sep 05 2019 11:11pm
Could you tell which e-mail you send?
Pls send my e-mail: judy@tzquanshun.com
Thank you,
Judy
amberwolf   100 GW
Post by amberwolf » Sep 07 2019 11:50pm
QSMOTOR wrote:
Sep 07 2019 4:18am
I didnt send anything.
I said there are posters in this thread asking you questions that you didn't answer.
*You* have to read the thread to find them, and then answer them.
999zip999   100 GW
Post by 999zip999 » Sep 08 2019 2:12pm
It could be hard as E.S poster may not be the same I.D . as email. I wish info came to this page.
QSMOTOR   1 kW
Post by QSMOTOR » Sep 10 2019 3:35am
999zip999 wrote:
Sep 08 2019 2:12pm
Yes, if you have any question, you can post on this page.
Dauntless   100 GW
Post by Dauntless » Sep 10 2019 10:09am
QSMOTOR wrote:
Sep 10 2019 3:35am
As they have proven. . . .
- Arthur C. Clarke
snakub   100 µW
100 µW
Post by snakub » Sep 13 2019 9:48pm
Hi I am trying to build a three wheeled electric motor cycle and I am interested in one of your hub motor kits for the two front wheels maybe even three(one more for the back for all wheel drive). I am interested in drag racing it possibly doing 10 second quarter miles. I would like one of the kits with the motor already in an aluminum or steel wheel. The vehicle more than likely will weigh less than. 300 lbs 500 with me in it. Do you have a kit recommendation?
QSMOTOR   1 kW
Post by QSMOTOR » Sep 14 2019 7:20am
snakub wrote:
Sep 13 2019 9:48pm
Thank you for your message, for your vehicle, could you tell below question:
1. Tire size of your vehicle? For example 130/70-13
2. Max speed requirement?
3. Voltage?
Thank you,
Judy
Ethan121   1 µW
Post by Ethan121 » Sep 17 2019 4:37am
Hello
I have just ordered a QS205 V3 50H from the Aliexpress store QS MOTOR LIMITED - https://qsmotor.aliexpress.com/store/10 ... edb68huyrs
Can you please confirm that they are a genuine supplier and I will not receive a fake QS Motor?
Thanks
tolkaNo   100 W
Post by tolkaNo » Sep 17 2019 6:17am
Do you guys have test report for your 35h 1500w hub?
snakub   100 µW
100 µW
Post by snakub » Sep 17 2019 1:02pm
Well I don't know exactly what size tire but I would like a 21 inch motorcycle wheel and 144 volts or whatever the maximum is if that's what's necessary there's really no limit because I won't spare much expense when it comes to batteries. Possibly 120 mph top speed.
john61ct   100 GW
273 v3 motor
Post by john61ct » Sep 17 2019 6:08pm
To anyone, but also QS rep
re: 273 v3 motor
Question #1 What kV windings do you recommend?
heavy tandem/cargo eBike application, 26inch wheel, 3inch tire or fatbike if possible for gravel / dirt roads
150kg minimum gross weight, in steep hills, climbing big mountains at 20-25kmh
but up to 250kg fully loaded in flat areas
Top speed is **not** important, but km/kW energy efficiency should be optimized for 35kmh on flat smooth roads
Question #2
I don't know much about freewheels, does this 273 motor use the US standard thread 1.375″ - 24UN?
My friend says to ask if your motor can be made to work with cassette / freehubs instead? I want to use Shimano "Hyperglide-C" type with 11-tooth sprocket.
If not, then is a 36mm wide 7sp freewheel OK?
or is 16mm wide single speed freewheel required, like 16T?
What is the overall axle length?
The 152mm is "overlocknut distance" correct? https://sheldonbrown.com/gloss_n-o.html#old
must match my frame "dropout spacing" width, correct?
https://sheldonbrown.com/gloss_sp-ss.html#spacing
