QS MOTOR,0.5-14kW Electric Hub Motor Manufacture China
duffmanaudio   1 W
1 W
Re: QS 500W-10kW BLDC In-Wheel Hub Motor Catalog (Manufactur
Post by duffmanaudio » Feb 18 2015 9:06pm
Do you have any new info on the non hub motor?
parabellum   10 MW
Post by parabellum » Feb 18 2015 9:59pm
Ok, after few days, maybe you have wrong names on pictures?
Samd   1.21 GW
1.21 GW
Post by Samd » Feb 18 2015 10:22pm
Interesting thread!
http://ballaratebikes.com/
liveforphysics   100 GW
Post by liveforphysics » Feb 19 2015 2:39am
Vito8828- Would it be possible to make your 70MM wide largest stator diameter hub-motor into a double-stator? I would need the windings terminated to be powered from 4x Sevcon size6 controllers, it would only need to handle having 240kW sent to it for ~7-8 seconds.
I want to hubmotor my Sparrow.
r3volved   100 kW
Post by r3volved » Feb 19 2015 4:10pm
liveforphysics wrote:I want to hubmotor my Sparrow.
3wd!?!?
cwah   10 GW
Post by cwah » Feb 21 2015 9:15am
Vito8828 wrote:
cwah wrote:Do you sell compact sine wave controller? Something like 12 Fet controller 65A
Hello,
We cooperated with many controller manufactures in China, and are able to provide controllers.
For Sine Wave controller, Sabvoton and Lingbo controller is well known.
Also Kelly has developed some Sine Wave controllers in year 2014.
For compact sine wave controller, we are testing some small sine wave controllers.
Which might on sale after Chinese New Year.
Best Regards
Please share the compact controller for sale after new year, we need good compact controller and not these massive one that takes so much space
GiantEV   100 W
Post by GiantEV » Feb 22 2015 2:36pm
Very interested in these motors. I'd want a thread for a bicycle freewheel of course.
Doctorbass   100 GW
Post by Doctorbass » Feb 22 2015 2:40pm
liveforphysics wrote:Vito8828- Would it be possible to make your 70MM wide largest stator diameter hub-motor into a double-stator? I would need the windings terminated to be powered from 4x Sevcon size6 controllers, it would only need to handle having 240kW sent to it for ~7-8 seconds.
:mrgreen: :mrgreen:
A 240kW chineese hub motor...
That's the Luke we know !! 8)
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
Doctorbass   100 GW
Post by Doctorbass » Feb 22 2015 3:08pm
I saw that this company look like to have Lightning Motorcycles as client... I wonder if they built their motor or some of their parts.
Scottydog   100 W
Post by Scottydog » Feb 22 2015 4:46pm
Doctorbass wrote:I saw that this company look like to have Lightning Motorcycles as client... I wonder if they built their motor or some of their parts.
Vito mentioned Lighting in his posting as a customer.
Vito8828 wrote:Hi,
1. MANUFACTURER of high quality Electric Bike/Scooter/Motorcycle/Tricycle/Car Hub in-wheel motor (CE approved) with competitive price for 10 years!
Ranging 350W~10kW, 48~150V, 30~120KPH, with the customers of Terra Motors, Current Motor, Lightning Motorcycles, etc.
Doctorbass   100 GW
Post by Doctorbass » Feb 22 2015 7:32pm
Luke.. Maybe you need this 63kW hub motor prototype.. "just a bit" modified :mrgreen:
Doc
Doctorbass   100 GW
Post by Doctorbass » Feb 22 2015 7:37pm
This is the prototype for the 2 stator, dual controller, 63 kw hub motor. The prototype was built to test the design at 22 kw on the LRC motor scooter. The test is primarily to determine if the design delivers on longer range than lower power motors as paper studies show it should get. The LRC currently can run 140 miles on a charge at highway speeds. This motor is the format for the large Cruizer motorcycle in planning where it will be used at a planned 63 kw. Should the tests work as planned, the motor will become an option on the LRC scooter. In the production version the motor will be more narrow and lighter.
Doc
Scottydog   100 W
Post by Scottydog » Feb 22 2015 8:06pm
wow! I heard ZEV was going to test out the dual stator hub fairly soon!
QSMOTOR   1 kW
Location: QS Motor,Jinqing Town, Luqiao District, Taizhou City, Zhejiang Province
Post by QSMOTOR » Mar 10 2015 1:28am
duffmanaudio wrote:Do you have any new info on the non hub motor?
Thank you for your interest.
For BLDC PMSM Non HubMotors
Item: Qs 2000W 133 Built-in BLDC PMSM Non HubMotors
FOB Ningbo/Shanghai, USD 216.7/piece  (base on samples)
http://tzquanshun.en.alibaba.com/produc ... Motor.html
Description:
BLDC PMSM Inner Rotor Built-in Disc Motor
Magnet:                            133mm Diameter, 62mm height,
                                      5 pole pairs, 12 solts
Rated Output Power: 2000W rated
Rated Voltage:           48V
Rated Torque:            7.0N.m
Efficiency:                   92%
Rated Speed:             2454RPM
No load Speed:          2875RPM
Rated Current:            40.5A
No load Current:         4A
Application: Electric Motorcycle/Tricycle/Mini Car
P.S.: No-Load RPM could be customized to be 5000-6000RPM,
generally, it's 2000-3000RPM.
Valid time: 30 days
Producing Time: 20 workings days after receiving the payment.
Item:  Qs 3000W 133 Built-in PMSM Brushless DC Motor
FOB Ningbo/Shanghai, USD 233.5/piece  (base on samples)
Description:
Magnet:                            133mm Diameter, 100mm height,
Rated Output Power: 3000W rated
Rated Voltage:           72V
Rated Torque:            10.6N.m
Efficiency:                   89.8%
Rated Speed:             3440RPM
No load Speed:          3826RPM
Rated Current:            59.6A
No load Current:         10.7A
Valid time: 30 days
Item: Qs 5000W 171 Built-in PMSM Brushless DC Motor
FOB Ningbo/Shanghai, USD 416.7/piece  (base on samples)
Item: Qs 8000W 171 Built-in PMSM Brushless DC Motor
FOB Ningbo/Shanghai, USD 433.3/piece  (base on samples)
Description:
Magnet:                            171mm Diameter, 100mm height,
                                      5 pole pairs
Rated Output Power: 8000W rated
Rated Voltage:           72V
Rated Torque:            36.6N.m
Efficiency:                   92.3%
Rated Speed:            2009RPM
No load Speed:          3075.3RPM
Rated Current:           117.7A
No load Current:         10.93A
Valid time: 30 days
Judy -Powered by SIA
No QS Motor, No Super EVs!
-QS Motor/Taizhou Quanshun Motor Co., Ltd. -Taizhou SIA Trading Co., Ltd. (Export Dept.)
-International Sales -Tel: +86 0576 88551619 -Skype: vito-ho -QQ: 289026969
-WhatsApp/WeChat: +86 13575887162 -Email: judy@tzquanshun.com
-Official Web: http://www.cnqsmotor.com/en/
-Facebook: https://www.facebook.com/judy.gong.775
-Amazon: https://www.amazon.com/s?k=SPOKE+HUB+MO ... nb_sb_noss
\/ampa   100 W
Post by \/ampa » Mar 10 2015 1:33am
One of the most interesting specification for me is the motor weight. Can you make this information available ?
QSMOTOR   1 kW
Post by QSMOTOR » Mar 10 2015 1:38am
\/ampa wrote:One of the most interesting specification for me is the motor weight. Can you make this information available ?
Thank you.
It's a pity that the weight is not complete as we have thousands of motors.
Could you please advise which motor do you prefer and I could get back to you accordingly.
E.g.
QS 3000W 205 Spoke Motor V3 Type, G.W./N.W. 14.0kg/12.8kg
QS 13inch 8000W 273 Hub Motor V3 Type, G.W./N.W. 24.0lg/22.5kg
\/ampa   100 W
Post by \/ampa » Mar 10 2015 1:47am
From all three "BLDC Non Hubmotor" models.
QSMOTOR   1 kW
Post by QSMOTOR » Mar 10 2015 1:52am
\/ampa wrote:From all three "BLDC Non Hubmotor" models.
Thank you. Here is the the weight of Qs 5000W 171 Built-in PMSM Brushless DC Motor firstly.
G.W./N.W. 16.0kg/14.8kg
For others, I have to check later and get back to you accordingly.
QSMOTOR   1 kW
Post by QSMOTOR » Mar 10 2015 1:58am
Vito8828 wrote:Hi,
Thank you, : ).
We cooperated with Lightning for hub motors.
Btw., our manager and boss are in Business Trip in USA now.
Attached lastest picture with Mr. Richard Hatfield for reference.
QS-Richard Hatfield .jpg (95.92 KiB) Viewed 1530 times
QSMOTOR   1 kW
Post by QSMOTOR » Mar 10 2015 2:11am
Doctorbass wrote:Luke.. Maybe you need this 63kW hub motor prototype.. "just a bit" modified :mrgreen:
Doc
Thank you for sharing. We also work with ZEV in USA on hub motors. : )
Recently, they purchase a QS 13inch 6kW+6kW(45H+45H) dual stator hub motor V3 type for testing.
QSMOTOR   1 kW
Post by QSMOTOR » Mar 10 2015 7:46pm
Thank you for your kindly information.
As checked, dual 70mm is too wide for normal motorcycle/car.
For the moment, we could make it 13inch dual 50mm stator doulbe-shaft hub motor or 273 dual 50mm stator e-car hub motor.
Generally, the peak power for one 50mm hub motor is 20kW for few second.
If any question, please feel free to contact with us.
mikke   1 µW
Re: Brushless Built-in Motor(2000w~8000w)
Post by mikke » Mar 11 2015 8:22am
Hello
i was looking for some information on your hub motor 12" 500W 205 28H Export type/V2 Electric Scooter Hub Motor, i've looked in website and did not find any of these.
- moment of inertia
- Ld and Lq
- Self inductance and mutual inductance.
- back emf constant.
Is it possible to get them ?
Best regards.
teslanv   100 MW
Post by teslanv » Mar 14 2015 10:13am
Thanks for posting the details specifications of your motors.
I will definitely keep an eye on these.
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
madin88   1 GW
1 GW
Post by madin88 » Mar 15 2015 1:44pm
Vito8828 wrote:
neptronix wrote:Vito, in your experience.. do you notice a difference in efficiency between sine wave and square wave controllers?
In my point, there is a little difference in efficiency between sine wave and square wave controllers.
Sine Wave might be a little bit higher efficiciency.
Please refer to attached two test report for same motor, as you can see.
Sine Wave: 93.5%, Square Wave: 93.0%
Best Regards
what type of motor this is exactly?
that graphs looks to good to be true (at least for a single 205 / 50mm type motor) :)
edit:
i mean this http://tzquanshun.en.alibaba.com/produc ... Motor.html
white painting is good for hot climate. nice!!
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
QSMOTOR   1 kW
Post by QSMOTOR » Mar 15 2015 8:37pm
edit:
white painting is good for hot climate. nice!![/quote]
Vito: Thank you for your interest.
The motor in link is QS 3000W 205 (50H) E-bike hub motor extra/V3 type.
Item(e.g.): QS 3000W 205 (50H) E-bike hub motor extra/V3 type,
FOB Ningbo/Shanghai, USD 279.8/piece (base on samples)
Description:
1. BLDC Permanent Magnet Outer Rotor Spoke Hub Motor
2. Power: 50mm magnet height, 16 pole paris, 3000W rated, 3932W Peak.
36 spoke holes*4.2mm or 3.4mm (optional)
3. Speed: 30-80km/h (to be determined) in 48~72V , generally 650RPM in 72V, Winding 24*5 Turn, Torque: Depends on the speed
4. Designed to match with E-bike Disc brakes PCD6*44mm (not include Brake Disc),
drop-outs/Rear Bridge Clamping Width (150mm)
5. Two Halls(One for spare, in case of damage) , 10mm² Phase wire
6. Thermic Probe: KTY 83/122
7. Support regenerative braking & Reverse function
8. Waterproof grade: IP54
9. Efficiency: 89.8%
10. Stronger configuration--high grade magnet, more cooper, bear more Ampere.
11. 10mm or 12mm spade half of axle, generally 10mm
12. Color: White or Black
Package: Carton Ctn size: 34cm*34cm*33cm GW/NW: 14.0kg/13kg
MOQ: 1 pc for sample, 10 pc for mass production
Payment terims: T/T, Money Gram,Western Union 100% in advance (for sample)
Valid time: 30 days
Producing Time: 12-15 workings days after receiving the payment.
Attached test report and drawing for reference.
Best Regards
QS 205 E-Bike Spoke Motor 150mm Drop-outs Drawing.pdf
(219.23 KiB) Downloaded 155 times
QS 205 WP72V3000W 650RPM 24X5 89.8% V3 Test.pdf
(265.02 KiB) Downloaded 176 times
