QS MOTOR,0.5-14kW Electric Hub Motor Manufacture China
ridethelightning   1 MW
Re: QSMOTOR 0.5kW-12kW BLDC Hub Motor Index
Post by ridethelightning » Aug 09 2015 6:29pm
if the weight is in the right spot, would it be an issue?
id prefer low noise levels with low rpm if pos.
macribs   1.21 GW
1.21 GW
Post by macribs » Aug 09 2015 6:46pm
I agree, think of a motocross bike, they are what 200 lbs? But they don't feel heavy when you ride trails or on the track. Because weight is centralized. If you put that heavy hubmotor away from the rear wheel I do not think you would have weight issues worth noting. Bike should behave much better then say bike with a QS 205 H50 (similar to cromotor) or even the lighter mxus 3K in the hub.
If you think about it, the bikes that are being build are becoming more and more heavy. Huge DD hubs, motorcycle wheels, big battery packs and steel frames are common. I think a more powerful motor would translate to less time in the red zone, meaning you would not push the motor to its limits as often as with smaller motors. That could even have a positive effect on cooling, along with the added masses of the motor that should also help with cooling.
Paired with the controllers vito has the motor/controller combo would cost less then one Adaptto max-e. And give you the potential for even faster accelerations and speed.
Alan B   100 GW
Post by Alan B » Aug 09 2015 6:49pm
The Zeros are very quiet as an example, with a lot of weight savings in the motor. We're not talking going all the way to jackshaft/high RPM. But if you like the size and weight, it should work. But if you are going to have a modest chain ratio, what can you do better? Running a smaller hubmotor at higher RPM is one example. But this conversation doesn't really belong in this thread, perhaps.
My QSMotor (aka CroMotor) is just excellent, and it looks like there are more choices here. Really great to see this. Thanks to QSMotor for coming to ES.
Post by ridethelightning » Aug 10 2015 7:37am
please let us know how it performs.
i have one too, but until i get some stuff done so i have time to try it, its just a beautiful doorstop :lol:
PeeHell   100 W
Post by PeeHell » Aug 11 2015 9:58pm
Vito, do you have a 273 hub motor with a 10mm axle ? If you do, is the magnet height of such a motor ? Thanks
QSMOTOR   1 kW
Location: QS Motor,Jinqing Town, Luqiao District, Taizhou City, Zhejiang Province
Post by QSMOTOR » Aug 11 2015 10:04pm
PeeHell wrote:Vito, do you have a 273 hub motor with a 10mm axle ? If you do, is the magnet height of such a motor ? Thanks
Hello Peehell,
Thank you for your question.
The axle flat of 273 hub motor could only be 12mm or more than 12mm.
If you prefer 10mm, I suggest to choose 205 hub motor.
Best Regards
Judy -Powered by SIA
No QS Motor, No Super EVs!
-QS Motor/Taizhou Quanshun Motor Co., Ltd. -Taizhou SIA Trading Co., Ltd. (Export Dept.)
-International Sales -Tel: +86 0576 88551619 -Skype: vito-ho -QQ: 289026969
-WhatsApp/WeChat: +86 13575887162 -Email: judy@tzquanshun.com
-Official Web: http://www.cnqsmotor.com/en/
-Facebook: https://www.facebook.com/judy.gong.775
-Amazon: https://www.amazon.com/s?k=SPOKE+HUB+MO ... nb_sb_noss
gensem   100 kW
Post by gensem » Aug 12 2015 9:28am
Best Regards
Vitto,
You should use a 10mm axle flat because that it what every single ebike frame uses... just make it alot wider, like 10mm x 20mm and use larger bearings for phase wires to avoid grinding the axle.
Pic of an axle thats close to it.
Justin we really appreciate what you did!
gensem   100 kW
Post by gensem » Aug 13 2015 7:43am
Vitto,
I think you should also post spoke diameter and length for QS205 and QS273 to a give set of rims.
Something that looks like this.
Single-cross pattern
QS205 26" bicycle rim = 12-14g spoke 1XXmm
QS205 24" bicycle rim = 12-14g spoke 1XXmm
QS205 17" motorcycle rim = 8-10g spoke 1XXmm
QS205 19" motorcycle rim = 8-10g spoke 1XXmm
QS273 26" bicycle rim = 12-14g spoke 1XXmm
QS273 24" bicycle rim = 12-14g spoke 16XXmm
QS273 17" motorcycle rim = 8-10g spoke 1XXmm
QS273 19" motorcycle rim = 8-10g spoke 1XXmm
spinningmagnets   100 GW
Post by spinningmagnets » Aug 13 2015 9:21am
The QS 205/50H is big enough that custom torque-plates will be needed, and they are even more necessary on the 273 diameter stator motors. Once you've made that comittment, I wouldn't imagine that making the flats 12mm or more would be a problem, and doing that might make the axle stronger. Of course, if you make the flat section too thick, you are close to being back to a round axle.
Vito, I agree with making 17-inch and 19-inch motorcycle rims available. That would be a good option to have.
Artur   100 kW
Post by Artur » Aug 13 2015 10:29am
Best Regards
Vitto,
We can make 12mm dropout, no problem.
gensem   100 kW
Post by gensem » Aug 14 2015 7:47am
I thinked about it and you are actually right. But a 10x19mm axle would be more pratical.
gensem   100 kW
Post by gensem » Aug 14 2015 7:48am
Course you can Artur :)
Would I be ok grinding my 10mm dropout to 12mm?
QSMOTOR   1 kW
Post by QSMOTOR » Aug 17 2015 1:30am
Vitto,
HI Gensem,
Thank you for your advise.
As checked with our Engineer, we could make 273 40H axle flat to be 10mm, and widden the diameter of axle.
The MOQ is 10pcs.
Later on, we will make new drawing about it and keep it post on ES.
Best Regards
whiteponyTW   1 µW
Re: QSMOTOR 5kW 8kW MID Drive PMSM BLDC Non-Hub Motor
Post by whiteponyTW » Aug 17 2015 12:06pm
I just order one sample couple weeks ago. It is a little difficult for me to find one suitable sprocket. It's 20mm bore and 6mm key slot.
Would U offer some sprocket supplier (web or phone number) for me ?
QSMOTOR   1 kW
Post by QSMOTOR » Aug 17 2015 7:37pm
whiteponyTW wrote:I just order one sample couple weeks ago. It is a little difficult for me to find one suitable sprocket. It's 20mm bore and 6mm key slot.
Hi WhiteponyTW,
Sorry for the inconvenience.
For the moment, we don't have suitable sprocket supplier.
Cherry will get back to you accordingly.
If any news, will keep you informed.
Best Regards
Emoto   10 kW
Re: Cheap BLDC controller, 200A, suitable for 96v 8000w moto
Post by Emoto » Aug 18 2015 10:40am
Hi Cherry
A question about the android Bluetooth app Can you provide a list [with any screenshots] of all the programing and monitoring options.
Also can we choose what we want to monitor , have you tested it for stability.
Thanks
gensem   100 kW
Post by gensem » Aug 19 2015 10:35am
Vito,
Can you post winding available for the QS 4000w 273 hubmotor like you did for 205 v3? Spoke length would also be nice.
Thanks
ohzee   1 MW
Post by ohzee » Aug 19 2015 10:42am
This has probably been answered , but I wanted to make sure I had correct info.
I need a cromotor or as close to one as I can get in quality / performance. I thought I read one of these motors was a good stand in , but by just reading this
thread I am not sure which one that would be. Is there a model I can look at which is as close as possible to the cro standard wind ?
Sorry if this has been answered and thanks in advance for any info.
macribs   1.21 GW
1.21 GW
Post by macribs » Aug 19 2015 10:43am
ohzee wrote:This has probably been answered , but I wanted to make sure I had correct info.
AFAIK you shall look for the qs 205 H50 v3 with T3 winding. There is specs for this motor a few pages back in this thread. Kv of crom was 9.3 or 13 kv maybe? The QS motor has more copper and thicker phase wires then the cromotor :)
ohzee   1 MW
Post by ohzee » Aug 19 2015 10:54am
thanks macribs I very much appreciate the reply.
gensem   100 kW
Post by gensem » Aug 19 2015 11:02am
ohzee wrote:thanks macribs I very much appreciate the reply.
Actualy 5T is the closest kv (cromotor is 9.4kv)
33*4T has the most copper fill but 13kv could be a little hard on the controller.
Updated windings
Mammalian04   100 kW
Post by Mammalian04 » Aug 19 2015 12:19pm
Updated windings
Is there any reason the 6T is listed at 48v? Could it run 84v or is that less efficient somehow?
Artur   100 kW
Post by Artur » Aug 19 2015 1:03pm
shoud be ok :)
madin88   1 GW
1 GW
Post by madin88 » Aug 20 2015 4:33am
Updated windings
there is no 33 x 4T motor. it should be 33 x 3,5T
22 x 5,5 = 121 strands
28 x 4,5 = 126 strands
33 x 3,5 = 115,5 strands??
Vito, is this correct?
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
magna_503   10 W
Post by magna_503 » Aug 20 2015 5:49am
Guys, I bought a sabvoton controller from Cherry on Alie express and having a hell of a time getting it to communicate with my laptop. Once I figured out what the problem is, the controller is in shutdown mode as it's seeing 175deg c. Software said it is motor temp, but it's controller temp per Paul chen from Sabvonton/March motor.
I'm in communication with them and hopefully they'll come through with better service. IF not I might just pick up the adaptto.
His alieexpress store is
Quanshun Motor.
store No 1389549
Cherry zhou
Email address
cherry@tzquanshun.com
The model in SSC72100, but the sticker on the Sabvoton is MQ72100. MQ72100 is what they will rename it to.
First, I had a hell of a time getting it to talk to my laptop. This is after all the USB driver was installed. I thought I gave up on it, but decided to troubleshoot a little further. I plugged in their Bluetooth to the laptop and the bluetooth was flashing. I then plugged the bluetooth unit to the sabvoton and there were no flashing. It turned out, the ground pin on the USB cable B11 was plugged into B9 which isn't grounded. I have a 5vdc output but no ground. So i temporarily run a wire to ground to the the next pin B11, which was ground for the USB, and the bluetooth light up.
B9 is supposed to be the throttle ground, and clearly, pin 9 on the PCB is not connected to ground. I might have a throttle issued later?
Once I have communication going, and connected to it, the controller is seeing 175deg cel (shutdown mode).
I'm not seeing any temp input for it at the moment on the Pin out. I'll be contacting quanshun motor to figure out the issue.
Let's see what else is bad on this Sabvoton controller.
If you guys know which pin is for the temp sensor please let me know so i can connect it to ground while per this info from Di steven on Alie express
Sabvoton Controller
Sabvoton controller flies:
https://www.dropbox.com/sh/ipt3a1g2u234 ... W0ITa?dl=0
Pls. Note: When the Hall connector have 6 wires, it means the controller come with Thermistor/Temperture Sensor, if you don’t want to use this function, you can connect the controller Thermistor/Temperture Sensor wire with ground wire.
If you connect our QS motor with sabvoton controller cannot running, pls. exchange the Green and Blue wires(phase wire and Hall wire) of controller to match with motor.
If the motor with shock and abnormal sound, pls. adjust the parameter “current loop kp”.
Hopefully they'll come through with a service.
