QS MOTOR,0.5-14kW Electric Hub Motor Manufacture China
magna_503   10 W
Re: QSMOTOR 0.5kW-12kW BLDC Hub Motor Index
Post by magna_503 » Aug 20 2015 5:54am
Guys, I bought a sabvoton controller from Cherry on Alie express and having a hell of a time getting it to communicate with my laptop. Once I figured out what the problem is, the controller is in shutdown mode as it's seeing 175deg c. Software said it is motor temp, but it's controller temp per Paul chen from Sabvonton/March motor.
I'm in communication with them and hopefully they'll come through with better service. IF not I might just pick up the adaptto.
His alieexpress store is
Quanshun Motor.
store No 1389549
Cherry zhou
Email address
cherry@tzquanshun.com
The model in SSC72100, but the sticker on the Sabvoton is MQ72100. MQ72100 is what they will rename it to.
First, I had a hell of a time getting it to talk to my laptop. This is after all the USB driver was installed. I thought I gave up on it, but decided to troubleshoot a little further. I plugged in their Bluetooth to the laptop and the bluetooth was flashing. I then plugged the bluetooth unit to the sabvoton and there were no flashing. It turned out, the ground pin on the USB cable B11 was plugged into B9 which isn't grounded. I have a 5vdc output but no ground. So i temporarily run a wire to ground to the the next pin B11, which was ground for the USB, and the bluetooth light up.
B9 is supposed to be the throttle ground, and clearly, pin 9 on the PCB is not connected to ground. I might have a throttle issued later?
Once I have communication going, and connected to it, the controller is seeing 175deg cel (shutdown mode).
I'm not seeing any temp input for it at the moment on the Pin out. I'll be contacting quanshun motor to figure out the issue.
Let's see what else is bad on this Sabvoton controller.
If you guys know which pin is for the temp sensor please let me know so i can connect it to ground while per this info from Di steven on Alie express
Sabvoton Controller
Sabvoton controller flies:
https://www.dropbox.com/sh/ipt3a1g2u234 ... W0ITa?dl=0
Pls. Note: When the Hall connector have 6 wires, it means the controller come with Thermistor/Temperture Sensor, if you don’t want to use this function, you can connect the controller Thermistor/Temperture Sensor wire with ground wire.
If you connect our QS motor with sabvoton controller cannot running, pls. exchange the Green and Blue wires(phase wire and Hall wire) of controller to match with motor.
If the motor with shock and abnormal sound, pls. adjust the parameter “current loop kp”.
Hopefully they'll come through with a service.
magna_503   10 W
Post by magna_503 » Aug 23 2015 9:09pm
So I finally got some time to work on the Temp issued. Turned out B19 shorted to ground would change temp to -55deg C, and clear one and only error on start up. As soon as i get some Hall sensors, I'll do a hall angle test and start fine tuning the motor. Wish me luck
magna_503   10 W
Re: Cheap BLDC controller, 200A, suitable for 96v 8000w moto
Post by magna_503 » Aug 23 2015 9:10pm
QSMOTOR   1 kW
Location: QS Motor,Jinqing Town, Luqiao District, Taizhou City, Zhejiang Province
Post by QSMOTOR » Aug 23 2015 10:07pm
Emoto wrote:Hi Cherry
A question about the android Bluetooth app Can you provide a list [with any screenshots] of all the programing and monitoring options.
Also can we choose what we want to monitor , have you tested it for stability.
Thanks
Hi,
I'd like to attached a bluetooth file of Sabvoton for your reference.
For APT controller, it's also on developing, it may comes out about two months later.
Bluetooth application user manual.pdf
Sabvoton Bluetooth
(1.31 MiB) Downloaded 200 times
Judy -Powered by SIA
No QS Motor, No Super EVs!
-QS Motor/Taizhou Quanshun Motor Co., Ltd. -Taizhou SIA Trading Co., Ltd. (Export Dept.)
-International Sales -Tel: +86 0576 88551619 -Skype: vito-ho -QQ: 289026969
-WhatsApp/WeChat: +86 13575887162 -Email: judy@tzquanshun.com
-Official Web: http://www.cnqsmotor.com/en/
-Facebook: https://www.facebook.com/judy.gong.775
-Amazon: https://www.amazon.com/s?k=SPOKE+HUB+MO ... nb_sb_noss
QSMOTOR   1 kW
Post by QSMOTOR » Aug 24 2015 2:25am
magna_503 wrote:Guys, I bought a sabvoton controller from Cherry on Alie express and having a hell of a time getting it to communicate with my laptop. Once I figured out what the problem is, the controller is in shutdown mode as it's seeing 175deg c. Software said it is motor temp, but it's controller temp per Paul chen from Sabvonton/March motor.
Quanshun Motor.
store No 1389549
Cherry zhou
Email address
Sabvoton Controller
Hello Trung,
This is Cherry.
So sorry for my late reply. Hope my reply is not too late for you.
Pls. see my below answers one by one.
1. Take a long time to communicate with computer
Cherry: Generally, it because of the undesirable compatibility between system and software.
2. 175deg c on motor
Cherry: The wiring drawing always not included thermistor wire, it's yellow-white color.
Btw, would you like to inform me the flicker frequency for the trouble light?
3. Bluetooth problem
Cherry: Bluetooth no flashing after connect with controller, because of the B9 not connect with B11, or the controller no electricity.
Would you like to check it again?
Thank you for your patience.
magna_503   10 W
Post by magna_503 » Aug 25 2015 5:49am
Cherry,
So I followed the instructions to short out the thermistor to ground, and temp was reading -55c. I left it on for a few hours. Next day when I turned it back on, all the saved paramaters were zeroed out. I had to changed all parameters again. Then I found that the voltage reading was 1.92 volt. Motor temp was reading the parameter input.
For example,
I changed the motor temp to 105c, then the temp reading for the motor also changed to 105c. I changed the motor temp restart to 50, the motor temp also showed 50c.
Any parameter changed would result in temp reading changed to the parameter input.
Voltage reading would not show the correct reading neither, as it is reading between .82v and 1.92v. I have 49.95v dc power supply to power the unit for testing.
Again, I have not hooked the controller to the mxus 3000 yet, and I'm seeing numerous issued with the controller already.
QSMOTOR   1 kW
Post by QSMOTOR » Aug 26 2015 2:55am
magna_503 wrote:Cherry,
For example,
Hi Trung,
Can you available for remote manipulation by QQ or other App?
If it's suitable for you, Sabvoton engineer will remote manipulation you computer to check the controller.
magna_503   10 W
Post by magna_503 » Aug 26 2015 4:52am
I do not have software to do that. If u know of a free software suggestions?
atomek1000   100 W
Post by atomek1000 » Aug 26 2015 5:58am
try teamviewer - free and fast
ohzee   1 MW
Post by ohzee » Aug 28 2015 12:30am
gensem wrote:
ohzee wrote:thanks macribs I very much appreciate the reply.
Actualy 5T is the closest kv (cromotor is 9.4kv)
33*4T has the most copper fill but 13kv could be a little hard on the controller.
Updated windings
Ordered myself one of these motors tonight shipping to Roadrash for building.
Is the temp sensor standard ? I assume so , but I did read optional in one of their pdf's.
I asked the vendor letting him know it's needed so don't expect any issues.
Got a response.
Yes, there is thermister with this motor, generally, we make it KTY83/122.
PeeHell   100 W
Post by PeeHell » Aug 28 2015 10:20pm
QSMOTOR wrote:
Vitto,
You should use a 10mm axle flat because that it what every single ebike frame uses... just make it alot wider, like 10mm x 20mm and use larger bearings for phase wires to avoid grinding the axle.
Pic of an axle thats close to it.
HI Gensem,
Thank you for your advise.
As checked with our Engineer, we could make 273 40H axle flat to be 10mm, and widden the diameter of axle.
The MOQ is 10pcs.
Later on, we will make new drawing about it and keep it post on ES.
Best Regards
Correct me if I'm wrong, but that would be the motor with the most torque per amp we have seen so far on a bike.
QSMOTOR   1 kW
Post by QSMOTOR » Aug 31 2015 4:05am
magna_503 wrote:I do not have software to do that. If u know of a free software suggestions?
Hi, you can use QQ App.
Just doload an international type. :D It's free.
magna_503   10 W
Post by magna_503 » Aug 31 2015 4:47am
I'll download it when I get home tonight.
marcexec   1 kW
Post by marcexec » Sep 02 2015 5:12pm
PeeHell wrote:
QSMOTOR wrote:
Vitto,
HI Gensem,
The MOQ is 10pcs.
Best Regards
I'm just happy the manufacturer is engaging this much with the community. I'm eying the car-sized 273s for a future project myself...
A motorcyclist is never late, Frodo Baggins. Nor is he early. He arrives precisely when he means to.
My Suzuki RF400 build: now with Enertrac MHM602 and 6kWh AESC modules protected by a Zephyr BMS
Renault Equation modded to 10S6P recycled laptop 18650s & 1kW controller.
Master of Electric Motor Selection: "Adopt a motor" (PM me if you have trouble editing)
All the gear, all the time!
magna_503   10 W
Post by magna_503 » Sep 08 2015 3:55am
vito/cherry
I have QQ app installed on my androids, and laptop.
Could we setup for a Friday 1-2pm your time for troubleshooting the controller?
QSMOTOR   1 kW
Post by QSMOTOR » Sep 10 2015 7:18pm
magna_503 wrote:vito/cherry
Yes, no problem.
Would you like to add the engineer QQ first?
QQ 2760927729
magna_503   10 W
Post by magna_503 » Sep 11 2015 3:05pm
I didn't checked the forum last night. Maybe we can do this on next Thursday at 2pm.
Motobikewheels   100 W
Post by Motobikewheels » Sep 12 2015 7:44pm
Updated windings
Got a response.
Looks like we will have them on Tuesday. :D
gensem   100 kW
Post by gensem » Sep 13 2015 1:21pm
Vitto,
What magnets do QS use in the hubmotors? Is it 45sh?
Justin we really appreciate what you did!
newbiebiker   100 mW
Post by newbiebiker » Sep 15 2015 3:50pm
https://www.youtube.com/watch?v=m0sm0Jj ... e=youtu.be
which motor used in this Escotter ? and if possible add more details about that scooter too.
really impresive video.
Dream - hybrid bike (normal petrol bike + front wheel hub motor)
magna_503   10 W
Post by magna_503 » Sep 16 2015 1:34am
I tried to registered to QQ app, but everything is in Chinese. Is there an English version available? Would you guys be able to do Skype? I can tried Skype.
Post by Motobikewheels » Sep 16 2015 9:16pm
Thanks Vito for supplying these awesome motors to us
Sprayon Red Insulating Varnish :D
Post by Motobikewheels » Sep 16 2015 9:42pm
Mxus 3000 phase wire vs qs205 :shock:
QSMOTOR   1 kW
Post by QSMOTOR » Sep 16 2015 10:21pm
roadrash wrote:Thanks Vito for supplying these awesome motors to us
With my pleasure, Roadrash.
Did you add the Sprayon Red Insulating Varnish by yourself?
Best Regards
Post by Motobikewheels » Sep 16 2015 10:25pm
Best Regards
Yes sir !
