QS MOTOR,0.5-14kW Electric Hub Motor Manufacture China
hydro-one   10 kW
Re: QS 500W-10kW BLDC In-Wheel Hub Motor Catalog (Manufactur
Post by hydro-one » Mar 15 2015 8:56pm
so no freewheel threads , what is on that side of the 3000w v3 motor?
Pro ebiker
28s hk lipo
3ooA kelly/cromotor 17"
sana cruz bullit
Doctorbass   100 GW
Post by Doctorbass » Mar 16 2015 12:43am
VIto8828, I have a good question for you:
Is there any STANDARD ZIZE strand for the winding?
I see we always talk in term of turn and parallel strands.. but we never talk about the size of these strands witch matter alot when comparing the copper fill and max ampere!
I see you talked about a Winding 24*5 Turn.. witch is probably the highest i have ever seen for a motor that size.. are the 24 parallel strands the same size of the strands size of our common MXUS3000 and cromotor?
Thanks
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
madin88   1 GW
1 GW
Post by madin88 » Mar 16 2015 3:51am
Thanks for the test graph and data Vito. this is always very useful when comparing different motors.
now it would be great to see a test of the same motor but with V2 type stator. do you have one? Also a data discription would be nice to see.
Doc, V3 has different stator design thus other winding
V2 type: 51 teeth, 23 pole pairs -> common design
V3 type: 36 teeth, 16 pole pairs
not sure how this effects kV and amps needed for a given torque output, but there will be (little) differences.
afaik standard cross section of one strand is 0,5mm ø so 0,196mm². at least thats what i measured on MXUS 3000, and Cromotor
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
macribs   1.21 GW
1.21 GW
Post by macribs » Mar 16 2015 7:07pm
GiantEV wrote:Very interested in these motors. I'd want a thread for a bicycle freewheel of course.
I could see no info about threading for freewheel. I also checked their alibaba site.
@Vito does the extra/v3 have threading for freewheel?
DEHiCKA   1 mW
Re: QS 500W-10kW BLDC In-Wheel Hub Motor Catalog /Manufactur
Post by DEHiCKA » Mar 17 2015 8:46am
GiantEV, macribs, hydro-one
If you zoom enough, you can see it is threaded indeed.
I've checked the OD against other dimentions and it is 34mm.
I have exact 150mm dropouts width, and it is only 12.5mm left for a freewheel + whashers. Basic 16T 34mm threaded freewheel like DICTA is 16mm thick. Not sure I can find <12mm thick freewheel.
Vito can you, please, tell me the wall thickesses marked as ?1 and ?2 on the picture:
Trials/Freeride 39KG middrive:
35kV GNG Big block custom 8T/62T #420
Kelly KEB 10kW 450A Peak. Stainless LMX frame
26" FW, 24" RW Kris Holm rims 3" Duro tires / 17" moto trials RW & 3.5" trials tire
BCTECH   100 W
Post by BCTECH » Mar 24 2015 12:22pm
Placed an order with Vito. Very nice guy.
I have a custom motor coming and will report detail when I receive it.
Looking forward to it :)
macribs   1.21 GW
1.21 GW
Post by macribs » Mar 24 2015 1:45pm
BCTECH wrote:Placed an order with Vito. Very nice guy.
Did you order special winding, or thicker phase wires?
Seven   1 W
1 W
Post by Seven » Apr 01 2015 6:40pm
Hi mate, I've got one of these v3's it arrived a couple of days ago, it does indeed have a threaded section for the freewheel to screw on, I could take some pictures and measurements if you want, it's a weapon by the way, quality is excellent and I would recommend them to anyone,
macribs   1.21 GW
1.21 GW
Post by macribs » Apr 01 2015 7:22pm
This will be my choice also.
QSMOTOR   1 kW
Location: QS Motor,Jinqing Town, Luqiao District, Taizhou City, Zhejiang Province
Post by QSMOTOR » Apr 01 2015 7:53pm
Thank you very much for your interest & help.
Yes, there is thread 8mm for bicycle freewheel.
Attached "QS 3kW Spoke Motor Quotation & SPEC.pdf" for reference. : )
Best Regards
(536.51 KiB) Downloaded 340 times
Judy -Powered by SIA
No QS Motor, No Super EVs!
-QS Motor/Taizhou Quanshun Motor Co., Ltd. -Taizhou SIA Trading Co., Ltd. (Export Dept.)
-International Sales -Tel: +86 0576 88551619 -Skype: vito-ho -QQ: 289026969
-WhatsApp/WeChat: +86 13575887162 -Email: judy@tzquanshun.com
-Official Web: http://www.cnqsmotor.com/en/
-Facebook: https://www.facebook.com/judy.gong.775
-Amazon: https://www.amazon.com/s?k=SPOKE+HUB+MO ... nb_sb_noss
macribs   1.21 GW
1.21 GW
Post by macribs » Apr 01 2015 9:09pm
Vito8828 wrote: Thank you very much for your interest & help.
Best Regards
Hi Mr. Vito. Pm sent regarding QS 3000W 205 (50H) E-bike Spoke Hub Motor Extra/V3 Type.
Dauntless   100 GW
Post by Dauntless » Apr 01 2015 11:33pm
Doctorbass wrote: A 240kW chineese hub motor...
That's the Luke we know !! 8)
Sounds like an under 10 second car.
Any sufficiently advanced technology is INDISTINGUISHABLE FROM MAGIC!
- Arthur C. Clarke
liveforphysics   100 GW
Post by liveforphysics » Apr 02 2015 2:40am
I recently added an additional 10kWh of pack to the vehicle (25kWh total now), and it got faster due to more traction... I am pretty over series-brushed now though, it does make impressive low RPM torque, but I miss the top-end of brushless.
This vehicle has plenty of room for a very wide hubmotor, and if I go that route I intend to take advantage of all the space.
madin88   1 GW
1 GW
Post by madin88 » Apr 02 2015 3:36am
comparing the graphs of V2 and V3 there seems to be not so much difference in efficiency at given torque output.
vito, do you know what inductance these motors have? (im interested in 9kv and 12v versions)
QSMOTOR   1 kW
Post by QSMOTOR » Apr 02 2015 3:47am
madin88 wrote:comparing the graphs of V2 and V3 there seems to be not so much difference in efficiency at given torque output.
Thank you for your question.
Yes, there is not too much difference between V2 and V3 type.
But V3 type could bear more torque than V2.
Difference between V2 & V3
The raw materials are alike, main difference in inner construction.
For V3 (16 Pole Pairs):  stronger configuration than V2, wider lamination,
more cooper wire/phase wire and thicker Cross-sectional area section,
bear more current in usage.
Magentic Steel: V3 is wider and thicker.
Efficiency:  86~88%(V2) 88~92%(V3)
Thus, V3 have best performance.
For inductance, generally, we don't test it before delivery.
I will ask our engineer to test it in near future, and get back to you accordingly.
madin88   1 GW
1 GW
Post by madin88 » Apr 02 2015 7:16am
Vito, with "wider and thicker steel" you talking about the differences in stator teeth shape, because both have 50mm wide stator, right?
it would be great if the technical data does include motor inductance.
thanks
Seven   1 W
1 W
QS 500W-10kW BLDC In-Wheel Hub Motor Catalog /Manufacture
Post by Seven » Apr 02 2015 7:21am
If you guys need, I can measure the inductance of the V3 I have, I'll have to pull that side panel off my raptor so let me know if you need it need it
macribs   1.21 GW
1.21 GW
Post by macribs » Apr 06 2015 9:34am
Yes pls do. That would be nice to have correct measure. It says nowhere in the specs.
I've been told that the QS 205 is the same motor as cromotor. Is that correct? It seems it is a 3kw motor according to the specs.
I think cromotor can do more then 10 kw peak, what is the peak power of the QS 205 motor?
riba2233   1 MW
Post by riba2233 » Apr 06 2015 10:00am
It's not same as cromotor, they are similar and have same basis, but cromotor is enhanced version, it is reworked and modified in Croatia.
My electric moped: http://www.evalbum.com/4966
My electric car: http://www.evalbum.com/5364
macribs   1.21 GW
1.21 GW
Post by macribs » Apr 06 2015 11:29am
riba2233 wrote:It's not same as cromotor, they are similar and have same basis, but cromotor is enhanced version, it is reworked and modified in Croatia.
Ok, what is changed? Thicker phase wires?
What about power, you think they are similar in power?
riba2233   1 MW
Post by riba2233 » Apr 06 2015 1:09pm
http://endless-sphere.com/forums/viewto ... 55#p858155
And for power, cromotor is being declared as 6000W.
ziltoid81   1 kW
Post by ziltoid81 » Apr 06 2015 1:19pm
They order motors and rework them, instead of simply order these "upgrades" directly from the factory?
Another question.......i always read something about improvements and what not, but never simple and clear what is better. (we swap the axle from material x to y, we change the phase wires.......)
It will be the easiest way to promote the cro.
Name the benefits of getting a "real" cro.
But in the end the only real improvement could be the axle or bearings......they will not improve the stator, windings and so on.
So efficiently these motors are the same i guess, at least on dyno.
macribs   1.21 GW
1.21 GW
Post by macribs » Apr 06 2015 1:36pm
riba2233 wrote:http://endless-sphere.com/forums/viewto ... 55#p858155
Yes and we all have seen various motors declared at a certain power and other vendors selling the same motor with higher powers. So that is not something new. Do you think cromotor will outperform the QS motor? Or are they internally really the same motor?
riba2233   1 MW
Post by riba2233 » Apr 06 2015 1:37pm
I dont know, Im just reporting back what Ive found. Personally, I would never even consider hub motors.
macribs   1.21 GW
1.21 GW
Post by macribs » Apr 06 2015 1:44pm
It seems the v3 is updated for export.
Vito, what about the axle and bearings in the v3 motor, are there done any updates from v1 motor?
Is it possible to order motor with larger phase wires, larger bearings and stronger/larger diameter axle?
