QS MOTOR,0.5-14kW Electric Hub Motor Manufacture China
Teh Stork   1 kW
Re: QSMOTOR 0.5-16kW(Rated) BLDC Direct Drive Hub Motors
Post by Teh Stork » May 18 2016 5:52am
Just verified that the hall-sensors in my QS single-side axle hub is wrongly connected.
Applying 5 V to red and gnd to black, these voltages appear when spinning wheel slowly:
Green: 0 - 2.7 V
Yellow: 0 - 0.6 V
Blue: 0 - 0.6 V
Seems like the hall sensor hookup is wrong. Need to remove sidecover to verify, any hints on how to pull the sidecover off? Single side axle with wire coming out in middle, so kind of hard getting a spindle puller rigged correctly.
2013 VW E-UP!
Kona mtb: Cromotor, Kelly KEB, ~6kW peak, 1,4kWh 90V battery 29E cells, 38 kg
bigbore   10 kW
Post by bigbore » May 18 2016 8:56am
I have opened the left side cover hammering the shaft on the other side with a rubber hammer and pulling the cover with this hi tech stuff:
QSMOTOR   1 kW
Location: QS Motor,Jinqing Town, Luqiao District, Taizhou City, Zhejiang Province
QS 273 40H V3 45X4T vs QS 205 50H V3 24X5T Stators
Post by QSMOTOR » May 18 2016 9:25am
I just upload the "QS 273 40H V3 45X4T vs QS 205 50H V3 24X5T Stators" on facebook.
https://www.facebook.com/QSMOTOR.VitoHo ... 8077155812
Here is the pictures for reference.
Best Regards
Judy -Powered by SIA
No QS Motor, No Super EVs!
-QS Motor/Taizhou Quanshun Motor Co., Ltd. -Taizhou SIA Trading Co., Ltd. (Export Dept.)
-International Sales -Tel: +86 0576 88551619 -Skype: vito-ho -QQ: 289026969
-WhatsApp/WeChat: +86 13575887162 -Email: judy@tzquanshun.com
-Official Web: http://www.cnqsmotor.com/en/
-Facebook: https://www.facebook.com/judy.gong.775
-Amazon: https://www.amazon.com/s?k=SPOKE+HUB+MO ... nb_sb_noss
Allex   1 GW
1 GW
Post by Allex » May 18 2016 9:30am
What about this one :D
QSMOTOR   1 kW
Re: Dual stator 2X50H V3 Watercooled Spoke Hub Motor
Post by QSMOTOR » May 18 2016 9:37am
Allex wrote:What about this one :D
This is dual stator hub motor, it could be customized.
Dual stator 2X50H V3 Watercooled Spoke Hub Motor, here is the drawing for reference.
Dual Stator Spoke Hub Motr Drawing.jpg (104.58 KiB) Viewed 1423 times
双定子水冷辐条电机 1.jpg (240.65 KiB) Viewed 3529 times
双定子水冷辐条电机 2.jpg (215.52 KiB) Viewed 3529 times
Best Regards
QSMOTOR   1 kW
Post by QSMOTOR » May 18 2016 9:59am
Allex wrote:As Madin said, Watch from 60seconds about ideas for weight reduction.
Thank you, we will check.
bigbore   10 kW
Post by bigbore » May 18 2016 10:57am
With a custom swingarm with 360mm dropout I can mount it on the Bomber :mrgreen: :D :shock:
madin88   1 GW
1 GW
Post by madin88 » May 18 2016 2:01pm
bigbore wrote: With a custom swingarm with 360mm dropout I can mount it on the Bomber :mrgreen: :D :shock:
:lol:
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
liveforphysics   100 GW
Post by liveforphysics » May 18 2016 2:19pm
For future motors, the wheel will be so much stronger for side loading if the spoke flanges are spread out towards the edges of the hub. The more angle the spokes have going to the rim the more strength the wheel will have.
I love your awesome performance motors!
gensem   100 kW
Post by gensem » May 18 2016 2:40pm
Luke are you using your 273 16.8kv bicycle hub already?
Justin we really appreciate what you did!
macribs   1.21 GW
1.21 GW
Re: QS 273 40H V3 45X4T vs QS 205 50H V3 24X5T Stators
Post by macribs » May 18 2016 3:34pm
QSMOTOR wrote:I just upload the "QS 273 40H V3 45X4T vs QS 205 50H V3 24X5T Stators" on facebook.
Best Regards
Seems that fb link does not work.
What motor is that? Dual stator 273 or 250? Or something else maybe?
Doctorbass   100 GW
Post by Doctorbass » May 18 2016 4:18pm
gensem wrote:Luke are you using your 273 16.8kv bicycle hub already?
:D
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
steveo   1 MW
Post by steveo » May 18 2016 6:42pm
:D
Doc
+1 .. Luke give us a update!!!
common man.. i'll race your nyx bike with my dual winding hub motor ebike .. :twisted:
not the deathbike though.. i don't want to get own'd by that machine hahah.. or maybe with a with a decent head start... hmmm .. 70kw vs .. 32kw + hmm
-steveo
Repair Thread
http://endless-sphere.com/forums/viewto ... =3&t=27170
Hub Monster bike ~ 24s7p A123 15.4ah/18kv Six Phase Motor/Dual Max-E Adapttos/32kw~42.91Hp/Est 140LBS
X6 Kmx Trike ~ 24s4p 20ah/X6 MHM 602/Infinion EB324 IRFB 4110/20Kw~26.82Hp/Est 120LBS ~SOLD~
Lightening rods bike ~ 18s2p 10ah/1500w Inrunner/Infinion EB312 IRFB4110/2KW~2.68hp/Est 60LBS
EV Outboard ~ 12s8p 40ah/5KW GM Inrunner/Infinion EB324 IRFB 4110/18Hp Evinrude Drive/Est 100lbs
http://www.youtube.com/user/trdfreak03
Post by liveforphysics » May 18 2016 7:30pm
steveo wrote:
:D
Doc
-steveo
I have 2 NYX frames, forks, front wheel, 650A motor controller setup, battery, bars/cranks/pedals/seat/brakes.
I also have a rear rim for it, but what I'm stalled on it making a wheel that will take the kind of abuse I want to throw at it. The last 3 hubmotor wheels I built all died the first time I took them on our local downhill trails and did some high speed stair climbing and drops. I'm kinda over the spoke concept for hubmotors. I'm exploring making a carbon/epoxy joint between motor and rim.
With the controller I've got for it, it should do ~120mph and wheelie at most any point on the way there. Happy to race anything you want to throw at it. :twisted: :twisted:
gensem   100 kW
Post by gensem » May 18 2016 7:44pm
liveforphysics wrote: I have 2 NYX frames, forks, front wheel, 650A motor controller setup, battery, bars/cranks/pedals/seat/brakes.
My 273 40h should arrive in 15 days (unless vito rush it for me). I ll post a pic of the wheel probably in 3 weeks. Its a 17" 1.85 rim so it might not be what you are looking for (19" makes more sense for dh and stairs). Im almost sure motor flange will go before spokes/rim.
litespeed   100 kW
Post by litespeed » May 18 2016 9:29pm
I always thought the 273 motor should use a 16" or 18" wheel so you can put a 4" wide tire on it. I think that is the ticket for a motor this heavy.
Tom
Post by liveforphysics » May 19 2016 1:29am
I've got a 19in x 2.0 aluminum dirtbike rim, and I agree it seems it would rip the spoke ring apart built with dirtbike spokes.
I'm looking to make it a wheel that can take abuse to match the Nyx frame (which is very strong if you've not felt one of them yet.)
DasDouble   100 kW
Post by DasDouble » May 19 2016 7:21am
I have already posted this on Adaptto threat, but maybe the guys from QS Motor do know this problem, so I post it here too. (I have a Custom made QS V3 Custom Modified (Black New Version) from Vector):
Hey guys, my Adaptto Max-E is doing crazy since some days.. Maybe you can help me with this problem:
Before it was doing crazy, it worked just fine and I was able to ride about 9-10 kilometers, but after connecting the cables of my Tektro Dorado Brakes from Vector, it was like going absolutly crazy.. I have already checked together with my uncle, who is an electric-engineer, if I have connected some cables wrong, but he says that I did everything right.
So some little explaination: Everything worked fine for 9 kilometers.. Then I had less battery left, why I decided to install regen braking to save some energy (because my Eaton charger didn´t get delivered yet because german post didn´t do their homework). So then I installed the cables. After doing that I recognized, that I was only able to push the throttle, when pressing the brake button at the same time.. I hadn´t had my soldering iron with me and have been already on the half of the way, why I didn´t installed it back. So after riding to local bicycle store and installing my chain I rode back and let off from throttle and brake button at the same time, which caused a like ermergency braking. After this everything didn´t work anymore. I cut the cables from the throttle away, hoping that the throttle will work again, but nothing. I had to push my bike the last 500 meters back home, while my rear wheel was like already blocked a bit by the magnets. (To explain this blocking thing: It feld like every single magnet of the motor did not want to move. Like "going over this magnet" was hard, but then it was easy to push the bike untill the next magnet came).
My Vector half twist throttle gets recognized by the controller when doing calibration. But when I am out of the menu, means the normal display when riding, it is not working anymore. Just like it would not exist. Sometimes, and this "sometimes" is really annoying, it shows "protective" where it normally says "Eco, normal, boost", when twisting the throttle 50%. Also when I try to autodetect, sometimes the throttle works, sometimes not. If the throttle finally works, after resetting of the controller via <Setup>, etc. it says "Halls error 2", sometimes instead of "Halls error 2" it says "Halls error 1"... :| :?: Another problem: Yesterday, after 5-6 hours of trying to fix this problem, the throttle finally got recognized, but not in this way that the wheel starts to spin, but that the wheel gets blocked just like giving extra energy into the motor so that the wheel can´t spin.. :?: :? :| :?: :!:
I would really appreciate your help...
PS: When trying to charge the battery via 30A coil and laboratory charger with 20 volts, 30 amps, the motor sometimes starts to spin, while the charger goes really hard with the Ampere (up to 20 Amps), the volts still stay at 0-2 volts. Also I want to mention, that I have already switched the 6 hall sensors from the motor, but it still says "Halls error 2" and "..1". Also: I have already reseted my controller more then 2 times via <Setup> etc..
-Elias
Mechatronics-Engineering Student
-Built own ebike: ✔
-Built own 3.2kWh LiIon battery (300Amps): ✔
-Overtake Porsche with own Ebike: ✔
-Take off with ebike: ✖
~14kW, 3.2kWh LiIon, QS 205 8ml ff, hubsink
gensem   100 kW
Post by gensem » May 19 2016 4:06pm
I did ask Vito sometime ago about cast wheels for 273hub, but it seens like I was the only one after stronger wheels.
I do think about Nyx from time to time, but it will end up costing close 1.9k usd with shipping, thats equal= 7k reais (brazilian currency) without taxes. Best case scenario it woulda end costing 8-9k reais. To put it in wage perspective it would be pretty close as if I was living in america and paying 8k usd for the frame. -.-
gensem   100 kW
Post by gensem » May 20 2016 7:22am
Ok, some measurements.
Hubmotor 18.2-18.3kg
Rear rim 17" 1.85 1.3kg
17 80/90 50S + tube = 3.5kg (heavy but 180km/h rated)
8g stainless spokes (yet to receive) around 450g
Assembled wheel 23.5kg -.-
madin88   1 GW
1 GW
Post by madin88 » May 20 2016 7:27am
gensem wrote: Assembled wheel 23.5kg -.-
i wonder why Luke wants to go down stairs or dh with something like this :)
Ratking   1 kW
Post by Ratking » May 20 2016 8:02am
gensem wrote:Ok, some measurements.
Why not tubeless? Less weight less friction and safer. Many people have safely sealed the spoke/nipples with polyurethane/silicone or any other glue with good adhesion.
I will try that within the next couple of weeks, just follow my project if interested ;)
macribs   1.21 GW
1.21 GW
Post by macribs » May 20 2016 8:35am
Also you could seal spoke nipples holes just fine doing a round or two with duct tape. Many detailed videos on youtube how to make "ghetto tubeless".
It will shave some weight, but most importantly it will ease the roadside repair if you get a flat. A tiny dynaplug, a leatherman tool and a Co2 cartidge is all that is needed. Repair a flat in less then a minute. Easy peasy and AFAIK the best reason why to ride tubeless. Another reason is with tubeless you will likely never see a puncture where all air vanish instantly and cause traction loss. That is important if doing 60 mph on an e-bike. Tubeless flats are most like to leak out slowly and you will notice on the ride quality way before tire has lost all air pressure.
gensem   100 kW
Post by gensem » May 20 2016 8:49am
Humm...
I dont really see me going tubeless unless QS releases a cast rim for 273 hub.
I had a 250cc motorcycle for like 2 years mainly used for my daily commute, it had spoked wheels and used tubes and I never had a flat. Thats probably why im not worring much about flats.
macribs   1.21 GW
1.21 GW
Post by macribs » May 20 2016 8:52am
gensem wrote:Humm...
Yeah but even so your 250cc didn't have a 40+lbs hubmotor stuck in the center of wheel, all that weight so far from swing arm pivot point makes a large impact on tires. And most likely your 250cc had a more sturdy suspension then your e-bike. And a lighter wheel. So hard to compare really.
