QS MOTOR,0.5-14kW Electric Hub Motor Manufacture China
QSMOTOR   1 kW
Location: QS Motor,Jinqing Town, Luqiao District, Taizhou City, Zhejiang Province
Re: QS MOTOR, QSMOTOR 0.5-16kW Electric Wheel Hub Motors
Post by QSMOTOR » Jun 28 2016 3:46am
PKGB wrote:I placed the order on AliExpress. PI ORDER NO.QSM16PB0624001
Thank you for your support.
Aliexpress is ok, handled by my workmate Cherry.
You could check with her if any question.
Best Regards
Judy -Powered by SIA
No QS Motor, No Super EVs!
-QS Motor/Taizhou Quanshun Motor Co., Ltd. -Taizhou SIA Trading Co., Ltd. (Export Dept.)
-International Sales -Tel: +86 0576 88551619 -Skype: vito-ho -QQ: 289026969
-WhatsApp/WeChat: +86 13575887162 -Email: judy@tzquanshun.com
-Official Web: http://www.cnqsmotor.com/en/
-Facebook: https://www.facebook.com/judy.gong.775
-Amazon: https://www.amazon.com/s?k=SPOKE+HUB+MO ... nb_sb_noss
DasDouble   100 kW
Post by DasDouble » Jul 01 2016 7:33am
Hello dear QS-Team,
I have bought a custom made QS Vector Motor. After accidentally letting my bike drop to the left side while standing still, it is squealing when driving up to ~10kmh. The slower the speed gets, the louder is the squealing noise. What can I do against that?
Artur from Vector Team said I better do not use WD40 against that. Or can I drive it without having to worry? I would really appreciate your help.
Best regards,
Elias
Mechatronics-Engineering Student
-Built own ebike: ✔
-Built own 3.2kWh LiIon battery (300Amps): ✔
-Overtake Porsche with own Ebike: ✔
-Take off with ebike: ✖
~14kW, 3.2kWh LiIon, QS 205 8ml ff, hubsink
QSMOTOR   1 kW
Post by QSMOTOR » Jul 01 2016 7:42am
DasDouble wrote:Hello dear QS-Team,
Best regards,
Elias
Hello Elias,
Thank you for your support. Firstly, Vecotr is our official dealer.
For the squealing noise, could you please send more information with picture and videos?
To my email, vito@tzquanshun.com
I will check with our Engineer accordingly.
Best Regards
DasDouble   100 kW
Post by DasDouble » Jul 01 2016 5:46pm
Dear Vito,
thank you, for your like always existing fast and good support. I will send you an Email tomorrow (german time), which is in like 10 houres.
Good evening and best regards,
Elias
EDIT: After seeing that you are using WhatsApp, I have sent a video to you via WhatsApp.
-Built own ebike: ✔
QSMOTOR   1 kW
Post by QSMOTOR » Jul 01 2016 8:37pm
DasDouble wrote:Dear Vito,
Elias
Got it, let me see.
Best Regards
DasDouble   100 kW
Post by DasDouble » Jul 03 2016 9:50am
Hi, can I open the motor to look where the motor is scratching and where the squealing is coming from? Or will Loose warranty for doing that?
And which special oil do I need? In pretty sure that I should not use any oil for that.
Regards, Elias
-Built own ebike: ✔
Quokka   1 kW
Post by Quokka » Jul 05 2016 3:57am
Fedex truck turned up today... I must say QS do a great job with their packaging.
I was let down severly by another vendor with a wheelset that arrived with damaged bearings and broken hall sensors.
So far everthing looks great, thank you Vito
Wooden crate to protect motor
Competitor packing
Qulbix Q76R+ QS205+MaxE
QSMOTOR   1 kW
Post by QSMOTOR » Jul 05 2016 10:16pm
Quokka wrote:Fedex truck turned up today... I must say QS do a great job with their packaging.
At your service! Stuart/Quokka.
Your order is not only handled by me, but also our exporting team, include Cyan.
Btw., one customer told us the front hub broken due to package without wooden support several months agao.
So we decide to pack it with wooden support for front and rear wheel rim ever since.
For rear wheel rim set, we will pack it with standard carton package.
We just react a bit quciker. : )
Once again, thank you for your kindly feedback!
Best Regards
QSMOTOR   1 kW
Post by QSMOTOR » Jul 05 2016 10:20pm
DasDouble wrote:Hi, can I open the motor to look where the motor is scratching and where the squealing is coming from? Or will Loose warranty for doing that?
Regards, Elias
Hello Elias/DasDouble,
Thank you for your message on WhatApp.
Just checked, it;s ok to use bicycle Chain Oil.
I dont' suggest to disassemble the motor.
If the motor still scratching and squealing, you could try to open the motor to figure it out.
Or you will loose warranty.
If any question, please feel free to contact with us.
Best Regards
DasDouble   100 kW
Post by DasDouble » Jul 06 2016 3:03am
I have already answered Vito via WhatsApp, but I want to document it here also so maybe others with the same problem can read my results. I would not recommend bicycle chain oil. I don't know the words in English so I can't explain why. I have used some super synthetic lubricating oil from a BOSCH "repair-garage".
I have sprayed it into the axle for about 0.5-1 seconds. After that I was able to "hear the oil working". While doing that I have slightly turned the wheel so it could get inside. Still holding the motor turned, I turned the motor a couple of times and finally the squealing disappeared.
-Elias
-Built own ebike: ✔
QSMOTOR   1 kW
Post by QSMOTOR » Jul 06 2016 3:08am
DasDouble wrote:I have already answered Vito via WhatsApp, but I want to document it here also so maybe others with the same problem can read my results. I would not recommend bicycle chain oil. I don't know the words in English so I can't explain why. I have used some super synthetic lubricating oil from a BOSCH "repair-garage".
-Elias
Hello Elias,
Thank you very much for sharing on E-S at the same time.
It's so kindly of you.
Best Regards
XLR8   100 W
Post by XLR8 » Jul 07 2016 11:16pm
From my experience, the squeal is a dry oil seal on the wheel bearing so there is nothing to worry about. I had this problem on my QS 3000W 60V hub motor.
QSMOTOR   1 kW
Post by QSMOTOR » Jul 07 2016 11:38pm
XLR8 wrote:From my experience, the squeal is a dry oil seal on the wheel bearing so there is nothing to worry about. I had this problem on my QS 3000W 60V hub motor.
Thank you for your sharing, XLR8.
Best Regards
charlesmcnall   1 mW
Post by charlesmcnall » Jul 12 2016 1:10pm
So how does the APT AE96600 96V 8kw controller compare to a Kelly KLS96601-8080I,24V-96V,600A,Sinusoidal BLDC Motor Controller?
Configuration software? spec sheets? Bluetooth? Continues current at 96VDC? Max Current? for how long?
I am interested in one for an emotorycle project.
Are there internal capacitors that need precharge resistors?
What do people typically do for fuses?
Thanks!
Electric Ninja 250 http://evalbum.com/preview.php?vid=5243
Lemond Etape 1400W hub motor 48V 15ah - need to make EValbum
6hp Electric snowblower conversion http://evalbum.com/preview.php?vid=5250
marcexec   1 kW
Post by marcexec » Jul 12 2016 5:04pm
charlesmcnall wrote:So how does the APT AE96600 96V 8kw controller compare to a Kelly KLS96601-8080I,24V-96V,600A,Sinusoidal BLDC Motor Controller?
Thanks!
Check out the Luka EV project on hackaday, he's using 4 of them in the car and probably put more kilometers on them than anyone else.
He is also responsive on the project blog.
A motorcyclist is never late, Frodo Baggins. Nor is he early. He arrives precisely when he means to.
My Suzuki RF400 build: now with Enertrac MHM602 and 6kWh AESC modules protected by a Zephyr BMS
Renault Equation modded to 10S6P recycled laptop 18650s & 1kW controller.
Master of Electric Motor Selection: "Adopt a motor" (PM me if you have trouble editing)
All the gear, all the time!
Quokka   1 kW
Re: QS MOTOR,0.5-16kW Electric In-Wheel Hub Motors Manufactu
Post by Quokka » Jul 17 2016 7:42am
Had a chance to put some milage on the bike with the new QS205. Wow, what a weapon. Gave it a real hammering today and it didnt break a sweat. Definately reccomend this to anyone who wants something with wheel popping power
litespeed   100 kW
Post by litespeed » Jul 17 2016 8:16am
Your bike looks perfect.....congrats on such a great job!
Tom
minde28383   10 kW
Post by minde28383 » Jul 17 2016 10:46am
what's your thoughts putting this qs205 into 14inch rim? Wouldn't it have even better acceleration and better distance. Lets pretend/ignore that it would look awful in a e-bicycle frame.
ebike build in progress
CN 5.5kw scooter (on sale)
E Mindless Maverick Talisman longboard, 2.2KW motor, 150Amps controller (on sale)
GmagNeato   100 W
Post by GmagNeato » Jul 17 2016 3:38pm
Quokka wrote:Had a chance to put some milage on the bike with the new QS205. Wow, what a weapon. Gave it a real hammering today and it didnt break a sweat. Definately reccomend this to anyone who wants something with wheel popping power
Nice ride Quokka!! What battery config were you able to fit in that frame? I've always loved Quilbix's controller shield. Any idea what your total weight is?
1st build: (commuter conversion) Novara HT / DIY 15s7p Panasonic NCRB's (harvested from used laptop packs) / 40a generic Chinese controller / 1500w 5T Leaf motor (STOCK)
2nd build: EEB frame / 20s4p of 7200mah Turnigy Hard Case Packs, 74v nominal, 28.8ah, 2131wh / Adaptto Max-E (9G4 firmware currently) + BMS + 70a Charge Coil onboard / QS 205 V3 Extra 5T
Quokka   1 kW
Post by Quokka » Jul 18 2016 12:44am
Never thought of a 14" rim. Would accelerate really hard i guess.
Battery i am running is a 20s 12p of sanyo ga 3500ma cells. 72v, 42amp hours. Total weight would be 45-50 kg i guess
minde28383   10 kW
Post by minde28383 » Jul 18 2016 7:59am
What if qs 205 T3 (15kv) in 14inch rim with lipo 24s battery.
Such setup sounds very nice but sabvoton 72150 controller accepts only up to 95volts.
What would be max speed of such setup?
marcexec   1 kW
Post by marcexec » Jul 18 2016 3:16pm
minde28383 wrote:What if qs 205 T3 (15kv) in 14inch rim with lipo 24s battery.
The APT controller they're also selling can go to 120V: https://endless-sphere.com/forums/viewt ... ?p=1059954
gensem   100 kW
Post by gensem » Jul 18 2016 3:55pm
Bad quality photo of the bike getting together.
Justin we really appreciate what you did!
litespeed   100 kW
Post by litespeed » Jul 18 2016 6:22pm
Oh good gawd that motor is huge!
Can't wait to see videos of that thing in action.
Tom
Mammalian04   100 kW
Post by Mammalian04 » Jul 18 2016 11:32pm
gensem wrote:Bad quality photo of the bike getting together.
Very nice! That's what I am planning for my next build (273 with 17" front and rear). I'm still not sure what frame to go with yet.
