Genesis V2100 - Assault & Battery
\/ampa   100 W
Re: Genesis V2100 - Assault & Battery - Illegal in all 50 St
Post by \/ampa » Mar 10 2015 2:41pm
Slip is also much more efficient.
I have seen a rise from about 3% (regen like a normal brake) to about 10% when i use slip a few miles earlier engaged than normal braking regen.
diggler   1 kW
Post by diggler » Mar 10 2015 6:25pm
cool thanks for the info.
Another question.
Did you hook up the temp sensor to your CA?
If so how did you do it?
I just ordered a CA v3 and I noticed there temp sensor plug is 2 wire.
So do you just use the white wire with either the black ground or red power wire from the halls?
GAS ELECTRIC FAT BIKE 49CC/3000W MXUS V1 18s Lipo 18 Fet BUILDING...http://endless-sphere.com/forums/viewto ... =6&t=65638
600W CAPACITIVE SPOT WELDER BUILDING... http://endless-sphere.com/forums/viewto ... =2&t=66466
HOLANDIA BEACH CRUSER 1000W 9C ?TURN REBUILDING... no thread yet.
Next project will be 18" Iron Horse hard tail mid drive
teslanv   100 MW
Post by teslanv » Mar 10 2015 7:50pm
diggler wrote:cool thanks for the info.
Another question.
You will need to connect the white wire and pull a second tap from the black hall wire for the temp sensor.
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
teslanv   100 MW
Post by teslanv » Mar 10 2015 10:26pm
So all my testing thus far has been with the controller programmed to 100% Speed.
I think it's time to crank it up to 11. (120% speed)
Who wants to bet on whether or not I can hit 55 MPH on 20S LiPo?
Bellevue, WA
USA
magna_503   10 W
Post by magna_503 » Mar 20 2015 8:10pm
Is it just me or does the farfle swing arm looks like it could also be a controller/battery space?
macribs   1.21 GW
1.21 GW
Post by macribs » Mar 20 2015 9:32pm
magna_503 wrote:Is it just me or does the farfle swing arm looks like it could also be a controller/battery space?
Or a great place for a RC style outrunner. Heck there is probably even room for a reduction jackshaft on that thing. :lol:
Great to get the weight so close to pivot point. And such a mount would save you a lot of unsprung weight in the wheel.
There should be plenty of real estate on that swing arm so I am sure you will find use of it no matter what you decide to put there.
spinningmagnets   100 GW
Post by spinningmagnets » Mar 20 2015 10:01pm
Should fit fine (20-inch wheel shown):
magna_503   10 W
Post by magna_503 » Mar 21 2015 10:30am
Awesomeuse of space spinning magnets, with the fare swing arm being steel, a lot of stuff can be fabricated on it..
teslanv   100 MW
Post by teslanv » Mar 22 2015 11:17pm
Went to the Drag Strip today, all geeked out to test ride the bike with a fresh set of 6S Multistar batteries.
Unfortunately the event was rained out after we paid our entrance fees.
We decided to run a couple laps on the side track, and on 90V, I was able to get up to 53 MPH per the read-out on my CA. (60A Battery, 120A Phase, 100% Speed Max)
The other disappointing thing was that even though I came prepared with my laptop and programming cable, to bump up the current and speed settings, the cable USB stick broke in half on the ride up, so I was not able to reprogram. We will have to try this again in a couple weeks at 120% speed and higher battery & phase currents.
Also for next time, I hope to have my new CA V3 and datalogger installed, so I can include Video with motor data & speed overlays.
Bellevue, WA
USA
magna_503   10 W
Post by magna_503 » Mar 23 2015 8:55am
Can't wait for the result..
diggler   1 kW
Post by diggler » Mar 27 2015 3:17pm
I would think it would easily do 55, since your using that torquey 21.5" OD tire set up.
100% is like 64mph no load speed at 20s so 120% should be 76.
Only one way to find out. :mrgreen:
teslanv   100 MW
Post by teslanv » Mar 27 2015 4:39pm
Last night. 18S, around 69V charge. Managed to get 47 MPH on 120% speed. 50A Battery/100A Phase
Bellevue, WA
USA
diggler   1 kW
Post by diggler » Mar 27 2015 10:27pm
well that is interesting.
I got 42mph on 29" tires 65 bat 120 phase same 18s but 4 turn at 120%
My no load speed 64mph yours 63.
Just another instance that shows the big tires lug these hub motors.
But
I did have an at least 20lb gas engine on board, 15 more lbs of battery and the 4" wide knobby tires at 20-25psi probably have more drag than your moto tires. :wink:
teslanv   100 MW
Post by teslanv » Mar 28 2015 2:59pm
Bellevue, WA
USA
100volts+   10 kW
Post by 100volts+ » Mar 28 2015 3:10pm
I hate when that happens. I ditched the sticks and use only the newer modern "fingernail shaped" type of usb drives.
http://endless-sphere.com/forums/viewto ... =1&t=57440
Unlike puppets we have the possibility of stopping in our movements,
looking up and perceiving the machinery by which we have been moved. In this
act lies the first steps towards freedom. - PETER BERGER Sociologist
sllikskills   1 W
1 W
Post by sllikskills » Mar 31 2015 3:55pm
Hey Teslanv,
Just curious - what are the length of the spokes you have you have on your front 17" rim? Did you purchase the spokes from JRH as well?
Thanks!
An E-Bike crazed I.T. junkie/analyst who scratches on turntables like DJ Premiere...
Complete Custom x5403 Project Build: http://endless-sphere.com/forums/viewto ... 7#p1012857
teslanv   100 MW
Post by teslanv » Mar 31 2015 6:45pm
sllikskills wrote:Hey Teslanv,
Thanks!
JRH built the whole wheel.
Bellevue, WA
USA
BruceTS   100 µW
100 µW
Post by BruceTS » Apr 03 2015 12:55am
Thanks!
13 gage 195 mm with moped nipples on a DMR Convertible Front 20mm Disc Hub 36 holes
Genesis V2100, MXUS 3000W, Farfle Swing Arm (V2), 72v16ah 20s5p LG MH1 cells, range 70+ miles top speed 40mph
BruceTS   100 µW
100 µW
Post by BruceTS » Apr 18 2015 9:18am
Replacing the rear swing arm plastic bushings with sealed bearings. I've compiled a list of sources
This is from a thread I found about the small white bushing in the link arms
8mm x 12mm x 3.5mm sealed bearings are what you are looking for.
They sell versions with flanges and without flanges. My suggestion is to pick up a set of 10 flanged ones and 4 nonflanged ones. When you install them you put 1 flanged bearing on each side of the pivot arm and between them you install one of the nonflanged bearings. If there is a gap in the arms then you will need to install a teflon washer or modify your stock plastic bushings by cutting off the piece that inserts into the pivot arms and basically making a plastic washer. Experiment a little because these bikes are not high quality machines and the gap spacing will probably be different on every bike. That is the setup I run in my v2100 and my saber build and it works great.
Ebay item # 141281793871
Ebay item # 141321597186
First one is basic sealed bearing that you need at least 4 of. The second is the flanged bearings you need at least 8 of. I suggest getting a few extras of each one. Just paste the item # into ebay search and it will bring it up for you.
While you are at it I suggest ordering at least 2 of these...
Ebay item # 160501042330
Those are sealed bearings that go into the pivot arm directly under the seat. To install them you get a socket that is about the same size as the outer metal portion of the bearing and gently hammer them in place. To uninstall the stock ones just get a socket that fits in the hole and hammer them out. Doesn't matter if you damage the stock ones as they are crap anyway. For money reasons, I can assume, they used shielded instead of sealed bearings. All bikes should have sealed bearings only.
As for the main pivot the size is 30mm x 19mm and I just ordered a few of these to try
http://www.staton-inc.com/store/product ... 891-1.html
Since I'm building my own swing arm I can mill out the pivot to fit a larger OD bearing and have a few others in mind, since the ID is 19mm or 3/4 inch it will be easy sourcing them.
BruceTS   100 µW
100 µW
Post by BruceTS » Jul 14 2015 3:06pm
Figured I'd better start adding some pics of my build
Santa Monica.jpg (118.25 KiB) Viewed 1709 times
BruceTS   100 µW
100 µW
Post by BruceTS » Jul 14 2015 3:14pm
Not much to add, I just copied this build thread with a few changes of my own, using LG MH1 3200maH cells in a 20s5p configuration, 18FET Infineon Controller that I rerouted some of the wires so I can easily mount it on the frame vertical seat tube. The swing arm was built using plans and laser cut parts supplied by teslanv, I did all mill work and welding. Made a mold to cast the fiberglass shell for the battery pack.
I'm really enjoying this bike!
sllikskills   1 W
1 W
Post by sllikskills » Jul 24 2015 2:32pm
BruceTS,
thanks for your numbers. Yeah I also have a DMR convertible front hub. The rim I have is a Bridgestone 17" x 1.4" rim. I messed up before, ordering 190 and 191mm 12G spokes from JRH and now I have to re-order which is why I asked. I believe 195mm is just about right, but I have to recalculate. I measured a 428mm ERD on my rim. We'll see how it goes!
ecycler   10 kW
Post by ecycler » Aug 04 2015 12:03pm
Teslanv, does your chain clear with the controller mounted like that? Would a triple chain ring fit if you got it perfectly spaced?
Any grease is better than no grease.
The best exercises are the ones you enjoy doing.
I strongly prefer vehicles without doors.
ecycler   10 kW
Post by ecycler » Aug 04 2015 12:04pm
Bruce, are you able to use your inner chain ring with your controller mounted like that?
BruceTS   100 µW
100 µW
Post by BruceTS » Feb 16 2016 7:59pm
yes all my gear selection is useable, and yes it takes some playing around to make everything clear and function properly, no room for error.
