Genesis V2100 - Assault & Battery
spinningmagnets   100 GW
Re: Genesis V2100 - Assault & Battery - Illegal in all 50 St
Post by spinningmagnets » Feb 21 2015 11:36am
In the 3000W-5000W range of this system, the fat hubmotor as an option has already proven itself. I am truly excited to soon be seeing some builds with 20-inch rear wheel (22-inch DOT moped tire) allowing a big-block to be mounted just in front of the rear wheel. A simple sprocket change (after the bike is bought and/or built) can change the top-speed and short-range acceleration.
You could have a 50-MPH street cruiser that can stay up with traffic...or (after a 5-minute sprocket swap) geared to 35-MPH would easily beat exotic cars from stoplight to stoplight...(if you can keep the front wheel down!)
http://endless-sphere.com/forums/viewto ... 22#p883038
999zip999   100 GW
Post by 999zip999 » Feb 21 2015 2:25pm
Spinningmagnets think how fast that bike would be if you put a jockey size rider on it. Sorry LFP lol.
Look at the rear sprocket on the disc side.
I think that's a farfle custom swing arm.
windtrader   1 kW
Post by windtrader » Feb 21 2015 3:55pm
Ditto the option, just trying to keep Teslav concentrating on getting the first "kit" all tidied up so when a few builds start showing up it can fuel a viral launch as for something like this to fly there has to be near zero friction. In other words, one click buy it all or a simple list of components you choose then click.
All docs, guides, videos go to support this exact configuration. All the online discussion is confined to this uni-design thus minimizing the dilution of the power of the builders to go off topic.
Personally, I am totally in the mid frame mounted design so would love seeing a non hub motor option. But as we all know rear hubs are the most simple option with the fewest parts, fewest ways to install improperly, and least potential for complications. These are key ingredients for low friction.
We all know there are lots more on the detail check list, some Spinning mentions. Flexibility and more options are what we desire but not to the person who has a screwdriver, pair of pliers, and adjustable wrench as his toolkit.
Stay focused my friend.
Now close your eyes so I can paste the link to the Revolt-Norco swingarm mounted design
http://endless-sphere.com/forums/viewto ... lt#p993379
2old   100 kW
Post by 2old » Feb 21 2015 4:29pm
The main rear pivot on the stock Genesis appears to have a small bolt recessed in it. From your previous comments this pivot unit can be used with your swingarm, correct? Also, does one remove this pivot by just removing the one bolt or is a bearing press needed too? I want to start disassembling the bike so that when parts are available I'll be ready.
macribs   1.21 GW
1.21 GW
Post by macribs » Feb 21 2015 6:02pm
spinningmagnets wrote:In the 3000W-5000W range of this system, the fat hubmotor as an option has already proven itself. I am truly excited to soon be seeing some builds with 20-inch rear wheel (22-inch DOT moped tire) allowing a big-block to be mounted just in front of the rear wheel. A simple sprocket change (after the bike is bought and/or built) can change the top-speed and short-range acceleration.
Is there any ES bikes build as of today with the big-block mounted in front of the rear wheel on the swingarm?
I just wonder how that would look - wouldn't the big-block look a bit big and bulky mounted on the swing arm?
Post by spinningmagnets » Feb 22 2015 11:37am
I know this isnt a Farfle swingarm, but these 5-inch diameter motors will fit, when using a 20-inch wheel:
http://endless-sphere.com/forums/viewto ... 9#p1009754
macribs   1.21 GW
1.21 GW
Post by macribs » Feb 22 2015 11:44am
Thx spinningmagnets. As always you provide :)
No reduction and a tiny rear sprocket - geared for top speed?
Post by spinningmagnets » Feb 22 2015 11:56am
If getting an LR big block, I would definitely get the jackshaft regardless of the voltage to be used. It makes the sprocket choices very easy and affordable to fine tune the system, or even to swap-out the entire performance envelope in only 5 minutes whenever you want.
teslanv   100 MW
Post by teslanv » Feb 22 2015 11:41pm
Upgrading the Phase Wires on my 3T motor:
http://endless-sphere.com/forums/viewto ... 5#p1010665
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
100volts+   10 kW
Post by 100volts+ » Feb 24 2015 8:36pm
What is the name of that German battery bag that straddles the top tube and looks kind of like a motorcycle gas tank? That bag would look cool on the v2100.
Now i remember Additive ebike battery bag. I don't think it will work on a dual crown fork though
additive_v2_1 (6).jpg (196.49 KiB) Viewed 4038 times
http://endless-sphere.com/forums/viewto ... =1&t=57440
Unlike puppets we have the possibility of stopping in our movements,
looking up and perceiving the machinery by which we have been moved. In this
act lies the first steps towards freedom. - PETER BERGER Sociologist
100volts+   10 kW
Post by 100volts+ » Mar 01 2015 6:56pm
My 30s lipo v2100. There is no way to make 125v setup stealthy so I'm going for the anti-stealth look.
walmart bike.jpg (166.19 KiB) Viewed 3995 times
teslanv   100 MW
Post by teslanv » Mar 03 2015 8:27am
First ride to work yesterday. Lots of gawkers. :)
I let a few of my coworkers take it for a test ride. The ebike grin is infectious in my neighborhood. :wink:
Bellevue, WA
USA
windtrader   1 kW
Post by windtrader » Mar 03 2015 9:38am
Lots of gawkers.
sounds like a memorable ride. Guess Assault and Battery proves more fitting than anything with stealth in the name :)
tomjasz   10 GW
Post by tomjasz » Mar 06 2015 1:09pm
What is the maximum dimensional width of the tire you used?
I'm looking at Heidenau M3 as an option. Sadly every tire seems to have a slightly larger dimension and varies from maker to maker. Argh!
teslanv   100 MW
Post by teslanv » Mar 06 2015 1:28pm
tomjasz wrote:What is the maximum dimensional width of the tire you used?
Not sure what you are asking, Tom.
The Rim I used was a 17X1.6" Moped Rim, so most 17" Motorcycle or Moped Tires should fit. I used a 17X2.25" Tire, which has an Outside diameter of 21.5", since I wanted to maximize forward thrust, but 17X2.5", 17X2.75" and 17X3.0 Tires should also work fine with the 17x1.6" Rim. a 17x3.0" Tire would have an outside diameter of 23"
Bellevue, WA
USA
100volts+   10 kW
Post by 100volts+ » Mar 08 2015 11:46am
I think I know what you mean. I have 2.75 x 19 shinko front and back on prowheel 19x1,4 rims and the width of those when inflated is actually 3.2 to 3.3 inches when measured on the knobs (the very widest point)
shinko width.jpg (91.15 KiB) Viewed 3791 times
maxRpm   10 W
Post by maxRpm » Mar 08 2015 7:07pm
100volts+ wrote:My 30s lipo v2100. There is no way to make 125v setup stealthy so I'm going for the anti-stealth look.
You have any video of this ride? I so much want to see.
100volts+   10 kW
Post by 100volts+ » Mar 09 2015 4:58am
teslanv   100 MW
Post by teslanv » Mar 09 2015 12:49pm
Bellevue, WA
USA
edwolf   10 µW
10 µW
Post by edwolf » Mar 10 2015 5:45am
I wouldn't feel comfortable going 15mph on a wal-mart bike!
madin88   1 GW
1 GW
Post by madin88 » Mar 10 2015 5:59am
teslanv, do you have the chance to do a material test on that frame?
maybe you have a company near you which can measure brinell hardness of this aluminum. than you can roughly imply how many N/mm² or MPa it has.
This would make you feel more safe or not :mrgreen:
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
teslanv   100 MW
Post by teslanv » Mar 10 2015 7:45am
edwolf wrote:I wouldn't feel comfortable going 15mph on a wal-mart bike!
Believe me, edwolf. I had the same fears before I actually rode this bike. After several high-speed test rides, I no longer have this fear. But please don't do anything you are not comfortable doing.
There have been many guys on this forum using the Genesis V2100 frame.
Bellevue, WA
USA
100volts+   10 kW
Post by 100volts+ » Mar 10 2015 8:35am
I don't know what the hardness is but I have been running the crap out of the same frame for over 2 years and no problems yet. But I don't go over 60 miles per hour too often
diggler   1 kW
Post by diggler » Mar 10 2015 1:26pm
So slip charge mode.
What does this do exactly?
Does it kind of feel like engine braking?
Or is it more subtle?
GAS ELECTRIC FAT BIKE 49CC/3000W MXUS V1 18s Lipo 18 Fet BUILDING...http://endless-sphere.com/forums/viewto ... =6&t=65638
600W CAPACITIVE SPOT WELDER BUILDING... http://endless-sphere.com/forums/viewto ... =2&t=66466
HOLANDIA BEACH CRUSER 1000W 9C ?TURN REBUILDING... no thread yet.
Next project will be 18" Iron Horse hard tail mid drive
teslanv   100 MW
Post by teslanv » Mar 10 2015 2:28pm
Slip charge is kinda like engine braking. It just does a slight regen brake whenever you lay off the throttle.
Bellevue, WA
USA
