All the best for a happy holiday break. And a Happy New Year to you and yours!
JP spot welder
Re: JP spot welder
Re: JP spot welder
Hey guys, some news, please see the new update on first post. We are restocked and ready to ship in usual pace!
Re: JP spot welder
Great news! Still plugging along with repairs with your welder powered by recycled 650A/CCA AGM. A great score. It replaced a Sunnko 799. An unfortunate China welder experience, for me, while others fared well.
On my the bench that monster AGM is no problem. I keep it and a battery conditioner on 24/7/365. All good, no Lipo sweat.
You’ve always supported your products well. Thanks for several good years!
I have several welders. I can’t imagine a reason to not buy another of yours. Thanks for the support.
Hvala van,
TD
Hvala van,
TD
Re: JP spot welder
I second that endorsement. Mine has done literally thousands of welds and worked flawlessly.
Good luck with the continued sales.
Current Rides
Lightest true ebike on the planet: ON ROAD viewtopic.php?f=6&t=74269
eBoost on facebook: http://www.facebook.com/pages/Eboost/200306283342024/
Re: JP spot welder
Thank you guys for the support, I really appreciate it!
Re: JP spot welder
Just send me a PM, which you already have
Re: JP spot welder
Mine has been going strong for years (10's of thousands of welds). Switched to a more flexible car audio power cable which makes it a bit nicer to use.
Using 3S Sinopoly 100Ah LiFePO4 cells, quite degraded from use in a car, but works VERY well.
Re: JP spot welder
Whoa, that's really nice to hear! You are the only one from the DIYelectriccar forum that got the welder
Re: JP spot welder
Anyone weld any Boston Power Swing cells using this welder? If so what settings and material did you use? (.015, .030 nickel, .010, .005 copper)?? I am trying to build 14s5p battery packs for my kids electric scooters. I have 4 cases of these cells and have heard they are very difficult to spot weld. Thanks for your time..
- Attachments
- Boston power swing cell I'd like to use
- Screenshot_20180205-135727.png (183.25 KiB) Viewed 2729 times
Re: JP spot welder
Hi
I sent you a PM. I think you should put any additional contact info like whatsapp, wechat, etc., and also explain better how to order and pay. Thanks.
Re: JP spot welder
Send a message and then finish your profile with location. Easy peasy.
Re: JP spot welder
Hi
I'm very about my jpspotwelder
I have a question
It's possible to weld fuse wire on 18650 with the spot welder?
It's possible to connect one hand welder pen?
Can you tried?
Thanks
Sylvain
I have a question
Can you tried?
Thanks
Sylvain
Re: JP spot welder
I started using my welder and it seems I’m getting some weak welds... and they get a little stronger if I rotate the copper leads. Is my battery not strong enough? 530ca 425cca reserve capacity 75 (whatever that means) using .15 nickel at 26ms
If I get a stronger battery would it help? Or do I have to clean/sand the tips of the copper. I know I’m doing something wrong somewhere
Thanks for any input!
Re: JP spot welder
Sounds like the battery is too weak. Is it an old battery?destro23 wrote: ↑Nov 12 2018 10:39amI started using my welder and it seems I’m getting some weak welds... and they get a little stronger if I rotate the copper leads. Is my battery not strong enough? 530ca 425cca reserve capacity 75 (whatever that means) using .15 nickel at 26ms
Re: JP spot welder
I bought it certified/used from autozone. It currently reads 12.94 volts and it’s been off the trickle charger for 2 days. I’m gonna try and return it for a bigger one today. This may be the issue.
What size battery are you using?
I also have a optima 1000 ca / 800cca battery in my old GTO is that to strong for this?
Re: JP spot welder
Dont use too much pressure on the tips! 750CCA is good enough for 0,2mm
Join Endless-Sphere Telegram group: https://t.me/endless_sphere
Sur-Ron Dealer Europe SE
Sur-Ron Dealer Europe ENG
Re: JP spot welder
i just returned it for a 625cca battery... i'll test it out tomorrow.fechter wrote: ↑Nov 12 2018 12:10pmSounds like the battery is too weak. Is it an old battery?destro23 wrote: ↑Nov 12 2018 10:39amI started using my welder and it seems I’m getting some weak welds... and they get a little stronger if I rotate the copper leads. Is my battery not strong enough? 530ca 425cca reserve capacity 75 (whatever that means) using .15 nickel at 26ms
Re: JP spot welder
Yes, the key is to press so you get a good contact but you cannot press too hard. If you do, your welds will be weak - you need to have some resistance to make the actual weld, this is from my experience with this thing. BIG contact area =weak welds. This is why you get better welds if you turn the leads - probably because they are sharper there=small contact area. This could of course be compensated with more pulse current from the battery.
Re: JP spot welder
Hello riba. Sent a PM. Do you have a link where I can buy a 12V transformer for North America that will work with your welder?
Re: JP spot welder
riba2233 wrote: ↑Apr 24 2015 4:25pm
1. You can use standard 12V ac/dc adapter with 5.5/2.1 mm barrel connector (most common one), 500 mA is fine, maybe even less, but I haven' tried. It's polarity will be marked, it's standard negative outer, and inner pin is positive. There is a diode on the input so nothing will happen if you accidentally reverse polarity.
Here is the one I got:
https://www.ebay.com/itm/AC-100-240V-Ad ... rk:23:pf:0
US $3.82
Re: JP spot welder
Nice find!fechter wrote: ↑Nov 20 2018 2:52pmriba2233 wrote: ↑Apr 24 2015 4:25pm
US $3.82
Re: JP spot welder
hello friend.
Could I replace the battery with a modified microwave transformer?
Re: JP spot welder
The welder circuit won't work with AC. If you had a rectifier on the output of the transformer, it could possibly work but the rectifier would need to handle over 1000 amps. I don't think a transformer would be able to supply enough current to make good welds even if you could find a big enough rectifier.sevillano1982 wrote: ↑Dec 11 2018 7:44pmhello friend.
