Heavy Duty Torque Arm - Disc mount, clamping optional $35
Re: Heavy Duty Torque Arm - IS mount, clamping optional $35
Interested. How would tht work on the other side of the bike? I ideally would like 2 torque arm, one on each side.
Thanks
Thanks
I only use one in the non-drive side, maybe try printing out the template on the first post and see what it would look like? You could glue it to some cardboard or thicker material to get a good idea of how it might fit. They're designed to mount to the disc brake mount, so I don't know how you'd get it on the other side but post here if you figure something out.
--David
Projects:
Heavy Duty IS Disc Mount Bolt on Torque Arm for Sale (Clamping Optional)
DIY Programmable BMS (now using ATtiny)
3-192S Arduino BMS (using BQ76PL536A)
The plural of "anecdote" is not "data"
Projects:
Bump. Plenty available right now.
--David
Projects:
Projects:
This weekend I drilled and tapped one torque arm for clamping. Using a drill press I first used a center drill to start the hole, then used a good sharp 5.0mm HSS bit to drill the pilot hole, followed by a 6.0mm hole through one side for bolt clearance. Lots of cutting fluid to keep the bits cool helped a lot, and strong pressure to keep the bit cutting before the steel work hardens. Key to the whole process was using sharp bits, cutting fluid, and oil for tapping along with frequent backing out the tap to break chips. I also used a sacrificial piece of scrap aluminum through the middle to keep the piece flat in the drill press clamp.
I'm investigating having a machine shop do this on a larger quantity of parts, as I just don't have the time to do it myself. But for those with the right tools it's not a difficult process.
The screw is 30mm long, M6x1.0 thread.
--David
Projects:
Projects:
- eyebyesickle 10 kW
nice, these would be great for the cheaper bicycle frame conversions that never come with/have disc mounts... 2 birds with one stone... (i'd slap a cheap one on the other side, even though I am talking low power conversions...)
Are you thinking to add a disc brake mount? I woudn't recommend using them to add a disc brake as the forces involved in braking can be greater than due to the motor, and would then be carried by the axle instead of the frame. Sorry if I'm misinterpreting your comment, but these are only intended for use when you already have a disc brake mount.eyebyesickle wrote:nice, these would be great for the cheaper bicycle frame conversions that never come with/have disc mounts.
--David
Projects:
Projects:
Ah, makes sense. No you had it right. Looking for shortcuts. I should know betterdmwahl wrote:Are you thinking to add a disc brake mount? I woudn't recommend using them to add a disc brake as the forces involved in braking can be greater than due to the motor, and would then be carried by the axle instead of the frame. Sorry if I'm misinterpreting your comment, but these are only intended for use when you already have a disc brake mount.eyebyesickle wrote:nice, these would be great for the cheaper bicycle frame conversions that never come with/have disc mounts.
Hey David,
You still have these Torque Arms?
My first scoot > https://endless-sphere.com/forums/viewt ... =4&t=82956
Yep, plenty in stock. I keep the first post up to date with availability, and the paypal link (for USA) also keeps track of stock and will warn you if I'm out.
--David
Projects:
Projects:
Order on the way...
Thanks David!
Thanks David!
Order placed, looking for the Clamping unit. Thank You!
Torque arm arrived today, very solid/thick piece with clean edges. Looks and feels just bullet proof, Thank You!
maybe it would help to list the frames its working for? I got rust on mine so painted it and had to grind a few lumps out but it fits an orange patriot 2002
ps my dropout had been bent open slightly allowing 4% of axle movement to line the holes up. Im not 100% sure if this would still fit if the frame hadnt been abused and was still snug.
GEARS? Where we're going we dont need gears!
Due to metal plates and a body full of nuts and bolts I am as bionic as my bike. Mxus 4t 120v toshiba fets and 16ah 24s nanotech.
Yes, definitely helpful to know what it fits on. Thanks for posting yours. I like the black paint, makes it blend in nicely.
Regarding the rust, a few of them have some, I believe due to the cutting process. They're stainless steel though so any corrosion will be minimal.
--David
Projects:
Projects:
Does it fit a diamond back response ? It looks like it.
Can't say for sure, I only have room for so many bikes... Print out the template on the first post and that will tell you.999zip999 wrote:Does it fit a diamond back response ? It looks like it.
--David
Projects:
Projects:
Re: Heavy Duty Torque Arm - Disc mount, clamping optional $3
Are these still for sale?
You bet. I have stock and have been getting them in the mail within a day or two of ordering.rich43 wrote:Are these still for sale?
--David
Projects:
Projects:
I have sent you a PM, I am interested in ordering one.dmwahl wrote:You bet. I have stock and have been getting them in the mail within a day or two of ordering.rich43 wrote:Are these still for sale?
Replied.rich43 wrote:I have sent you a PM, I am interested in ordering one.
--David
Projects:
Projects:
I paid but sent two $50 payments by mistake as PayPal glitched, can you refund one and keep the other as payment for the torque arm?
Edit: David refunded it
Done.rich43 wrote:I paid but sent two $50 payments by mistake as PayPal glitched, can you refund one and keep the other as payment for the torque arm?
--David
Projects:
Projects:
I've sent you a PM; its great that you have a pdf to test print it. I was going to try and make my own but your solution looks better than what I could fabri-cobble together.
Commuter/Street Build viewtopic.php?f=6&t=98286:
Rocky Mountain Element
Magic Pie 4 front + Leafmotor 1500 rear w/ Infineon 4 Clone @ 200A phase
Samsung 40T 14S7P
Offroad Build viewtopic.php?f=6&t=102195:
2019 Rocky Mountain Blizzard 20
Cyclone "3kw" 13T motor to 36T chain ring then 32T chain ring to 11T-46T Cassette @ 100A phase
em3ev 14S5P 30Q or 14S6P 25R pack
Samsung 40T 14S7P
Haven't heard that one before, I'm going to have to borrow it from now on.pwd wrote:...fabri-cobble...
--David
Projects:
Projects:
My torque arm arrived and I got it fitted:
post imgcertificity.com
I did some minor grinding to get it to clear the brake caliper and the frame. This is on my Rocky Mountain Element 10. The fit for the axle is perfect; I just filed it a bit on each side and it slid on nice and tight. Now the bike should be able to handle 40 amps and regen. Thank you dmwahl
Samsung 40T 14S7P
Samsung 40T 14S7P
