Heavy Duty Torque Arm - Disc mount, clamping optional $35
Re: Heavy Duty Torque Arm - Disc mount, clamping optional $3
I would like to buy one for front fork IS. Have sent PM but don't think you have read it yet.
I don't see any PMs from you, try again perhaps?Swe wrote:I would like to buy one for front fork IS. Have sent PM but don't think you have read it yet.
--David
Projects:
Heavy Duty IS Disc Mount Bolt on Torque Arm for Sale (Clamping Optional)
DIY Programmable BMS (now using ATtiny)
3-192S Arduino BMS (using BQ76PL536A)
The plural of "anecdote" is not "data"
Projects:
Oh I see now that I sent the PM to migueralliart
you should have it now...
Edit: or well actually it was migueralliart I wanted to buy from, I am writing in wrong topic. I don't think these here will work on front fork...? If I am wrong please correct me.
This was resolved via PM, but for the benefit of everyone else the torque arm was designed for a rear fork, but there's no fundamental reason it wouldn't work on a front fork. The angle of the flats relative to the disc mount is what's important, which is why I include a printable template on the first page of this thread.Swe wrote:I don't think these here will work on front fork...? If I am wrong please correct me.
--David
Projects:
Projects:
PM sent your way.
VIDEO of diy mount for other side
hi huys,
Got mine a while ago. Very good quality. Very thick and very hard steel.
I accommpliched to install them on both sides and want to share it with u..
Took me about 2 days (15 hours) complete with driving and cutting and everything:
You can actually get a measurable deflection using a M6 screw and hand tightening it. Whether or not it's needed is another matter altogether, but I've measured several tenths of a mm deflection when tightening the clamping bolt in mine. Of course when it's clamped around the axle the deflection is much less, but still there.mudale222 wrote:About clamping.. i don't really think u can clamp a 9.5mm of harden steel
--David
Projects:
Projects:
What are people doing for the non disk side? Has anyone DP420 epoxied these torque arms to the frame?
Edit: I just watched Mudale222's video. Thank you. Anyone else?
It wasn't the intent of the design to epoxy them, but if you look a few posts above this one someone was planning on doing just that. Perhaps he will chime in here...shorza wrote:What are people doing for the non disk side? Has anyone DP420 epoxied these torque arms to the frame?
--David
Projects:
Projects:
Thanks, I just saw that. What about everyone else? Are they just using 1 torque arm?dmwahl wrote:It wasn't the intent of the design to epoxy them, but if you look a few posts above this one someone was planning on doing just that. Perhaps he will chime in here...shorza wrote:What are people doing for the non disk side? Has anyone DP420 epoxied these torque arms to the frame?
A single arm seems to be the most common, just based on the fact that maybe 80% of people only order 1. Maybe they're using a different one for the other side, but I don't think 2 are necessary for most people. Then again I like selling 2 at a time, so maybe just order 2 to be on the safe side
--David
Projects:
Projects:
Actually my epoxy just came couple a days ago.. didn't put it.
Did about 1000km on this setup so far with no problem, fast roads and stuff.
I think if it's won't make any movement i'll keep it that way without the epoxy.
For people who's want to use the epoxy (specally real high power system), i'm suggesting not to relay on it as there only solution, but to attach it by other means and use the epoxy as second secure way.
Remember that epoxy (if and when crush) will do it instantly and catastrophically.
Re: Heavy Duty Torque Arm - Disc mount, clamping optional $35
Do you still have for sale? Thanks
Yep, plenty available. I ordered a whole bunch of them and they’ve been selling regularly. I should probably post periodically so people know they’re still available.
--David
Projects:
Projects:
Thanks. Is it possible to have it pre-drilled? I don't have a pillar drill so my holes are not precise.
I can tap it myself
What would be the price for 1 shipped to the UK?
Thanks
I can tap it myself
Thanks
First post,
Prices outside US
Canada - $40 for 1, $75 for 2
United Kingdom, Belgium, Sweden, Australia, Israel - $45 for 1, $80 for 2, $120 for 3
To purchase via Paypal, go here.
Price is $35 which includes US shipping. You'll need an address set up in Paypal, which allows me to automatically print a shipping label and expedites the process significantly. For non-US orders, pm me with your Paypal email address and I'll send you a request or give you my paypal email address.
Bump. I have about 10 left.
--David
Projects:
Projects:
Nice work, and LOTS cheaper than a one-off or several other well made arms.
Any idea when you might have more of these?
You're all in luck... I found 9 more in a box in my basement when I was cleaning and can ship immediately. If these go quickly I may order another batch, we shall see.
--David
Projects:
Projects:
I can vouch for this torque arm, mines been solid for over 1000 km's now
Thanks tolkaNo, always good to hear feedback. Mind sharing a build thread or what motor, controller settings, bike, etc you used it on?
--David
Projects:
Projects:
Sure its a fairly basic build
Motor is a 1kw DD hub @ 3.2kw
EM3EV Infineon 12 fet controller @ 50a
18s5p Samsung 30q battery self built
Bike is a Mongoose black diamond double, the face of the dropout had to be machined down on a mill in some areas to get the TA to sit flush
Howdy, I'm interested in those torque arms, PM sent.
Purchase link and instructions are on the first post, page 1.
--David
Projects:
Projects:
