AUS ally rims - still here.
ridethelightning   1 MW
Re: AUS ally rims - still here.
Post by ridethelightning » May 24 2016 5:14am
just thought id give this thread a bump, and also say ill be away from june 3rd to sept 3rd, so anyone who might be planning on buying rims from me, here's your last chance for a bit :wink:
RTL
Quokka   1 kW
Post by Quokka » May 24 2016 5:21am
I'll bite. 4 more please kind sir! You still have my details? After 19s
Qulbix Q76R+ QS205+MaxE
Post by ridethelightning » May 24 2016 8:07am
Sure Quokka. will get it on the way. :D
Quokka   1 kW
Post by Quokka » Jan 28 2017 5:26am
Looks like shinko's sr241's are finally in Oz.
I have ordered a few and will report back if they turn up
-EDIT. They have started bringing in both the 244 and 241's. They are avilible through the importer on the east coast.
244's are about 85 bucks from my local moto shop 241's are 85 on the net. I have orded a set of both
Quokka   1 kW
Post by Quokka » Jan 29 2017 7:57pm
36
Post by ridethelightning » Feb 01 2017 3:52am
Quokka wrote:Looks like shinko's sr241's are finally in Oz.
thanks for the tipp-off. iv been interested in getting these legendary tyres, but has always been cost prohibitive.
Quokka   1 kW
Post by Quokka » Feb 01 2017 7:37am
Confirmed mate, they are here. I have both 241 and 244's. 241 is probably a better tire for offroad. The 244's have a harder compound.
Aebrennan   100 W
Post by Aebrennan » Feb 16 2017 2:51am
2 19 inch rims sent to Sydney please.
Post by ridethelightning » Feb 16 2017 6:16am
ok, ill let you know when i have m boxed
Post by ridethelightning » Feb 17 2017 8:22am
just got some sr 241s 125au shipped to tas for a pair. thats great.
\ (•◡•) /   100 mW
Post by \ (•◡•) / » May 31 2017 11:50pm
still got some 19" rims available, if so would be very interested in 2 shipped to vic. thanks :)
Post by ridethelightning » Jun 02 2017 7:39am
18s,19s still available
\ (•◡•) /   100 mW
Post by \ (•◡•) / » Jun 02 2017 8:18am
ridethelightning wrote:18s,19s still available
Sweet!, can i take 2 of the 19x1.4's. i sent you a PM :D
Post by ridethelightning » Jun 02 2017 8:36am
sure. great..user name u got there :lol:
GmagNeato   100 W
Post by GmagNeato » Jun 04 2017 6:10am
Hello RTL. Could you ship a few of these to the states? If so lmk the cost per rim. Thanks.
1st build: (commuter conversion) Novara HT / DIY 15s7p Panasonic NCRB's (harvested from used laptop packs) / 40a generic Chinese controller / 1500w 5T Leaf motor (STOCK)
2nd build: EEB frame / 20s4p of 7200mah Turnigy Hard Case Packs, 74v nominal, 28.8ah, 2131wh / Adaptto Max-E (9G4 firmware currently) + BMS + 70a Charge Coil onboard / QS 205 V3 Extra 5T
Post by ridethelightning » Jun 04 2017 6:23am
well my friend, i could, but i suspect after the shipping cost, you might be better to buy from treatland tv moped store or somewhere like that..
i will look into it anyway.
the only thing these rims might have over your local ones is they are custom for smaller spoke nipples if required, to be used with front mtb hubs, or can be drilled for larger ones with rear hubs.
Post by ridethelightning » Jun 04 2017 6:30am
how many were you after?
im getting 70-80 aud for 3kg by standard post.
activeau   1 µW
Post by activeau » Jun 05 2017 6:01am
If any 19" left could i please have 2x to SA thanks will pm address thanks
Post by ridethelightning » Jun 05 2017 6:26am
geeez! why does every one want the 19s? :lol:
yes,still got a couple left i think, but definately got a massive pile of 18s still sitting there!
if id known, id only have got more 19s.
btw, from this point id rather do only bank transfer, paypal fees are quite high these days.
cheers.
\ (•◡•) /   100 mW
Post by \ (•◡•) / » Aug 04 2017 12:11am
Just started lacing up my front wheel and it seems i have ran into a bit of a issue. i followed this guide on youtube (https://www.youtube.com/watch?v=_6Sd3bMeDck&t=77s) to lace to front wheel. although now after lacing the wheel and tightening the spokes it seems that the The 3rd cross spokes (the spokes than go in the opposite direction to the other spokes) are hanging out around 4-6mm longer than they should be, although the rest of the spokes seem fine. i can't cut the spokes down 6mm as they would have almost no thread left. what am i doing wrong?. i put the spokes coming from the right side of the hub into the holes in the left of the rim, was this the wrong thing to do?. but according to the guide i followed i had to place the first drive side spoke to the left of the valve hole which was a hole to the left side of the rim. here's some photos of what i'm talking about:
http://imgur.com/a/AZ3Zw. thankyou
Post by ridethelightning » Aug 04 2017 3:28am
im no expert, but 222mm rings a bell for lacing the 19s with most front hubs, that i did last time.
looks like the nipples are not seating properly on some of the holes, perhaps they are too large, if this is the case, will need to drill very slightly, but not too much as this will effectively make the ERD smaller, and spokes too long.
if you dont need to, better not.
another thing to remember is that where the elbows are on the outside of the hub, the distance will be longer.
from memory, it does not matter which way you start lacing with regards to the valve, as with moto rims, the direction of the spoke holes will sort that out automatically.
Lash   100 W
Post by Lash » Mar 09 2018 5:43pm
Thanks RTL for supplying the rims and ozman and others for the spoke calcs for the mxus 3000w motor, i went with 128mm spokes as suggested, laced them up and then had them trued and tensioned in the shop. Excellent result. The inner spokes are at about their limit though. Which is fine, but if anyone is pedantic, a slightly shorter spoke could be the way to go for the inner ones. (shorter distance).
I'm only using them for the rear so unsure of fronts.
CFM   100 µW
100 µW
Post by CFM » Mar 14 2018 5:03am
I will take 2, 19" if still available... Please PM me with costs etc....
Post by ridethelightning » Mar 14 2018 7:45am
ok will do.
