Tangent Motors RC mid drive kit
Re: Tangent Motors RC mid drive kit
I have another thread on here but wanted to share my first experience with Daves Tangent Motors Drive kit now I've being playing for a couple of days...here is what I wrote on another thread:
It's on and is a hoot...a torque monster hoot!
Still some tinkering to do with the CA3 I think but first impressions are:
First and foremost, it is brilliant fun...although I should add that I have zero ebike experience before this but I do have 27 years of thrashing and crashing dirt bikes from 2 stokes to 400 4 strokers, muscle bikes, sports bikes and the infamous Vmax so I am cool with big power on 2 wheels....
The starting torque on this unit is hilarious...never have wheelies been so easy.
The kit is plush, right out the box every bit looks and feels lovingly hand made and incredibly solid.
The installation was smooth once I had the right tools and understood how each part interacted with another.
Cabling is simple and intuitive.
The lack of noise is something to get use to for sure....a small whine and whir is worlds apart from a thumper dirt bike...the feedback from an engine makes it feel faster...this is Tangent Drive kit is stealth power in a few kilos of future fun right here.
I've been testing, running back and forth to work and basically having a ball for 2 days now...albeit probably only about 2 hours in total so far and have not needed to recharge the two 6s 16ah lipos....I have 4 for 2s2p 50v 32ah that I've not even hooked up yet....I estimate about 10-12 miles of run time at this point. so maybe 15 out of 16ah which may well turn to be 30 miles from the 32ah pack....I should point out again that this is for the 3220 Astro kit with hv160 controller and not the standard kit Dave sells with the smaller 3210 motor and hv80 controller which will be more "fuel" efficient.
Sunday will tell more when I go out with the boys on their dirt bikes for our usual offroad route.
On a private road I've topped out at 39mph so far with the two batteries down to about 46v and about 300wh left, running the amps to 150 max but have only peaked at 133 thus far....not sure what I have to do to draw more as the motor was given some abuse to get that....I'll find a way no doubt.
Of note to others.....don't let people without motorbike or high power e bike experience ride this...2 tried today and despite my setting lower power and giving instruction...both flipped it out from underneath them. No non bikers from now on unless it is tamed waaaaay down.
General note: tuck trousers into to socks so you don't have to call for a knife to cut your mangled trousers off your leg before being able to dismount....ahem...
And a little snap shot tease before the videos roll....
http://www.HamsFitness.com Strength, Conditioning & Diet
Nice, clean build!, hanging out for the video
Video soon....
I am looking for more speed than my current gearing offers (39MPH) me and am undecided as to which sprocket to swap out for best results:
motor output to bigger or...
crankset motor receiver to smaller or....
crankset chain wheel to bigger....
three ways to get more speed but not certain hoW this effects torque numbers...
Also need to refine the throttle response which Dave has been helping with but any other user experience of CA numbers is welcomed
Be sure CA's speed limiting is totally disabled by following the user guide instructions. The default settings made my throttle really jumpy, but after fixing that it's smooth.HamsFitness wrote:Video soon....
Unless it's super important to you to be able to pedal along at top speed I'd scale up the motor output. It's got the most room to grow, and making gears larger reduces wear vs. making them smaller.
Cheers:)
I've just jumped to a 38t chainring and thats sees 42mph on a sagging battery of 45v.
Any advice on throttle output settings...playing with fast threshold now...seems a little more pokey now but your experience is appreciated
- Contact:
Have you built any with the 80100?tangentdave wrote:It sure could. That motor is an outrunner so we'd have to modify how the housing holds the motor. Should probably cover the spinning finger death also, keep the dirt out. Something like an oiled dirt bike air filter could be perfect...
-dave
A kit without the motor and ESC would be interesting. I would like to try the VESC. If you are able to produce this I would be very interested.
The video is up on Dave's build thread for those interested...
Any updates on this kit, now that there should be plenty of ridden miles?
I'm about 200 miles in and going well barring an issue with the lighter gears but Dave hooked me up with a new stronger set and they seem fine so far.
Kit is great fun and there is no hill I can't climb at 20+ mph.
Running the 3220 version
You did mean there is no hill I can NOT climb...?HamsFitness wrote:Kit is great fun and there is no hill I can climb at 20+ mph.
windtrader wrote:You did mean there is no hill I can NOT climb...?HamsFitness wrote:Kit is great fun and there is no hill I can climb at 20+ mph.
edited
Taken me long enough but finally come around to the advantages of the mid drive. I love lightweight bikes and your setup seems to be the perfect astro solution I've been looking for.
The ability to mount within the frame is fantastic.
Are the discounted mount only kits for ES members still available or am I too late to the party?
- tangentdave 1 kW
- Contact:
Hey Dockers. I'm only selling the kit through ES right now, so there's only one price. PM me or check out the website: http://www.tangentmotors.com
-dave
-dave
GGMT/Tangent 8kW
tangentmotors.com
tangentmotors.com
That started me thinking about installation... so I have some questions...
Here is my first...
Do you think this wiring (see drawing) will work for adapting the Luna hydraulic brake sensors to the CA3
Taking the 5v from the Auxiliary Potentiometer port, Ground from Ebrake Cutoff Port and EBK from the Sensor Lead?
- tangentdave 1 kW
- Contact:
It's even more simple. Here's the relevant info from http://www.electricrider.com/v/vspfiles ... rGuide.pdf
An onboard pull-up means you don't need to supply voltage to the switch: https://learn.sparkfun.com/tutorials/pull-up-resistors
-dave
-dave
GGMT/Tangent 8kW
tangentmotors.com
tangentmotors.com
Thanks,
If I see the colors correctly... only the blue and black are used on the hall effect sensor... the red is spare/unused.
So I trust that is tested, but I am curious how the Hall effect sensor is powered
- tangentdave 1 kW
- Contact:
The pullup circuit will power the hall sensor:
In our case the pullup resistor is inside the CA. Post this question in the 'ebike technical' forum if you don't get the switch working, more smart people prowl over there than the for sale section.
-dave
-dave
GGMT/Tangent 8kW
tangentmotors.com
tangentmotors.com
Just a little update on my Tangent ride:
the 3220 is holding up just dandy. I've recently managed to fry my shunt and ESC but no idea of the actual cause but I am now running the Talon 120 as per Dave's advice with amps limited down from 150 to 120 (although I haven't seen anything higher than 120 for a very long time riding this so that's no problem).
I have been experimenting with differing gearing and still haven't decided which set up I like
Now I am thinking I want a more bad arse frame to house this beauty and better battery set up too!
Any frame suggestions welcome?
I wonder, has anyone tried putting a Tangent in a dedicated ebike frame like a futr or other stealth style set up?
Re: Tangent Motors RC vs stealth bomber b52
I've just got off a stealth b52 bomber to see if enjoyed the hub drive set up...my full thoughts are here:
viewtopic.php?f=3&t=84430&p=1235786#p1235786
But the cliff notes are:
Brilliantly built and solid. Lovely to ride. Suntour gearbox was hard to shift but nice once engaged.
A quiet ride that felt no match for the 3220 powered Tangent. Perhaps it is due to the weight...who knows.
It felt like a very light motorbike with less power. Overall very nice but i feel this mid drive kit is superior in nearly every way and once i figure out a stronger drive chain set up in the higher gears it'll be even further ahead in all possible ways.
Hard to say how good Daves kit is until you've compared it to something of equal power...but at 5 times cheaper and more power/stealth/off road ability...Tangent motors is well ahead of the most expensive "heavyweights".
If you're thinking about buying a Tangent Ascent set up...do it and enjoy the smiles for miles.
Another little update for anyone pondering the IGH question: Will they hold up to the power?
I now have an Alfine 8 set up and test rode it for just under 20 miles offroad today and what a different experience it is...held up fine to today's riding and hopefully many more miles.
A much easier and slicker set up for me personally with this. Very pleased but I have no clue how long it will last for
Keep us updated! Upgrading to something like that in the future is appealing, though my derailleur is holding up okay for now.Ham wrote:Another little update for anyone pondering the IGH question: Will they hold up to the power?
Will do. My derailleur was fine too but I loved the simplicity and clean chain line the hub offers and once I have the twist shifter installed...the cleaner handlebars also.
Plus less cleaning of a mud clogged rear cassette
So far so good. Very impressed and has only added to the blast that is Tangent
- ElectricGod 1 GW
Cool kit...I have a couple of 3220's this would work with.
XB-502: viewtopic.php?f=10&t=83302&p=1222730#p1222730
Currie scooter: viewtopic.php?f=35&t=83830&p=1227407#p1227407
Benjamin Franklin - "Any fool can criticize, condemn and complain and most fools do."
