Vedder Anti-Spark switches. Extras for sale.
sl33py   10 kW
Post by sl33py » Oct 28 2015 1:32am
Hi All. Got a couple made because i really wanted to build my own. PCB's are inexpensive and had a few extra made.
Offering up the extras to the community for i hope a reasonable "kit" price. $25 ea plus cost to ship to you. Flat rate shipping in the US $4 (for as many as you'd like).
Any international folks - shipping i'll get the exact price to your destination and that's all you pay. Just PM me your address when you let me know you want 1/2/3.
I've already had a lot of folks PM me from my build thread. It will be first come first served. PM me. Hope this helps someone else get a great anti-spark switch.
This is not a business or make it rich quick plan. It may take a day or two to package and ship - since i have a real job (also busy), but promise i'll get it sent off asap.
Also - I plan on donating 1/2 of any profit to Vedder - this is his work, not mine. I'd like a few bucks for my time and shipping materials. I expect i'll get $5-10 maximum each (split w/ Vedder) which i hope to put into a reflow oven. I have about 20 extras. I've already donated 50 euro to Vedder and hope to get another chunk to donate to a hard working guy who's made this available to us all!
So here's what i have: PCB's, and components from Mouser:
I'll make sure they are all labeled and taped down, plus in original reel containers.
You will need to get the rest - switch, wire, connectors, fuse (simple ATO), and solder paste:
You will need ability/tools to do SMD soldering. Hot air setup or reflow oven, or reflow skillet... or maybe just super steady hands and a super fine solder tip. I used hot air on mine for the SMD's.
There you have it! PM me if interested and i'll edit when they are all gone. Thanks all!
makithepaki   1 mW
Re: Vedder Anti-Spark switches. Extras for sale.
Post by makithepaki » Nov 16 2015 8:06pm
i would be intressted in making my own. Where can i get the plans
JackDaviesDesign   1 µW
Post by JackDaviesDesign » Dec 16 2015 11:00am
https://github.com/vedderb/SparkSwitch
cycborg   1 kW
Post by cycborg » Dec 16 2015 2:14pm
Are the FETs IRFS7530? Note that these have a voltage rating of 60 V, so they're probably safe up to 12s. Unfortunately, IR doesn't have a similar FET with the same footprint with a 100 V rating. For a 75 V rating, you can substitute IRFS7730-7P, which should be safe up to 15s.
Anybody know of higher-voltage FETs with the same footprint and reasonable Rdson?
perbear   100 mW
Post by perbear » Dec 16 2015 2:33pm
cycborg wrote:Are the FETs IRFS7530? Note that these have a voltage rating of 60 V, so they're probably safe up to 12s. Unfortunately, IR doesn't have a similar FET with the same footprint with a 100 V rating. For a 75 V rating, you can substitute IRFS7730-7P, which should be safe up to 15s.
These covers 80-100V;:
AUIRLS4030-7P
AUIRFS4010-7P
AUIRLS4030-7TRL
IRLS4030TRL7PP
IRLS4030TRL7PP
IRLS4030TRL7PP
IRFS4010TRL7PP
IRFS4010TRL7PP
IRFS4010TRL7PP
IRFS4010-7PPBF
IRLS4030-7PPBF
FDB024N08BL7
FDB024N08BL7
FDB024N08BL7
teklektik   10 GW
Post by teklektik » Dec 16 2015 3:07pm
sl33py wrote: Also - I plan on donating 1/2 of any profit to Vedder - this is his work, not mine. I'd like a few bucks for my time and shipping materials. I expect i'll get $5-10 maximum each (split w/ Vedder) which i hope to put into a reflow oven. I have about 20 extras. I've already donated 50 euro to Vedder and hope to get another chunk to donate to a hard working guy who's made this available to us all!
Frankly, it would be very nice if folks started referring to this as the Fechter-Vedder Anti-Spark Switch since the fechter designed the circuit and vedder did the board.
Here is the post where vedder switched his design to fechter's. Vedder links to fechter's post in his github directory where the PCB files are located (https://github.com/vedderb/SparkSwitch).
I'm a big fan of the contributions made by ES members....
What say we recognize ALL the guys on the team?
fechter
Inrush Limiter 3.jpg (20.36 KiB) Viewed 10341 times
vedder
Ryuudan   1 W
1 W
Post by Ryuudan » Aug 12 2016 1:20am
Do you still have them? I would build my own, but don't have the tools or experience in SMD soldering.
akiraEC   100 W
Post by akiraEC » Aug 13 2016 3:53pm
Where are you located ?
Envoyé de mon ASUS_Z00AD en utilisant Tapatalk
Ryuudan   1 W
1 W
Post by Ryuudan » Aug 17 2016 6:01am
I'm in Japan.
Thud   100 MW
Post by Thud » Aug 17 2016 8:34am
Credit where credit is due. Fechter simply modified original art from Jeremy Harris.
viewtopic.php?f=3&t=40142#p586436
notice Jeremy's circuit is from 2012
get some......
RootedSuperuser   10 W
Post by RootedSuperuser » Apr 22 2017 2:47pm
I noticed on your site that you have updated the switch, refined it a bit more.
Although for me, I would wire in a key switch and do my own pigtails, its for a bike pack.
Without wires/pushbutton and comes with a wiring schematic would be fine for me,
You don't post any ratings for the item, I'm presuming a BMS that outputs 58.8V(Max) 30A from a 14S6P battery pack may be the limit of your device.
My question to you is: Will this item be applicable for my use?
teklektik   10 GW
Post by teklektik » Apr 22 2017 6:42pm
Thud wrote: Credit where credit is due. Fechter simply modified original art from Jeremy Harris.
Completely wrong.
Examine the schematics - they are obviously different.
Read the explanations in the thread.
Fechter's design fixes a problem in Jeremy's design by forcing a linear gate voltage. This is the magic that prevents the circuit from eating FETs.
This is not 'modified art'. It is a fundamental design change that significantly alters the way the circuit operates.
Jeremy's circuit follows the same path that Vedder was pursuing before he switched to Fechter's concept - read Vedder's comments in the referenced thread above.
Post by RootedSuperuser » Apr 22 2017 7:03pm
Completely wrong.
DUDE .... I REALLY DON'T CARE WHAT YOU HAVE TO SPEW ABOUT!
If you don't have something to provide as answer to my question....STOP SPAMMING WITH USELESS INFO I DID NOT REQUEST.
So in this case ... WILL EITHER OF THEM WORK FOR ME!
t_tberg   100 W
Post by t_tberg » Apr 22 2017 11:58pm
Completely wrong.
teklektik does more for this community than you could imagine. The world doesn't revolve around you, Rootedstupiduser
Post by RootedSuperuser » Apr 23 2017 12:07am
Completely wrong.
DUDE...WTH is your problem?!
He has a sale here and all you want to do is f###ing annoy the buyer...ME!
Now *iss off and let him answer my question and make a sale, or I will be the leaving to spend my money elsewhere and he can point his finger at you for losing a sale!
Don't you know when to back off and keep your mouth shut?
madin88   1 GW
1 GW
Post by madin88 » Apr 23 2017 4:27am
Man, you should get banned from this forum because of your way of expressing!
teklektik corrected a false satement, so it was anything but spam.
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
t_tberg   100 W
Post by t_tberg » Apr 23 2017 11:24am
Don't you know when to back off and keep your mouth shut?[/quote]
sl33py isn't looking for a quick buck he made that clear here
I don't think he'd care about loosing a sale, I'm sure everyone would love to see less of you around here
Doctorbass   100 GW
Post by Doctorbass » Apr 26 2017 6:41pm
Please keep respect in mind ...
Teklektik.............Posts: 3314
RootedSuperuser Posts: 32
RootedSuperuser, you are new here and have the same goal as everyone here: share, have fun with ebike and be happy....
Teklektik has done ALOT for the E-S community..!!!
I guess if you would better know him you would correct your language and have big respect for him.
Innapropriate Language on E-S has never been tolerated.
Lets be constructive, 8)
RootedSuperuser, please find a way to improove communication and make everyone happy, including you. :wink:
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
cal3thousand   1.21 GW
1.21 GW
Post by cal3thousand » Apr 27 2017 12:45pm
Completely wrong.
Another person here to chime in regarding teklektik's MASSIVE contributions to this community INCLUDING dispelling bad information and quackery.
@RootedSuperuser Stop waiving your consumerist flag around here. Knowledge and respect speak on this forum, not dollars. I suggest you shut your loud wallet and pay with respect (in your choice of language and angles of communication)
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
neptronix   100 GW
Post by neptronix » Apr 28 2017 12:29am
rootedsuperuser, this thread is not about you. If you don't like a post, scroll by it. I don't want to see any more drama in this thread.
Let the guy sell his stuff in peace and let's move on.
tomjasz   10 GW
Post by tomjasz » May 15 2017 2:16am
Kind of a confusing thread, who has the pcb kit or finished device. I have no flow over. Can i still build or is there a finished kit or partially finished?
1.21 GW
Post by cal3thousand » May 15 2017 1:50pm
tomjasz wrote:Kind of a confusing thread, who has the pcb kit or finished device. I have no flow over. Can i still build or is there a finished kit or partially finished?
From what I understand:
It's $25 for a the parts you see taped to the paper. You'd have to build it yourself. $29 gets you one to your door, $54 for 2, and $79 for 3.
cycborg   1 kW
Post by cycborg » May 15 2017 2:45pm
As to whether you can build it, there's this:
sl33py wrote:Hot air setup or reflow oven, or reflow skillet... or maybe just super steady hands and a super fine solder tip. I used hot air on mine for the SMD's.
So there are a couple non-oven options.
That said, sl33py hasn't posted on this thread in a year and a half, so I wouldn't be optimistic. He said he only had "a couple" made, so this thread kinda looks like a week of sales, followed by months of drama. :?
tomjasz   10 GW
Post by tomjasz » May 19 2017 11:23pm
Thanks,
I try every year to get into the senior program at the community college in electronics but it's apparently on paper. Seats available only if class isnt filled. So... horticulture and electronic skills are mega miles apart. I envy those who've gained the skills. I'll just admire the work...
