Qulbix Q76R Frame Kits & Complete Bikes PRE-ORDER
icherouveim   1 kW
Re: Qulbix Q76R Frame Kits & Complete Bikes PRE-ORDER
Post by icherouveim » Aug 31 2018 7:23am
Merlin wrote:
Aug 30 2018 5:19am
before you spend your 400 on a new dnm.....please do yourself a favor and buy a rock shox/Fox used.
its like buying a new car for 8500 ....a 40kw chinese plastic car compared to a used mercedes/Audi/BMW etc...
you feel the difference even without riding.
I am really surprised because for the last years I hear DNM is the best value for money brand for an ebike build.
Is it finally so bad compare to other manufacturers ? I haven't tried something else but my DNM USD-6 works pretty well.
Also why the most of the online ebike shops sell DNM suspensions?
Merlin   1 MW
Post by Merlin » Sep 01 2018 4:07pm
Because if you are a dealer you get it half the price.
It is what it is... Not more or less.
It works yes... But if you ever tried a fox or rs you will even as a beginner feel instantly the difference.
I never saw a dnm on a dh bike.
I don't want to bash these forks because I say it again. For that price it is what it is.
Cruising in your hometown going out for an icecream it's totally OK :p
BUT when you are open for 400 bucks on a fork it is simply a mistake not buying "something other"
Buy a dnm used for 150 no problem... But new it's for me just a bad deal.
What is really impressing is the dual brake....
You can throw out all single 4 piston brakes on the market (hope Shimano, magura etc when the dual brake comes to action.
You can easy flip your bike over with a 20kg/40lbs rear wheel.
Allex   1 GW
1 GW
Post by Allex » Sep 02 2018 2:54am
Good price on Manitous now, they were around 1500USD before:
https://www.aliexpress.com/item/Manitou ... autifyAB=0
L3chef   10 W
Post by L3chef » Sep 02 2018 2:58am
Allex wrote:
Sep 02 2018 2:54am
Damn. Those look so sweet
icherouveim   1 kW
Post by icherouveim » Sep 02 2018 8:55am
Allex wrote:
Sep 02 2018 2:54am
it's a great deal!
Does it have similar performance with fox and rs?
Allex   1 GW
1 GW
Post by Allex » Sep 02 2018 3:34pm
Yes, they are great, Manitou Dorado has won countless World Cup races...
Check this review
http://www.downhillnews.com/reviews/201 ... eview.html
L3chef   10 W
Post by L3chef » Sep 05 2018 11:38pm
@offroader
Do you have any pics showing how you did your terminals on that battery pack?
Edit. How do I tag someone in a post?
Offroader   10 MW
Post by Offroader » Sep 06 2018 2:23pm
L3chef wrote:
Sep 05 2018 11:38pm
@offroader
What exactly do you mean terminals? I got pics of pretty much everything so I just need to know what you want.
L3chef   10 W
Post by L3chef » Sep 06 2018 2:34pm
Offroader wrote:
Sep 06 2018 2:23pm
L3chef wrote:
Sep 05 2018 11:38pm
@offroader
I meant positive and negative leads. Went through the thread again and found the pic. Must have missed it the first time
L3chef   10 W
Post by L3chef » Oct 08 2018 2:04am
Should I get 155 or 165 mm drop outs with a mxus v3 motor, disc brakes and freewheel.?
Merlin   1 MW
Post by Merlin » Oct 08 2018 5:33am
155...
L3chef   10 W
Post by L3chef » Oct 09 2018 12:00am
Perfect. Order placed!
cmacclel   100 µW
100 µW
Post by cmacclel » Nov 14 2018 9:49pm
I ordered the frame over 2 weeks ago I'd really like to look at the manual if anyone has the password. I've Emailed Qulbix over a week ago with no response. What would be the recommended rear shock Length? I've seen 240mm and 265mm for the DNM BURNER-RCP2S.
Thanks
Merlin   1 MW
Post by Merlin » Nov 16 2018 5:50am
240.
forget the 267length. its way to high/long.
if you wanna go higher the last of 3 mounting points is high enough for 2m ppl.
cmacclel   100 µW
100 µW
Post by cmacclel » Nov 16 2018 8:21am
Merlin wrote:
Nov 16 2018 5:50am
240.
Thanks I ordered the 240mm last night.
Offroader   10 MW
Post by Offroader » Nov 16 2018 8:30pm
cmacclel wrote:
Nov 16 2018 8:21am
Merlin wrote:
Nov 16 2018 5:50am
240.
Yes 240 is the smart move. I use a 267 and it works but I guess because there is so much rear travel I had difficulty to get the chain tensioned properly with my rear derailleur but I just was able to get it. I had no more adjustment though.
Offroader   10 MW
Post by Offroader » Dec 02 2018 11:22am
Would anyone know if the suspension on the Q76. Would that be considered a linear suspension or a progressive suspension?
Progressive would be where as the suspension gets compressed it gets harder to compress.
While a linear suspension would compress at the same rate through the travel.
efMX Trials Electric Freeride   100 kW
Post by efMX Trials Electric Freeride » Dec 02 2018 1:13pm
Offroader wrote:
Dec 02 2018 11:22am
for a progressive rear suspension system you would likely need some suspension linkage(s) beyond single pivot, or progressive spring and or damping.. of course when you add motor power that can also influence the rear suspension..
suspension 101 :
https://blisterreview.com/recommended/s ... 01-designs
some ride & sk8 videos:
metacafe.com/channels/NATAS666DAMIEN
http://www.youtube.com/natas666damien
i have nothing for sale.. :)
L3chef   10 W
Post by L3chef » Dec 09 2018 3:51pm
Does anyone use a bms with their 76 frame? If so, where do you mount it?
Offroader   10 MW
Post by Offroader » Dec 09 2018 9:14pm
I never mounted it but it depends on how much room you have in the battery compartment. I don't have enough room in the battery compartment so I was going to put it inside that space at the very bottom of the bike through the hole.
L3chef   10 W
Post by L3chef » Dec 10 2018 2:07am
I'm copying your battery build, except I will use Samsung 30q and I will parallel connect them.. So it will be difficult to fit a bms anywhere inside the frame. Also I cant find a smart bms that would fit width wise.
MinoRoad   100 µW
100 µW
Post by MinoRoad » Dec 10 2018 2:51am
Here is a great Ant Bms where many use and it fits exactly in Qulbix Q76r frame.
https://de.aliexpress.com/item/Smart-Di ... 4c4dIo0EFi
L3chef   10 W
Post by L3chef » Dec 10 2018 3:18am
Thanks mate! Appreciate it
MinoRoad   100 µW
100 µW
Post by MinoRoad » Dec 10 2018 9:56am
you are welcome :thumb:
Offroader   10 MW
Post by Offroader » Dec 10 2018 11:10am
L3chef wrote:
Dec 10 2018 2:07am
I know the MAX-E BMS fits in this location as I put it in there to see if it would fit. I would of course keep it encased in foam and make sure it is in there so it doesn't bounce around, you will have to push foam in there.
In the picture I circled in red the location I was going to put it.
