Qulbix Q76R Frame Kits & Complete Bikes PRE-ORDER
MJSfoto1956   100 W
Re: Qulbix Q76R Frame Kits & Complete Bikes PRE-ORDER
Post by MJSfoto1956 » Feb 17 2019 9:41am
madin88 wrote:
Feb 14 2019 5:43am
... on BMS with common charge and discharge port, the discharge current has to flow through two banks of Mosfet's, whereas on BMS with separte ports for controller (P-) and charger (C-), the discharge current just has to flow through one bank. This means they can reduce the number of Mosfet's on the bank for the charge port which would explain the lower price.
common port:
pros: usually identical max allowed charge and discharge currents, protection against overcharge from regen (or charge via controller)
cons: more heat at given discharge current
separte port:
pros: less heat a given discharge current
cons: usually lower max allowed charge current, no protection against overcharge from regen
Thanks for the succinct explanation!
M
hgclobo   1 mW
Post by hgclobo » Feb 19 2019 12:52pm
So, last week I got my frame kit and today I just got the 200A SPIM08HP packs, I test fitted them and even though I pre measured everything before buying the batts I was still a bit nervous they weren't going to fit but check the pictures out, im glad to get them in with space to spare for the BMS, of course its no 36Ah pack, its only 8Ah but I think its going to be a super fast build, I can now take my time sourcing and building a 240 cells 30Q pack.
Next step is to paint my frame and rims before starting the build, pictures when done...
TheBMallory   10 W
Post by TheBMallory » Feb 23 2019 1:52pm
Started building the parallel packs (have not put them in series yet) :
I'll probably have to double every nickel strip, especially those in series. Kweld works great btw
MJSfoto1956   100 W
Post by MJSfoto1956 » Feb 23 2019 4:27pm
madin88 wrote:
Feb 14 2019 5:43am
common port:
separarte port:
This may seem like an odd question but it is important for my particular use-case:
  • Can you discharge (i.e. power some load) while charging with a "common port" type of BMS?
(I'm 99% certain you can with a "separate port" type)
Michael
L3chef   10 W
Post by L3chef » Mar 02 2019 6:25am
TheBMallory wrote:
Feb 23 2019 1:52pm
Started building
Any updates on the battery pack build?
TheBMallory   10 W
Post by TheBMallory » Mar 03 2019 8:36am
Not really, I can only work on it a few hours during weekends and I'm waiting for the BMS to be delivered.
Here's a pic :
This side is finished since then. I still have to do the other side.
I doubled every series connection.
I purposely left some space on the top right corner in order to have some space to fit some electronics, maybe the BMS if it fits.
That is a LOT of spot welding. I'm glad I got a proper tool
Rix   100 GW
Post by Rix » Mar 03 2019 5:27pm
Battery looks great.
hgclobo   1 mW
Post by hgclobo » Mar 04 2019 2:29pm
Paint (lime green plastidip), statorade and hubsink done.
Next step is to lace the wheels, pictures when done...
1st green coat
4th and last green coat
just hanging
26in and 19in rims
finished, 4 gray coats and 4 green coats
statorade
hubsinks
hgclobo wrote:
Feb 19 2019 12:52pm
Rix   100 GW
Post by Rix » Mar 04 2019 3:47pm
Going to be sweet!!!!
Merlin   1 MW
Post by Merlin » Mar 08 2019 9:23pm
hubsinks allready installed?
you cant lace a wheel now :D
spraypainted the frame and rims? mhhh....powdercoat will last wayyyy longer.
hgclobo   1 mW
Post by hgclobo » Mar 08 2019 11:03pm
Damn, didn’t think the sink was going to be an issue with the lacing, no biggie, I’ll remove it, lace it and place it again.
And about the paint, well plastidip is not meant to be permanent, just a super easy way to paint over what you already got and super easy to remove and repair, under tge plastidip I still have the original black/white powdercoat.
Merlin   1 MW
Post by Merlin » Mar 09 2019 4:21am
Was too late for me. Missed that you are using dip.
I like dip but have no experience. But lacing a wheel with spokes I wonder if it will last without scratches.
Let me know how it ends + pics. =)
TheBMallory   10 W
Post by TheBMallory » Mar 16 2019 2:28pm
Battery almost finished, can someone please tell me I didn't screw up cable management for the BMS ? It was really a pain... I now have high and low spots and I intend to use the same solution as Offroader
I have yet to solder the power cables and I'll shrink wrap everything
Offroader   10 MW
Post by Offroader » Mar 16 2019 5:00pm
You have to check the voltages of the wires to make sure the BMS wires are correct. They should rise about 4 volts each successive wire or how much your voltage is.
Why do you mean high and low spots?
TheBMallory   10 W
Post by TheBMallory » Mar 17 2019 2:07am
Yes voltage is correct. By high and low spots I mean that the sides are not completely flat anymore and vibrations could make some cables rub against each other. I saw you put some foam in some places in order to prevent that
TheBMallory   10 W
Post by TheBMallory » Mar 17 2019 6:27am
Test fit.
Putting the BMS inside is going to be fun, although there's room.
Rix   100 GW
Post by Rix » Mar 17 2019 9:56am
TheBMallory wrote:
Mar 17 2019 6:27am
Test fit.
Very nice Mallory, call your build "offroader II" thats a lot of battery. I like it.
