Bomber Style Frame Set (EBB) Black - $500 - 2 left
999zip999   100 GW
Re: Bomber Style Frame Set Black/White - Sold Out
Post by 999zip999 » Aug 15 2016 10:59am
Reasonably priced.
Powervelocity.com   10 kW
Post by Powervelocity.com » Aug 15 2016 1:02pm
The frame is well overbuilt for the purpose. I have a couple left if someone wants to buy ;)
I put a monstrous 50lbs battery pack in it, and all the other heavy stuff like QS motor and MC tires. Still holding up fine.
The other thing is that it has probably the largest battery compartment out there. No other frames I have seen can fit as many 18650s.
Here is the build thread: https://endless-sphere.com/forums/viewt ... =6&t=79612
Microbatman   1 kW
Post by Microbatman » Aug 16 2016 9:54am
Just a comment on Powervelocity
Their customer service with ES members is 1st class.
I purchased a 18FET 4115 sine wave controller and they provided excellent support to get it up and going.
Returned all PMs in a timely manner.
And their instructions on how to hook up my controller were clear and worked!!
MotorCrystalyte X5304 20 Inch Rear Wheel DISC Brake Controller Crystalyte 48A72V4110MOSFETS
Batteries A123 24s2p
Charger Mastech 5020
Frame Azonic Steelhead
Grateful/fortunate/blessed to have the resources and family support to enjoy my ebike hobby
DasDouble   100 kW
Post by DasDouble » Aug 16 2016 12:33pm
@Velo how did you mount the charger inside? And what charger did you use that it is able to manage the vibrations?
+ Did you had to turn a switch or so before riding so the controller doesn't get damaged because of the plugged in psu?
-Elias
Mechatronics-Engineering Student
-Built own ebike: ✔
-Built own 3.2kWh LiIon battery (300Amps): ✔
-Overtake Porsche with own Ebike: ✔
-Take off with ebike: ✖
~14kW, 3.2kWh LiIon, QS 205 8ml ff, hubsink
Green Machine   100 kW
Post by Green Machine » Aug 17 2016 3:59am
I personally think these frames are way way overbuilt.....
there is nothing to worry about in terms of stength.
I would like to see them a lot flimsier i mean lighter.....
Post by Powervelocity.com » Sep 01 2016 12:19pm
We have a couple of frames left from several custom builds we did.
Both are new in boxes, black color. $500 each. This is the best value in the market today.
Local stock in the Northern California (Sacramento area).
PM if interested.
rzc2fk   1 µW
Re: Bomber Style Frame Set (EBB) Black - $500 - 2 left
Post by rzc2fk » Oct 13 2016 6:09pm
Pick up the last one with sweeten deal by the kickstand in the package.
tomjasz   10 GW
Post by tomjasz » Oct 13 2016 6:33pm
After watching the fire in a vented steel body, bye bye ABS! Nope.
Skaiwerd   100 W
Post by Skaiwerd » Jan 05 2018 5:38pm
Green Machine wrote:
Aug 17 2016 3:59am
Look at horizon ebike frame on eBay. There is a smaller frame out now that seems to be the lightest. Russian made. Hummm. The side plates are not my thing but. Mid drive with the motor mounted on the swingarm has me wondering. Probably have to lengthen it. Anyone fitting 27.5 plus tires at three inches wide? It’s only 3/4 inch bigger from axle to inside swingarm.
exe   10 W
Post by exe » Jan 05 2018 9:33pm
Lots of issues with the Russian frame. The side panel is made of 2 stamped aluminum pieces (frame is steel). The inner fake carbon fiber stuck on a stamped aluminum piece, it is using double sided tape to keep it on the side of the other outer piece. Double sided tape, I kid you not. All for aesthetic reason. Mine fell down just sitting on the floor before assembly. Plus, water is going to get in between the two aluminum side pieces (per side). They could have just had a one piece design, and you can put whatever sticker design you want on it yourself instead of introducing waterproofing and fastening problems. Plus did you notice the philips side cover screws used?
Skaiwerd   100 W
Post by Skaiwerd » Jan 06 2018 5:20pm
Powervelocity.com wrote:
Jan 06 2018 2:19pm
Yep, you get what you paid for. This has always held true.
Only window shopping now. The side covers are no big deal. I could make my own using Kydex molding it by heating it in my oven and shaping it to a wooden positive shape. Afternoon project type of thing. My vague point is if you are going to cut and weld to suit your needs a cheap bike just makes sense. I’d love to try to mid drive a smaller frame bike like the futr beta, but it’s common sense to spend $500ish vs $1500 for the frame, also they have a proprietary bottom bracket it appears that would be an issue. Some just assemble and ride, not me. I need a challenge. I hate the feeling of my ebike not rideable, fixing after a crash ( 2 broken garvin forks, yeah no more), or upgrading like shortening wires and eliminating plugs etc to name some examples. I’m planning my 2nd build so the anxiousness to get it going to go ride right away is not there. I’m not dissing that enduro frame with molded plastic side covers, Luna sells it and it’s crazy marked up on amazon at $800. Or at least another copy it’s hard to tell.
DasDouble   100 kW
Post by DasDouble » Jan 07 2018 8:50am
555USD for Frame + Shock + fender + Motor + Controller? Damned, thats cheap!
Or is it only the frame? If so, no need for that.
-Built own ebike: ✔
Skaiwerd   100 W
Post by Skaiwerd » Jan 07 2018 12:12pm
DasDouble wrote:
Jan 07 2018 8:50am
Just the frame. For diy builds. Just shows the typical enduro frame is getting a smaller version. Now there are two choices. With more bang for your buck rides like the Sur-Ron edirtbike the diy build to suit market may suffer. On the flip side it makes the market work harder to come up with new products for the real builders who think their builds are better, cheaper or both. I like that if you build it you really should be able to fix it. Once frames can be easily altered for mid drives we should see some interesting bikes. The guys here are doing it with their high end set ups but a cheaper solution is for the masses. Perhaps a cyclone on a swingarm.
Skaiwerd   100 W
Post by Skaiwerd » Jan 07 2018 2:32pm
Jan 07 2018 1:44pm
You mean something like this? LightningRods has been offering middrive kits for pretty much all major DYI frames for a while now.
https://endless-sphere.com/forums/viewt ... start=4800
There are the pioneers here that we look to for inspiration. Lightningrods is one of them. I’m after what’s next. The innovators are working on that now I hope. I’m looking out to see for sure.
