Sabvoton Sinewave Controller FOC 12-16KW $379 Programmable
evolutiongts   10 kW
Post by evolutiongts » Dec 31 2015 6:20pm
For sale are a few Sabvoton Controllers new in box. $379
Plug and Play with Cycle Analyst from the Factory
Factory Unlocked can run 200A on the 72V150A and 150A on th 96V100A
Variable Regen
https://electricrt.com/blogs/news/sabvo ... figuration
https://electricrt.com/blogs/news/sabvo ... -tech-info
Track Proven Performance
150A maximum battery amps and 350A maximum phase amps. 450A Peak Phase Current
Fully Unlocked from the factory for up to 200A maximum battery amps.
Excellent controller for high performance electric bike performance
Can also be used in scooter, gokart and other electric vehicles
Controller Weight: 4.6LBS
Controller Dimension: 145x16x50mm
One of my all time favorite controllers can run all day at the racetrack 7500w-10000w peaks all day long.
Cromotor
Only at 6600W, full power (150 Battery amps / 350 Phase A is insane!)
Cromotor
Transmit Mid Drive
For sale on my website but I'm selling here to my ES'ers at discounted rate
http://laebike.com/products/programmabl ... -150a-350a
http://www.electricrt.com
Electric Race Technologies
Schwinn 405 2WD Track Bike 18KW
EDGE 1500W Hub / MXUS 3K Turbo
ASI BAC 2000 / BAC 4000 Bluetooth
viewtopic.php?f=6&t=93079
10Kw KMX death trike
MUXUS 3K Turbo
Sabvoton 72V150A
Moto Wheels all around
Front Suspension Kit
viewtopic.php?f=6&t=83423
Giant Trance 4 Full Suspension
Cyclone 3000W
74V 3000W
http://endless-sphere.com/forums/viewto ... =6&t=59005
jansevr   1 kW
Re: Sabvoton 72V150A New in Box $375
Post by jansevr » Dec 31 2015 10:08pm
Nice controller. Unfortunately I run 84v. Do you have any higher voltage sabvoton controllers or know where I can get one? Thanks.
evolutiongts   10 kW
Post by evolutiongts » Jan 01 2016 1:23am
This controller can run up to 95V maximum before cutting off. I ran my controller at 82V fully charged and works no problem. I run 125amps on this controller with 20S Lipo @ 10000w and its brutally powerful.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
LiFeCycle   1 W
1 W
Re: Sabvoton Sinewave Controller FOC 72V150A $375 Programmab
Post by LiFeCycle » Jan 03 2016 6:45pm
Hey evolutiongts
Any idea whether the halls are opto-isolated on this controller? I shorted the halls to one of the phase wires, and now the controller is showing an error code with 5 flashes of the LED.
If the computer is opto isolated it may be fix-able, otherwise I'm in the market for one of these as a replacement.
Cheers
jansevr   1 kW
Post by jansevr » Jan 03 2016 6:56pm
Does this run sensorless or only with hall sensors?
evolutiongts   10 kW
Post by evolutiongts » Jan 04 2016 12:33am
LiFeCycle wrote:Hey evolutiongts
Cheers
I'm finding out now, will let you know.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
evolutiongts   10 kW
Post by evolutiongts » Jan 04 2016 12:34am
jansevr wrote:Does this run sensorless or only with hall sensors?
Hall sensor only
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
evolutiongts   10 kW
Post by evolutiongts » Jan 04 2016 10:50pm
Cheers
LED 5 indicates over-temp
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
LiFeCycle   1 W
1 W
Post by LiFeCycle » Jan 05 2016 12:03am
Cheers
Thanks for confirming. Do you have access to a technical service manual for this controller?
evolutiongts   10 kW
Post by evolutiongts » Jan 06 2016 6:07pm
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
evolutiongts   10 kW
Post by evolutiongts » Jan 08 2016 12:32pm
This would make a great combo for MXUS 3000W or Cromotors. Will be testing it with my QS V3 Extra motor. 125A peaks, 12KW.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
evolutiongts   10 kW
Re: Sabvoton Sinewave Controller FOC 72V150A $350 Programmab
Post by evolutiongts » Jan 11 2016 11:26pm
Bump
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
macribs   1.21 GW
1.21 GW
Post by macribs » Jan 12 2016 12:19am
evolutiongts wrote:This would make a great combo for MXUS 3000W or Cromotors. Will be testing it with my QS V3 Extra motor. 125A peaks, 12KW.
Be sure to update thread when you have tested with the QS v3 Extra. Btw PM send.
markz   100 GW
Post by markz » Jan 12 2016 4:55am
Whats the lowest voltage it can run at?
I guess it doesnt matter really, because the Cycle Analyst can limit it.
evolutiongts   10 kW
Post by evolutiongts » Jan 12 2016 1:44pm
I believe it can run as low as 36V
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
evolutiongts   10 kW
Post by evolutiongts » Jan 15 2016 10:36am
I run paired up with my Transmag Mid Drive Motor @72V
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Mammalian04   100 kW
Post by Mammalian04 » Jan 15 2016 1:12pm
Is that sped up? If not, that is some power out the gate.
evolutiongts   10 kW
Post by evolutiongts » Jan 15 2016 1:32pm
Mammalian04 wrote:Is that sped up? If not, that is some power out the gate.
I never speed up my videos it has that much torque and that's only on 72v I can run 96v
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Mammalian04   100 kW
Post by Mammalian04 » Jan 15 2016 2:35pm
Phew! Punchy!
evolutiongts   10 kW
Post by evolutiongts » Jan 25 2016 3:31am
Bump for a cheap and powerful, sine wave controller programmable with flux weakening
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
macribs   1.21 GW
1.21 GW
Post by macribs » Jan 25 2016 4:16am
Have you gotten around to test this with the QS v3?
evolutiongts   10 kW
Post by evolutiongts » Jan 26 2016 5:27pm
Not yet hopefully I'll get around to it soon
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
evolutiongts   10 kW
Re: Sabvoton Sinewave Controller FOC 72V150A $299 Programmab
Post by evolutiongts » Jan 27 2016 4:27am
I really have to move a few of these so price is lowered to $299. 10-12KW sine wave controller, works great with MXUS 3000, Cromotor, mid drives, any 3 phase motor really. Easy to program, excellent software, includes USB programming cable. You will need a shunt adapter to hook up to a Cycle Analyst, has a hall wire so you can hook it to a CA-DP.
This is a high performance controller, I never had any issues with controller.
Works up to 95V
Battery Amps 150A Max
Phase Amps 350A Max (lots of wheelies!)
Programmable Regen, Regen works all the way down to a stop
Variable Regen (Not tested)
Flux Weakening (For more top speed at the expense of efficiency)
Adjustable Throttle Curve
Reverse
3-Speed
Virtually Silent
Smooth Torque Throttle for excellent control
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Merlin   10 MW
Post by Merlin » Jan 27 2016 9:06am
the SVMs have no Variable Regen.
But the 72150 works PERFECT with a CroV4 / Q3 205. Absolutley silent from dead stop.
evolutiongts   10 kW
Post by evolutiongts » Jan 27 2016 1:28pm
Merlin wrote:the SVMs have no Variable Regen.
The SVM I got from Greyborg a year ago has variable regen (transparent wire). These are the latest production units off the factory (Dec 2015)
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
