Nucular electronics - complete kit for ev! [beta]
maitilupas   100 W
Re: Nucular electronics - complete kit for ev! [beta]
Post by maitilupas » Oct 23 2018 10:25pm
VasiliSk wrote:
Oct 23 2018 9:01am
maitilupas, which one do you want? i will add you to queue and PM when ready to ship it.
the 12f please!
thank you
VasiliSk   100 W
Post by VasiliSk » Oct 24 2018 4:45am
Added.
Ok well, i decided to make separate chat for English users. here we go: https://t.me/nucularelectronics_en
BCTECH   100 W
Post by BCTECH » Oct 24 2018 10:07am
is it difficult to add a time clock built-in to the LCD display? I found this will be a very useful feature that is not yet mentioned.
VasiliSk   100 W
Post by VasiliSk » Oct 24 2018 10:09am
This feature planned for BMS, since there is a BIG battery for clock :)
Display will show time from BMS
Aeron   100 mW
Post by Aeron » Oct 25 2018 4:30am
VasiliSk wrote:
Oct 23 2018 9:01am
Casing much bigger than pcb. I will try to make a smaller one, but not sure if i can keep same power for small case
It looks really nice.
IMO, the size is fine. I'd rather have the "full power" than a smaller case.
I guess heat dissipation is the problem with a smaller case ? (hence the reduced power ?)
VasiliSk   100 W
Post by VasiliSk » Oct 25 2018 4:36am
Not only dissipation, capacitors for small casing should be less height, so more stress for them
Aeron   100 mW
Post by Aeron » Oct 25 2018 4:52am
That makes sens, thanks (I'm not electronics savvy ^^).
one more question, you mention in the 6F descritption:
Voltage range 20-70V / 20-90V
I'm not sure I understand. Can I run a 20S battery ? (so around 84V full charge)
ElectricGod   10 MW
Post by ElectricGod » Nov 06 2018 2:08am
I have 3 controllers coming soon...yippee!
ElectricGod...it's a joke...don't take things so seriously folks!
XB-502 Moped:
https://endless-sphere.com/forums/viewt ... 0#p1222730
Currie scooter:
https://endless-sphere.com/forums/viewt ... 7#p1227407
madin88   100 MW
Post by madin88 » Nov 06 2018 7:11am
I have got a 12F unit and got it running with success. Setting it up was not hard after reading through the setup guides on wikidot - a few times :D
The unit works great and i am happy. Performance is smooth but still torquey and efficiency seems to be on a high level. Can recommend it!
I started a second thread for owners:
viewtopic.php?f=2&t=97163
It may be a good idea to also use this thread for any other news like new fw updates, suggestions / wishes or bug reports if there appear some.
devo1223   100 W
Post by devo1223 » Nov 06 2018 12:35pm
Hi Vasili, Will you put me on the list for the 12F, thanks!
Vector lite stuffed with 30Qs
Mxus 3k turbo 3t in 17in moto rim
viewtopic.php?f=3&t=92531&p=1353484&hil ... e#p1353484
VasiliSk   100 W
Post by VasiliSk » Nov 13 2018 6:39am
devo, added.
Today i made first ride on 24F controller. It's crazy.
macribs   1 GW
1 GW
Post by macribs » Nov 13 2018 8:35am
:thumb:
BCTECH   100 W
Post by BCTECH » Nov 13 2018 12:17pm
looks good!
with stock motor and stock battery?
VasiliSk   100 W
Post by VasiliSk » Nov 13 2018 12:39pm
stock motor, my own custom battery 16S, just for testing
ElectricGod   10 MW
Post by ElectricGod » Nov 13 2018 12:41pm
VasiliSk wrote:
Nov 13 2018 6:39am
devo, added.
500 phase amps? That's impressive!
I'm guessing at 100 volts max?
What was the actual pack voltage? 16S so...66 volts?
When will 24 fet controllers see the light of day? I have use for 2 of them nearly immediately.
XB-502 Moped:
Currie scooter:
brumbrum   100 kW
Post by brumbrum » Nov 13 2018 4:16pm
Give the guy a chance, Haah! The solder has barely had time to cool on the very first board.
Some lovely torque. How much sag you getting on your pack. Just wondering what it takes to get to 60kph
My NYX and cromotor build
viewtopic.php?f=6&t=74615
My LMX 161 dirt bike build
viewtopic.php?f=6&t=94074
ElectricGod   10 MW
Post by ElectricGod » Nov 13 2018 8:04pm
brumbrum wrote:
Nov 13 2018 4:16pm
Ha! TAKE MY MONEY NOW!!!
OK...no not really...this controller needs some vetting yet. But I am quite interested!!!
My hope is it can do 150 volts. I'm willing to sacrifice some of those crazy 500 phase amps for some higher voltage. My next build will be running 131 volts and I'll need 24 fet controllers that can keep up. The big reason I've made no progress so far is the controllers. There's quite a few options in 100 volts, but virtually nothing in 150 that is worth while without breaking the bank. I have a motor that ought to punch in at the mid 40kw range that is just dying to see life at 150 volts.
Then...the next project will be even bigger. I have a 60-70kw axial flux motor. I figure put it in a motor cycle or even a small car...
XB-502 Moped:
Currie scooter:
brumbrum   100 kW
Post by brumbrum » Nov 14 2018 2:25am
ElectricGod wrote:
Nov 13 2018 8:04pm
brumbrum wrote:
Nov 13 2018 4:16pm
That's some serious power. You may need Vasiliy to make you a bespoke high voltage version. Its great to see someone stepping up into adaptto's shoes with an all in one solution. I will be looking forward to eventually getting a 24f myself. I'm not on a waiting list. I usually find with these things that money does the talking and not wishful thinkers and queues.
VasiliSk   100 W
Post by VasiliSk » Nov 14 2018 2:42am
same as 12F - 90V max. 150V not planned
my battery was 60V
24F production will be after NY. Oh, did i say that it is just x1.5 longer than 12F?
ElectroRider   1 W
Post by ElectroRider » Nov 14 2018 6:27am
VasiliSk wrote:
Nov 14 2018 2:42am
Wow that's great! I was looking for a compact 24 fet high power controller but they didn't exist.....until now!
ElectricGod   10 MW
Post by ElectricGod » Nov 14 2018 6:36pm
VasiliSk wrote:
Nov 14 2018 2:42am
my battery was 60V
Please plan on doing a 150 volt version.
For folks using inrunners or outrunners, compensating for insufficient motor RPM for high speeds is just a gearing change. For folks with large hub motors...well you need voltage to get them going fast. You don't want to use an over sized wheel/tire as that kills the motors efficiency.
Me personally, I have a hubmonster 6 phase hub motor I want to implement. I already know that it can deliver 40kw and at 24S, that comes out to about 80mph. However with that much power and running at 32S, it can do 116mph and at 36S about 135mph. AKA...I REALLY want a set of decent FOC 24 fet controllers that can run at 131 volts.
When I get around to using that Motenergy 60-70kw axial motor, it too will need to be fed 131 volts...at least.
Please, please, please plan for 150 volts! Take pity on us power hogs.
1.5X larger than your 12 fet...geez...that's tiny for a 24 fet! I have several 24 fet controllers and they are huge compared to any 12 fet I have. They are all easily 2.5X larger.
XB-502 Moped:
Currie scooter:
bionicon   100 W
Post by bionicon » Nov 15 2018 12:39am
:bigthumb:
csc   100 W
Post by csc » Nov 15 2018 5:01am
Vasiliy my range increased by 30% when I run the bike without saving energy at all (often WOT during accelerations and long high speed rides).
In 2wd I confirm that it takes around 80amps battery (splitted in two motors, around 30 / 50) to cruise at 90kmh continuously.
Motors max temp 70°, controllers max temp with a 120mm fan over the 2x12f : 45°
Absolutely brilliant, thank you so much !
