Nucular electronics - complete kit for ev! [beta]
Re: Nucular electronics - complete kit for ev! [beta]
Aixam 550 Twin retrophite Qs 138 70H, Thermo-Nucular electronics 24F, LG Chem 20s 60Ah
If he bought surron "plug n play" its only wire related.
IF you are new to that you'll expect that at minimum the keyswitch is enabled/working. Simple fix in Extra Parameters but as i said if you are new, your lost.
wow, so in reality 350 battery amps, 500 phase amps, thats around 30kw for me!j bjork wrote: ↑Dec 15 2020 4:04amIf I remember correct it says about 20kw, I guess it is just to give people a number.
There is no 20kw limit. With the "right" setup you can probably reach 30kw, maybe more.
And 300A is not the limit, you can set the controller to 400A. But you can only set the battery for 350A discharge, but there is a boost where I think you can get the missing 50A. I dont remember exactly, it is some time since I messed with it. There might be some changes in recent updates too.
...dont forget your voltage drop under load
if you squeeze 350A out of a battery expect a 12-15v+ drop on a fresh charge.
but yes. no matter what voltage your running, 350A is possible. I did with my tiny LMX Motor
How long do I need to wait for 12f controller currently?
I’ll be a beta tester for the light module......that thing is almost as cool as your controller......maybe cooler!
My pre order has been in for like ever.
Tom
Tom
I searched wiki and also this thread, but could not find any information what connector should I buy to connect throttle to the display. I received my 24F last february but just now started to use it and I bought it without these extra connectors.
Can someone give me excact product for these. Also found reading this thread, that I should replace halls+motor temp connector to some ip68 version, can someone link these also.
Electric kart 60kw: viewtopic.php?f=34&t=68543
100v 35Ah LiPo battery: viewtopic.php?f=14&t=97763
100v 25Ah LiFePo4 battery: viewtopic.php?f=14&t=85912
Scooter battery: viewtopic.php?f=14&t=108227#p1582703
The connectors are supplied with the controller.
If I had these, I would't ask
My question was where can I bought these, does someone have a link or something similar?
PHD 2.0 4P connector — 4 pcs.
PHD 2.0 6P connector — 1 pcs.
PHD 2.0 8P connector — 1 pcs.
Pins for crimping — 26 pcs.
Source:
https://nucular.tech
Source:
You are really unlucky they come with all the controllers, unless you specifically ask not to have them.
You can find it here :
https://a.aliexpress.com/_BOhQl9
PHD 2.0 connectors, it the kit with Display these connectors. You received this with your parcel (in the pack with GoPro mount for the display).nuxland wrote: ↑Jan 19 2021 8:46amI searched wiki and also this thread, but could not find any information what connector should I buy to connect throttle to the display. I received my 24F last february but just now started to use it and I bought it without these extra connectors.
Unfortunately, we have big delays with 12F.
Hi everyone!
We have completed the development of the lighting controller uLight and put together the first batch, which we will soon start sending out to previously placed pre-orders. Kits in stock and available for ordering.
In the kit:
uLight controller
PHD 2.0 6P connector — 4 pcs.
Power wires 22AWG 2x200 mm with connectors XH 2.54 2P — 6 pcs.
Power wires 22AWG 300 mm with pins, crimped on both sides — 8 pcs.
Wires 26AWG 300 mm with pins, crimped on both sides — 20 pcs.
Price — 48 USD
Detailed specifications, photo, video review, and connection scheme are here https://nucular.tech/#uLight
In the kit:
uLight controller
Price — 48 USD
I hope it's not a dumb question but...
I see you can charge through the controller. The 24F says up to 10kw continuous and 300 battery amps. Does this mean it's possible to charge using 10kw (or close to that)? For example using 250+ amps for a 36v system, or would it cause problems for the controller?
I understand most batteries can't do this, I just want to know if the controller itself can handle it because I'm not sure.
No, charge power at least limited by /2
Also depends on cooling
