Nucular electronics - complete kit for ev! [beta]
VasiliSk   100 W
Re: Nucular controller
Post by VasiliSk » May 29 2018 2:29pm
My regen didn't heat up fets so much, all power go to battery
VasiliSk   100 W
Post by VasiliSk » Jun 04 2018 4:33am
We have tested our e-boat kit :D
Reached speed 10kmh, need higher RPM, motor worked oh half power.
madin88   100 MW
Post by madin88 » Jun 04 2018 12:31pm
What a cool thing :)
Do you think you can push max current into the motor with those long battery wires?
Wouldn't it be necessary to add additional caps because of the increased inductance?
- 10kW belt drive with Neumotor 8057: viewtopic.php?f=30&t=91144&start=50#p1377787
- Fully road legal (L1E approval) e-bike based on Votec V-FR frame
/ MXUS 3T / 17" Mitas MC11 / Adaptto Max-E / 20s12p 25R
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
VasiliSk   100 W
Post by VasiliSk » Jun 04 2018 1:14pm
did you ever try to measure battery inductance? it is really huge
VasiliSk   100 W
Micro Nucular controller
Post by VasiliSk » Jul 18 2018 4:31am
Good news everyone!
I have designed and started Micro Nucular controller! Some of you may see posts about that on russian forum
It's a tiny piece of... POWER!
However i need to run full load tests first, but it seem to be:
70Vmax
120Aph max
70Abat max
There also 100v version may be. I will test them later and ride for a while to check all problems.
Also i have received 12F and testing-assembling them now, who asked for a sample can receive them in near month. New black anodized casing looks super-cool, but photos are not so good.
New wires are also longer a bit.
About LEVCAN, i made it working, now testing software and multi-controller functionality. It is a lot of work to do else, some of code looks quite shitty now (parameters are quite buggy huh), but we are working on it.
madin88   100 MW
Post by madin88 » Jul 18 2018 6:54am
The small size of the 6F is impressive!
Infineon 12F for instance has less power and would take up probably two or three times the space.
What about the menu language will it be available in english?
VasiliSk   100 W
Post by VasiliSk » Jul 18 2018 7:05am
Yes i will make translated binaries (as for now), later english will be default+translation files for display for any language
VasiliSk   100 W
Post by VasiliSk » Jul 18 2018 8:31am
I have updated first message with some information :arrow:
csc   100 W
Re: Nucular electronics - complete kit for ev!
Post by csc » Jul 20 2018 3:50am
Good news. Awesome work. Would you please finish the translation job so that a lot of us could buy it ?!
VasiliSk   100 W
Post by VasiliSk » Jul 21 2018 1:59pm
Succesfuly tested Micro Nucular Controller 6F
Max power output:
70Abatt, 57V, 100Aph
PCB looks good, later will test again with 120A fets
Aeron   10 W
Post by Aeron » Jul 23 2018 12:22pm
This looks promising !
I subscribed to this thread as I am very interested in the 6F version :wink:
brumbrum   100 kW
Post by brumbrum » Jul 23 2018 1:41pm
VasiliSk wrote:
Jul 18 2018 8:31am
You mentioned earlier in this thread that you may be testing your controller with an LMX motor. Did this ever happen? Finding a FOC controller that works with the LMX motor would be big news.
My NYX and cromotor build
viewtopic.php?f=6&t=74615
My LMX 161 dirt bike build
viewtopic.php?f=6&t=94074
VasiliSk   100 W
Post by VasiliSk » Jul 23 2018 2:06pm
brumbrum, no ;( unfortunately i had no chance to install it on lmx
is any there photo of disassembled lmx motor? i can say if it's gonna work or not
brumbrum   100 kW
Post by brumbrum » Jul 23 2018 3:55pm
VasiliSk wrote:
Jul 23 2018 2:06pm
There are a few here.. viewtopic.php?f=28&t=57668&start=800#p1280635
Thanks.
VasiliSk   100 W
Post by VasiliSk » Jul 23 2018 4:05pm
Looks like common cheap chinese motor. it should work, if bemf is not so square
i made some runs for this motor, but without load. it has same steel. However i can't find bemf screenshot..
Oh! i found it. it is soooo square
im not shure it's gonna work good. the only chance LMX have changed their winding for better sine.... but..
brumbrum   100 kW
Post by brumbrum » Jul 23 2018 4:41pm
At least i now know the real reason for sinewave controllers not working. lMX has previously said it is to do with weak hall signals??
VasiliSk   100 W
Post by VasiliSk » Jul 23 2018 4:49pm
This is not exactly lmx motor, but same steel form.
Well, i have designed own digital hall filter for these 'not-so-good' rotors, there possible twice pulse for one commutation. Filter also was tested with MAC motors (new and old), they also have some signal errors. On MAC FOC works good, one my user run with 2kw + temperature limit 120C = 60kmh max
here is motor album:
https://imgur.com/a/Hherr7I
btw lmx should better use new qs motors, black one on photo above. there is 2kW version, but it is really epic and have IPM rotor (goooood flux weakening!) and very nice sine wave and separate hall rotor. I think these can be boosted up to 4x easy
brumbrum   100 kW
Post by brumbrum » Jul 24 2018 3:30am
Thanks for sharing the motor album, the Denzel motor measurements are useful for comparison.
I am very interested in the digital filters for hall signals. Do they attach in-line with the hall signal wires? Or am i barking up the wrong tree? Is it something that you would share or sell?
brumbrum   100 kW
Post by brumbrum » Jul 24 2018 3:37am
VasiliSk wrote:
Jul 23 2018 4:49pm
this looks like very good news indeed. I can see an upgrade on the cards. Thanks! :)
VasiliSk   100 W
Post by VasiliSk » Jul 24 2018 4:07am
Hall filter programmed in my controllers. there is no separate device
VasiliSk   100 W
Post by VasiliSk » Jul 27 2018 5:08pm
Good news!
We are going to Mondial Tech (Paris) in category Electrification & Hybridization. On October 1st we will attend Tomorrow in Motion. You can visit us and take a look on electronics kits! First lucky ones will be able to obtain samples also :D
liveforphysics   100 GW
Post by liveforphysics » Jul 27 2018 9:44pm
Congratulations buddy!
I would be interested in a sample of your highest power density unit with integrated BMS to try on my road bicycle.
Stanislavchik   1 mW
Post by Stanislavchik » Jul 29 2018 10:35am
using the controller for several months. I installed it instead my 12fet infineon because it has the current control option as kelly, support thun (torque), pas sensors also and has the screen for small price. My target is riding with 60km.h. with pedals and MAC motors, and this controller is the best for that. :D
VasiliSk   100 W
Post by VasiliSk » Aug 10 2018 6:14pm
Connected today first bafang mid drive motor, i've added support for it's encoder PAS sensor. Really amazing torque for such small motor, it is running on soft currents for now as i don't know how much this can handle. Also i should do some improvements on startup, sometimes have glitches.
Torque sensor still WIP.
Also got some kind of gearsensor. Planning to make special function when you can switch speeds under load, but torque will be limited while switching, not just motor shutdown. So chain will feel good and almost no torque recovery time.
