Nucular electronics - complete kit for ev! [beta]
PITMIX   100 W
Re: Nucular electronics - complete kit for ev! [beta]
Post by PITMIX » Apr 07 2020 4:45am
OK, thanks. I also noticed this problem on Votol EM 100 controllers with a Qs 120 70H. There is a setting to reduce the attenuation of fields but this reduces the speed of the motor. Thank you for your work Vasili.
Aixam 550 Twin retrophite Qs 138 70H, Thermo-Nucular electronics 24F, LG Chem 20s 60Ah
madin88   1 GW
1 GW
Post by madin88 » Apr 08 2020 6:33am
I am using charge mode quite often and thought that it would be good to have more infos on the screen which show whats going on.
Is there anything planned?
something which look like this:
If you connect the PSU to controller then a pop up message shows "charger detected, switch on to start"
Then if you switch on the PSU the message changes to "charging" and showing % and time it takes to fully charge
And when finished a message like "charge complete, disconnect charger"
That would be helpful for people who are not so familiar with it.
Having the option to set cut off current would be also nice. Now there is max A, min A and delta V which is awesome (tesla charge curve), but i wish there would be a setting for cut off current where it stop charging once the current drop do this value during CV.
BCTECH   1 kW
Post by BCTECH » Apr 08 2020 10:34am
madin88 wrote:
Apr 08 2020 6:33am
x2
like what adaptto showing on screen when charging works good
PITMIX   100 W
Post by PITMIX » Apr 08 2020 1:15pm
I think the load information will be very complete when there is the bms
stuffc   1 mW
Post by stuffc » Apr 09 2020 7:33pm
How do I make my 12f nucular go faster? My kelly 7218s smokes it right now but has lower amps ext...
mwesleyroper   1 mW
Post by mwesleyroper » Apr 10 2020 5:29am
VasiliSk and/or others,
I'm going to try a Nucular controller with a Bafang G510 Ultra motor. To my knowledge, 4000 watts is the most put through a G510 and it did well. Would the 6F be a good match for the G510?
VasiliSk   1 kW
Post by VasiliSk » Apr 10 2020 5:51am
stuffc Activate field weakening and set speed 102+%
mwesleyroper 6F can do 4000W at over 60V, if phase current is enough should be good
tylerwatts   100 W
Post by tylerwatts » Apr 13 2020 6:13pm
Hi VasiliSk
Do you have any experience running big RC motors with your controllers? Such as Turnigy CA120 outrunner with low inductance values? What pwm frequency can/do your controllers run at?
Please share any working examples or owner threads of such combinations.
Thank you
Cheers
Tyler
PITMIX   100 W
Post by PITMIX » Apr 14 2020 1:03am
Tylerwatts look at the first pages of the topic.
VasiliSk Jan 14 2016 10h09 wrote:
Jan 14 2016 4:09am
the only high pole count motor i have to test ERPMs
http://www.youtube.com/watch?v=6RcsN_ZUSRE
Predator 30-8
http://www.youtube.com/watch?v=nKp6QjuzmMM
these was made on old pcb
cheeko   100 W
Post by cheeko » Apr 14 2020 1:24am
PITMIX wrote:
Apr 14 2020 1:03am
Jan 14 2016 4:09am
Predator 30-8
Wonder how much Amps they will pull underload on decent weight bike and person
20S7P Futr Beta 26" Mxus3k with the Unbelievable Nucular 12F
VasiliSk   1 kW
Post by VasiliSk » Apr 14 2020 7:40am
So i decided to open a new market for my controllers :D
Made hallway little ride. okay.. big NO to sensorless, it just sucks on start. HFI magic sounds cool but there is a lot of work to do still other than that. Will take a new bms prototype for testing here:
Put halls and t-sensors, add PWM control for remote, assemble battery..
serious_sam   1 kW
Post by serious_sam » Apr 14 2020 5:31pm
Hi Vasiliy, is the BMS canbus or bluetooth comms ? The Nucular page mentions programming the controller via bluetooth and smartphone, so I assume there is a bluetooth transceiver in the display already ?
VasiliSk   1 kW
Post by VasiliSk » Apr 15 2020 2:13am
Hi, we are planning to make BT as separate module. It will connect to CAN bus and work as display replacement, with inputs for throttle/brake/etc
Merlin   10 MW
Post by Merlin » Apr 15 2020 5:56am
Throttle and brake over bt?
VasiliSk   1 kW
Post by VasiliSk » Apr 15 2020 5:59am
not yet, i mean board with bt will also have inputs, to put it on handlebar for ex. and keep single wire going to controller
Merlin   10 MW
Post by Merlin » Apr 15 2020 6:02am
Not yet?
I hope never :D
Wireless throttle sounds like a one way ticket to hell :mrgreen:
serious_sam   1 kW
Post by serious_sam » Apr 15 2020 6:03am
So BMS will be connected via canbus?
VasiliSk   1 kW
Post by VasiliSk » Apr 15 2020 6:07am
Merlin well yes and no, still need a wireless throtte/brake for my e-board and it would be cool to have some lcd on remote too just to show charge/volts/etc
BMS ofc connected to CAN, there is no point to make classic bms, they are useless without integration
Merlin   10 MW
Post by Merlin » Apr 15 2020 6:17am
Eboard from hell is also OK :mrgreen:
tylerwatts   100 W
Post by tylerwatts » Apr 17 2020 3:33am
PITMIX wrote:Tylerwatts look at the first pages of the topic.
Jan 14 2016 4:09am
Predator 30-8
Hi PITMIX
Yes thanks, I see that. But this was a long time ago and the controller's have developed significantly. I was asking about use cases as well demonstrating loaded performance and reliability particularly.
I recognise this is a fantastic design and the guys have created a great product. I just somewhat cautious and need a reliable solution. The outrunners seem the best motor package for my project but that's dependant on a reliable and capable controller driving them.
I will ask the owners thread for any experience also, but I'm hoping VasiliSK has some experience from beta testers who have used this sort of set up for a while etc. It is my best option regardless if I go with an RC motor but I like/need data points to give me confidence.
Cheers
Tyler
VasiliSk   1 kW
Post by VasiliSk » Apr 17 2020 3:39am
I was saying before that RC motors not recommended due to low inductance, they will not let you to use 80V@max phase due to high current ripple, you may expect only 80% form maximum. About data - there was few users, i dont have any comparable performance information
tylerwatts   100 W
Post by tylerwatts » Apr 17 2020 5:11am
VasiliSk wrote:I was saying before that RC motors not recommended due to low inductance, they will not let you to use 80V@max phase due to high current ripple, you may expect only 80% form maximum. About data - there was few users, i dont have any comparable performance information
Ok thank you Vasili for prompt reply.
If I run slightly lower voltage such as 60v nominal will this be better and allow full current or should I limit current rather? I can make power through ROMs with less torque for my application so this is ok otherwise I can hear differently.
Cheers
Tyler
Offroader   100 MW
Post by Offroader » Apr 21 2020 10:05am
For the people who are using this controller on the sur-ron, how did you attach the controller to the bike?
Did you fabricate your own brackets?
Merlin   10 MW
Post by Merlin » Apr 21 2020 10:06am
if you join the telegram group you get plenty of info and theres a guy who made nucular fitting brackets for surron.
Badger1666   100 µW
100 µW
Post by Badger1666 » Apr 25 2020 3:51pm
hi
can two controllers work together(1 master and 1 slave) running same settings on can bus with one throttle ? .
I want to use two on a dual drive scooter.
and when will they be available ?
I did ask on nucular contact, but got no response.
thanks
