Nucular electronics - complete kit for ev! [beta]
DanGT86   10 kW
Re: Nucular electronics - complete kit for ev! [beta]
Post by DanGT86 » Apr 25 2020 4:35pm
Similar question about running 2 controllers: Have dual Nucular controllers been used on a dual stator motor? I've seen people separate the 2 stator windings out on the zero motorcycle motors and run 2 controllers. I've also seen the same approach on the dual stator axial flux motenergy motors. Most of these motors are sin/cosine encoders but if fitted with a set of halls and magnets do you think 2 Nuculars would run a single motor? Is there anything about axial flux motors that would make them a bad fit for your controllers?
Any future plans to support sin/cosine motors?
VasiliSk   1 kW
Post by VasiliSk » Apr 25 2020 5:54pm
if you have 2 sets of winding it should work
Planned but low priority, i heard only 3 people requested it so far
DanGT86   10 kW
Post by DanGT86 » Apr 25 2020 6:08pm
If its a low priority that is fine. You will probably get to it before I can afford it anyway. :wink:
Seems to me most of the motor options in the 25kw and higher range are paired with sevcon controllers. I have no desire to learn how to program one of those. My dream vehicle would be a full size MX bike with a zero motor with 2 of your thermo controllers.
Truth be told maxing out a single thermo nuc on a qs 3k mid motor is probably enough for my skill level but its always nice to plan ahead.
Badger1666   100 µW
100 µW
Post by Badger1666 » Apr 26 2020 1:48am
VasiliSk wrote:
Apr 25 2020 3:56pm
Yes you can
Time depends on model, check website nucular.tech
thanks pre order placed
Username1   10 W
Post by Username1 » Apr 28 2020 5:01am
Can this controller work well for a 24v battery? I see the voltage range is 20-90. Will it still work perfectly even if i drain my battery to the 20v limit? These are high power batteries, so i may use the full 300a at times.
Username1   10 W
Post by Username1 » Apr 28 2020 5:50am
Ok great. One more question, do you think the waiting time on the website of 4 months is still accurate, or could it be delayed longer from the virus? I just found this project so i'm not informed on these things.
Centurio   10 mW
Post by Centurio » Apr 28 2020 8:59am
Hi VasiliSk,
There are just little informations about the BMS on you homepage yet. Are you still open for some ideas / wishes or is the development already in a soon finish state?
My ideas:
- No power flow through the BMS
- The BMS monitors and banlances the battery cels
- The power is switched on with a relay
- There are several thermo sensors (if too hot switch off the relay)
- If Undervolt protection reached switch off relay
- The BMS is not limited to 16 or 24 cells. There can be 17 or 19 ...
- There may be a second relay contact for precharge purposes
This could be a very nice BMS used for alost any discharge current, because there is e relay carring the current.
VasiliSk   1 kW
Post by VasiliSk » Apr 28 2020 9:04am
big bms will have tiny powerstage for charger/aux and output for relay
S is configurable
Badger1666   100 µW
100 µW
Post by Badger1666 » Apr 29 2020 10:23am
I was looking at wiring pdf, can the spare io be config for a 3 speed switch and a boost button ?
thanks
Badger1666   100 µW
100 µW
Post by Badger1666 » Apr 30 2020 3:46pm
So then does 3 speed just set the top speeds or can you setup battery amps and phase amps to each of the separate speeds?
cheeko   100 W
Post by cheeko » Apr 30 2020 11:58pm
Badger1666 wrote:
Apr 30 2020 3:46pm
Yes to both
20S7P Futr Beta 26" Mxus3k with the Unbelievable Nucular 12F
The Mighty Volt   10 MW
Post by The Mighty Volt » May 01 2020 10:08am
Hi. I need a controller for a cheap chinese motor, "KUNRAY", runs around 48v or more, 4800rpm.
It's a 3 phase BLDC with hall sensors.
Can you provide an option for my needs?
Thank you.
OneBadWolf   1 mW
Post by OneBadWolf » May 02 2020 5:26am
john61ct wrote:
Jan 18 2020 4:03pm
Yes, exactly my point, the reason CA is "obsolete" with such modern sophisticated controllers.
The CA is not a motor controller. It cannot add a feature to a motor controller, it can provide information about, and limit the controller, and it can "feed" information to a controller, in a way the controller may not process it on it's own. Throttle curves, power limits, amp limits, speed limits, SOC, speedo and function as a overgrown volt/amp meter as well as providing a wealth of arcane information that has no real world use if your controller is functioning well. Unless it's really important to you to have a real time comparison of amp hours to hamster BTUs. It also does a decent job of blinding you at night, (in either green or orange) takes up space, adds weight, and is marvellous at serving as an additional point (points) of failure. (love those JST connectors) If we lived in a time where you could not adjust controller parameters, it could prevent the controller from drawing too many amps. If the controller only had a on or off type throttle curve, it could mellow that out. Basically though, for those many many people out there who don't own a smart phone with a GPS, it serves as a speedo.
john61ct   100 GW
Post by john61ct » May 02 2020 5:56am
I am not at all saying a CAv3 adds any value to a controller as sophisticated as Nucular. I am no expert on either.
However just to clarify, it does add features missing from most cheap controllers, including the critical limiting ones to prevent burnout as well as all the others you mention..
But, it does not provide any "information" to a controller, there is no "communication" from the CA, it just physically "drives" the controller, feeds a throttle voltage.
And can be run headless, without any display.
Xtr6   100 W
Post by Xtr6 » May 02 2020 2:01pm
Connecting a Magura throttle gives me the first movement no responce. Did someone has the same experience?
OneBadWolf   1 mW
Post by OneBadWolf » May 02 2020 4:49pm
john61ct wrote:
May 02 2020 5:56am
Um. The CA is the head. the display is integrated into the CA. Are you suggesting the CA will function with the LCD desoldered? why even use one then?
OneBadWolf   1 mW
Post by OneBadWolf » May 02 2020 5:19pm
I scanned the thread, but may have missed it. What's the difference between the old 6f and the new one?
j bjork   10 kW
Post by j bjork » May 03 2020 1:47am
What is this ca discussion doing in this thread?
The nucular has a display, and you can set it up how you want. I don't see any use for ca here.
john61ct   100 GW
Post by john61ct » May 03 2020 3:22am
I was simply pointing out some errors in your post
OneBadWolf wrote:It cannot add a feature to a motor controller, it can provide information about, and limit the controller, and it can "feed" information to a controller, in a way the controller may not process it on it's own
OneBadWolf wrote:Um. The CA is the head. the display is integrated into the CA. Are you suggesting the CA will function with the LCD desoldered? why even use one then?
If you have to ask that last, either you're just not that familiar with the CAv3 (maybe only previous versions?)
or have only been working with programmable controllers that give you all the features you need.
I was not suggesting soldering nor eliminating anything, just hiding the display away for when programming is needed, or just use it with your smartphone.
Again, I do not know enough about Nucular to argue that CAv3 can add any value here.
And thus it seems a thread derail to discuss it further.
The Grin Tech CAv3 page, plus the user manual layout all its features well. Maybe post any further questions here viewtopic.php?t=37964
john61ct   100 GW
Post by john61ct » May 03 2020 3:24am
j bjork wrote:What is this ca discussion doing in this thread?
Me either, I agree, not sure why he resurrected the question.
Allex   1 GW
1 GW
Post by Allex » May 04 2020 4:31pm
wrong thread
