Nucular electronics - complete kit for ev! [beta]
Re: Nucular electronics - complete kit for ev! [beta]
Hi I just checked at the pins on the throttle socket on back of lcd computer... NO 5v.
Thanks
Jon
Thanks
Jon
Hello hello.. think I may have found the problem...
- Attachments
- fuse.jpg (56.66 KiB) Viewed 1123 times
WINNER! Tricky little bit of soldering ..all done
Vasili, if you hadn't of sent me on the trail of thought, I may never of spotted it.. just followed the tracks from the socket
It was heavy crash, so obviously dislodged it.
Big thanks
Jon
Big thanks
Jon
Have you found a way to send your controllers to the USA for a reasonable price?
Building and maintaining the "Quickest and Fastest" URB-E in the USA
I am still waiting on a pre-order for a micro. Can I decide to have it potted when my controller is ready or does that move me back to the end of the list?
Edit:
Oops. Just read back a few pages and remembered that all the micros are potted. Answered my own question.
Edit:
Hi Vasiliy, does the bms measure the internal resistance of the battery cells and can it give the rated power that we are asking from the battery. Thank you.
Aixam 550 Twin retrophite Qs 138 70H, Thermo-Nucular electronics 24F, LG Chem 20s 60Ah
We are shipping worldwide now by UPS, 60~80$ (depends on qty)
PITMIX i havent made that yet, we are still prototyping hardware
Hi, what your pre-order number?DanGT86 wrote: ↑Aug 24 2020 9:51pmI am still waiting on a pre-order for a micro. Can I decide to have it potted when my controller is ready or does that move me back to the end of the list?
Edit:
I have preordered 2 Nucular 24F with a display right now. What will be the wait time?
Anyone put a 24F on Electric Motion Trials bike? I am on the wait list. Got on in late May or early June.
I have 1390C. How much I need to wait?
Hello, I am deciding between the 6F and 12F. On a 52V system, can the 6F do 40 continuous battery amps?
with some cooling yes, if you have heavy device choose 12f
- OneBadWolf 10 mW
What methods do you suggest for additional cooling of the controller? Just out of curiosity, has anyone ever employed Peltier effect devices on motor controller housings, or is the efficiency too low to be practical? I used some on processors and memory as an alternative to liquid cooling,but that was on a desktop,with abundant power.
New updates posted on wiki: http://wiki.nucular.tech/en:firmware
Controller update v0.7.18
Changelog since v0.7.12 :
Experimental logger added.
Fixed many charger glitches, however still have few.
Added soft start to charger and more safe phase detect.
Completely reworked field weakening, now should not have any hard braking after release.
Added minimum speed reference for speed PID.
Added RC PWM control on P1 port (throttle/brake).
Added more logger parameters.
Few important FOC control fixes, DC current should be calculated better under field weakening.
Fixed one weird ultra-rare bug in square mode.
LEVCAN operates on queues now, log time 2x faster when display updated.
Decreased DCi Ki default from 500 to 200.
Slightly decreased FW start point.
Added full debug info export.
Added logger mode selection and tuned logger start.
Removed first line from log for easy datazap upload.
Throttle / brake curves added (8 point configuration) with presets.
PAS extra scale added for additional modes.
Soft acceleration for cruise added, more shutdown triggers.
Cruise logic updated - phase current limited by selected mode, not throttle position.
Minimum cruise speed - limits cruise activation.
Cruise increment/decrement - control cruise speed with buttons ( port = CR+/CR-)
Cruise restore - recovery last saved cruise speed with button, activated only above min cruise speed. (port = CRr)
Power limit added to modes and battery configuration. 0 = power limit disabled.
Small menu fixes.
CAN inputs increased to 16.
Parameters export / import fixes.
12V shutdown fix.
Display update v0.60B
Fixed throttle drop.
Small menu fixes.
LEVCAN updated.
Button setup simplified, by default all set to CAN mode.
Added exFAT support (but display still can be updated only from FAT32).
Added charge screen.
Added fast statistics type selection.
Added wider event window.
Mph stats fixed.
Small menu fixes.
12V shutdown fix.
Small menu fixes.
LEVCAN updated.
Mph stats fixed.
Big job!
I will have to test all of this.
Does the 24F controller has a 12V DC output to power lights, horns, and other stuff on a registered e-scooter?
Any idea how long on order 920c? Trying to decide whether to wait or not for my projectviewtopic.php?f=28&t=106672&start=125
Chambers i guess after NY, there is some new Production Adventures™ happening and need to wait a new batch.
bigbore New controllers will have 12V 3A dc-dc, about 2.5A you can use if you have display
So there isn’t going to be any new controllers sold for the rest of the year??
