Nucular electronics - complete kit for ev! [beta]
PITMIX   100 W
Re: Nucular electronics - complete kit for ev! [beta]
Post by PITMIX » Dec 16 2020 10:30am
:bigthumb: I have not had other controllers allowing such customization of settings and with such simplicity thanks to access from the LCD screen. This is also why for me it is the best.
Aixam 550 Twin retrophite Qs 138 70H, Thermo-Nucular electronics 24F, LG Chem 20s 60Ah
Merlin   10 MW
Post by Merlin » Dec 16 2020 1:06pm
If he bought surron "plug n play" its only wire related.
IF you are new to that you'll expect that at minimum the keyswitch is enabled/working. Simple fix in Extra Parameters but as i said if you are new, your lost.
mbgjt1   10 W
Post by mbgjt1 » Dec 16 2020 6:25pm
j bjork wrote:
Dec 15 2020 4:04am
If I remember correct it says about 20kw, I guess it is just to give people a number.
There is no 20kw limit. With the "right" setup you can probably reach 30kw, maybe more.
And 300A is not the limit, you can set the controller to 400A. But you can only set the battery for 350A discharge, but there is a boost where I think you can get the missing 50A. I dont remember exactly, it is some time since I messed with it. There might be some changes in recent updates too.
wow, so in reality 350 battery amps, 500 phase amps, thats around 30kw for me!
Merlin   10 MW
Post by Merlin » Dec 16 2020 7:50pm
...dont forget your voltage drop under load ;)
if you squeeze 350A out of a battery expect a 12-15v+ drop on a fresh charge.
but yes. no matter what voltage your running, 350A is possible. I did with my tiny LMX Motor :D
VasiliSk   1 kW
Post by VasiliSk » Jan 18 2021 9:43am
upek   10 W
Post by upek » Jan 18 2021 2:30pm
How long do I need to wait for 12f controller currently?
litespeed   100 kW
Post by litespeed » Jan 18 2021 6:12pm
I’ll be a beta tester for the light module......that thing is almost as cool as your controller......maybe cooler!
My pre order has been in for like ever.
Tom
nuxland   100 W
Post by nuxland » Jan 19 2021 8:46am
I searched wiki and also this thread, but could not find any information what connector should I buy to connect throttle to the display. I received my 24F last february but just now started to use it and I bought it without these extra connectors.
Can someone give me excact product for these. Also found reading this thread, that I should replace halls+motor temp connector to some ip68 version, can someone link these also.
Electric kart 60kw: viewtopic.php?f=34&t=68543
100v 35Ah LiPo battery: viewtopic.php?f=14&t=97763
100v 25Ah LiFePo4 battery: viewtopic.php?f=14&t=85912
Scooter battery: viewtopic.php?f=14&t=108227#p1582703
PITMIX   100 W
Post by PITMIX » Jan 19 2021 9:37am
The connectors are supplied with the controller.
nuxland   100 W
Post by nuxland » Jan 19 2021 9:52am
PITMIX wrote:
Jan 19 2021 9:37am
If I had these, I would't ask :)
My question was where can I bought these, does someone have a link or something similar?
upek   10 W
Post by upek » Jan 19 2021 4:18pm
PHD 2.0 4P connector — 4 pcs.
PHD 2.0 6P connector — 1 pcs.
PHD 2.0 8P connector — 1 pcs.
Pins for crimping — 26 pcs.
Source:
https://nucular.tech
vanturion   1 mW
Post by vanturion » Jan 19 2021 9:26pm
upek wrote:
Jan 18 2021 2:30pm
For reference, I've been waiting since May 2020 for a 12F, which will put the wait at about 1 year or so based on the latest projections.
Turbomatic   10 mW
Post by Turbomatic » Jan 20 2021 1:17am
upek wrote:
Jan 18 2021 2:30pm
We don`t know when will be available 12F yet, approx several months
PITMIX   100 W
Post by PITMIX » Jan 20 2021 1:19am
nuxland wrote:
Jan 19 2021 9:52am
You are really unlucky they come with all the controllers, unless you specifically ask not to have them.
You can find it here :
https://a.aliexpress.com/_BOhQl9
Turbomatic   10 mW
Post by Turbomatic » Jan 20 2021 1:21am
nuxland wrote:
Jan 19 2021 8:46am
PHD 2.0 connectors, it the kit with Display these connectors. You received this with your parcel (in the pack with GoPro mount for the display).
Turbomatic   10 mW
Post by Turbomatic » Jan 20 2021 1:26am
vanturion wrote:
Jan 19 2021 9:26pm
upek wrote:
Jan 18 2021 2:30pm
Unfortunately, we have big delays with 12F.
Turbomatic   10 mW
Post by Turbomatic » Jan 21 2021 3:29am
Hi everyone!
We have completed the development of the lighting controller uLight and put together the first batch, which we will soon start sending out to previously placed pre-orders. Kits in stock and available for ordering.
In the kit:
uLight controller
PHD 2.0 6P connector — 4 pcs.
Power wires 22AWG 2x200 mm with connectors XH 2.54 2P — 6 pcs.
Power wires 22AWG 300 mm with pins, crimped on both sides — 8 pcs.
Wires 26AWG 300 mm with pins, crimped on both sides — 20 pcs.
Price — 48 USD
Detailed specifications, photo, video review, and connection scheme are here https://nucular.tech/#uLight
