Nucular electronics - complete kit for ev! [beta]
tomjasz   10 GW
Re: Nucular electronics - complete kit for ev! [beta]
Post by tomjasz » Dec 26 2018 3:01pm
Mad Matt wrote:
Dec 25 2018 5:42pm
Hi, I am interested in a 6f and display and also a 12f and display. How do I order from you?
See last few lines of first post!
You can ask me in Telegram @vasilisks Nucular electronics chat
Inform me if you need one, there is a big queue, i will note you and contact when ready to ship.
Nucular electronics - complete kit for EV!
Nucular electronics - Telegram chat (support, updates and more)
Aeron   10 W
Post by Aeron » Dec 29 2018 7:23am
Yet another noob question : what kind of signal is expected on "BRK" pin to detect any action on brakes ?
Aeron   10 W
Post by Aeron » Dec 29 2018 7:33am
Sorry, I wasn't clear enough. Is 0V interpreted as no brakes and 5V as max brakes ?
I'm trying to figure out what hall sensors would fit.
Aeron   10 W
Post by Aeron » Dec 29 2018 8:03am
Oh, nice ! I didn't find any mention of that in the wiki so I was looking for the proper sensor. Thanks !
Is the throttle "sensor direction" also configurable ?
ElectricGod   100 MW
Post by ElectricGod » Dec 29 2018 8:00pm
Aeron wrote:
Dec 29 2018 8:03am
You need something like these if you want to use your brake levers for variable regen.
https://www.ebay.com/itm/CA-1-PCS-HWBS- ... 2720963821
https://www.ebay.com/itm/Mechanical-Bra ... 0005.m1851
This is just on/off.
https://www.ebay.com/itm/Hydraulic-Mech ... 0005.m1851
A simple thumb throttle would do the trick and you could activate it with your left thumb.
https://www.ebay.com/itm/Thumb-Lever-Th ... rk:45:pf:0
They have 2 magnets and a 49E hall inside. A south magnet pole pulls the hall down to 0v. Slowly pull the magnet away and voltage rises to about 2.5v. Start bringing a north magnet face towards the hall and voltage raises to 5v. Any hall throttle works the exact same way. Zero throttle is a south magnet pole touching the hall. Pulling the south pole away slightly causes the hall voltage to rise to a maximum of about 2.5v. Then the north magnet pole starts getting closer which causes the hall voltage to rise above 2.5v and a max of 5v.
douglashart   100 W
Post by douglashart » Dec 30 2018 2:00am
Desc:
Shows charge, speed, power, currents, cell voltages and etc.
As I understand , you haven't developed a BMS yet but , does this mean(above) the display will actually moniter individual cell voltages? Has leads cable?
I have high hopes for this controller in my next bike. Is anyone riding one?
doug
Routybouty   100 W
Post by Routybouty » Dec 30 2018 10:42pm
Does this controller fix the low end torque delay of the Adapttos of the past?
Waiting for that perfect ebike.
Merlin   1 MW
Post by Merlin » Jan 09 2019 6:38am
what do you mean with low end trq delay?
redline2097   100 W
Post by redline2097 » Jan 09 2019 3:52pm
I think he means that it does not work like those shitty 18fet infineons which overshoots phase amps way over limit on start. :D
ElectricGod   100 MW
Post by ElectricGod » Jan 09 2019 4:04pm
redline2097 wrote:
Jan 09 2019 3:52pm
Is that actually "shitty"? Stall state is the hardest point to get out of. I'd want to throw everything I can at the motor to get it rotating and then back off after I see a few RPM's.
I'm not familiar with how the Adappto's do it, but it's some kind of soft start it sounds like. Just depends on the person/EV I think. If your EV is uncontrollable at full power when taking off from a stop, you might want soft start for the first few seconds. However, if your EV is not having this issue, then you would NOT want soft start.
I have 3 EV's. 2 don't need soft start. The third is a small stand-up scooter and if I don't use soft start, it just wheelies all the time even at very low throttle.
If these controllers don't have this option, it would be a good one to add.
Bartosh   1 mW
Post by Bartosh » Jan 09 2019 4:07pm
redline2097 wrote:
Jan 09 2019 3:52pm
I wouldn't necessairly call it a bad thing. I wish my Sabvoton had more startup power. And yes, the throttle delay on accel/decel is already set as low as possible (-; Anyway I think it is a good question.
Edit: +1 what EG said.
VasiliSk   100 W
Post by VasiliSk » Jan 09 2019 7:27pm
I'm also not understand the question. There is no delays, you can configure current ramp (dA/dt) in controller menu
larsb   100 kW
Post by larsb » Jan 10 2019 11:52am
Routybouty wrote:
Dec 30 2018 10:42pm
Urm.. Let's pose a theoretic question: if you ask a seller if their product has a negative feature then what can he answer..?
This is not an adaptto. The question is a bit rude posed in this way.
Ride on :D
Allex   1 GW
1 GW
Post by Allex » Jan 10 2019 12:14pm
Merlin wrote:
Jan 09 2019 6:38am
His question is actually valid. Many controllers dont give you full power unless the motor start spinning at a certain speed. This was one of the negative aspects on newer Adaptto firmwares.
Bartosh   1 mW
Post by Bartosh » Jan 10 2019 12:17pm
larsb wrote:
Jan 10 2019 11:52am
Routybouty wrote:
Dec 30 2018 10:42pm
I think it's already been answered. If it's time dependent and you can set it in the way not to affect the current increase, very well. The problem is some controllers don't give you that much control. Don't want to get into details in this thread, but I bet Sabvoton implemented such the feature several years ago and made it RPM dependent. And that is a shame :/
larsb   100 kW
Post by larsb » Jan 10 2019 12:26pm
Yeah i know where the question comes from, just that question posed like this puts seller in a weird position. ask the users instead, not in the sales thread
Ride on :D
ElectricGod   100 MW
Post by ElectricGod » Jan 10 2019 3:54pm
VasiliSk wrote:
Jan 09 2019 7:27pm
This ^^^^ is the answer. I saw that in the settings and it did NOT occur to me that's what I was looking at. Of course IF I had actually RTFM, I'd have known that!
http://nucularelectronics.wikidot.com/e ... ller-setup
VasiliSk   100 W
Post by VasiliSk » Jan 13 2019 5:46am
I've got some interesting question in PM
NOW what happens when you fully twist the throttle (WOT) and the motor is somehow locked or the front wheel is put against an obstacle at 0 RPMs? Is the dc/phase current going to peak hard as soon as you twist the throttle? Or it requires to reach a certain RPMs / speed / motor revolutions to reach the max phase/dc current set in the controller?
Controller will apply full amp at start, but if motor doesn't spins for 2sec, absolute maximum phase amps will be limited to 75% of hardware maximum
j bjork   100 W
Post by j bjork » Jan 13 2019 7:00am
Something I would like is a limited mode. Something like this: when you turn on the ignition you are in limited mode, You can only use a few 100W, and only go 25km/h (configureable to what you want). Maby only able to use pas, throttle only for push assist up to 3km/h for example.
You should not be able to see max speed, average speed, max power used and things like that. To exit limited mode you have to do a secret button combination, or brake sequence or something like that.( Not a password on the screen)
Something very fast and easy to do, but difficult to figure out. Then you are in unlimited mode until next time you turn off and on the ignition.
Another thing would be control the lights on the bike, if there is on/off of the backlight on the display it would be nice to be able to control the light on the bike at the same time.
But as I understand it seems like the light is always on, but controlled by a light sensor. So then it might not be much benefit to have such a function.
ElectricGod   100 MW
Post by ElectricGod » Jan 17 2019 4:57pm
j bjork wrote:
Jan 13 2019 7:00am
You are talking about the 3 speed switch connection. Implement it however you like.
Inside the LCD are several connections for controlling other things. All of those small connectors are also in the back of the LCD.
izeman   10 GW
Post by izeman » Jan 17 2019 6:12pm
No. That's not what he's talking about. He talks about a secret switch to activatw ANY mode that's more powerful than what's legal. So a way to hide some settings or statistical data from spying (police officer's) eyes.
ElectricGod   100 MW
Post by ElectricGod » Jan 17 2019 8:38pm
izeman wrote:
Jan 17 2019 6:12pm
Right...exactly what I said...he wants to set the 3 way speed switch and have it hidden someplace that no one will find, but is easily flipped for Power Mode. That's the 3 speed switch!
On one of my EV's it's like that...an innocuous toggle that is NOT where it is obvious or seen. No one would see this or know what it is except me. Flip it all you want sitting still and there is no evidence it does anything. Just a random toggle. BUT it's the exact thing asked about. Low is pathetic and weak...30% phase current and won;t let you go but 25mph. Medium is stronger, but tops out at 30. High is 60mph and good luck to the cars trying to keep up! Put the switch wherever you want and hide as you see fit.
izeman   10 GW
Post by izeman » Jan 18 2019 1:18am
No. That's not what he's talking about. :)
Believe me. We had a longer personal discussion about it.
IF you have such a switch (which WILL be found at close inspection) and this switch will enable higher power modes then you're busted.
And even if you don't have a switch and the setup menu of your controller is open to access all the time then this a illegal, as you just can program it too higher levels - at least in the EU.
