Page 16 of 16
Nucular internals pics
Posted: Jan 25 2019 6:29pm
by ElectricGod
With permission from Vasili...a few pics of the internals of these controllers.
I'm planning on doing a review of these controllers in a separate thread after I've "played around" a bit more. I've reviewed a variety of EV related products in the past.
12 fet: Everything is coated in conformal. If there is water incursion, this will protect the electronics. There is a lot of attention to details in this controller. I was instantly impressed when I opened it up. Ceramic insulators, 8 awg wires, conformal, well secured daughter boards, BIG copper traces for power busses. All these are good things.
6 fet: No conformal...after opening up the 12 fet and being delighted by conformal on everything, I really expected it here too.
LCD: No conformal here either. The shell is 3D printed instead of molded except for the lense.
Re: Nucular electronics - complete kit for ev! [beta]
Posted: Jan 26 2019 2:44pm
by j bjork
It is really compact built, not much unused space there.
It looks like the display might be a bit sensitive of water?
Posted: Jan 27 2019 5:48am
by VasiliSk
ElectricGod you've got beta boards of 6F x)
lcd shell is molded based on 3d printed model with some processing
Posted: Jan 27 2019 1:51pm
by madin88
VasiliSk wrote:
Jan 27 2019 5:48am
Do you plan to offer the molded LCD shell as replacement part?
Posted: Jan 27 2019 6:15pm
by L3chef
What stage are the 24s bms at? Will the width be 65mm as I read somewhere?
Posted: Jan 28 2019 1:56am
by VasiliSk
madin88 wrote:
Jan 27 2019 1:51pm
I will tell later..
L3chef, under development. it will be about 65-70mm
Posted: Jan 28 2019 1:59am
by notger
VasiliSk wrote:
Jan 27 2019 5:48am
So the final 6F Controller will be coated with conformal too, right ?
When will you go into Display Mold production ?
greets
Notger
Posted: Jan 28 2019 2:36pm
by L3chef
If there is a que for the bms, sign me up please
Posted: Feb 07 2019 3:49pm
by Ohbse
Keen for a 24 Fet and BMS! Love your work so far.
Posted: Feb 08 2019 9:06am
by DanGT86
Is the cost for multiple controllers always $100 cheaper than the initial cost of the first or is that just for the 12fet?
Do all the controllers work in tandem?
Posted: Feb 08 2019 9:29am
by VasiliSk
12F + display is 300$ + 50$ shipping
extra 12F is 250$, shipping depends on quantity
All controllers can be connected to single network
Posted: Feb 08 2019 10:20am
by DanGT86
So is an extra 6FET $50 cheaper than the first?
Posted: Feb 08 2019 10:28am
by VasiliSk
Yes, but it is not cheaper, it is price without display since you need only one
Posted: Feb 08 2019 12:46pm
by ElectricGod
VasiliSk wrote:
Feb 08 2019 9:29am
Are you saying I could use 4 controllers via a single LCD? If so, that would be brilliant! I am building a 4WD long board with four controllers. A single LCD and throttle for all of them would be way cool. I was thinking about using the VESC, but IF I can run 4 of your 6 fets in parallel from a single LCD, well that's a far better option.
Posted: Feb 08 2019 12:55pm
by VasiliSk
Yes..
(for dual - triple - quadro motor designs)
Posted: Feb 08 2019 12:59pm
by ElectricGod
VasiliSk wrote:
Feb 08 2019 12:55pm
Yes..
This is good news! I have a pal in the UK that's building a dual motor stand-up scooter. This will be very useful to him too.
Posted: Feb 11 2019 10:52am
by VasiliSk
Small news while waiting for new batch.
Assembled another 24F prototype inside of SurRon controller casing:
And of course:
So i have two 24F to run on test bench for full power, but oops:
Something happen. After fixing this problem i've noticed that my bench just bends under 400A phase... i need a better bench to test for full 500A power.
Posted: Feb 11 2019 2:31pm
by L3chef
Lol :lol: :bigthumb:
Posted: Feb 12 2019 6:19pm
by ElectricGod
VasiliSk wrote:
Feb 11 2019 10:52am
And of course:
I'm betting the third phase connection (C) is at the far end of the board. it looks like batt- connects at that center through hole. This isn't the final mosfet layout. You'll mount them vertically. Nice use of ceramic insulators!!! How much capacitance do you have here in large electrolytics? I'm used to 24 fet controllers having a large bank of caps totaling something like 12-14,000uF.
Posted: Feb 12 2019 6:29pm
by liveforphysics
VasiliSk wrote:
Feb 11 2019 10:52am
And of course:
Congratulations my friend! That's some incredible hotrodding! I love fitting it in the original controller heatsink. :-)
Posted: Feb 18 2019 1:26pm
by zeccato
Hi, in the Russian forum told me that the PAS can be connected to the controller.
My question:
For the PAS to be limited to 25km/ h and 500W peak, and simultaneously the trhottle to 100% 1500W without limit speed, I think the controller should lower the V. (and W.?), don't I?
some controllers to decrease the pas speed: I think they decrease the amps, while others decrease the volts,
What does this controller use?
I wonder why some controllers say lowering speed, but in reality they don't.
Posted: Feb 18 2019 3:35pm
by liveforphysics
zeccato wrote:
Feb 18 2019 1:26pm
My question:
Controllers all just connect the motor phase leads briefly to full pack voltage, watch for current to rise, then disconnect from full pack voltage, and repeats this current control cycle over 10,000 times a second. It never gets to reduce pack voltage, nor would that ever matter or help it function, because the motor only responds to current, and the spikes of voltage input filtered through the motors winding/core inductance is what regulate that current.
With motors, think in terms of power rather than volts/amps and things start to make sense.
Posted: Feb 19 2019 2:05am
by zeccato
Thank you, I'd like an answer about that:
I would like PAS limited to 25km/h 500W peak, and at the same time the TRHOTTLE at 1500W without speed limits, does it?
Note: PAS connected to the controller not to the display, i want to leave the display at home, because a programmable display that can increase the speed, in some countries (like mine) is still not legal.
On my clone Infineon have these functions, and it works well so with: 35% PAS (=450W pik), 100% Trhottle (1500W pik).
Posted: Feb 19 2019 3:22am
by VasiliSk
As i said on russian forum - yes, you will need to setup pas for something like max 30% and for throttle 100%.
Controller regulates current (=torque)
Not sure if you will meet 500W precisely, since it will limit torqe, and power depends on motor speed, but i think with speed limit it should work fine
Posted: Feb 19 2019 4:43am
by zeccato
Thank you, I'm confident that everything will work well, as I asked.
I wish you success
Note: I have found more info on Wiki, thanks.
