Nucular electronics - complete kit for ev! [beta]
VasiliSk   1 kW
Re: Nucular controller
Post by VasiliSk » May 02 2018 4:37pm
GITech, no i don't know about revolt new series, and i do not want use them anymore as we have dev. own motor and it works muuuch better for specific mid-drive ebike.
Not shure that i'm gonna change FET in the near future, as this may lead to some scheme changes.. However i'm gonna develop extreme small 6F version on 75V FET
Yep. Nucular controller :)
madin88   1 GW
1 GW
Post by madin88 » May 03 2018 2:06am
In the russia board there are more infos about the BMS
https://electrotransport.ru/ussr/index. ... msg1304677
some features (translated text):
16S 50A 65 * 100mm
battery heating, 4 temperature sensors, CAN bus, there is still a small built-in display, smooth start, 12 volts is
made for quick-release battery
soft in development. autonomy - yes. programmability - yes. Watch the tapestry voltage - yes
other configurations still in development
GITech   100 W
Post by GITech » May 04 2018 12:36pm
Tnx Vas! My bike has been down for tooo long and I wanna fix it up for this summer...! Rant! lol
Prices and/or ETA on controller and motor? Specs? :shock: 8)
Ebike: Wallmart Genesis frame, unique Lovejoy 2-speed simplified/redundant drive mounted on custom aluminum swingarm conceptualized by me, machined by Thud. Brushless 80-100~100kv w/halls, 16s6p - 59.9v, 30Ah, 1.7+KWh, Fully Loaded Lyen 12 FET 3077 controller w/ Cycle-Analyst, full custom lighting.
Thanks to Justin at ebikes.ca for saving ES!
Ideas and projects by GITech are protected by: http://creativecommons.org/licenses/by-nc-nd/3.0/
VasiliSk   1 kW
Post by VasiliSk » May 04 2018 3:51pm
Controller month~two for www sale, motor needs some investments to start production :P
Bare motor 2.2kW nominal, 2.8kg, 50mOhm for 48V @ 3000rpm, inranner, air cooled. How much this can do in boost i don't know, for almost continious 2kw it stays cool (hill climbs on bike)
madin88   1 GW
1 GW
Post by madin88 » May 05 2018 1:55am
VasiliSk wrote:
May 04 2018 3:51pm
Even if there is high demand, plenty of inquiries etc, you should allow enough time to develop at least the hardware part to the end.
I am not saying there are any issues :) , just were thinking about the Ada**** case.
VasiliSk   1 kW
Post by VasiliSk » May 05 2018 2:03am
I hope hardware finished :lol: 2 yrs of development...
yes i have a good example how-to-not-to-do. aslo i've fixed a lot of hw bugs thx to our betatestes.
Ribiero   10 mW
Post by Ribiero » May 09 2018 1:32pm
Congratulations and good luck with your controller/bms. Would it be possible to have some basic dimensions for the proposed motor. The specs sound very promising and you clearly know what you are doing.
Ribiero   10 mW
Post by Ribiero » May 09 2018 2:51pm
Thanks very much for the speedy reply. Perfect size for ebike packaging. from the information earlier in the thread I make it about 70kv and 5ish Nm.
Ribiero   10 mW
Post by Ribiero » May 09 2018 2:55pm
Thanks very much for the speedy reply. Perfect size for ebike packaging. from the information earlier in the thread I make it about 70kv and 5ish Nm. Just checked out Instagram. Looks great, room for a strong axle, plenty of cooling fins and a 3d fan. Look forward to more updates.
VasiliSk   1 kW
Post by VasiliSk » May 09 2018 3:07pm
Fan was made for electric boat, i don't know yet what loads will be
VasiliSk   1 kW
Post by VasiliSk » May 28 2018 2:33pm
Big update! (English sub.)
Added a lot of features: FOC (sine), cruise, reverse, control modes - speed and torque, charger mode auto start. Motor detect updated.
Willow   10 kW
Post by Willow » May 28 2018 10:41pm
I'm loving it. When can we buy one?
madin88   1 GW
1 GW
Post by madin88 » May 29 2018 2:36am
The feature with the constant speed if battery becomes discharged is nice.
And i like that this controller is compatibile with low resistance / inductance motors due to the low inductive power stage together with ultra quick measurement of currents.
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
Rube   100 W
Post by Rube » May 29 2018 4:01am
Congratulations, must take a lot of hard work and time to configure these features. Very innovative for the hobby market. I look forward to purchase and testing.
VasiliSk   1 kW
Post by VasiliSk » May 29 2018 7:22am
Production delayed, i hope it start selling on July
macribs   1.21 GW
1.21 GW
Post by macribs » May 29 2018 9:56am
VasiliSk wrote:
May 29 2018 7:22am
No problem. Take you time and make it right from the start. You got a lot of people rooting for you here on ES, and we want to see you succeed. Worst thing would be to rush this project to meet the market. Just take your time, do it right and I am sure you will get plenty of support and customer your way.
Great video with lots of nice new features.
litespeed   100 kW
Post by litespeed » May 29 2018 10:47am
Did I miss the pricing on this one or what your thinking to start?
Excellent looking device.
Tom
redline2097   100 W
Post by redline2097 » May 29 2018 1:46pm
VasiliSk wrote:
May 29 2018 1:03pm
~300$ сontroller + display
Amazing.
parabellum   10 MW
Post by parabellum » May 29 2018 2:09pm
Nice features set!
How is the FOC only behaviour at loaded start?
What happens in sensor or combined option if hall sensor fails?
VasiliSk   1 kW
Post by VasiliSk » May 29 2018 2:11pm
Nice start
Currently FOC only sensored, later i will add sensorless FOC also
For square you can switch to sensorless
thorlancaster328   10 W
Post by thorlancaster328 » May 29 2018 2:13pm
What kind of FETs do you use? I assume they're all N-channel. 200 amps for 30 seconds sounds very nice, even across 2 FETs.
And for the over-regen protection, I'd just put a thermistor next to the FETs and dial back the regen if the FETs got too hot.
Find weakest component, upgrade it, repeat until satisfied. Rome was not built in a day.
When in doubt, get bigger MOSFETs / Batteries / Motors / Etc.
