15/18F Silent Controller 36-150V BT-iOS-Android/GPS-$179-199
Powervelocity.com   10 kW
Re: 15/18F Silent Controller 36-150V BT-iOS-Android/GPS-$179-199
Post by Powervelocity.com » Jan 11 2018 1:52pm
Yep, most motors are using either 10K NTC (best) or linear thermistor like KTY. The are super simple to connect - just need to run one wire to the dashboard while the other end is using the common ground. Clyte must have gone against the mainstream by using a sensor with dedicated power. It should still work if you just run the signal wire but you need to know the type of the thermistor and do some extra calibration. It can work, just more hassle to pair it with existing dashboards.
tommy1212 wrote:
Jan 11 2018 8:41am
It's a crystalyte crown tc3080. Thanks for the link ordered and will be to me tomorrow. Seems like the easiest option even for the CA setup.
Powervelocity.com wrote:
Jan 11 2018 2:09am
Hmm, MXUS must have switched to a three leg thermistor. The quickest thing to make it work is just swap it with a 10K NTC thermistor.
Wire one leg to the ground and the other one to the Bluetooth temp input. Done.
This type will provide the best precision:
https://www.amazon.com/Uxcell-a14092200 ... istor+3435
tommy1212   10 mW
Post by tommy1212 » Jan 11 2018 9:18pm
Thanks for the great info. I'm def going with the 10k ntc. Seems most places advertise crown motors with 10k ntc. Not the case with my motor and now I can tell the difference. Will be nice having the power velocity controller displaying motor temp in Fahrenheit which I can relate to better than Celsius.
Jan 11 2018 1:52pm
tommy1212 wrote:
Jan 11 2018 8:41am
Jan 11 2018 2:09am
Post by Powervelocity.com » Jan 12 2018 11:00am
Celsius, Fahrenheit, miles, km - everything is supported and switchable in the app from day one.
More on the app, BT module, what it can do and how to use it is here:
https://endless-sphere.com/forums/viewt ... 31&t=89847
tommy1212 wrote:
Jan 11 2018 9:18pm
Trelos   10 mW
Post by Trelos » Jan 31 2018 11:26pm
Id like to order an 18 fet controller but there is no shipping option to Australia on your website, can you please pm me some details .
Ive emailed but have had no response for 48 hours
Cheers
Stealth bombers , fighter , turbo levo , its a lifestyle !
Post by Powervelocity.com » Feb 01 2018 11:19am
Shipping to Australia or pretty much any country is not a problem.
PM sent.
Trelos wrote:
Jan 31 2018 11:26pm
Cheers
dirttorpedo   1 W
Post by dirttorpedo » Feb 18 2018 4:28pm
Truly amazing controller. With all the info available from Powervelocity.com and this forum, setup and adjustment were a breeze. It's an amazing piece of tech. Way more user friendly and reliable than other expensive and over hyped controllers out there. Very powerful right out of the box.
The Commuter: 2006 GT Kustom Kruiser- 16s LiFePo4 (25ah), generic Chinese motor, Grin 48v 35A
The Trail Bike: 1999 GT XCR-3000- 20s Calibike li-ion (15ah), H3540, Grin 72v 40A
cwah   10 GW
10 GW
Post by cwah » Mar 02 2018 8:24am
Do you have a WATERPROOF and compact version for 60v 40A power?
I'd also need waterproof throttle and regen throttle as complete kit.
Thank you
Help me find my stolen electric brompton: http://bit.ly/1a0vbBC and Bosch Sinus B3 http://bit.ly/1eV0WQz
Post by Powervelocity.com » Mar 02 2018 3:15pm
All controllers are IP65 protected. That means they will sustain any water/moisture exposure excluding full immersion. So, mounting externally and exposing it to the rain is not a problem as long as connectors are protected from moisture.
This applies also to most hall sensor throttles but if you want more protection, IP67 conforming Domino throttle is a good choice.
cwah wrote:
Mar 02 2018 8:24am
Thank you
\ (•◡•) /   1 W
Post by \ (•◡•) / » Mar 03 2018 10:22pm
Hey PowerVelocity, does the IP65 rating include the 24FEt controllers in the new larger case?, Thanks
Post by Powervelocity.com » Mar 05 2018 12:34am
Not by default.
24F have bolt on connectors for battery and phases, so, ideally, need to be mounted somewhere where water can't get on them.
\ (•◡•) / wrote:
Mar 03 2018 10:22pm
amg03andrey@yahoo.com   1 µW
Post by amg03andrey@yahoo.com » Mar 13 2018 11:58am
Hello Friends I really need your expertise ..
I'm trying to build an electric-bike of my dream can you please advise on which one is super better for extreme fast acceleration the battery 86 or 96 volts with 100 AH with 100amps or 150AMPS continuously
with heavy duty cables and plugs..
I need to achieve fastest acceleration as possible super fast from 0 to 60 in couple seconds... !!!
Please help me to get the best controller maybe this one :)?? http://powervelocity.com/index.php?id_p ... er=product
15kW 120v Sinewave/Silent Controller - Android-iOS-Bluetooth Dash & Programming
See my attachment my case on my bike the black one all dimensions are there
The swing arms has been change to with heavy duty, also torque arms has been change to 3/8 steel
I got 8K.W to 10k.w hub motor !!! here is the link for where to buy fast hub motor new FOR 147mm or 150MM dropouts
999zip999   100 GW
Post by 999zip999 » Mar 13 2018 2:37pm
Yes get that controller with bluetooth. Here a link for more motor info.https://endless-sphere.com/forums/viewt ... 31&t=65972
agedashidofu   1 W
Post by agedashidofu » Mar 14 2018 8:51pm
Hello,
So sorry if this question has been answered before.
I'm planning to run 18F version sensorless (as my hub motor is now w/o hall sensor)
Will the App on iphone be able to pick up / read the speed and rpm?
If not, if I connect this to cycle analyst, will it be able to pick up / read the speed and rpm?
many thanks for your help on this!
Post by Powervelocity.com » Mar 14 2018 10:39pm
Neither CA nor any other dashboard device can pick up speed from nothing, so it will need some kind of a sensor. If you are not using motor hall sensors, the easiest solution is to install a sensor on your rear or front wheel with a magnet fixed to a spoke. I can provide this.
Then the app/BT module and/or CA will be able pick up RPMs/speed.
agedashidofu wrote:
Mar 14 2018 8:51pm
Hello,
Flyin Hawaiian   10 µW
10 µW
Post by Flyin Hawaiian » Mar 15 2018 5:18pm
I purchased the 18F + BT controller. Unfortunately, after plugging everything in I am not seeing the controller listed in the PowerVelocity App in either the Programmer or Settings views. I did plug in a CA and verified that I am getting power.
Anyone have some suggestions on how to connect the controller to the app. Im using a iPhone 6s plus with the latest iOS 11.2.6 (15D100)
Thanks!
Grip and rip!
Post by Powervelocity.com » Mar 15 2018 5:59pm
The controller will be visible once you turn on the ignition. Have you done that?
Also, make sure the Bluetooth on the phone is turned on.
Then go to Settings - Manage. You should be able to see "PowerVeloCity-i" in the list of Bluetooth devices.
Flyin Hawaiian wrote:
Mar 15 2018 5:18pm
Thanks!
10 µW
Post by Flyin Hawaiian » Mar 15 2018 8:25pm
Yes, I wired up a key ignition. When turning the key, the CA turned on which I used to verify that the controller is powered on. Bluetooth on my phone is turned on. However, I am not seeing "PowerVeloCity-i" listed.
I appreciate your support Vad!
Mar 15 2018 5:59pm
Mar 15 2018 5:18pm
Thanks!
Grip and rip!
Post by Powervelocity.com » Mar 16 2018 3:42am
PM please - we'll get it resolved.
Mar 15 2018 8:25pm
Mar 15 2018 5:59pm
Mar 15 2018 5:18pm
Thanks!
brumbrum   100 kW
Post by brumbrum » Mar 22 2018 3:17pm
I bet these questions have been asked before but after scanning a number of pages i cannot find the answers...
1. Have these controllers been tested with any mid-drive motors?
2. Is it possible to get a square wave version of the 18fet with blue tooth?
My NYX and cromotor build
viewtopic.php?f=6&t=74615
My LMX 161 dirt bike build
viewtopic.php?f=6&t=94074
Post by Powervelocity.com » Mar 22 2018 6:21pm
1. Yes
2. and Yes
The only thing is that the middrive needs to be lower pole count (up to 8 poles ideally) and lower KV (probably up to 50kv the most) to work well. We have good success using controllers with LightningRods middrive kits (https://endless-sphere.com/forums/viewt ... start=4850)
The dual mode controller version will run square wave if you disconnect sensors (sensorless mode).
brumbrum wrote:
Mar 22 2018 3:17pm
dapkcuf   100 µW
100 µW
Post by dapkcuf » Mar 26 2018 10:02am
Hello Powervelocity,
I would like to buy one of your 12F controller (the one that include the dual mode), however shipping to France is not possible on your website.
Could you please let me know how to proceed ?
I am planning to run it on a magic pie 4 with 22s8p battery pack. Will it work properly?
Thanks.
paul drury   10 mW
Post by paul drury » Mar 27 2018 3:03am
Good morning,
I have the 12FET controller with the bluetooth programming but I am experiencing a few problems with the software. I am using android and I have paired the controller without a problem, I launch the app and set the type to F12-100 and it says ready to program, I hit read and the app just hangs and then times out, I know its probably something very simple that I am missing but any help would be appreciated.
thanks
Paul
Post by Powervelocity.com » Mar 28 2018 9:28am
Please make sure to download the latest version of the app from the Google Play store. Make sure your phone is connected to the internet. Open the app and go to the Settings and Maanage to connect to the controller (it needs to be on). Go back to Settings and wait 20 seconds or so. It will prompt to update the module firmware if you have not updated it yet. Update the module firmware if prompted.
Then go to the Programmer and try to Read again.
paul drury wrote:
Mar 27 2018 3:03am
Good morning,
thanks
Paul
Post by Powervelocity.com » Mar 28 2018 9:33am
Please direct all order inquiries to sales@powervelocity.com
It will work fine with a magic pie.
dapkcuf wrote:
Mar 26 2018 10:02am
Thanks.
