15/18F Silent Controller 36-150V BT-iOS-Android/GPS-$179-199
spata   1 W
1 W
Re: 18F Silent Controller 36-150V VAR.REGEN/BT Progrm/GPS-$1
Post by spata » Sep 29 2016 4:34am
For anyone interested XPD have also added a description of the KH6XX (sinewave) protocol HERE.
- Spata
Mad Huey   100 mW
Post by Mad Huey » Sep 29 2016 10:11am
Hey POWERVELOCITY i sent a PMI asking for your paypal details. Wanting a cintroller asap
ABritInNY   100 W
Post by ABritInNY » Sep 29 2016 5:43pm
Powervelocity.com wrote:Just wanted to share some good news. We have been quietly working with XPD Software developer to add the programming functionality for the sinewave controllers.
So, it's official now: XPD supports programming for sinewave controllers we sell. That means you have yet another option to program your controller using a better quality software compared to native configurator. That means also you can use multiple platforms other than Windows. That includes Macs and other *nix type of systems or anything that can run Python.
New version of XPD can be downloaded here:
https://sourceforge.net/p/xpd-ebike/cod ... ree/trunk/
OK so I know you said it was better quality software, but it seems to have less scalabilty for the functions I need, not more. The software you gave, allows me more fine control over regen whereas this has only 3 settings. I see that block time settings are tweakable but I always leave at 1 second so irrelevant to me.
What board do we select 4 sinewave? regular 218? are all voltage settings r12 mod friendly (like the android app,) or still skewed? Do you perhaps have recommended settings for XPD that work well for us to try, or do we just experiment?
Still very good news :D the more variety of options the merrier I guess :wink:
EEB frame w/ 1500w Leafmotor 4t winding,
3000w Mxus 3T w/upgraded teflon phase wires
Powervelocity 18fet - Lyen 18 fet 4110 ESC's, 24s 30ah prismatic cell Lifepo4 batt w/60a-120a BMS,
20Ah lifepo4 5c cells w/65a- 85a bms
CA V3, Dropper Seat post.
[Fusion 48v AGM (4x 12v 15ah) 1000w nom DD rear hub, 50a max ESC, 21sp FS Genesis overkill 650b conversion]
Alan B   100 GW
Post by Alan B » Sep 29 2016 6:20pm
They still have block time variable? I would set that to zero in all cases. Telling the software to ignore the phase current at launch can lead to such high currents that the FETs fail. I blew one 24 FET controller 5 times with a low impedance high current battery and a Cromotor. Super high phase currents also generate a lot of motor heat. They do make fun thrust, but choosing a reasonable phase current should give adequate thrust.
If folks still want a "high thrust launch" which is what block time is for, there should be a separate phase current setting for it, other than "whatever the battery can deliver and the motor can take" which could be more than the FETs can handle. Or perhaps there is such a limit programmed into the controller already, and that is what is used during block time. If so, then it is already covered.
izeman   100 GW
Post by izeman » Sep 30 2016 12:26am
Yes. Block time set anything else but ZERO is a controller killer.
Gesendet von iPhone mit Tapatalk Pro
Powervelocity.com   10 kW
Post by Powervelocity.com » Sep 30 2016 4:32am
That's good to know. I've never paid too much attention to this setting but have now disabled it completely and hid in the smartphone interface, so it's not programmable anymore.
Interesting though, I've seen another definition for Block time. Something like this:
BlockTime: The amount of time to try rolling the wheel before deciding that it has been blocked (e.g. if the Hall sensors signals won’t change for that much time, the controller will stop trying).
I guess that's wrong?
Alan B wrote:They still have block time variable? I would set that to zero in all cases. Telling the software to ignore the phase current at launch can lead to such high currents that the FETs fail. I blew one 24 FET controller 5 times with a low impedance high current battery and a Cromotor. Super high phase currents also generate a lot of motor heat. They do make fun thrust, but choosing a reasonable phase current should give adequate thrust.
izeman   100 GW
Post by izeman » Sep 30 2016 6:22am
your explanation may be correct. at least it sounds logical, that the naming comes from "blocking the wheel".
basically setting it to a specific values, disables the set current limit for the set time. so your battery and/or the installed FETs are the limit. and if your battery is powerful enough (and not limited by eg a CA) it will allow the FETs to suck all the current they can from the battery. and this MAY be too much for them. and you will receive some dead units for repair :(
unfortunately this block time thing makes your controller look very powerful. it gives a very snappy start from a standstill. this boost is only there for a fraction of a second (or up to several seconds), but as these electronics blow within milliseconds it can be way too long.
maybe try it out yourself?! and better to keep it set to 0 by default, and make this a "void waranty" feature (if you can include that in the firmware, like some kind of software fuse).
Alan B   100 GW
Post by Alan B » Sep 30 2016 6:52am
Perhaps the manufacturer should answer the question and define the parameter.
Post by Powervelocity.com » Sep 30 2016 11:38am
Should be easy to verify what it really is - current overshoot or hall detection delay. I'll test over the weekend and post results.
izeman wrote:your explanation may be correct. at least it sounds logical, that the naming comes from "blocking the wheel".
Baron   100 W
Post by Baron » Oct 02 2016 3:31pm
Hey, I have the 12fet controller. Where can I download the programming software?
evolutiongts   10 kW
Post by evolutiongts » Oct 02 2016 7:24pm
Excellent
http://www.electricrt.com
Electric Race Technologies
Schwinn 405 2WD Track Bike 18KW
EDGE 1500W Hub / MXUS 3K Turbo
ASI BAC 2000 / BAC 4000 Bluetooth
viewtopic.php?f=6&t=93079
10Kw KMX death trike
MUXUS 3K Turbo
Sabvoton 72V150A
Moto Wheels all around
Front Suspension Kit
viewtopic.php?f=6&t=83423
Giant Trance 4 Full Suspension
Cyclone 3000W
74V 3000W
http://endless-sphere.com/forums/viewto ... =6&t=59005
Baron   100 W
Post by Baron » Oct 03 2016 1:02am
Powervelocity.com wrote:https://sourceforge.net/p/xpd-ebike/cod ... ree/trunk/
your link's broken, but I guess the software is called xpd-ebike https://sourceforge.net/projects/xpd-ebike/
Jestronix   10 kW
Post by Jestronix » Oct 04 2016 7:20am
Anyone have a quick color wiring chart for this controller ? I can guess most be could be a good sticky for this controller.
Post by Powervelocity.com » Oct 04 2016 1:34pm
Here is one for 12Fet but, it's almost the same.
Jestronix wrote:Anyone have a quick color wiring chart for this controller ? I can guess most be could be a good sticky for this controller.
ABritInNY   100 W
Post by ABritInNY » Oct 04 2016 10:56pm
What kind of switch is needed for the cruise activation wire? Do you sell one?
Jestronix   10 kW
Post by Jestronix » Oct 05 2016 12:25am
Powervelocity.com wrote:Here is one for 12Fet but, it's almost the same.
Legend ! in two ways :)
Alan B   100 GW
Post by Alan B » Oct 05 2016 12:47am
There are labelled tubes on the wires denoting the connector on my 12 FET. Nice marking.
Color codes for the individual connectors would be good, are they the same as some other controllers that we already use, perhaps?
Post by Powervelocity.com » Oct 05 2016 1:42am
Wire colors are very much similar to Xie Chang family of controllers with just slight variations.
all wiring is super easy to identify even without marking just by looking at the connectors. Well, if you dealt with controllers before.
Five pin hall sensor connector is self explanatory, as well as battery and phase wires.
What's left is a throttle 3 pin (black, blue, green), a two-pin ebrake (blue with white stripe, black), cruise (solid blue, black), three pin 3 speed connector (black, black, gray).
Optional can be two other connectors for alarm: two-pin power - black and red (gotta be careful with these as they supply pack voltage, not 5v), and alarm signal (orange, brown and pink).
Single purple wire is a high ebrake that can be used instead of regular ebrake to enable stop lights as it is shorted to battery positive instead of ground like in case with low ebrake (EBS-).
That's pretty much it.
Alan B wrote:There are labelled tubes on the wires denoting the connector on my 12 FET. Nice marking.
