15/18F Silent Controller 36-150V BT-iOS-Android/GPS-$179-199
alsmith   100 kW
Re: 15F/18F SW/Silent Controller 36-150V BT-Android/GPS-$179
Post by alsmith » Feb 20 2017 2:49pm
[quote="Powervelocity.com"]There are a couple of tricks how to minimize the risk of pulling the solder pads from the PCB after soldering wires onto them. The easiest one is to tie those wires in a knot right in front of the silicon gasket exit point. That way pulling wires from the outside will not cause pilling the solder pads inside as the knot will be stopping it. However, I would go with the X4 pin mod first.
Yep, I should have done that!
Powervelocity.com   10 kW
Post by Powervelocity.com » Feb 20 2017 9:58pm
A new version of the Android app is released. Lots of improvements, here is just a few to mention:
- Complete support for all versions of controllers including 6, 12, 15, 18, and 24 Fet, 100V, 120V, and 150V;
- LVC, Regen Voltage, etc. are now precisely calibrated - what you set is what you get;
- Bug fixes.
Available for download here:
http://powervelocity.com/index.php?cont ... achment=25
Post by Powervelocity.com » Feb 28 2017 4:24pm
Android App Update 2/28/2017
Every setting is now accompanied with the description of what it does. Just tap the question mark.
The updated version is here:
http://powervelocity.com/index.php?cont ... achment=27
FluxZoom   100 W
Post by FluxZoom » Apr 03 2017 7:27am
FluxZoom wrote:How goes the progress on making a way to display things like speed, watt hours consumed, Wh/mi and so on? Last I heard vargen was still in beta, has this changed?
Powervelocity.com wrote:Targeting march.
Any update on the timing? Thanks!
Post by Powervelocity.com » Apr 03 2017 11:15pm
Hopefully, "soon". Takes a lot of time to get things right.
shakira_81   1 µW
Re: 15/18F Silent Controller 36-150V BT-iOS-Android/GPS-$179
Post by shakira_81 » Apr 08 2017 7:44am
Hello
I'm interesting of your 18fet controller, can you write me back if you can help me?
redline2097   100 W
Post by redline2097 » Apr 09 2017 12:37pm
How I should setup these parameters order to run about 30% overspeed:
Flux weakening level, finetune, position, turnpoint?
Post by Powervelocity.com » Apr 10 2017 1:15am
Just set speed to 130%, that would be 30% above the normal speed.
Flux and other parameters take some experimenting to get them to work on a particular motor.
I was able to reach 130mph freewheeling on MXUS3000 in a 17'' moto rim at 100v with Flux set to 24 and everything else set to 0.
With other motors, parameters may need to be different.
redline2097 wrote:How I should setup these parameters order to run about 30% overspeed:
redline2097   100 W
Post by redline2097 » Apr 10 2017 1:18am
Powervelocity.com wrote:Just set speed to 130%, that would be 30% above the normal spees.
I have MXUS3000 4T in 17" moto rim. I will test the flux later with rest settings to 0 too. :)
redline2097   100 W
Post by redline2097 » Apr 11 2017 6:24am
Does the regen support throttle instead of push button? I have push button now and it hits pretty hard :D
Ecyclist   1 kW
Post by Ecyclist » Apr 12 2017 10:17am
What is max erpm this controller can handle?
Don't expect from life to be easy and then it will be.
My builds:
Avian with hypocycloidal drive https://endless-sphere.com/forums/viewt ... 2#p1318056
2016 GNG extreme drive https://endless-sphere.com/forums/viewt ... 28&t=82252
redline2097   100 W
Post by redline2097 » Apr 12 2017 2:44pm
Before I set anything, which setting on flux should be close to 130%? :)
Post by Powervelocity.com » Apr 13 2017 10:30pm
The regen strength has a huge adjustment range from 0 to 200. Just set it to 20 or 30 units. It will be very light.
redline2097 wrote:Does the regen support throttle instead of push button? I have push button now and it hits pretty hard :D
redline2097   100 W
Post by redline2097 » Apr 16 2017 9:32am
Hmm odd. I don't have any effect on any Flux weakening or 130% speed option. I top always about 52-54kmh. I use the latest G55 trunk of xps program and trying to modify KH618 profile. Is this correct?
Do you happen to have some configuration file for mxus on your pc? I could try your setup. Only volts/amps modified.
Post by Powervelocity.com » Apr 16 2017 7:39pm
Can't tell about XPD as I am not using it.
I was using the native software to get it up to 130 mph when I tested.
I'll PM the profile.
redline2097 wrote:Hmm odd. I don't have any effect on any Flux weakening or 130% speed option. I top always about 52-54kmh. I use the latest G55 trunk of xps program and trying to modify KH618 profile. Is this correct?
redline2097   100 W
Post by redline2097 » Apr 20 2017 5:15am
This is just theoretical question:
If flux weakening is set to target 130% speed and I am using Switch 2: setting 77% (77*1,3=100). Will the controller eat more battery than driving without flux at speed 100%? So same total speed, other is without flux and other is with it.
I want to have three power speed levels on different purposes:
1) 50% speed with low battery amps when pedaling on urban to getting max mileage from battery
2) 100% speed with high battery amps when cruising on enduro type terrain
3) 130% overspeed setting with very high battery amps when wanting full power of bike
Post by Powervelocity.com » Apr 20 2017 10:46am
Without testing, I would say that, if there is any difference, it would be negligible. With all other things being equal, the consumption will be about the same with or without flux enabled and the switch set in position 2. Based on my observation, flux weakening kicks in when the throttle is wide open. Technically, settings it at 77% will limit that.
Power consumption will depend primarily on how fast you accelerate and how fast you cruise. Speed and acceleration rate affects the current draw.
In my case, 30-40mph is the best practical and efficient speed range when the current draw is withing 20-40A. With that, I can easily go 50 miles per charge on a 3.3kwh battery pack.
I can probably get up to 100 miles if I baby the throttle and cruise at 20 mph.
redline2097 wrote:This is just theoretical question:
cero   10 mW
Post by cero » Apr 22 2017 1:04pm
Powervelocity.com wrote: flux weakening kicks in when the throttle is wide open.
Does it kick in, just when the throttle is wide open, even at low speeds or when the throttle is wide open and 100% speed is reached?
Today I discover some strange thing about the controller.
I unsoldered regeneration BK bridge, and find out that if I press the brake, regeneration is still working at speeds over 13km/h, bellow 13km/h controller locks the motor same as antitheft.
Post by Powervelocity.com » Apr 24 2017 1:18am
Good question.
I tested at WOT and 130% speed. It kicked in at that time.
I am almost positive that it should not kick in at low speeds as that makes no sense if you still have voltage to spin the motor faster without flux. I'll double check and post the results.
Ecyclist   1 kW
Post by Ecyclist » Apr 24 2017 11:15am
My builds:
