MXUS 3K Turbo (V3) 45mm Direct Drive Hub Motor
amberwolf   100 GW
Re: MXUS 3K Turbo (V3) 45mm Direct Drive Hub Motor
Post by amberwolf » Jan 11 2017 1:27am
The v2 above is about 20lbs; I doubt v3 would add almost 50% more weight.
Offroader   100 MW
Post by Offroader » Jan 11 2017 2:05am
Yes 20.6 is almost exactly what the V3 Turbo weighs, I've weighed it.
Aceinthesky   10 mW
Post by Aceinthesky » Feb 15 2017 5:59pm
So I bought a mxus 3000w turbo v3 from faster bikes. Finally got around to installing it only to find that one set of hall sensor wires do not work. I was get to get the motor working with the other set of hall sensors. I'm using ca v3 with and Infineon 18fte controller. I got everything working and dialed in I just can't get the temperature sensor to work. I used some post on the forum to plug in the right values for the sensor but it just shows -120 degrees no matter wether the sensor is plugged In or not. I have the ca with seperate speedometer sensor. Any ideas, could I have a bad sensor.
Offroader   100 MW
Post by Offroader » Feb 15 2017 11:12pm
Aceinthesky wrote:So I bought a mxus 3000w turbo v3 from faster bikes. Finally got around to installing it only to find that one set of hall sensor wires do not work. I was get to get the motor working with the other set of hall sensors. I'm using ca v3 with and Infineon 18fte controller. I got everything working and dialed in I just can't get the temperature sensor to work. I used some post on the forum to plug in the right values for the sensor but it just shows -120 degrees no matter wether the sensor is plugged In or not. I have the ca with seperate speedometer sensor. Any ideas, could I have a bad sensor.
What is the Ohm resistance of the temp sensor wires? Should read something like 900-1000 ohms.
You do know that there are two temp sensors on the v3? I believe they may both share the same ground wire, but they may be separate wires.
bionicdan   1 kW
Post by bionicdan » Feb 22 2017 6:04am
My motor acts very differently from one set of halls to the next and wonder if my 18fet infineon/cellman controller is switching to sensor less. Its much more grunty and gritty sounding on one set and soft and lower powered on the other.
When i first ran it i left one set of halls bare and bundled together. Can this damage them?
GEARS? Where we're going we dont need gears!
Due to metal plates and a body full of nuts and bolts I am as bionic as my bike. Mxus 4t 120v toshiba fets and 16ah 24s nanotech.
DAND214   1 GW
1 GW
Location: About 1200 miles south of Chicago, in sunny/rainny Port Richey, Florida!
Post by DAND214 » Feb 22 2017 11:15am
bionicdan wrote:My motor acts very differently from one set of halls to the next and wonder if my 18fet infineon/cellman controller is switching to sensor less. Its much more grunty and gritty sounding on one set and soft and lower powered on the other.
I don't believe that controller will run Sensorless.
Dan
teslanv   100 MW
Post by teslanv » Feb 22 2017 11:25am
It's possible that one set of halls is damaged. Have you tested both sets of halls?
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
teslanv   100 MW
Post by teslanv » Feb 22 2017 11:27am
Yes, there are two sets of Hall and temp sensors on the 3K-Turbo motors. The temp sensors are probably KTY83/110 sensors. Teklektik did a nice write-up of how to program a CA V3 with the KTY83/110 sensor here:
viewtopic.php?f=2&t=76133#p1149859
Bellevue, WA
USA
snejky   10 W
Post by snejky » May 11 2017 12:53am
Hi. I need to know speed range on 23 inch tyre, 21s, 4T. Any experience? Thank you :-)
amberwolf   100 GW
Post by amberwolf » May 11 2017 1:32am
You might check the http://ebikes.ca/simulator
PIck show all from dropdown menu on motors, then mxus 4504
snejky   10 W
Post by snejky » May 15 2017 2:58am
Thank you, solved. :-)
snejky   10 W
Post by snejky » Jun 27 2017 2:13am
Hi. Which type of Honeywell sensor is most suitable for mxus? There is lot of types. Thanks
teslanv   100 MW
Post by teslanv » Jun 27 2017 7:49am
snejky wrote:Hi. Which type of Honeywell sensor is most suitable for mxus? There is lot of types. Thanks
http://www.ebikes.ca/catalog/product/ga ... 706/id/310
Bellevue, WA
USA
lionelt   10 mW
Post by lionelt » Aug 16 2017 4:56am
I've MXUS V3 4T, as i ride on mountain (french alps) i need more torque (more amps phase), my ctl Lyen18FET can 80A/250A but motor wires are too thin and become hot very quickly. Also as a sensor set is failed (due to high temp probably), i would do these mods :
0 - remplace actual rim 26" by a 17" mc and tire shinco 241 17x3 for more torque
1 - add heatsink + ff to avoid quick increase heat
2 - change sensor set : ok ref is HONEYWELL ss41
3 - change phase wires ==> What maximum size can be passed without modification of the axis? 10WG, 8AWG or idealy 7AWG ?
thx for your advice
Vector MXUS V3
18FET Lyen
18S 40AH LIPO
E-Chopper Nirve Switchblade
GM MP2 front wheel
GT 130 Wattmeter
48V 12Ah LI-ION case
All electronic & battery inside bag in leather brown assorted with Seal and handle
Range 35 kms - Speed 40km/h no assist direct from handle throtle
madin88   1 GW
1 GW
Post by madin88 » Aug 16 2017 11:25am
0: 17" i call the optimal size. the shinko 241 is a good choice, but on one of my own bikes i took the 2,75" wide type simply because it doesn't look so beefy. I read somewhere that the 3" has softer rubber, but could not compare them..
2: take the SS413a "L" type if you can find them (L means they will fit into the slots) and install them properly. the sensor in the middle which is loacted between two stator teeth often is mounted twisted by the factory.
3: do you really have the V3 version? :)
If so, than there should be no overheating issues as the cross section is similar (or even larger?) as the winding itself ;)
However, if you are after every % of performance than you could upgrade them outside of the motor (you may be able to squeeze larger wires through the axle, but it will not be easy as i can say from own experience).
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
999zip999   100 GW
Post by 999zip999 » Aug 16 2017 2:11pm
Just use heavy phase wires about10 inches up. Pretty hard to pull fatter wire thru that axle.
korpin   10 kW
Post by korpin » Sep 22 2017 7:35pm
so...my motor says XF4045 1604 0109 I am guessing the 1604 means 4 turn motor correct?? can an expert message me?
teslanv   100 MW
Post by teslanv » Sep 22 2017 11:32pm
korpin wrote:so...my motor says XF4045 1604 0109 I am guessing the 1604 means 4 turn motor correct?? can an expert message me?
Nope. 1604 is the month & year. April 2016.
The winding is not indicated in the serial number, but it should be hand written on the stator. Have to pull a cover off to see it.
Bellevue, WA
USA
markz   100 GW
Post by markz » Sep 24 2017 10:31pm
There is another way I've read here on Endless Sphere to get the KV of a motor, but you'd need a power supply at known voltage, and run it unloaded, and a rpm meter. I've seen something similar that looks like this being used on YT.
http://www.ebay.ca/itm/Digital-LCD-Lase ... 77&vxp=mtr
They used a piece of reflective tape.
But yeah the MXUS would have it written with a marker on the inside somewhere, thats the easiest way, but if its not, then you know what to do.
grga   1 W
1 W
Post by grga » Nov 11 2017 8:44pm
What do you guys think about V3 Turbo 3T on 20S LiFePo4 and 50A, top speed?
amberwolf   100 GW
Post by amberwolf » Nov 12 2017 1:06am
choose mxus 4503 for motor
markz   100 GW
Post by markz » Nov 12 2017 4:26am
grga wrote:What do you guys think about V3 Turbo 3T on 20S LiFePo4 and 50A, top speed?
Why do you want to go so fast, or are you lacing that into a hill climbing monster on like 16" wheel which only loses 10kph or so. Where do you have do be in such a hurry?
ebike11   1 MW
Post by ebike11 » Nov 12 2017 10:16am
Hi guys
Just got the 3000w turbo
It didnt come with a freewheel sprocket. Id like to get a single speed that can be removed with a tool to compare different freewheels with different tooth counts.
Id like to stay away from the chinese ones that i see all over the place. Perhaps a Shimano. But i dont know the thread etc. specs. of the motor. What are you guys using?
Thx in advance
teslanv   100 MW
Post by teslanv » Nov 12 2017 10:19am
ebike11 wrote:Hi guys
Thx in advance
For a single speed, you'll want to decide which is more important: Easy Pedaling when you run out of power, or being able to pedal along with the motor at higher speeds.
For Easy Pedaling, I like the ACS Crossfire Freewheels, in a 18T or bigger.
For High Speed pedaling, a 12T Freewheel is handy.
Bellevue, WA
USA
markz   100 GW
Post by markz » Nov 12 2017 1:27pm
Its not a pleasure pedaling with no juice, I've been there a handful of times with the mxus 3kw motor.
