MXUS 3K Turbo (V3) 45mm Direct Drive Hub Motor
L3chef   10 W
Re: MXUS 3K Turbo (V3) 45mm Direct Drive Hub Motor
Post by L3chef » Sep 17 2018 8:44am
Hello! Recieved my mxus v3 3k that I ordered from MXUS alibaba. Shouldn't the v3 come with 4mm phase wires as standard? I think mine are 2.5mm .. I don't have any caliper here with me to measure them but they don't look to be 4mm..
https://ibb.co/dOrzre
https://ibb.co/govg4z
Ouh I posted this in the wrong thread. My bad.
Duncan75   10 mW
Post by Duncan75 » Nov 24 2018 1:40pm
I've also received one with thin non-copper wires and had to replace them.
If you want to have piece of mind, it's advisable to upgrade the wires and bearings on these.
wojtek   100 kW
Post by wojtek » Jul 03 2019 11:38am
I never had a motor that has 2 x hall sensors. Does it make sense to connect the respective wires together?
Velokraft Batmobile
KMX Cobra with Xlyte 5403
Go-One Evo with Cromotor
BATMOBILE - in progress
Giant CRS Alliance - SOLD
3Element Espire - SOLD
Custom built Specialized BigHit with BBS02
Velokraft e-VK3
Velokraft Vk2
Steintrike Mungo Sport HS3540
Scorpion FS HS3540
Kona Dawg BMC v2
minde28383   10 kW
Post by minde28383 » Jul 03 2019 12:03pm
wojtek wrote:
Jul 03 2019 11:38am
Never had an idea to connect respective wires. Second set of halls are in case first set brakes.
ebike11   1 MW
Post by ebike11 » Sep 18 2019 4:37pm
Are the threads of the axle/axle nut M16 x 1.5 ???
Jonboy   1 kW
Post by Jonboy » Feb 02 2021 3:52pm
16 with 10mm flat.. 1.5 tread
6moe66   1 mW
Post by 6moe66 » Feb 13 2021 5:02pm
Love the 3KT but can anyone explain the resolver poles?
I have set up my Kelly KLS with 23 Motor Poles(x2) as there are physically 46 magnets but what should i be setting the resolver poles to and what difference will it make when programming?
Also, has anyone got the motor temp sensor working on a Kelly controller? Specifically the KLS72 -S?
