US Group buy for the new MXUS 3000w V3
Motobikewheels   100 W
Post by Motobikewheels » Mar 02 2016 5:27am
Last year i did a ton of wheel builds for es members under the username roadrash and made descent money doing it, so i figured i would give back to the community and do a group buy for the new MXUS V3 motors.
The motors have gone up $20 from the v2
Total price would be $240 with the m16 axle shipped to your door if you live in the Continental US as long as we get over 20 motors
Upgrades
4mm² phase wires
6004 Bearing 20mm on the wire side
20mm axle (partial)
Two set of hall sensors
Also offering a smokin deal on wheel builds
$160 16" prowheel with SS spokes laced and trued
$170 17" MMP with SS spokes laced and trued
$150 19" MMP with SS spokes laced and trued
OR take off 40 if you want to DIY and just need the rim and spokes
Re: US Group buy for the NEW MXUS 3000w V3
Post by Motobikewheels » Mar 02 2016 6:01am
3 fatbikerider
1 motobikewheels
1 maxRpm
1 skWarDog DIY 17" rim and spokes
1 wye 19" DIY rim and spokes
1 gelroos laced 19" rim
1 moonshine 4t 19" rim black spokes laced
1 fl bomber laced white 17" rim
1 Seraphim Pheonix laced 19" rim
1 devo1223 laced 19" rim
1 tiny_n_terrible laced 19" rim 4T
1 dansir413 laced 19" rim
1 ElecTech bare 4T
1 999zip999 bare 4T
maxRpm   10 W
Post by maxRpm » Mar 02 2016 9:04am
I'll decently jump on this as soon as 20+ sign on.
skWarDog   100 W
Re: US Group buy for the new MXUS 3000w V3
Post by skWarDog » Mar 03 2016 4:17am
I'm interested, starting to gather bits to put together an Intense 951 frame to add to the fleet now. Might as well try a MXUS, sounds like a great price! Wondering how much that chunk of Changzhou City scrap iron weighs though? Heavy, right? :roll: I'll deal with it though.....first take it apart make sure it's tight & right. Then drill & mill it and dip n' bake it... that'll keep it cool & hold it together, too!!
Think I'll pick-up a 17" wheel kit off you. I prefer assembling my own wheels though. Besides, I need to drop the stator in the dip tank first. Hey, how come the 17" rim & spoke kit is more expensive than the 19"? Isn't the rim smaller and spokes shorter, so there's less metal????? :o
"Whiskey for Me, Electricity for my Horse"
If you can't Dazzle them with Brilliance, Baffle 'em with BS!
Tits SuMo Juice Bagger http://endless-sphere.com/forums/viewto ... =6&t=65448
[+] sk
silent killa
wye   10 mW
Post by wye » Mar 03 2016 6:09am
Hello,
I would like to purchase one of these . With a 19" rim .
One of the new things people began to find out in the last century was that thoughts--just mere thoughts--are as powerful as electric batteries--as good for one as sunlight is, or as bad for one as poison. To let a sad thought or a bad one get into your mind is as dangerous as letting a scarlet fever germ get into your body. If you let it stay there after it has got in you may never get over it as long as you live.
Frances Hodgson Burnett, The Secret Garden
markz   100 GW
Post by markz » Mar 05 2016 2:29pm
Whats the difference between the factory MXUS 3000W V2 and the factory MXUS 3000 V3?
farmerjoe99   1 W
1 W
Post by farmerjoe99 » Mar 05 2016 2:43pm
markz wrote:Whats the difference between the factory MXUS 3000W V2 and the factory MXUS 3000 V3?
"Upgrades
4mm² phase wires
20mm axle (partial)
Two set of hall sensors"
for more info here's the announcement thread:
viewtopic.php?f=30&t=76109
markz   100 GW
Post by markz » Mar 05 2016 4:24pm
Yeah I didnt know if you upgraded it then spun it as V3.
Thats totally cool the factory is doing that.
Whats the purpose of 6 halls instead of the usual 3?
farmerjoe99   1 W
1 W
Post by farmerjoe99 » Mar 05 2016 5:55pm
I'm not sure but I think the idea is in the case one set fails you can use the other set without having to tear down the
motor and fix the original set.
I see in the other thread I posted a link to above the v3 can come with thicker "bent" magnets will those be
in these motors or are they special order?
Post by Motobikewheels » Mar 05 2016 6:26pm
farmerjoe99 wrote:I'm not sure but I think the idea is in the case one set fails you can use the other set without having to tear down the
Yeah the extra set of halls is for a backup and i'm pretty sure all the v3 motors will have the bent magnets. I will check with mxus tonight
teslanv   100 MW
Post by teslanv » Mar 05 2016 9:36pm
Motobikewheels wrote: Yeah the extra set of halls is for a backup and i'm pretty sure all the v3 motors will have the bent magnets. I will check with mxus tonight
The bent magnets are not standard, as far as I am aware. At least it was an up charge on my motor order.
Same with the M16 axles. I had to buy an MOQ of 100 pcs to get those...
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
cassschr1   10 kW
Post by cassschr1 » Mar 05 2016 10:58pm
Can someone explain bent magnets.
spinningmagnets   100 GW
Post by spinningmagnets » Mar 05 2016 11:07pm
Better to call them curved, and they are curved so that they fit perfectly against the cylindrical steel backing rim. Theres no picture in this thread, but somewhere around here is a comparison pic showing a closeup comparison between the short / flat magnets arranged around the inside diameter of the round outer rim, and the curved magnets that fit perfectly. Its a small improvement, but it costs near the same, and its the way they should be in order to get the maximum power and efficiency in the smallest, lightest, and least expensive motor of its power level.
Post by Motobikewheels » Mar 06 2016 9:00pm
spinningmagnets wrote:Better to call them curved, and they are curved so that they fit perfectly against the cylindrical steel backing rim. Theres no picture in this thread, but somewhere around here is a comparison pic showing a closeup comparison between the short / flat magnets arranged around the inside diameter of the round outer rim, and the curved magnets that fit perfectly. Its a small improvement, but it costs near the same, and its the way they should be in order to get the maximum power and efficiency in the smallest, lightest, and least expensive motor of its power level.
Still waiting on a response from MXUS. I'm sure one way or another we can have these motors built with the curved magnets
DanGT86   100 kW
Post by DanGT86 » Mar 06 2016 11:43pm
Probably no way this would fall under the group buy pricing but is there a front wheel motor option? Does that even exist? I got a drift trike project on the back burner that I can't help but think deserves one of these.
Post by Motobikewheels » Mar 07 2016 1:27am
DanGT86 wrote:Probably no way this would fall under the group buy pricing but is there a front wheel motor option? Does that even exist? I got a drift trike project on the back burner that I can't help but think deserves one of these.
135mm steel fat bike fork would work.
Samd   1.21 GW
1.21 GW
Post by Samd » Mar 07 2016 2:26am
Hang on a minute. A number of people busted their butts to develop that motor and even invested in custom axles. Now there's a group buy?
http://ballaratebikes.com/
gelroos   1 mW
Post by gelroos » Mar 07 2016 4:50pm
I'd be down for one laced into a 19".
Steveo's OLD X6 Kmx Trike ~ 24s 12ah/X6 MHM 602/Infinion EB324 IRFB 4110/20Kw~26.82Hp/Est 120LBS
markz   100 GW
Post by markz » Mar 07 2016 4:59pm
Well you guys should send one motor to Justin at ebikes.ca so we can see the true advantages of curved aka bent magnets.
Other then that, the upgraded axle is a big bonus. Some have designed and sold their own custom axle with beefed up bearings for lots of money. Im gunna wait until my stock axle deforms or breaks before I invest in an axle upgrade. The double up of halls does not interest me much. To be honest it might actually be a hinderance as one could pop loose.
999zip999   100 GW
Post by 999zip999 » Mar 07 2016 5:26pm
Great idea Markz. Maybe you can make the Donation ?
markz   100 GW
Post by markz » Mar 07 2016 7:06pm
999zip999 wrote:Great idea Markz. Maybe you can make the Donation ?
Where do I make the donation?
Post by spinningmagnets » Mar 07 2016 7:29pm
A while back I noticed that a lot of new fatbike purchasers were upgrading to a Bluto suspension fork. As a result, there are a lot of new stock Surly Pugsly/Moonlander forks on ebay. Typically $120-ish new retail, roughly $60 on ebay. Chromo, with disc caliper mount.
999zip999   100 GW
Post by 999zip999 » Mar 07 2016 8:37pm
Maybe you get motorbikewheels to set it up. But that's not what this thread about. And Justin would need time and effort. I'm glad the motors are improving. It's a new time when China is helping.
Post by Motobikewheels » Mar 07 2016 9:37pm
skWarDog wrote:I'm interested, starting to gather bits to put together an Intense 951 frame to add to the fleet now. Might as well try a MXUS, sounds like a great price! Wondering how much that chunk of Changzhou City scrap iron weighs though? Heavy, right? :roll: I'll deal with it though.....first take it apart make sure it's tight & right. Then drill & mill it and dip n' bake it... that'll keep it cool & hold it together, too!!
17" is more because Holmes hobbies raised the price on them
Post by Motobikewheels » Mar 07 2016 9:52pm
Been getting some pm's. It would make it a lot easier for me if you guys could post what you want right in the thread.
Mxus message
Barent sent me response that he can sell you the M16 Axle in our store which is 5$/pcs.
So you can order from us, but the MOQ for the whole order should be 20pcs.
The bent magnets can not be used this time because of some problem, so we will still use the normal one.
