KMX Trike Front Suspension
adam333   100 W
Post by adam333 » Mar 15 2016 4:25pm
KMX Trike Front suspension:
Fit on any adult KMX frame.
Travel : 57mm (2.25in)
Bike total width will increase by 146mm (5.75in)
Material: Alu 6061-T6 Black Anodized
Weight: 1.4 kg each.
No modification required on your KMX. Just remove the brakes & wheels, bolt the new suspension, reinstall the brakes and wheels.
The installation kit include a left and right suspension unit + hardware + step by step instruction.
Fenders available as an option.
2min video showing the suspension in action:
With the increased clearance, it is also possible to install fat tire on the trike:
The suspension is designed for light wheels though. Heavy wheel will significantly reduce the suspension effects.
Pricing:
KMX Trike Front suspension retrofit kit: 795 US$ + shipping.
Available from http://www.kmxsuspension.ca or you can send me a pm or a email at: sales@royindustries.ca
____________________________________________________________________________________________________-
Air shocks are now also available but they add an extra 150 US$
weight go down to 1.25kg ea.
You will need an air shock pump for best results.
Air shock used
KMX Trike Front suspension retrofit kit with air shock: 945 US$ + shipping.
S.S. screws are also available but this option will add an extra 180 us$
note : Stainless Steel is not as strong, but it's a good option if rust is a concern.
20 in Black ABS Fender is now available for sale!
20 x 2.3 tire shown here:
Not suitable for 16 in tire.
Weight: 700g each sides
Ground clearance: 2 in
Max tire size: 20 x 2.3 in
Pricing: 150 US$ + shipping.
Customer feedback:
Robert Joseph's Optima Rider electric trike:
Quote: Thanks for offering this excellent kit, it is extremely well made and fantastic for the speedier ebikes!
Guillermo’s KMX Batmobile:
Quote: THANK YOU. This thing is not just better, it’s on another dimension better.
Paul MacDonald’s KMX Typhoon Ebike:
Quote: I am overjoyed and at peace with the way this trike has turned out. Thank you so much for offering this suspension kit on the Endless Sphere.
Paul MacDonald’s KMX Typhoon Ebike Review
Michael S Copeland's KMX Venom with S.S. Screws:
Quote: Just took my first ride with the new air suspension kit. Wow, what a difference
Installation:
This was about as easy as a kit can get. Remove the wheel. Remove the brake. Install the suspension unit. Reinstall the wheel. Adjust the brake. The whole process took me an hour and a half. Most of the time was adjusting the brake. The Avid BB7s had to be adjusted as far away from the rotor as possible, but they fit. No issues. There is a clearance issue on the right side that Adam mentions in the very detailed and understandable instructions. Used a file and notched the brake mount on the original spindle. Easy. Kudos Adam. Excellent DFX. Design for performance, design for durability, design for assembly. Excellent!
Comfort:
The reduction in road chatter is very nice. Most of the big hits are softened quite a bit. Hits to the rear wheel still are jarring, but I have a 26" rear, so the hits aren't as bad as a 20" rear wheel. The big hits on the front are handled well. Still feel them but they aren't jarring. I purposefully hit some big potholes, just to see how the suspension would handle the hit. I felt it, but nothing like without suspension.
Stability:
Here is where this unit shines. There's still some bump steer, but it's nothing like without it. Being wider, the stance is more stable, but turns don't require as much english with my body to stay upright. Also, the suspension movement makes loose gravel much more stable. There's a fast downhill with REALLY loose sand and gravel. The unsuspended trike would still feel really squirrely, but the suspension makes it much more controllable. I feel a little faster, just because I'm more in control of the trike. It's a NOTICEABLE difference.
Thanks again Adam, well done!
Terry’s KMX Ebike:
Quote: Went for my first test ride last weekend and holy crap, this thing is fast! The suspension worked flawlessly when I hit some pretty good bumps at high speed. Thanks again for a great product!
gman1971   10 kW
Re: KMX Trike Front Suspension
Post by gman1971 » Mar 19 2016 3:29pm
Very nice. I just saw your video on YT. So what does the 795 price include? Does it include the shocks/springs? Or just the hardware.
G.
I am all about high-speed, low-drag, mid-drives and gears...
A-3 trike, ?-kW, ??+ mph (Cyclone powered) Very fast, ludicrous speed fast...
A-1B trike, 6+kW, 65+mph (Cyclone powered): https://www.youtube.com/watch?v=oFC8MRwvgUM
A-2A trike 3kW, 50mph (Cyclone powered): https://www.youtube.com/watch?v=bNoqp0wl6Vo
eB-1C bike 3kW, 42mph (Cyclone powered): https://www.youtube.com/watch?v=_weSmz_h3Ig
adam333   100 W
Post by adam333 » Mar 20 2016 12:16am
Thanks,
The kit is fully complete. ( it include chocks and hardware )
It include everything you need ( except your own tool ) which is a few allen keys and a wrench or a Vise grip.
There is also a step by step instruction include with the kit.
Doctorbass   100 GW
Post by Doctorbass » Mar 20 2016 12:49am
That is a really nice kit and it could fit perfect on my 2011 typhoon! Thanks for the video, it show how well your kit is working!
I just wonder how the steering is affected with the wheel and the pivot that are more distant to each other... i guess you have more force to apply to teh steering to change direction right? or is the pivot axis remain on the wheel base?
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
gman1971   10 kW
Post by gman1971 » Mar 20 2016 1:12am
That sounds great! So is a complete bolt on solution. Once I am done assembling my trike the I'll probably get it... it sure looks like the way to go!! BTW, your trike is pretty amazing... I plan on going mid-drive on mine, I really like having gears as opposed to a single hub motor. :)
G.
adam333   100 W
Post by adam333 » Mar 20 2016 8:45pm
Doctorbass wrote: I just wonder how the steering is affected with the wheel and the pivot that are more distant to each other... i guess you have more force to apply to teh steering to change direction right? or is the pivot axis remain on the wheel base?
Doc
Thanks Doc :)
The bike feel more stable at higher speed. I don't really feel much difference in the force required to steer the bike. If you stop by Montreal, let me know, so you can test it by yourself :)
gman1971 wrote: That sounds great! So is a complete bolt on solution. Once I am done assembling my trike the I'll probably get it... it sure looks like the way to go!! BTW, your trike is pretty amazing... I plan on going mid-drive on mine, I really like having gears as opposed to a single hub motor. :)
Thanks for the kind words :)
I personally prefer hub motors, chains always seems to break or derail, and they require maintenance.
Doctorbass   100 GW
Post by Doctorbass » Mar 21 2016 1:32am
Doc
Thanks Doc :)
Yeah this summer i might stop by as well as to see Boisrondeven and Maxwell65
Doc
gman1971   10 kW
Post by gman1971 » Mar 21 2016 10:33am
NP,
Maybe I'll get to hub motors at some point... but so far my mid-drive experience has been positive... :)
G.
Doc
Thanks Doc :)
steveo   1 MW
Post by steveo » Mar 21 2016 2:53pm
i'll check this out after.. cant view yt vids at work :x
Repair Thread
http://endless-sphere.com/forums/viewto ... =3&t=27170
Hub Monster bike ~ 24s7p A123 15.4ah/18kv Six Phase Motor/Dual Max-E Adapttos/32kw~42.91Hp/Est 140LBS
X6 Kmx Trike ~ 24s4p 20ah/X6 MHM 602/Infinion EB324 IRFB 4110/20Kw~26.82Hp/Est 120LBS ~SOLD~
Lightening rods bike ~ 18s2p 10ah/1500w Inrunner/Infinion EB312 IRFB4110/2KW~2.68hp/Est 60LBS
EV Outboard ~ 12s8p 40ah/5KW GM Inrunner/Infinion EB324 IRFB 4110/18Hp Evinrude Drive/Est 100lbs
http://www.youtube.com/user/trdfreak03
rborger73   10 kW
Location: Currently NW of Pittsburgh, next destination unknown..
Post by rborger73 » Mar 24 2016 1:22pm
So with the suspension does it also seem to do the work of a steering arm as well? I'd think there should be a little less of the easy over steer issue going on? Finishing up a clients KMX tornado within the next month. Hit a top speed of 58 yesterday in about 2/10ths of a mile the other day with it. Anything over 30 and while not super scary with it getting twitchy, but the fear of sneezing and drifting into on coming traffic does creep up occasionally. lol Customer buying has been race car building and driving for 40 years or more, so he can handle it, but I may suggest this option to him when I deliver and see if he wants to upgrade it. If it took care of the over steer, I'd be that much more inclined to go with this solution.
adam333   100 W
Post by adam333 » Mar 24 2016 1:46pm
rborger73 wrote:So with the suspension does it also seem to do the work of a steering arm as well? I'd think there should be a little less of the easy over steer issue going on? Finishing up a clients KMX tornado within the next month. Hit a top speed of 58 yesterday in about 2/10ths of a mile the other day with it. Anything over 30 and while not super scary with it getting twitchy, but the fear of sneezing and drifting into on coming traffic does creep up occasionally. lol Customer buying has been race car building and driving for 40 years or more, so he can handle it, but I may suggest this option to him when I deliver and see if he wants to upgrade it. If it took care of the over steer, I'd be that much more inclined to go with this solution.
My top speed on this trike is 65km/h ( 40 mph ). At that speed, the over steer is definitively a non issue. I have no experience above that speed though. your bike reach 58 mph? or km/h?
This being said, if you increase the front wheel diameter, the bike is definitively getting twitchy. ( the video was done on the regular 16 inch tire and it is really stable )
rborger73   10 kW
Post by rborger73 » Mar 24 2016 2:01pm
MPH. 20" rims in the front. Ya anything north of 40 you furrow your forehead and start really focusing on steering. I got pretty used to it, but ya rider error could be fast and furious if not watching. lol
gman1971   10 kW
Post by gman1971 » Mar 24 2016 2:23pm
What power level to reach 58mph? I am shooting for 60 to 70 with 5 kW mid drive.
G.
methods   10 GW
Post by methods » Mar 24 2016 2:33pm
I love this board...
Wow what a vibrant community of problem solvers. This post makes me want to resurrect my KMX and try commuting it again for a while. I cant tell you how many times I have 2-wheeled a pot-hole at 35mph and jarred my brain. Balloon tires helped... but an ebike that is sustainable MUST have suspension.
I see the springs but are those actually shocks inside or are they just carriers?
thanks,
-methods
Increasing battery voltage and controller current limit will result in a non linear experience
oatnet   10 MW
Post by oatnet » Mar 24 2016 7:35pm
Very Cool. 8)
Member 117 of 26,000+
153v DUNE BUGGY © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler FrictionDrive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
rborger73   10 kW
Post by rborger73 » Mar 25 2016 1:03am
gman1971 wrote:What power level to reach 58mph? I am shooting for 60 to 70 with 5 kW mid drive.
G.
20s with an mxus 4t adaptto mini E. With moped rim and tire. Think it is 18 or 19" rim, but with the moped tire I think around 24" if I recall... half asleep.. some of this may be wrong.. lol
gman1971   10 kW
Post by gman1971 » Mar 25 2016 2:06am
G.
Very nice, then it sounds like I might be able to get at least to 60 with 18S on my mid drive since I have the gearing to push it a bit harder than a hub. I'll be running a 26" rear wheel as well.
G.
evolutiongts   10 kW
Post by evolutiongts » Mar 25 2016 4:31pm
I'm interested in one as well.
http://www.electricrt.com
Electric Race Technologies
Schwinn 405 2WD Track Bike 18KW
EDGE 1500W Hub / MXUS 3K Turbo
ASI BAC 2000 / BAC 4000 Bluetooth
viewtopic.php?f=6&t=93079
10Kw KMX death trike
MUXUS 3K Turbo
Sabvoton 72V150A
Moto Wheels all around
Front Suspension Kit
viewtopic.php?f=6&t=83423
Giant Trance 4 Full Suspension
Cyclone 3000W
74V 3000W
http://endless-sphere.com/forums/viewto ... =6&t=59005
methods   10 GW
Post by methods » Mar 26 2016 7:59pm
methods wrote: I see the springs but are those actually shocks inside or are they just carriers?
Did I miss a detail?
-methods
gman1971   10 kW
Post by gman1971 » Mar 27 2016 1:02am
Rode my KMX trike on human power 28 miles today, went up 11% hills and down... awesome, and I didn't thought the feel was that bad without suspension... I was expecting the harshest of rides but it was actually rather nice so if the thing rides so well stock I can imagine with this suspension it will be amazing to ride!!
G.
adam333   100 W
Post by adam333 » Mar 27 2016 8:37pm
-methods
This is the spec of the shocks used right now:
Motorcycle Shock Absorber 125mm*750LBS/IN Black Scooter Damping Suspension
Brand Name: HAOTAI
Item Length: 125mm
Item Weight: 0.34kg
Material: Metal
LBS/IN: 750LBS
Color: Black
Usually, they are used on miniature electric scooters.
methods   10 GW
Post by methods » Mar 27 2016 8:47pm
Right... I have read a lot of Chinese descriptions :mrgreen:
What I am asking is if there is gas in that shock or if the dampening system is only a spring.
I know it sounds like an obvious question... but I am a guy who gets surprised a lot.
thanks,
-methods
adam333   100 W
Post by adam333 » Mar 27 2016 11:14pm
From the feeling I have while riding it, I believe there is gas inside. Otherwise it would just keep bouncing on and on when I go over a speed bump.
methods   10 GW
Post by methods » Mar 28 2016 10:25am
If someone could spin off that adjustment nut and actuate the piston to see it would be appreciated.
thanks,
-methods
adam333   100 W
Post by adam333 » Mar 28 2016 9:11pm
methods wrote:If someone could spin off that adjustment nut and actuate the piston to see it would be appreciated.
thanks,
-methods
no problems, I have a new set coming by mail in a few days, I will make the test and post the result.
