12F Sine/Silent 36-100v/45A Controller iOS/Android,GPS-$139
fechter   100 GW
Re: 12x Sino/Silent 36-100v/45A Controller Program/GPS/etc -
Post by fechter » Oct 14 2016 7:26pm
snejky wrote:Var regen used with hall sensor?
Yes, right now it's designed around a standard throttle output.
I've been running this controller on my A2B bike for a while now. I'm a fan of torque based throttles and had that on other rides, but I have to say the way this controller behaves leaves little room for improvement. It's very controllable at low speeds like when climbing steep trails. So much smoother than the old Xie Chang controllers. Sometimes I miss the ability to pop an accidental wheelie, but I'll gladly do without that in favor of controllable power. At full cruising speed, you do need to give more throttle to get thrust from a coast, so it is definitely speed mode, but at lower speeds it does feel a lot like a torque mode throttle.
pomah   10 mW
Re: 12F Sine/Silent 36-100v/45A Controller Bluetooth,GPS-$13
Post by pomah » Oct 30 2016 3:40pm
Anyone tested this or running this with a mac motor?
fechter   100 GW
Post by fechter » Oct 30 2016 5:18pm
pomah wrote:Anyone tested this or running this with a mac motor?
Not that I have heard yet. The MAC motors are not all the same either. At some point in production, I think they fixed the hall timing to be 'normal' instead of way advanced. The older MACs don't work with a lot of controllers.
pomah   10 mW
Post by pomah » Oct 31 2016 3:30am
Ok, I was going to buy a new one, I dont get how they can fix it, since they have double pole count compared to other similar motors, and they still have three hall scensors, or am I getting this wrong?
Well Still not sure what way to go, this controller or the phaserunner, the phaserunner is smaller in size and just 100 USD more when all the options are selected...
999zip999   100 GW
Post by 999zip999 » Oct 31 2016 12:44pm
I had the hardest time finding a controller for my bmc 600 h.s. Finally em3ev worked. I do have the sinewave and muxus 3,000 but wouldn't take apart my daily rider to cut up wires to check.
pomah   10 mW
Post by pomah » Oct 31 2016 4:09pm
999zip999 wrote:I had the hardest time finding a controller for my bmc 600 h.s. Finally em3ev worked. I do have the sinewave and muxus 3,000 but wouldn't take apart my daily rider to cut up wires to check.
The em3ev controller is a squarwave, that is why I'm looking into this one.
vipster76   1 mW
Post by vipster76 » Mar 31 2017 8:11am
i just bought one of these from andy braidford
anyone know what phase/hall combo works for ebay motors?
i have a 9c knock off and uses the common phase/hall setup most motors use from ebay (plugged in 3 controllers before and worked)
a s12s was the main controller before i bought this one
any help appreciated :)
ScooterMan101   1 MW
Post by ScooterMan101 » Apr 03 2017 11:23pm
What month and year , or at least , what year did the new Mac, with neutral hall timing , get made/started selling ? ( before it changed it outside looks ? )
I have a 2013 Mac, and the newest one is easy to see the difference on the outside , the latest one's being sold have what looks like a machined hub flange , looking much like the Crystalyte Crown Motor.
the 2013-2015 Mac or even through part of 2016 ? have a hub flange that is not machined between the spoke holes.
My first conversion ...
https://endless-sphere.com/forums/viewt ... 1#p1077497
It's 2018 already, lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
vipster76   1 mW
Re: 12F Sine/Silent 36-100v/45A Controller iOS/Android,GPS-$
Post by vipster76 » Apr 04 2017 9:36am
i sorted it
it turned out that the jumper cable for programming needed to be cut.
works fine with all the colours matched up.
PRW   10 kW
Post by PRW » Apr 04 2017 11:48am
what does this mean? I will get one to try with a Mac, but need it as simply plug and play as possible..
Powervelocity.com   10 kW
Post by Powervelocity.com » Apr 05 2017 3:27am
Since you are getting a Bluetooth module, there won't be a programming cable. It's not necessary if you can program the controller from a phone. So, no worries on this.
PRW   10 kW
Post by PRW » Apr 06 2017 12:20pm
Powervelocity.com wrote:Since you are getting a Bluetooth module, there won't be a programming cable. It's not necessary if you can program the controller from a phone. So, no worries on this.
thanks: you haven't sent me an invoice as yet?
ScooterMan101   1 MW
Post by ScooterMan101 » Apr 06 2017 12:43pm
@ Powervelocity.com
I have looked 2 times now on your website for the 6 fet , bluetooth , sine wave controller for the price, the specs, if it has the plug to plug into the CA v 3 , etc.
All that I am seeing on the website is the biggest controller that you sell.
If you are not updating your website, you can PM me with all the details of the 6 fet controller.
Thanks
Post by Powervelocity.com » Apr 06 2017 1:21pm
The site will be updated with the full lineup of controllers and options. The controller currently on the website is 18F which is not largest size. The largest one is 24F and the smallest one is 6F.
I'll send you the link with specs on 6F in a bit. Thanks.
ScooterMan101 wrote:@ Powervelocity.com
Thanks
aethyr   10 W
Post by aethyr » Apr 12 2017 12:32pm
Are you able to customize this to handle more than 45a of current?
aethyr   10 W
Post by aethyr » Apr 14 2017 10:51am
60a continuous, 100a burst. I need the smaller form factor of the 12 fet.
PRW   10 kW
Post by PRW » Apr 23 2017 8:53pm
Powervelocity.com wrote:The controller turns on when you short the single red "ignition" wire to the battery positive. It will not come online if you just connect the battery leads. I believe that's how Lyen turns on (well said :roll:) but I am thinking there may be some variations. Just want to make sure you use the red ignition wire to power it.
the ignition connector has both a red and an orange wire. By "single red ignition wire", do you mean both red and orange wires are connected to the battery positive?
Post by Powervelocity.com » Apr 24 2017 1:08am
No. These wires (orange and red) are meant to be connected together. You just plug it into your key switch or any on/off switch. Shorting these wireless will turn the controller on.
izeman   10 GW
Post by izeman » Apr 24 2017 1:29am
Powervelocity.com wrote:No. These wires (orange and red) are meant to be connected together. You just plug it into your key switch or any on/off switch. Shorting these wireless will turn the controller on.
btw: this is how LYEN/xiechang/infineon controller's ignition works as well. you connect the ignition wire to VCC.
Post by Powervelocity.com » Apr 24 2017 1:54am
Technically, red wire is the batt VCC and orange is the input for the step down low voltage circuit that powers the MCU, etc.
It's already fitted with a connector where you can just plug in a key switch.
