12F Sine/Silent 36-100v/45A Controller iOS/Android,GPS-$139
PRW   10 kW
Re: 12F Sine/Silent 36-100v/45A Controller iOS/Android,GPS-$
Post by PRW » Apr 24 2017 7:38pm
note to buyers: the connectors on throttle supplied do not match the connectors on the controller. You will need to change out connectors.
I will report back on whether the controller works with the old and new Mac motors if and when I get it working.
Powervelocity.com   10 kW
Post by Powervelocity.com » Apr 24 2017 8:44pm
They normally match. It was one off.
PRW wrote:note to buyers: the connectors on throttle supplied do not match the connectors on the controller. You will need to change out connectors.
PRW   10 kW
Post by PRW » Apr 24 2017 11:02pm
Powervelocity.com wrote:They normally match. It was one off.
ok, thanks for clarifying.
PRW   10 kW
Re: 12F Sine/Silent 36-100v/45A Controller Bluetooth,GPS-$13
Post by PRW » Apr 24 2017 11:11pm
pomah wrote:Anyone tested this or running this with a mac motor?
ok, tested it with a Mac (the new Mac, 10T). All works well, but seems to have a slightly harsh start (I will retest tomorrow just to make sure all connections were good).
Did a video, as well as a video of the EM3EV controller for comparison. Throttle plugged straight to controller, CA not connected.
Powervelocity Controller (2 videos)
EM3EV Controller (2 videos)
fechter   100 GW
Post by fechter » Apr 25 2017 2:05pm
It would be good if you could measure the battery current at full speed/no load. This will tell a lot about the compatibility.
izeman   10 GW
Post by izeman » Apr 26 2017 4:29am
hmmm to me they all sound more or less the same!? maybe some riding videos will show a more significant difference.
it will also prove that controller can run the mac under load fine. running the mac on the bench is one thing. trying to start it uphill and run it up to full rpm on a steep hill is something completely different. :(
wish you good luck and all the best! :)
Post by Powervelocity.com » Apr 26 2017 12:11pm
The sound seems to be coming from gears.
Without load, the difference between sine and square wave can be heard on gearless motor.
izeman   10 GW
Post by izeman » Apr 26 2017 12:16pm
Powervelocity.com wrote:Without load, the difference between sine and square wave can be heard on gearless motor.
imho under load it should be more obvious. but this is only my personal finding.
Post by Powervelocity.com » Apr 26 2017 12:49pm
Yep, it would be obvious. Square sends a lot of vibration into the frame when starting hard from standstill. Sine just picks you up like a wave and silently pulls you forward.
999zip999   100 GW
Post by 999zip999 » Apr 26 2017 2:11pm
The hardest motor to spin is the old bmc geared.
vipster76   1 mW
Post by vipster76 » May 09 2017 12:53pm
what components are needed to get the bluetooth programming working?
Kin   10 kW
Post by Kin » May 09 2017 7:57pm
vipster76 wrote:what components are needed to get the bluetooth programming working?
I was wondering the same, especially for android phones (if there's any difference in hardware)
New to endless-sphere? Notice a lot of signatures recommending Ebikes.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
Post by Powervelocity.com » May 10 2017 9:56pm
Hardware is irrelevant.
All the magic is happening in the software and that's a lot of hours of researching, developing, debugging, and improving the code. Not something that anyone has ability or willingness to do.
Kin   10 kW
Post by Kin » May 10 2017 10:08pm
I think all that is meant, is whether we need to buy anything extra to get the mobile device programming enabled, or if it is default with the controllers you are selling. Also, what sort of app we would need.
I was not questioning the development work of the bluetooth capability, just whether it would be available.
Post by Powervelocity.com » May 10 2017 10:18pm
Here is more detailed information on a larger controller but it all applies to 12F:
https://endless-sphere.com/forums/viewt ... 31&t=75888
The module is a $45 option. Currently, it works with iOS or Android. Apps for both platforms are provided.
Kin wrote:I think all that is meant, is whether we need to buy anything extra to get the mobile device programming enabled, or if it is default with the controllers you are selling. Also, what sort of app we would need.
ScooterMan101   1 MW
Post by ScooterMan101 » May 11 2017 9:03pm
Is this why I am not seeing the 6 Fet up on your website ?
Is the 6 Fet Controller ready with all the software downloaded/installed on the 6 Fet Controller ?
Is the 6 Fet Controller ready to use a smartphone / small tablet as a display to display current watts and amps being used, and at end of rode total watt hours and amps used ?
Powervelocity.com wrote:Hardware is irrelevant.
My first conversion ...
https://endless-sphere.com/forums/viewt ... 1#p1077497
It's 2018 already, lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
Post by Powervelocity.com » May 12 2017 5:34pm
Working on making that happen.
ScooterMan101 wrote:Is this why I am not seeing the 6 Fet up on your website ?
Mikelon   1 µW
Post by Mikelon » Jul 03 2017 7:55pm
Hi,
Can you sell me one 12 FET sine wave controller with Bluetooth programming option (or Android) for $139 + shipping?
If so, then I also would like to order a 6 FET 36v-100V sine wave controller with Bluetooth programming option? Please, give me a price quote for a 6FET controller.
Feel free to reply directly to my e-mail address: afddox@yahoo.com
Sincerely,
Albert
vipster76   1 mW
Post by vipster76 » Jul 04 2017 4:39am
just a bit of owner update :)
i have been running my 12fet @ 60a 48v for over a month and it never overheats and i have a few nasty hills near me.
i did try 72v@60a for about 6 miles and had no problems. the torque was noticeably better!.
my motor is a mxus v2 3T 26" and my battery is 2x 12000mah multistars. i get about 10 miles range if i nail it for the whole ride on the road.
as for my previous comment i wanted to know what extra parts (hardware) i needed to buy to get bluetooth working. i currently program via usb/ttl adapter.
i want a 18 fet but the size puts me off.
Post by Powervelocity.com » Jul 05 2017 4:05pm
The prices are posted and are some of the most competitive for BT-enabled controllers on the market.
6F controllers are priced at $149 which already includes the BT module. These controllers will also work in dual mode (sensored and sensorless).
Mikelon wrote:Hi,
Sincerely,
Albert
Post by Powervelocity.com » Jul 05 2017 4:13pm
Nothing special is needed. One wire needs to be moved on the board. For that you need a Philips screwdriver to open the controller and a basic solder iron to desolder the wire and solder it to another pin. After that, you can just plug the BT module into the TTL connector.
vipster76 wrote:just a bit of owner update :)
izeman   10 GW
Post by izeman » Jul 11 2017 2:33pm
Hi
Please check your pm inbox. I sent an inquiry but don't get a reply.
Thx
Post by Powervelocity.com » Jul 12 2017 1:03am
A few people inquired about issues with Speed 1,2,3 and Flux weakening settings in the smartphone apps. I am glad to report that these are officially fixed.
The latest version of Android app with fixes is available for download here: http://powervelocity.com/index.php?cont ... achment=28
The iOS app will be updated soon as well.
With Flux set to 24 units, I was able to shoot the an unloaded 4T hub motor in 17 inch moto rim to 120 mph at 100v or around 1400 RPMs.
Enjoy ;)
izeman   10 GW
Post by izeman » Jul 12 2017 3:49am
Thanks for the invoice! One more question as I'd like to have torque throttle mode and you mentioned that it's on the future feature list: is the firmware user upgradeable? Or will i need to buy a new controller? I haven't seen that question asked before.
