6pence Resistance Spot Welder
pguk   100 W
Location: North England, birthplace of the Industrial Revolution
Re: 6pence Resistance Spot Welder
Post by pguk » Apr 19 2018 2:02pm
Neat video Andi.
I charged my pack lately after it had sat over winter. I bulk charge and don’t use a bms. Cells were all at 4.13V except one, which was 4.14V. I discharged this one bank through a bulb for a few seconds - all good.
Shipping to USA for the kit will be around 8 GBP.
I finally invested in a JBC soldering station. This makes the power board build so much easier although there is still a good few hours work involved in assembly. I have one for built and ready for a good home. I may build more if there is interest. I ask 80 GBP for the assembled power board.
6pence spot welder https://endless-sphere.com/forums/viewt ... 31&t=81274
"It is all nice and proper, but only an idiot would think that the father is sixpence to the good on the transaction." C.S. Lewis' Mere christianity
Storapa   100 W
Post by Storapa » May 05 2018 5:11am
I've just welded yet another pack together. Friends at work now use my spotweld for building packs for various drones and bike lights.
It's welded hundreds of cells together so far and hasn't missed a beat. I've just remachined the welding tips for the first time, but that is all that has been required.
A great little spot welder.
Daily machine. - Giant Toughroad, Mac 8T, Thun torque sensor, Phase Runner, CA V3
Scratch built machine - Crystalyte HS 3540, 12 fet IRFB4110 Infineon controller, CA V3, 74v - 20Ah Lipo battery pack. https://endless-sphere.com/forums/viewt ... =3&t=75457
pguk   100 W
Post by pguk » Jun 08 2018 9:10am
Storapa
Great feedback, so glad it’s working for you :D
henrynz   1 µW
Post by henrynz » Feb 16 2019 11:03pm
Hi all, first time poster + first time youtube video!
Thanks for all the info everyone has provided on this topic and particularly pguk for the unit itself. I recently bought a unit with the power board pre-made.
I made a video so that someone considering the unit for thicker nickel (0.3mm) might get more insight of what kind of setup could be involved. My unit uses two car batteries of about 580CCA each. I appear to be getting 0.3mm pure nickel to weld well. Any suggestions appreciated and hopefully I can do an update later of a completed setup. Overall very happy with the unit but I've only been testing it briefly. :bolt:
henrynz   1 µW
Post by henrynz » Feb 23 2019 7:58pm
Sorted out my wiring a bit, made some better copper tips from scrap copper but they seem to be leaving a layer of copper on the nickel and I think it would be best if they were physically attached so that the distance stayed consistent:
I've been having reasonable success with settings similar to below, next step is probably to make a welding pen that holds the tips together and to add a trickle charger to batteries so that welds are consistent. Welds are really hard to rip apart but the six spots are still quite variable across the tab so I still need to limit more variables I suppose.
