ERT BBSHD Sinewave Controller Upgrade Plug-n-Play
evolutiongts   10 kW
Post by evolutiongts » Oct 28 2016 3:28pm
Image[youtube][/youtube]
Electric Race Technologies is offering its Sinewave Controller Upgrade for the Bafang BBSHD
External Sinewave Controller is easily to mount and install
Very smooth power due to Sinewave technology, and allows up to 100V and 45A
The stock controller on the BBSHD limits you to 60V and 30A
This upgrade is extensively tested and proven
Up to 40mph+ on a 72V Battery System
Cycle Analyst Compatible
Temp Sensor
Fully Programmable
Please specify which connectors your BBSHD uses as there are two versions. Version A uses Anderson Power Poles and Version B uses Quick Disconnects
https://www.electricrt.com/blogs/news/u ... ll%20Guide
https://electricrt.com/blogs/news/ert-b ... rogramming
$159 - ERT BBSHD Sinewave Controller
+$20 Half Twist Throttle with Voltage Meter Key Switch
+$10 Controller Programming Cable
+$150 Cycle Analyst V3 Plug and Play (With Thermal Protection and PAS Hookups)
Pre-configured
Phase Runner Coming Soon as well.
http://www.electricrt.com
Schwinn 405 2WD Track Bike 18KW
EDGE 1500W Hub / MXUS 3K Turbo
ASI BAC 2000 / BAC 4000 Bluetooth
viewtopic.php?f=6&t=93079
10Kw KMX death trike
MUXUS 3K Turbo
Sabvoton 72V150A
Moto Wheels all around
Front Suspension Kit
viewtopic.php?f=6&t=83423
Giant Trance 4 Full Suspension
Cyclone 3000W
74V 3000W
http://endless-sphere.com/forums/viewto ... =6&t=59005
E-dub   1 µW
Re: ERT BBSHD Sinewave Controller Upgrade Plug-n-Play
Post by E-dub » Dec 03 2017 11:08pm
Greetings. Nice work. Are you open to sending members of this forum like myself instructions on how you installed the sinewave controller. There is nothing out there that I can find in regards to assembly. Many thanks.
dustNbone   10 kW
Post by dustNbone » Dec 04 2017 5:38pm
You mean connecting an external controller to the BBSHD? If you remove the stock controller there's phase/hall wires coming from inside the motor, you just connect it the same as any sensored motor. Making it look nice/be weather resistant will involve making a new "cover" for the area where the controller mounts. I just gutted a (dead) bafang controller but I'm not sure what he did with this kit.
Looks great though. If this was available when I did my conversion I'd probably have gone for it, though with a 25A controller because I have a BBS02.
EDIT: The first link (install guide) gives a 404 error
alswiseowl   100 W
Post by alswiseowl » Oct 01 2018 12:30am
hi there,
how much for the kit delivered to sydney Australia...
I already have a 74v battery to use on the kit..
thanks
StuRat   100 W
Post by StuRat » Oct 01 2018 4:27am
Another aussie order, but I'll wait for the phaserunner
bobmutch   100 W
Post by bobmutch » Dec 16 2018 9:04pm
what is the status on this document...
my ride Fuji 72V20Ah LiPo, CA3, 18F MC, 1500W Rear Hub. I'm here to learn.
