Ferrofluid APG1110 - Ultimate Cooling for your Hubbie
chucho   1 kW
Re: Ferrofluid APG1110 - Ultimate Cooling for your Hubbie
Post by chucho » Dec 12 2016 6:19pm
Merlin wrote:nope,
just 10ml of it for the big hubbies.
7ml should be enough for the MXUS guys.
I read sometime ago 5ml where just enough for MXUS and that is what i have used on mine.
Someone who does not doubt is a danger to the rest
9c+24slipo+60A lyen12fets+CAv3+26"hookworms=Fun commute
Cargobike+9c+13s33Ah=Fun transport
Kona entourage+ gng+ 40A lyen12fets+CAv3=Fun crosscountry
Flux+adaptto Max-e+Mxusv2+19" shinko= Monster fun Any Way
Merlin   10 MW
Post by Merlin » Dec 13 2016 4:31am
up to you. you can do "somewhere/sometime" stuff or just what justin measured/find out ;)
chucho   1 kW
Post by chucho » Dec 13 2016 9:21am
Merlin wrote:up to you. you can do "somewhere/sometime" stuff or just what justin measured/find out ;)
Lol, You where the first one talking about "should be fine" :lol:
If i put more than 5ml on the mxus it sounds and sometime leaks.
This is what Justin said:
"We're packaging it in a 10mL syringe, and for most of the common direct drive hub motors around 5mL is all that is required to gain the thermal conductivity benefits"
"From what we've seen with the motors so far is that each mL of fluid is good for about 50 cm^2 of rotor surface area. So if you know the width and diameter of your stator, calculate the total area of magnets in cm^2 and divide that by 50 to get the approximate fluid fill that is required."
Merlin   10 MW
Post by Merlin » Dec 13 2016 10:25am
- you have to seal your sideplates
- 5-6ml is what justin said, yes.
so we talk about 1ml now? if you check the pics theres IS an improvement in heat dissipation
(up to 14ml was tested and up to 10ml there was a higher conductivity between core and shell)
not much and probably not worth for efficiency guys seeking the 99,999%
but for my self i choose the "maxium" possible.
pushing 10kw through your motor is wasting energy deluxe. but for us power junkees its the ultimate cooling.
Kcore / Shell
4ml - 6.20
5ml - 6.76
6ml - 6.88
8ml - 6.97
10ml - 7.03
so i say it again:
up to you. its your motor, and your ride.
seal your sideplates. thats it.
if your motor squeeks, i cant tell you why. My MXUS v3 has 7-8ml inside, my Cro and Qs205 has 10ml it.
no squeeking, no sweeping :mrgreen:
as you like to quote...
justin_le wrote:
So here's the best part, after a week's worth of testing and running that motor again and again in the wind tunnel test chamber with the side plate flanges sealed (but the injection hole left wide open), there wasn't a single drop of leaked ferrofluid anywhere to be seen.
if you ride your mxus with 2-3KW, long ways, long and high hills and need the benefit of better efficiency, no problem. I would also fill only 5ml in it. Just for the same "bite" of maximum demands in the other direction of Drag vs Rolling resistance.
DasDouble   100 kW
Post by DasDouble » Dec 13 2016 5:28pm
What would you recommend for me as an QS V3 205 Motor from Vector- owner with up to 14 kW in use? 10ml or 5ml?
Thanks
Mechatronics-Engineering Student
-Built own ebike: ✔
-Built own 3.2kWh LiIon battery (300Amps): ✔
-Overtake Porsche with own Ebike: ✔
-Take off with ebike: ✖
~14kW, 3.2kWh LiIon, QS 205 8ml ff, hubsink
Merlin   10 MW
Post by Merlin » Dec 13 2016 7:00pm
if you ask me, 10ml :wink:
ridethelightning   1 MW
Post by ridethelightning » Dec 18 2016 3:02am
50ml arrived recently. thanks Merlin.
drew12345   10 kW
Post by drew12345 » Dec 21 2016 4:26pm
I received mine last week. Thanks Merlin!
chucho   1 kW
Post by chucho » Dec 21 2016 7:21pm
drew12345 wrote:I received mine last week. Thanks Merlin!
Me also, thank you!!
It was great it did not had to go throw customs... cause i dont know how would i explain what it is, all of that syringes full of black liquit, if they stop it :lol:
silviasol   10 kW
Post by silviasol » Dec 22 2016 12:24pm
Wow. Did ferrofluid go up in price in the past 5 years? I have this big bottle of it I got for like $60 or something back in 2009.
Current project: 10s 20ah sensored goped hoverboard
http://endless-sphere.com/forums/viewto ... 35&t=62155
DasDouble   100 kW
Post by DasDouble » Dec 22 2016 2:48pm
Merlin how many milliliters of ferrofluid do you have in stock rightnow?
-Built own ebike: ✔
Merlin   10 MW
Post by Merlin » Dec 23 2016 3:03pm
silviasol wrote:Wow. Did ferrofluid go up in price in the past 5 years? I have this big bottle of it I got for like $60 or something back in 2009.
maybe its the schoolish chem stuff that evaporate in no time.
@Double
enough to fill some more Motors :D
around 150ml
Quokka   1 kW
Post by Quokka » Jan 04 2017 7:05pm
Subd
Qulbix Q76R+ QS205+MaxE
markz   100 GW
Post by markz » Jan 05 2017 8:59pm
I priced it out from the supplier and its expensive stuff.
How much ferrofluid do you have left?
Quokka   1 kW
Post by Quokka » Jan 17 2017 5:19am
Hey Merlin, Pm'ed you. Did you get my message?
Merlin   10 MW
Post by Merlin » Jan 18 2017 8:13am
will check now....had some things to sort in real life *doh!
but if the question is: YES its on the way to the bush ;D
born49   100 mW
Post by born49 » Feb 03 2017 1:40am
Hello guys,
what do you use to seal motor covers after you apply ferrofluid ?
Is it even necessary to seal it ? Or does magnets hold it at appropriate place ?
Thanks !
Quokka   1 kW
Post by Quokka » Feb 03 2017 4:11am
Got my ff. all set for a weekend of fun :D
I will be using permatex ultracopper for sealing the sideplates with a gore valve glued in with high temp epoxy
born49   100 mW
Post by born49 » Feb 03 2017 11:12am
I'll try permatex ultracopper than :)
Thanks !
LuboN   100 mW
Post by LuboN » Feb 19 2017 4:48pm
Hi, I would like to have 30ml please... Is it on stock?
Merlin   10 MW
Post by Merlin » Feb 19 2017 8:54pm
Yup a bit is left.
Pm me please
Post by ridethelightning » Feb 20 2017 12:45am
Quokka wrote:Got my ff. all set for a weekend of fun :D
where did you get the gore valves from??
Quokka   1 kW
Post by Quokka » Feb 20 2017 1:26am
Gore valves.
https://www.e-bike-technologies.de/inde ... cing-valve
The guys is on on endless sphere as well making custom CA mounts. I bought a few of them, think they were 10 bucks each Pretty reasonable when compared to other places.
Jaycar sells jb weld for aussies. Worked well so far. I will do the new QS205 the same way for the NYX. I am amazed how well this ff stuff works.
spinningmagnets   100 GW
Post by spinningmagnets » Feb 21 2017 2:05pm
Looked for "hobby syringe" and found some, also "inkjet refill syringe" are cheap and available in 10ml. $0.75 ea
HEY! Just found "oral medication syringe" at $0.15 ea for 10ml
http://www.blowoutmedical.com/oral-medi ... AoKi8P8HAQ
LuboN   100 mW
Post by LuboN » Mar 06 2017 6:03am
Merlin, did You get my PM? I am becoming a bit nervous, it is 2 weeks now...
