24F Silent Controller 20kw 100-150v iOS/Android- $299>
Re: 24F Silent Controller 20kw 100-150v iOS/Android- $299>
Ok, so I was going over some small bumps in the pavement and all of a sudden the motor cogs really hard and the throttle does nothing. The motors spun freely when not connected to the controller, so I checked to see if the controller connections had any shorts between them and I found one between the green phase connection and the positive battery wire.
When I opened up the controller I didn't find any obvious signs anything had gone wrong, but I did notice that one of the tiny capacitors had been pushed aside by the battery wire. Maybe the bumps caused the wire to break the capacitor and short it?
The capacitor isn't shorted so I have no idea what the problem is
- Contact:
That looks like shorted mosfets on the green phase. Replacing those should bring it back to life.
NextGen Controller 25kw 130v BT
12FET Sinewave/Silent Controllers 100V/5kW - Smartphone-Bluetooth programmable - $139
15FET and 18FET Sinewave/Silent Controllers 150V/8kW - Smartphone-Bluetooth programmable - $179-199
24FET Sinewave/Silent Controllers 150V/15kW - Smartphone-Bluetooth programmable - $299
PowerVelocity.com
PowerVelocity.com
I haven't been able to find any info on the magnachip mosfets in the controller. What could I use to replace them?Powervelocity.com wrote: ↑May 23 2019 11:09amThat looks like shorted mosfets on the green phase. Replacing those should bring it back to life.
- Contact:
They are not available in the US.
I can send you a few if you are comfortable replacing them.
PM me your address.
PM me your address.
TorgueRPM wrote: ↑May 23 2019 12:38pmI haven't been able to find any info on the magnachip mosfets in the controller. What could I use to replace them?Powervelocity.com wrote: ↑May 23 2019 11:09amThat looks like shorted mosfets on the green phase. Replacing those should bring it back to life.
PowerVelocity.com
PowerVelocity.com
Edit: PM incoming. Sorry for taking up space here.
Hello PV person.
I tried to converse with you through email, but that doesn't seem to be going well, so I'll try this.
I bought one of the 18Fet controllers almost exactly 2 years ago. The BT module is internal. I am on Android.
It seems with each software update that it has become harder to program the controller. I barely got it programmed with my new battery voltage a few days ago (took many attempts). Then I saw that there was an update for the BT Module firmware, I assume. So I applied it. It appeared to apply properly, but every time I go into settings, it wants to apply the firmware update again.
Now I can't program or communicate with the controller at all. I see that PowerVelocity-I is there, but it won't program successfully.
My wife's iPhone doesn't see any bluetooth device so no help there.
Looks like I'm having the same problem as TorgueRPM
http://powervelocity.com/forum/viewtopic.php?f=8&t=25
Can I please get one of those ASAP? I'm down right now and having to use a car to commute is painful. Thanks!
PS The controller works fine otherwise. I have to reprogram it because I have changed battery voltage and it keeps cutting out at the LVD that I set. I can't reset that because I can't program the controller.
I am very much so willing to pay a reduced price (for previous buyers) for one of those new BT 2.0 modules that you mention here:TorgueRPM wrote: ↑Mar 28 2019 9:26amI think there might be an issue with my bluetooth module. It won't connect from the app unless I connect through my phone settings first (I only tried that because it wasn't connecting). Half the time the app doesn't even see the module, but when it does and I try to connect, it turns yellow and slides down the screen before reappearing.
- Contact:
Please PM or email if you haven't done so. We should have a new module for you.
Trailblazer wrote: ↑Jul 12 2019 10:45amHello PV person.
PowerVelocity.com
PowerVelocity.com
Hey, I found this thread after looking for a 20kW controller to run with the 7-18kW motor from cyclone. By any chance has anyone tried this motor/controller combo? The representative at Cyclone said the motor could handle 250A for a short burst.
As well, the webpage description the controller is listed as 20kW, but the link calls it a 15kW.
So what is the continuous amp rating? 150 with short bursts of 200(battery current)?
http://powervelocity.com/home/58-24f-15 ... mable.html
Thanks for any input. I see there has been no activity for several months on this thread.
- Contact:
It's likely that 250A mentioned was actually phase current, not battery. Check on that. If it's Cyclone 3000, then it's rated for 3kw, well maybe double that. 20kw would evaporate the coils in it.
bmurai wrote: ↑Aug 20 2020 9:32amHey, I found this thread after looking for a 20kW controller to run with the 7-18kW motor from cyclone. By any chance has anyone tried this motor/controller combo? The representative at Cyclone said the motor could handle 250A for a short burst.
PowerVelocity.com
PowerVelocity.com
It's supposed to be much beefier than the 3kW(which I have for my ebike). According to the seller it is 14kW continuous and 18kW peak. Really hard to find good info online for unbiased tests though.Powervelocity.com wrote: ↑Aug 20 2020 11:48amIt's likely that 250A mentioned was actually phase current, not battery. Check on that. If it's Cyclone 3000, then it's rated for 3kw, well maybe double that. 20kw would evaporate the coils in it
Perhaps it is the phase current limit? I am unsure how phase current could be much higher than battery current. I will need to read up on this.
For follow up, do you have information for the continuous rating of that controller from your website?
Thanks !
