24F Silent Controller 20kw 100-150v iOS/Android- $299>
TorgueRPM   10 mW
Re: 24F Silent Controller 20kw 100-150v iOS/Android- $299>
Post by TorgueRPM » Mar 12 2019 4:04pm
Powervelocity.com wrote:
Mar 11 2019 12:11pm
It should be taking off quiet and smooth.
I would check that all hall sensors are operational and make sure the hall and phase combos are correct.
TorgueRPM wrote:
Mar 09 2019 9:08pm
TorgueRPM wrote:
Mar 09 2019 5:57pm
I'm replacing the motor controller on a Chinese electric motorcycle with a qs260 hub motor. the Halls are connected but the motor acts as if it's being driven by a sensorless controller, with lots of cogging from takeoff. Has anyone else had any issues like this?
By cogging I mean a lot of noise and juddering
Yep, that was it. I wired the phase and halls as suggested for qs motors in the quick start manual and it feels like a different machine!
Powervelocity.com   10 kW
Post by Powervelocity.com » Mar 12 2019 6:50pm
So, could you share the correct combo for this specific motor so we can update our documentation?
TorgueRPM wrote:
Mar 12 2019 4:04pm
Mar 11 2019 12:11pm
TorgueRPM wrote:
Mar 09 2019 9:08pm
TorgueRPM wrote:
Mar 09 2019 5:57pm
TorgueRPM   10 mW
Post by TorgueRPM » Mar 12 2019 7:36pm
The motor is a QS260, between a 205 and 273 in size. I think they are really only found in rim-integrated wheels for the most part. The combo is the same as the other qs hub motors, for both hall and phase wires: Y-Y, G-B, B-G
cheeko   100 W
Post by cheeko » Mar 13 2019 6:03pm
PW
Just wanted to ask when i boot up the app the Temp sensor on the controller works but once you start taking off its disappears and no longer showing, i checked all connectors and there ok, it seems to happen straight after the update week ago.
Any ideas
Regards
Peter
20S7P Futr Beta 26" Mxus3k with the Unbelievable Nucular 12F
Post by Powervelocity.com » Mar 14 2019 12:52am
Please send some screenshots.
cheeko wrote:
Mar 13 2019 6:03pm
PW
Any ideas
Regards
Peter
cheeko   100 W
Post by cheeko » Mar 14 2019 1:40am
Mar 14 2019 12:52am
cheeko wrote:
Mar 13 2019 6:03pm
PW
Any ideas
Regards
Peter
Ill do that tonight. its weird as i have glued the plug in so its definitely not loose.
TorgueRPM   10 mW
Post by TorgueRPM » Mar 28 2019 9:26am
I think there might be an issue with my bluetooth module. It won't connect from the app unless I connect through my phone settings first (I only tried that because it wasn't connecting). Half the time the app doesn't even see the module, but when it does and I try to connect, it turns yellow and slides down the screen before reappearing.
I have been leaving the ignition switch connected and turning on the bike with a precharged contactor.
Any ideas?
Post by Powervelocity.com » Mar 29 2019 11:40am
Please delete/unpair the module from the Android settings and clear the Bluetooth cache.
Then go back to the app and try to connect.
TorgueRPM wrote:
Mar 28 2019 9:26am
I think there might be an issue with my bluetooth module. It won't connect from the app unless I connect through my phone settings first (I only tried that because it wasn't connecting). Half the time the app doesn't even see the module, but when it does and I try to connect, it turns yellow and slides down the screen before reappearing.Screenshot_20190328-081813.jpg
Any ideas?
cheeko   100 W
Post by cheeko » Apr 03 2019 10:22pm
Mar 29 2019 11:40am
TorgueRPM wrote:
Mar 28 2019 9:26am
Any ideas?
Just recently i have had issues once you turn off bluetooth and turn back on it works.
TorgueRPM   10 mW
Post by TorgueRPM » Apr 03 2019 10:25pm
I've tried everything that's been suggested, including the turn it off then back on trick. It's not a huge hassle, I just have to go into my settings and pair first
cheeko   100 W
Post by cheeko » Apr 07 2019 7:49pm
TorgueRPM wrote:
Apr 03 2019 10:25pm
Maybe Try reinstall the app, mine connected fine this morning i guess it might clash with other things connected bluetooth is there anything else connected to it same time.
TorgueRPM   10 mW
Post by TorgueRPM » Apr 08 2019 5:49pm
cheeko wrote:
Apr 07 2019 7:49pm
TorgueRPM wrote:
Apr 03 2019 10:25pm
I have tried that, nothing has worked. Now the module won't connect in any way. I might try installing the app on my friends phone, that will tell me if it's my phone or something else.
cheeko   100 W
Post by cheeko » Apr 08 2019 8:45pm
Yeah that will hopefully its not bad Blue Tooth Module.
Post by Powervelocity.com » Apr 09 2019 12:35pm
What brand and model of phone are you using?
Have you tried to go to Bluetooth Cache and clear it then reboot?
That usually helps on some wonky Androids. iOS is normally trouble free.
cheeko wrote:
Apr 08 2019 8:45pm
TorgueRPM   10 mW
Post by TorgueRPM » Apr 09 2019 9:32pm
Apr 09 2019 12:35pm
cheeko wrote:
Apr 08 2019 8:45pm
Yes, I've done that several times, hasn't changed anything. I'm using a Samsung galaxy S7, and I also tried it with my friend's Google pixel 3 xl, and it still didn't work.
\ (•◡•) /   1 W
1 W
Post by \ (•◡•) / » Apr 10 2019 3:39am
TorgueRPM wrote:
Mar 28 2019 9:26am
Any ideas?
Hey, This has always been the way for me. Exacting as you are saying, for me here's what I do to pair, and it works everytime.
(I have a Samsung s8 btw, so will be same for your s7)
1. turn on controller/bike
2. open up Bluetooth in phones settings, under the pair section at the bottom tap 'powervelocity-I' (don't connect to 'powervelocity-A)
3. quickly open powervelocity app, go to the app settings and it should say connected
4. go back to dash and it's ready to go
For me this has to be done every time my bike is turned back on and off, i've tried everything and this is the only reliable way, and works 95% of the time (very rarely I just have to ride 10metres and then the controller will show up under phone's bluetooth settings). it takes me 5 seconds now and is just routine, it's worth it for such a great smooth controller after all :)
Post by Powervelocity.com » Apr 10 2019 1:20pm
Hmm, that's very strange that you need to connect each time. Once it's connected it should stay there and auto connect when you just start the app.
I've mentioned this a few times but haven't heard anything back as to whether you have tried to clear the Bluetooth cache.
This is how to do it on S7/8:
https://help.elitehrv.com/article/135-c ... he-android
Please do that and reboot the phone. In most cases that fixes the issue.
You can also go to the app Bluetooth scanner (Connect button in Settings), click and hold on the device until "Disconnect" appears. Click disconnect and reconnect.
Most issues I've seen come from attempts to pair in Android BT. This was needed for older BT types 2.0 and below (which is what -A is.). It may be counter intuitive, but you don't have to do that with the BLE 4.0 devices. You should be connecting directly from within the app to PowerVelocity-i. The module is dual standard: legacy -A and the new -i BLE 4.0 which is what you want to use now.
I'll do a video explaining this.
\ (•◡•) / wrote:
Apr 10 2019 3:39am
TorgueRPM wrote:
Mar 28 2019 9:26am
Any ideas?
cheeko   100 W
Post by cheeko » Apr 10 2019 7:48pm
Apr 10 2019 1:20pm
\ (•◡•) / wrote:
Apr 10 2019 3:39am
TorgueRPM wrote:
Mar 28 2019 9:26am
Any ideas?
Ever since the last App update if had troubles with it connecting on first open on app but once i turn Bluetooth off and on it connects, i have S9+ its never ever disconnect while riding though.
TorgueRPM   10 mW
Post by TorgueRPM » Apr 12 2019 2:21pm
Apr 10 2019 1:20pm
\ (•◡•) / wrote:
Apr 10 2019 3:39am
TorgueRPM wrote:
Mar 28 2019 9:26am
Any ideas?
I've actually mentioned several times that I have cleared the cache and restarted the phone and nothing has changed. I can't connect through the app, and when I connect through the phone's Bluetooth, it disconnects on its own after a certain amount of time. This means that I can never use the dash function.
altersack53   10 µW
10 µW
Post by altersack53 » Apr 12 2019 3:13pm
hi Powervelocity.com,
We have a 7kW QS motor.
Can I please get the 24F 120V with bt priority shipped to Germany?
In your shop I can't order.
Best regards
Horst
MJSfoto1956   10 kW
Post by MJSfoto1956 » Apr 12 2019 5:41pm
cheeko wrote:
Apr 10 2019 7:48pm
Just a data point and nothing else: While I don't have an Android (and never will given the many issues I am aware of wrt security, updates, and incompatibility) the iPhone PV app works like a charm every time with my PV controller -- even across multiple IOS devices. I would give the quality of the hardware and software an A+. YMMV
M
Trump lied. People died. His supporters high-fived.
Слишком мало, слишком поздно
cheeko   100 W
Post by cheeko » Apr 22 2019 10:58pm
Yeah ill give it another go, i think maybe i bought a watch which is connected to Bluetooth so maybe it doesn't like being secondary.
Cheers
TorgueRPM   10 mW
Post by TorgueRPM » Apr 23 2019 9:00am
I use an HM-10 bluetooth module to connect to my electric longboard, and that hasn't been working either. I think the Android 8.0.0 Oreo update is the cause of the issue, and after looking it up on the electric-skateboard.builders forum, I found several threads confirming this. Apparently the bluetooth in Android 8 is different somehow and many older bluetooth modules no longer work.
Post by Powervelocity.com » Apr 23 2019 12:52pm
On the BT module, we use dual Bluetooth chip that supports older standard 2.0 and newer BLE 4.0. Hence, under phone BT settings, you can see "PowerVeloCity-A" (older, supposed to be backward compatible with Android) and "PowerVeloCity-i" (compatible with all iOS and Android 4.4 and above). The current version of application is using only 4.0, that's when you connect you can see only "PowerVeloCity-i" advertised. If you go to Android BT settings, you can can still see "-A" but it should be used and you should really be pairing with the module from within the phone BT settings menu. BLE 4.0 and above allows you to connect without pairing from within the application and that want to do. Because of the huge variability in hardware, drivers and OS versions, some users had issues connecting to the module. This seems to affect Chinese brands of phones and/or custom ROMs installed on any phones.
However, we are close the releasing PV BT module 2.0 which will support BLE 5 standard and will be less prone to these issues. Besides, it will have new features. The existing customers/owners of PV BT module will get a sizable discount if they chose to upgrade.
TorgueRPM wrote:
Apr 23 2019 9:00am
TorgueRPM   10 mW
Post by TorgueRPM » Apr 23 2019 1:14pm
Apr 23 2019 12:52pm
TorgueRPM wrote:
Apr 23 2019 9:00am
That's great to hear, I'll definitely buy one once they're available.
