24F Silent Controller 20kw 100-150v iOS/Android- $299>
TorgueRPM   10 mW
Re: 24F Silent Controller 20kw 100-150v iOS/Android- $299>
Post by TorgueRPM » May 22 2019 7:40pm
Ok, so I was going over some small bumps in the pavement and all of a sudden the motor cogs really hard and the throttle does nothing. The motors spun freely when not connected to the controller, so I checked to see if the controller connections had any shorts between them and I found one between the green phase connection and the positive battery wire.
When I opened up the controller I didn't find any obvious signs anything had gone wrong, but I did notice that one of the tiny capacitors had been pushed aside by the battery wire. Maybe the bumps caused the wire to break the capacitor and short it?
TorgueRPM   10 mW
Post by TorgueRPM » May 22 2019 8:13pm
The capacitor isn't shorted so I have no idea what the problem is
TorgueRPM   10 mW
Post by TorgueRPM » May 23 2019 12:38pm
Powervelocity.com wrote:
May 23 2019 11:09am
That looks like shorted mosfets on the green phase. Replacing those should bring it back to life.
TorgueRPM wrote:
May 22 2019 8:13pm
I haven't been able to find any info on the magnachip mosfets in the controller. What could I use to replace them?
Powervelocity.com   10 kW
Post by Powervelocity.com » May 24 2019 11:36am
They are not available in the US.
I can send you a few if you are comfortable replacing them.
PM me your address.
TorgueRPM wrote:
May 23 2019 12:38pm
May 23 2019 11:09am
TorgueRPM wrote:
May 22 2019 8:13pm
Ebuilt   1 W
1 W
Post by Ebuilt » Jul 03 2019 11:48pm
Edit: PM incoming. Sorry for taking up space here.
:bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt:
Trailblazer   10 W
Post by Trailblazer » Jul 12 2019 10:45am
Hello PV person.
I tried to converse with you through email, but that doesn't seem to be going well, so I'll try this.
I bought one of the 18Fet controllers almost exactly 2 years ago. The BT module is internal. I am on Android.
It seems with each software update that it has become harder to program the controller. I barely got it programmed with my new battery voltage a few days ago (took many attempts). Then I saw that there was an update for the BT Module firmware, I assume. So I applied it. It appeared to apply properly, but every time I go into settings, it wants to apply the firmware update again.
Now I can't program or communicate with the controller at all. I see that PowerVelocity-I is there, but it won't program successfully.
My wife's iPhone doesn't see any bluetooth device so no help there.
Looks like I'm having the same problem as TorgueRPM
TorgueRPM wrote:
Mar 28 2019 9:26am
I think there might be an issue with my bluetooth module. It won't connect from the app unless I connect through my phone settings first (I only tried that because it wasn't connecting). Half the time the app doesn't even see the module, but when it does and I try to connect, it turns yellow and slides down the screen before reappearing.
I am very much so willing to pay a reduced price (for previous buyers) for one of those new BT 2.0 modules that you mention here:
http://powervelocity.com/forum/viewtopic.php?f=8&t=25
Can I please get one of those ASAP? I'm down right now and having to use a car to commute is painful. Thanks!
PS The controller works fine otherwise. I have to reprogram it because I have changed battery voltage and it keeps cutting out at the LVD that I set. I can't reset that because I can't program the controller.
Post by Powervelocity.com » Aug 02 2019 1:34pm
Please PM or email if you haven't done so. We should have a new module for you.
Trailblazer wrote:
Jul 12 2019 10:45am
Hello PV person.
TorgueRPM wrote:
Mar 28 2019 9:26am
